PDA
View Full Version : Audi 5000 / 200 / V8 Discussion
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. Hello all,
  2. Anyone know what the automatic final drive drain plug size is?
  3. ok heres the thing...
  4. Group A Battery Wars
  5. Racing Motor and Trans Mounts for the type 44
  6. Do you have any thoughts on hop ups for a 200Q10v?
  7. Dead speedo came to life after car wash for short time
  8. bunch of things iv been pondering.
  9. Wheel widths/diameter: what fits?
  10. Will the drivetrain from a 4000 "bolt" into my 5000
  11. Avant overload springs????
  12. hey hey picking up a 5000 this weekend!
  13. got my wheels and suspension installed !
  14. Needed: Transmission for my '90 200 Turbo...
  15. Higgins is back up for sale . .
  16. my 92 v8 came with the trail hitch package
  17. 1989 Audi 200 Q - Ignition cuts out
  18. My 1990 200 avant
  19. 10V Spark Plugs
  20. How come they are selling such a nice looking ride ?
  21. what a gem for sale
  22. fitrightregulators
  23. 200tq to 5000t parts compatibility??
  24. just moved
  25. Short shift for 200tq
  26. Radiator change, how hard?
  27. 5 window distributor
  28. 1991 Quattro V8 heater troubleshooting help needed
  29. Fuel pump finally died...
  30. why does my sunroof close when I start my car?
  31. 87 5000 turbo several things.
  32. the roads my avant has to endure!!
  33. Master cylinder for 200 10V Avant
  34. GREAT SITE WITH AFFORDABLE IMPORTANT PARTS!
  35. I have my new 17in wheels & tires
  36. new smoked tail lights fitted
  37. Need desperately a Final Frive pinion/gear set: Audi 200 Aut
  38. For Sale:1.8bar chipped ecu
  39. Audi V8 instrument cluster swap need help !
  40. some pictures of my audi 100.
  41. starter replacement
  42. does wood trim dashboard of v8 fit audi 200 / 100?
  43. Wiper Park Position
  44. Hello from Sweden !
  45. My rack is leaking
  46. Pretty Blue Smoke
  47. Gumball
  48. what type of bulb do the front turn signals take?
  49. UPDATE: what coolant temp sensor is for the comp
  50. Northeast Audi owners........
  51. new member and my car
  52. coolant temp sensor
  53. Quick Confirmation...
  54. How tough is it to replace a ripped cv jt boot?
  55. How a 200tqs 10v should alway sound
  56. NEW member here!
  57. WOW, this is really messed up....
  58. 91 v8 clutch
  59. buying wood trim that on the doors panel for audi v8
  60. WANTED: 86 5000CST Cylinder Head
  61. selling my 5000, anyone interested?
  62. Seat connectors
  63. Important wheel question
  64. Seat Belt Replacement
  65. Audi V8 (3.6) coolant sensor location?
  66. Replacing rear prop shaft: how hard is it?
  67. 200 10vt sedan
  68. Sold my 200 20v, kind of a sad day....
  69. 1990 v8 quattro transmission problem?
  70. Rack to pump hose (rack end)
  71. need a source for Euro headlights for a 90 V8Q
  72. Does this apply to 1989 200q?
  73. Where to find a set of Euro headlights for V8?
  74. Oil Pressure Warning Light ???
  75. Runs ****ty when engine warms to operating temp
  76. Fuel lines leaking. Solution?
  77. How can I keep my low beams on with high beams?
  78. 3B pilot bearing removal
  79. Ambient temp. start problem '89 200tqa
  80. Voltmeter drops randomly at idle
  81. Sunroof Adjustment Pointers (100)
  82. what's the deal with this sweet interior
  83. Distributor rebuild?
  84. disputing a speeding ticket?
  85. Can you drive a Quattro without rear prop shaft?
  86. Grease oil seals?
  87. Anyone on here grab the Glacier Blue 20v Avant on N.E. Craigslist?
  88. Would like to fix cruise control
  89. now were talking audi's
  90. V8 converted 200 Avant
  91. 2B "Revolution" Camber/ Caster adjustment system
  92. Sell Me Brakes
  93. Who is using a single piece driveshaft?
  94. New dash speakers in 200
  95. couple questions about keeping my v8 in the road
  96. Car From Neighbor
  97. ABS Sensor, works until the last 5 feet of stopping, any Guru's want to tackle?
  98. hi girls im back and my power steering hose is leaking like a mother!
  99. Difference between Koni 10v and 20v rear struts
  100. Sunroof Stuck Open
  101. Newb question
  102. ecu wire problem
  103. How to remove a 5000/100/200 radiator?
  104. new owner of 90 v8 with questions
  105. '86 5000 turbo start-up problem
  106. need throttle body and ISV ASAP!!!
  107. could it be the cleanest v8 out there?
  108. Does anyone know this car
  109. rear stabilizer on Audi V8
  110. All lights work EXCEPT low beams...
  111. 87 5000 turbo no turn signals
  112. Definitely mixed up with 200 Aut. Flywheel / Torque Converter. How many bolts?
  113. looking for Interior parts for Audi 100 1990
  114. Oh how I love my v8
  115. V8 Brakes, Mmmm
  116. Finished cooling system repairs over the weekend
  117. 1990 Audi 100 5 cyl. won't start
  118. looking for 200 interior
  119. DIY 200 20v QT Catback Thread
  120. Does anyone have an Idle Stabilizer Valve for a V8q laying around?
  121. Wheel bearings, searched threads but .......
  122. Max safe boost for Stock turbo 20V (3B)
  123. looking for a 86 audi 5000 turbo drivers side headlight?
