- What would be the right price for '89 Audi 200 TQ with 105K miles
- Please help: 5000cs wagon has weird clicking/rubbing bad noise coming from throttle body area...
- okay really would like help for phase 107
- got my boost gauge in
- Damn 16 year old brake hose
- Remember my no start/jump issue from a few days ago...
- Windows and sunroof had no power this AM. O Manual says there is a >
- Opinions on sellers that refuse to give specific pics of areas of their car or info?
- Another No Start. Thoughts ?
- Who all has sat there cursing the damn pin holding the clutch slave in place?
- fuel pump relay
- reverse clutch bleeding help please
- still working on clutch/shift issues, anyone know anything about the 5 speed shift mechanism?
- What control arm do I need?
- any parts cars out there?
- suspention question for ya????
- just figured out the gas mileage on the 85 200 qt
- Advancing the Timing on an '89 100 "NF"
- Anyone have a p/n for the interior/dash light booster module please? TIA.
- Paging Ofeelya...
- V8 revs up to 4k rpm, won't come back down...
- Ignition "looseness" ie. key would work in only a select "spot" now no longer starts
- Engine Losing Power or Misfiring?
- Engine removal ? (non turbo)
- 1989 audi 200 qt for sale
- she's all fixed yay!
- Finally found out what is causing my 1990 V8 Quattro to ...
- Junkyard adventurers: want a cheap ($2.50) way to quiet your car a bit?
- oil pan removal
- Note to self: Buy yourself a gift b4 returning home after logging 4000+ miles!
- Any BTDT with Bailcast Stickyboot split boots for CV joints?
- 2 piece exh manny
- FYI..That black plastic that covers the heater box, wipers etc..
- Square one with mixture setting
- 87 5kcstq will not start via ignition, but it will with a rolling clutch pop in 2nd...
- Bose rado woes
- 20vtq speedo inop since new clutch
- rebuilding radiator fan motor, bearing size is 6001, but do i need ZZ or 2RS?
- power lagg!!!!!!!!!
- stebro or local shop?
- timing belt and water pump question, is there 2 types??
- Just to clear things up...
- problems with acceleration
- Bose head-unit wiring diagram for 1990 200q.
- The gas test is complete and there is a difference....
- Timing/no start/f@#kDamnSh@7
- Speedometer off by 5 mph..
- Is a 10vt head interchangable with a 10v non-turbo head? Only diff I know of is sodium valves.
- Hood release broke.........I am beginning to think this car hates me........
- 5000 CS rear heated seats question
- Why isn't one of you selling BPV kits?
- OK, so I've done almost everything but the car still does'nt pull up in the revs's ( LONG)...
- Wont start
- Hey guys, i went ice racing with the 5k....
- 85 Audi 5000S Starting prob
- Anyone in Arlington and have a 5000s?
- World's longest lasting head swap continues...
- Suspension Questions
- I spotted this over x-mas while in florida... this is why you need quattro in FLA...
- It was bound to happen....hotwire?
- Does an aftermarket BPV pressurize the crankcase?
- Question/need advice about tail pipe
- Audi 200TQ Oettinger
- clutch slave bleeding
- okay... riddle me this... ferocious searching for idle today after smooth driving yesterday...
- stupid question number 1289
- Anybody have a GOOD WGFV?
- Gee, I'm full of questions tonight: if I were to get an aftermarket int, how should I mount tabs
- What is the deal with the michelin man hose... ridges to catch oil?
- Go baby go! Just took the audi out for its first drive since fixing... nice little drive
- 91 200q on Audifans
- Radiator is in, but now I have two stupid questions...
- Auto-Check Unit Location
- 20V Bucking Issue still present! DAMN.
- here gentlemen and ladies if any are present is my moron question of the day
- my trunk on the 85 wont open
- saw a neat option on an 87 5kt this weekend
- don't park..
