- I know the V8 seats fit the 200q20v, but isn't there a seperate connector for the rear seat heaters?
- '91 200 TQ Avant For Sale
- New Audi Owner
- 20vt radiator...?
- When installing hoses to heater core - which hose goes to the top and bottom?
- Anyone have the part# for a VDO ISV for a 200T?
- New sony head for the V8...but no sound!!!!!
- 3/4 up the temp gauge @ 2500 rpm highway on a 70 degree day? (long)
- Los Angeles/San Fernando Valley locals, new mechanic shop:
- Tool: Tee Wrench P377. Anyone know what size that is, in "mm" or inches.
- Does the CSV flow at WOT?
- Still having 3000 rpm idle speed!!! I'm a bit desperate...Help anyone...Longish
- 1991 100Q for sale, $2495
- ETKA
- Anyone know the hex dimension on the 2069 tool?
- 1991 200Q20V. Detonation under load/low rpm/hill climbing. LOTS of ECU retard felt.
- 1991 200Q20V. a/c compressor wont engage. Low speed fan engages. Disconnected the MFTS, no change
- Hood release cable broke?
- Just bought a V8: questions on interchangable parts
- does this resistor/chip work? on ebay
- Transmission/Differential Maint.
- New Parts!!! WOoO
- Can someone confirm the amperage of this alternator
- Tons of stuff - cheap/free
- blower control module
- Anyone have a...
- What do youz guyz runnin' 1.8t's use for motor oil? Summer vs winter?
- Caliper needs replacing....
- Car Stolen, Police found it. Starter won't start.
- Dam car got worst. Need help with codes...
- Need help with front speaker Bose Amps
- 1990 V8 in my local junkyard
- The wagon lives! Sorta....(200 10V TQA)
- Boost gauge issues, revistited.
- bpv installation pics/tips?- getting close to increasing boost...
- tightening the e brake cable (s) ?
- Argh! Trouble Pulling Codes (200 20v)
- 1990 200 Turbo Quattro 10v Avant For Sale
- Recently.........
- Is there anyone on this forum from Missoula,Mt?
- Looking for a pass. Headlight, window/lock parts...
- I need a few dealer-only auto transmission parts - Anyone have a good dealer?
- found some kinda interesting stuff on the audi motors
- Was there ever any bbs RS's made that would fit a 200tq?
- Audi 5000 S 1987 dashboard is dark
- Did you guys see this?
- update on hydraulic fluid leak
- Roof rails for a '91 200Q20v Avant?
- I can't believe I pulled a 4444....
- psi @ ECU for boost control?
- Radiator fan always on after AC fix
- 200q, 10v and 20v: Can I drive sans a dash whilst it is being repaired? Anyone ever try this?
- Looking for a Delta radio...
- The V8 on a whole new level!
- Is there a way to test and repair a CC programmer??
- what is normal operating oil pressure for 200tq?
- 5000S Power Window Problems
- Is there a difference in length between timing belts part # 035 109 119 & 034 109 119
- Anyone have an Alternator laying around for a 200 20v?
- Is Ben Swann around?
- Well... my car finally is out of the shop!
- Free 1986 Audi 5000S
- Anyone know what this is?
- MC-2 Timing
- Question about a particular quick fix.
- First crack: Fuchs + Dunlops for sale
- New ZF V8 trans f/s
- Where is everyone procuring their Eurolights from these days?
- I am now having trouble with my alarm, arming and disarming upon unlocking the doors mostly...
- One of my more funnier posting lol :)
- V8q 5spd or 20vt 200tqa?
- about to give up on low boost- please help!!!!!
- AGH! After replacing multiple iggy switches, then replace tumbler... won't start... again!
- All Righty..."Silvey" does exist for those of you whom have longed to see Her...
- wiper motors
- Seat heater switches
- Gents, please refresh my memory...
- Successful Fuel pump bypass??
- Does Benn Swann still have a website?
- Idle Problems, plz help
- I've been hitting the fuel cut lately
- Anyone have part numbers/suggestions for suspension parts for '91 200 20v?
- Key-Lock problem
- ECU Help
- love this forum- wouldn't be able to fix this car without it!
- Hard fuel line adaptors
- V8Q just ticking during jump start
- Any special tools required to replace a CV boot?
- Where do these go?
- Anyone need pretty MINT V8?
- Having a high idle issue...
- Audi 5000CS issue
- Should I be worried?
- Recommendations for 17" wheels over UFO brakes
- Trying to place a classified ad for my 91 200 20v, can't log in
- boston mechanic
- chipping
- 88 audi 5000cs quattro
- So now half my lights don't work...
- Anyone second this idea?
- Idle Questions
- does the 3b MM hose have a seperate fitting/inlet for a BOV?
- hydraulic hoses - where do green o-rings go?
- Where is the O2 sensor on the NF motor?
- No, this can't be a T44....
- What's the deal with these things?
- 1990 100 starts/Does not start
- looking for a fastener for euro lights.
- didn't someone in maine just reseal a steering rack?
- Got a spare V8 engine lying around?
- Best (cheapest) place to buy front & rear brake pads for '90 200 qt?
- Play in driveshaft
- New electrical gremlin
- engine idle question
- Bit the bullet and put in new injectors=end of cold start probs :)
- Ok, just getting finished with heater core replacment
- Temp Sensor question
- O/T I know but anyone in here know about computers?
- Airbag light reset/clear
- 88 audi 5000cs quattro problems
- 87' 5ktq
- Check engine light coming on under boost??
