- SEXY
- My least-favorite Type44 repair . .
- Pictures of H.I.D's
- Headlight trouble
- looking for info
- 87 5000csqt rec for a chip?
- so i brought my block to the machine shop...
- audi 5000 cs quattro cis issues
- V8 and Vag-Com
- ISV shutting off at random
- a/c blower - no high speed?
- need euro lights!!!
- i need a rack & clutch master for 5000
- Quattro 200 20v sluggish and dies Please Help n00b
- Had to gut cats years ago and now I need an emissions inspection for plates
- bentley manual for 100/200 for sale (three volumes)
- test drive 2009 BMW 750i
- wastegate frequency valve
- power steering rack
- '90 V8 needs new speaker amps f/r
- Ignition Switch replacment problems.
- drivng lights?
- 90 V8 Instrument Cluster / Interior Lighting Problems
- Installing Audi 200 seats in to a 5000
- Tornado Red 88 5kcsTQ in Concord, MA today Anyone on here?
- Ignition Switch (electrical part)
- Priming new fuel filter/change interval
- Looking for early Audi NF cylinder head
- WARNING POTENTIAL SCAMMER ON AUDIFANS!
- Not idoling
- Metal tube on back of rack
- HELP--rebuilt starter spins but doesn't engage
- Momo steering wheel on 200 20v
- Window switches dead
- how much are 10vT going for these days?
- Will hte seats of a 5k fit in a 4k?
- car is running rich and mass gas smell
- need a part number on a o ring.....
- Looking for a 91 200 sedan or wagon in/near New England
- Camshafts...
- power steering leak 87 5000csqt
- Idle issues '87 5000 CS TQ
- Audi 5000 S A/T Help!
- Break light
- Measuring CO via Milllivolts at o2 which is righer 300 MV or 600MV?
- Need Both Cat Converters, 200 20v.........
- Center support bearing...
- 87 5000csqt parts for sale
- moving on
- My 86 5000 S Avant is a clunker?
- How I charged my 85 5kt through the LOW side with Duracool cans.
- buying parts for audi 100 1990
- Engine stumbling and fuel lines very hot
- `88 200 dashbord issue
- Information on how to read the 85 5kt eccono/multi function display?
- 5000 with intermittent no spark(sorry long post)
- leaking power steering fluid
- Elertical Issues V8
- how to pull front end off 87 5000cqt?
- Muffler Mod Audi V8 4.2
- i'm looking to chip my 5000
- Need some more power fun with 86 5000CS - Quattro Turbo
- MC-1 Knock Sensor swap
- Red wagons for sale
- embarrassing mistake...
- MFTS connector
- HID kits for sale
- Window off the track
- S-Fest 2009
- 91 200tq clear corners/side markers?
- trip computer
- Anybody see this on ebay?
- Trim
- fluid mixer
- is the bosch fuel pump 0580 254 040 same as 001 ??
- Audi vanity plate
- K26 Turbo Question
- 3b engine build. i have a TON of questions...
- Hello Friends
- How much water in heater box
- Hole in Brake Line
- Will a Audi V8 Fuel Tank fit a Audi 5000 CS qt ?
- Supercharger on a 3.6L?
- Need some help
- 20v shocks
- 1986 5000 cd turbo fwd
- Turbo Identification
- 200Q MC-1 knock sensor - boost fault question
- V8 guys
- audi 5000 fuel pressure
- '91 Audi 100 FWD will not start *** help!
- audi 5000 contin..
- 5000s part for sale
- yay!
- audi 5000 won't start
- Bumper clip
- A couple of switch questions..
- Chris from Sweden // Audi 200 Exlusiv
- 93 V8 4.2 / AT
- power steering cap seal/gasket
- How to plug the heater hose
- V8 Pwr steering hose
- V8 5 spd Hall Sender?
- wheel bearing
- anyone ever replace the clutch in there A/C compresser
- What is leaking?
- hard to start when warmed up question
- Government trade in program $4500?
- Hydraulic system sadness.
- What the F is wrong with people.
- Subframe bushings
- Why did Audi discontinue it?
- 1987 Audi 5000 quattro wagon for sale
- finally...
- v8 wipers wont park ? ? whats broke ?
- Giving up the 200
- CV Flange Gaskets?
- Audi Part number for Injector "O" ring ?