- Please help - how do you adjust auto transmission throttle position cable
- 84 audi 5k cooling, electric, and climatronic problems
- I need a favor from anyone that lives in Vermont...One of my nephews is collecting license plates
- Anyone got an intercooler solution for me? Mine (20v) is shot! where to get one? I'll buy yours!
- Normal operating temp?
- Update on my 20V bucking issues...
- Fan Speed
- Resistor Fan Pack
- thermo-time switch
- I need a part number for a radiator hose...
- Starter removal question...
- driver's side door lock not working
- is this worth the money????
- Power Steering rez question...
- Resistor Fan Pack
- well she finally died..
- Stupid question of the day....
- Alternator adjuster stripped..... Where can I get one?
- BPV installation question.... Where do you want to connect it?
- So there I was, going for lunch...
- 86 5KQT doesn't start, has spark, returns code 2113.
- Considering parting out my 87 5kTQ
- My return trip to MT. from MN. is on the horizon...Those of you who may have inquired about my car
- 91 200 turbo for sale
- Scrapping a 200 FWD. Who was it that was looking for a turbo exhaust down pipe?
- Window switch wiring question:
- idea we got rolling
- steering racks, 200q10V, 1990 V8- interchangeable?
- 20v head
- Is this 10v or 20v engine?
- ugh, so i started to dig into why my car wont shift
- Uhm... 20020v engine on audifans with RS2 manifold for $1000???
- Looking to buy
- Found this while searching for parts
- anyone know anything about a mac05b computer?
- when 10v was replaced with 20v: 1990 or 1991?
- Where can I find Ben Klumper? Sold me a K26 rebuild kit as a K24!!!
- Someone explain where to install this?
- Finally got to look at my clutch to see what the problem was, think we found it
- 1986 5000 turbo quattro Performance chip?
- Idle problem with '86 5000 QT
- what is 1.4 bar??????????
- My $1.88 Boost Leak Finder complete w/Valve Stem for easy pressurization
- 150k
- Anybody ever saw Type44 models by Minichamps?
- anyone interested in a set of 15 inch fuchs wheels?
- <announcer's voice> Ladies and gentlemen.... with much fanfare and little effort...I present..
- 85 5000s
- Trip computer on '89 200 TQ
- CEL on early '89 200 TQ
- Someone did the "Chinese door handle" swap over in the 4k/CGT forums
- BPV questions
- MC2 learning curve- any new gotchas on a no-start?
- advancing distributor timing w/o advancing cam timing on MC-1
- URS4 springs in 91 200 20v Sedan
- 20valve head....
- 200 Speedometer Disassembly?
- Idle increase when heat is on...'87 5000sq
- Was there a dark blue with tan leather combo avail on the 200 20vt?
- Any ideas why the fwd auto-tragic has decided to spew ATF out the upper vent?
- new car owner
- looking at a semi cheap 200, guy says cooling system overpressureizes and springs leaks
- 87 Audi 5000S Oil Leak from fill cap
- Only brake servo assist (and steering) when idling
- Where do I find my chassis # on my VIN?
- Looking for rotor suggestions for an 86 5KTQ...
- kinda retarded question
- Question about dash removal>?
- First Annual DTW Audi Michigan Rally - Open to all -
- Any interest in a new autometer boost guage?
- Urgent - knock sensor - Which one???
- Idle switch problems
- What to look for and check when buying 200TQ?
- THROTTLE POSITION CENSOR.....
- does a mac 14 ecu learn..
- more on salvage title issue also looking for nice 44
- Any of you guys have experience with this?
- a few good videos.....
- silly question...is 3B turbo oil cooled?
- Finally going to bite the $#@^ing bullet and bring it to a mechanic
- Trip computer
- Auto Transmission dipstick - '91 Quattro V8
- Has anyone used Lusac oil stabilizer? How much per fresh oil?
- Ignition Coil Fuse/Relay?
- Would you be afraid of salvage title?
- 89 TQ Avant CD wiring
- picked up the 85 200 tq today
- This guy is nuts..