- Turbo coolant line question
- WTB: Used MC1 head
- silly 200 rear brake question
- Delema!!!!!! 93'V8Q or a 2001 A8?
- turbo afterun water pump ..
- Who has attempted to do this, and have youy succeded?
- Instrument Cluster problem
- 1991 100Q Overheating issues... !?!?!?
- Vacuum question
- Parts for sale! possibly trade.
- Yes, another update on running like poop
- lost coolant, car overheaded -> now won't make full boost?
- More to the cold start valve (CSV) which parts are similar??
- Top speed issue fixed...
- IA Stage II inquiry
- Interesting - V8 vs 200 taillights
- Update on my hood release cable
- A/C compressor inoperative...
- An ad that will make you go "hmmmmmm..."
- 5000 CS drivetrain function
- Removing the steering wheel
- Changing from 15" to 16" rims
- 1987 5000 Quattro
- I need to lighten my load....
- 3 Spoke steering wheel installation ?.
- cc head unit
- open air temp. circut question
- window problems
- v8 quattro drive trouble
- has anyone tryed to replace wire from selinoid to starter moter?
- 1991 100 Quattro making strange noise... ???
- Forget about boost gauges........HUD
- Screeching noise? Thoughts???
- can any1 help?
- What do you guys think of these wheels? also, an update on my car
- 88 5000cs quattro stays running with starter fluid
- 1990 Electrical Problem
- wot check engine light
- turn the key to start and nothing( sometimes )
- 88 5000 cs quattro dont start?
- will not start
- Im afraid to even ask but ..............
- Climate control recirc flap spring has come loose on my '87.......
- Steering column feels "loose" when going over bumps
- Why can't I sell this 200 Avant??
- Boxerfan, et. al. I'm looking for the stock ign timing numbers.
- Hey guys... I'm gonna be parting out a 5000 very soon...
- Blower Fan
- No one understood my detachment issue...
- Audi 100 to 200 Turbo
- '86 audi 5000 tq cold start problem....plese help me
- studdering + misfire problems
- Amusing things you can do with 4,800lbs and 276 hp
- Will high output alternator from a 1991 Audi 90..............
- 200 TQ Brake pad sensor
- Auto trans compatability
- How many V8q's per yr?
- 5000S Turbo conversion wiring harness + bently schematic question - stuck! need some expert advice!
- Adventures in front end repair
- Air temp sensor question for the pros
- OBDII for Pocket PC
- Avant window trim issue - any solution?
- Gamma CC - completely locked out
- Okay, fess up...
- Update on things (rich/poor running)
- V8 O2 R&R
- My ABS is coming on:
- 1990 V8Q MAF Sensor Cleaning & Wheel Speed Sensors
- BTW quick differential oil check
- Transmission problems when hot...
- vibbration
- 6th injector mod for 10v?
- Anybody knows if the crankshaft pulley is the same on a (90) 20v 1991 as on a 5000TQ 1987? Thanks
- Hey... anyone in MI near Detroit want/able to help me out with a little shuttle driving?
- '91 200 T - Is it OK to use my differential on a donor transmission?
- thanx to quattrotrac,burnning distributors rotor,and a clutch question
- Surging, new O2, advice sought.
- Picture needed of fuel lines hooking to distributor
- Testing intake boost pressure on the 3B 20vt
- UFO replacement disk?
- Stupid Sunday morning question.......
- 5000tq diag test codes?
- Anyone need a CD changer?
- 91 200 - Auto Transmission - Worth Rebuilding?
- dead battery, how can i open the doors?
- Folks, just pulled some trunk trim pieces on my 4.2 V8Q if anyone is interested
- For Sale -1989 Audi 200 Turbo parts
- repaired intermittent instrument cluster display issues
- used samco mm hose off a 200 20v. $50 bucks. anyone need it? good security.
- I'm going to weld up a 3" exhaust here soon and I was wondering about headers vs manifolds on audis
- 88 5000tq ignition distributor
- '92-'95 S4/S6 tranny....will it fit my '91 200 20V?
- Thank You Everyone
- coolant color?
- Wiring diagrams.. anyone??
- V8 4.2! whats going on with my gas mileage?
- CD Changer in the glove box?
- anybody know where the multi-func temp sender is on my '90 200 10v QT?
- Pulling the steering wheel with airbag... ? aftermarket steering wheel options?
- MC1 oil pump gasket
- Adjusting co2 mixture in 5kcstq?
- Some items you guys might be interested in ... (edit)
- Hesitation, Throttle Stuck Open, Cruise Contol Failure
- I stumbled across a good Trans Am video ('88 Sears Point)
- 88 5000 csqt dash light issue
- engine codes
- Coolant leak . . .
- lock up Torque Converter
- FM Modulated CD Changer Question for 875kcstq
- coolant in the nr4 cylinder
- Instrument cluster removal- 91 200q20v
- CV Joint Problem
- newbish question
- Bomb replacement (longish).
- Anyone have a nice, clean door panel...
- Speed limiter or what? Help me, need some input
- 9*18 on my 200-20v
- Anyone interested in an adjustable wastegate cap? Painted blue with big thumb screw.
- Fek! V8 Needs a rack! Jorgen Anyone?
- 4000 owner needs a quick favour.
- nasty looking hose
- Intermittent Instrument Panel Lights (200 20v)
- Need quick troubleshoot on inop window switch
- Audi V8 UFO Rotors
- Name this part (200 20v) :-(
- 91 200TQ Radio Siren
- More 5000 NF woes :(