- Auto-x
- Audi 200 quattro, 20v, 1990
- Happy Canada Day July 1st & USA, 4th of July
- 200q toronto area -swont
- 5000 Bentleys for sale. Mechanical and electrical
- Hydrogen
- Runs for a minute, then sputters and dies.
- Parting a 200tq
- Headlight Trim?
- X-post. Someone seeking V8 Electrical help
- Any 5000/100/V8 owner check this out
- Touching up bumpers
- Need Part Number-1990 Quattro V8 32V
- 1990 Quattro V8 32V-Electrical Nightmare
- Paging SteveAngry: seat help
- Anyone have a spare power steering reservoir?
- how to clean up the fender badge?
- if anyone is any good at fuel injector stuff please read this!!!
- 1986 quattro 5000 cs CLUTCH LABOR PRICING
- Out of curosity has anyone had a problem
- Rear Differential Not Disengaging
- need part number
- Photo with new wheels
- audi v8 keychain
- 87 5000 cs stereo help.
- 90 200TQ Stereo Help!
- Custom Grill?
- 1990 V8Q Oil Pressure Sensor & Misc
- Installing H&R spacers
- V8 5spd for SALE
- Fusebox concerns
- 330mm rotors fit under 16" A4 wheels?
- Plug wires need replacing only after 18 or so months?
- Battery voltage
- Quick bodywork question
- Fault code 2322...air temp sensor.
- O2 Sensor again
- Ghost in the machine 2
- I am STUCK!
- for sale: 87' 5000csqt
- check this video out
- Questions about 200s
- How is this for awesome?
- oil leak
- If u are interested in a 20v check out the market place
- How easy can an ECU go bad?
- 1986 Audi 5000CS Odometer fix
- no longer able so switch into any gear...
- 200 to 90 conversion
- AC issue
- audi 90 20 valve engine
- Can I use a hight fuse
- '91 200 battery issues
- Limp mode?
- Fouling an o2 Sensor (again)?
- New Alternator....still won't charge
- High pressure power steering hose replacement
- Lug nuts. A few questions
- New to Audi
- 1990 Audi200 TQ Avant
- Test fit...
- DIY slave cylinder
- Wiring help badly needed turbo swap
- hello
- Bumpers
- Awesome ABS
- any ideas?
- '91 200 avant question
- euro light install, 91 Avant
- Need Track Wheels / Tires for 200TQA 20V
- Help with my V8?
- power steering pump
- Keyless Entry
- V8 Twin Turbo project almost finished......
- Fender
- CHIP!!
- I SCORED A QUATTRO
- Having a really tough time putting some order on fuel lines 10VT
- 1993 V8 4.2 108.000 miles at local junk yard
- rear window fit
- over heating side affects?
- 1990 audi V8 quattro
- ABS switch
- 89 Audi 200 G60 brake problem
- overheating
- 1991 200q20v boost anomalies
- 3B Throttle Linkage
- Spark plugs....
- boost issue.
- Alternator Failure
- say WHAT!!?!? FS 1992 audi V8 with 26k miles
- never mind brake pads i need some help with transmission parts
- No Spark
- stage 3 clutch kit
- brake pads for ufos
- Ignition switch??
- 91 200 auto - strut insert, wheel bearing
- heter issues
- V8 Quattro Red Hot Cat
- oil change
- Audi 200 Sway Bar Question
- OMG WOW...it's amazing what can pop up for sale
- Audi 100 2.0E with audi v8 wood trim ( pictures)
- 5000 warning lights and break stuff
- Mess of problems
- Just had my wheels refinished
- Audi v8 1990
- Just got these in the mail from 034
- Kenwood Car Audio Cuts Out in my Type 44
- Outside Temp Sensor Compatibility?
- Audis are alive and heal themselves
- clear side / signal lights for a V8 ?
- I'm back!
- New Rims and Tires on my Audi V8 4.2 /1993
- Buying a Quattro V8
- refurbished tires in vancouver?
- What a color on a v8
- CV Joint Replacement
- alternator light coming on?
- May need 1985 5k Turbo Inst Cluster or board
- I have same problem with my 1989 200q built in June
- 5000 turbo motor in 100?
- V8 Tail Lights
- damnit i ****ed up!!!!
- break bomb removal
- Seeking BTDT on fixing sagging headliner
- Oil Change Tip # 7......
- Looking at possible 1991 200 quattro 20v
- gauge cluster no lights!
- I need to order a drivers window switch but...
- Any interest in an '85 5000 (not quattro)
- Fuel pump?