- Sound deadening the spare wheel well
- Engine won't start
- Tranny Fluid just changed to Synthetic/ should shifter be less stiff? 2nd gear is stiff from 3rd con
- Fuel Pump Check Valve
- Audi 5000CD Turbo rear doors will not open
- Audi 5000CD Turbo - car will not start
- Speedometer adjustmant? Does the adj. behind the Dash tht says "plus 5, negative 5 etc" in fact chge
- What does the Ignition timing reference sensor do excatly??
- have you seen the 5000 engine on e-bay?
- what is this? is it somethig that is needed?
- blower motor/ heating
- no oil tempature on guage
- is the wastegate frequency valve a wear item?
- just a crazy idea......wide body audi 5000!!!!!!!!
- how to change heater core?5000s
- Ok everyone I need your knowledge base for a small problem on my 100Q
- Broken Driver's Side Mirror - 89 Audi 100
- For those that have the Bentley 1984-1988 Vol 1 could you please turn to page.......
- Pics from our recent Pines to Palms Drive
- anyone need a distributor cap and rotor? (87 5000CSTQ)
- Wow, cheap canadian instrument cluster on ebay.
- Rewiring driver door hinge wiring.. Future effort planning (87 5000cstq)
- Did the type 43 seatbacks have airline trays?
- Sound deadening the trunk. How about spare wheel well?
- Whine from tranny...can I get home?
- Ontario, Canada users, helped me out yearrrrrrs ago where are you?
- Audi on Ice (movie)
- repacking outer cv joints on 1993 V8
- power lagg...............
- Adjust the timing
- Are the V8q auto tranny's prone to failure same as the '80's Audi/VW models or had Audi
- FOR SALE: 1991 Audi 200 turbo quattro 20v 5 speed - $3500
- Trouble with fuse circuit #4 in my '87 5KS.............
- This is odd : ( another dash light issue )
- Best place to get an alternator?
- Need a part number...
- ***200 20V now Bucking at 4k RPMS and only reaching 1.1-1.2bar of boost...
- Anyone go crazy on a 5000 turbo diesel?
- What other alternator would fit in a '86 5ktqa?
- Audi 5000 Tranny Swap
- Wheel bearing...can any shop fix?
- I FINALLY FOUND IT !!!!!
- Rear diff fluid - what to use
- OK - now time to strap the IC..
- What were the "later options" of a '90 V8Q?
- Which terminal to test alternator?
- I keep tossing alternator belts... any ideas?
- My friend has placed his 1990 3.6 liter V8 Quattro on eBay
- Has anybody got a set of reflectors for turbo euro headlights they'd like to sell?
- in 4 days (kinda long)
- Window Regulator
- Audi 5000S For sale in Seattle area.
- boost controller....
- tach? update
- OK... started posting my AFM...
- XX Tuning Dyno Plots are up from Sat's Dyno Day...
- sorry
- funny pic
- Looking to replace cat and exhaust on the 3.6 liter 1990 v8 quattro
- Dash Removal/Button Questions
- I am at a crossroads and need advice from you high milers......
- Hood strut rebuilder (Canadian content)
- How to dispose of used Audi antifreeze??
- Looking for needles in the global haystack
- NOTICE: Today is V-day. DO NOT FORGET!
- Oops....
- Help a brother!
- 1990 Audi V8 FOR SALE:
- tachometer?
- Air/Fuel ratio adjusting
- radiator stopleak
- '86 5KTQ: Thumping during deceleration
- The Audi Prayer
- My personal '89 200 TQ money pit ;o)
- My photos from Saturdays' Dyno Day / Gathering at XX Tuning in E. Hartford, CT
- Battery not staying charged over night
- Boxerfan - cna you repost or email me your "how to"
- Did all V8's ('90-'94) have UFO's?
- T-Shirt Poll:
- Crankcase breather hose, vacuum leak, car won't die when oil cap removed.. valve question
- Does a type 44 alt volt reg need to be polarized?
- oil in intercooler......
- Anything special about changing the windshield washer pump?
- So how many of you in the northeast went for an exilarating ride in the recently accumulated snow?