  124. looking for a 1991 audi 200 turbo??
  125. A/C Compressor Tensioner
  126. '90 V8 Slushbox wanted.
  127. Leaky rack or pan gasket? Grrrr (long)
  128. Carlisle car show info!
  129. Oil pan gasket replacement
  130. Dash/console light question
  131. Wheel fitment assistance
  132. Poor Running / Idle ... things to check?
  133. Coolant issue
  134. Handbrake
  135. MC2 Flywheel anyone?
  136. V8 acceleration surges/pulses
  137. Vacuum Leak
  138. Differences between a euro 200 and a 5000cs
  139. Any trouble with force 5?
  140. I'm back (more pics)
  141. Audi 100 Not Starting
  142. Ronal Center Cap fitment
  143. Looking for a good 10vt exaust manifold!
  144. Do we have an ekta shot of Trans cooler
  145. V8 Passenger CV Axle replacement
  146. Shipping Glass: How best to pack-no-break
  147. anyone retrofit a "lane changer" blinker stalk to one of our cars?
  148. curious as to who is staying and who is going
  149. Quickie from the road (red avant pickup)
  150. Autohauz good ?
  151. need some parts anyone have em laying around?
  152. Engine Surging (oscillating even) Help
  153. KAWF wut?
  154. rear quarter glass
  155. Engine cleaners
  156. Tail light bulb question
  157. Pulled fault codes (related to 2 posts down)
  158. Audi 100 Starter Removal
  159. Reliability issues with a long drive coming up (questions)
  160. Battery gauge
  161. The car runs like crap sometimes
  162. What is the best way to get the MAC11 harness extracted through the firewall?
  163. Boost gauge installed pics.
  164. The small wire to my starter is in bad shape,
  165. Picture of the Day / Parts
  166. 87 5KCSQ Strange power steering/hydraulic problem
  167. question about front grill
  168. Paging AudiSpaulding - Ribs is Cancelled Tonight
  169. I just replaced my rt rear brake caliper, the original was 38mm. & the rebuilt is apparently 41m
  170. Clutch MC on 1990 100Q
  171. Finally got some wheels that work for me.....
  172. Sold my S6. Looking for a turbo, stick, quattro black interior avant
  173. anyone ever run the ngk pfr6q in their MC?
  174. gear oil - center
  175. When you score, you score
  176. Interior starting to look much better.
  177. Switchblade Keys for '89 200QT?
  178. planing trip from ohio to alabama, anyone inbetween?
  179. Jersey Meet Thursday Night
  180. Friend of mine just got 2001 BMW 540i
  181. T belt tensioner
  182. It's official, I'm flying out to NJ to pickup the '90 200TQ Avant!
  183. Those of you that have amplifiers installed, where did you mount it?
  184. Anyone have some t44 turbo e-code lenses they'd like to rid themselves of?
  185. maybe somebody knows or remebers.....
  186. Just a thought, electric seats
  187. replacing door handle on 1987 5K
  188. 1989 200 TQ Avant with an airbag but with a Mac11 ECU?
  189. latest upgrade on interior of my V8
  190. flooded or starved?
  191. Wiring Diagram for Power Seats 88 5ktqm
  192. How hard to swap fuse box ?
  193. Alcantra Sports vs Cloth
  194. does anybody know if theres a way to turn off the fan while the climate control is on?
  195. new info on misfiring...
  196. Flat battery
  197. It appears that an A6 after-run coolant pump works!
  198. After-run pump
  199. Has anyone here replaced their brake servo?
  200. Anyone willing to trade an Avant for a project UrS4?
  201. not mine just another fine 200
  202. Which relay controls window
  203. Removal of the A/C system
  204. im gonna try to describe this to the best of my abilities...(a tad lengthy)
  205. strut brace
  206. V8 quattro rail fuel lines needed
  207. Always the little things!
  208. Friend needs help with 90 V8Q 3.6 Auto...
  209. Update 87 Audi 5000 S Quattro NF, not running right. BUT BETTER!
  210. My new C4
  211. '85 200CSQ Pics For Boxerfan...
  212. WTB V8 tail lights, please email me.
  213. New bilstien shocks for V8, no affiliation, hope someone needs them
  214. ...if i have an 86 that is an early build...is it possible it is a numbered car??
  215. Q: What was the first year Quattro was available in the 5000 model line?
  216. PSA...Some good closeout deals here
  217. Missing OEM Gearbox internal parts for Audi 200 20V!! Where to get them??
  218. does anyone here want/need the underdash storage compartments off of a non-turbo 5000?
  219. Higgins has been sold . .
  220. Missing/cutting out on high boost 91 200 20vt
  221. What is required to re-do V8 suspension?
  222. Part number!
  223. 1987 5000 cs quattro power steering rack and pinion replacement
  224. 1985? 5ktq Avant FS in Hamilton, Ontario
  225. v8 UFOs destroyed....options?
  226. Valve and piston collision question...
  227. Hey Im in the market for a new(to me) Audi and I came across a thread about a v8 converted 200 avant
  228. While at Standard wreckers yesterday I saw a 5000 TQ avant.
  229. Has anyone swapped an URS4 cluster into a 200 20v?
  230. Off to collect the 5ktq that hit the horse.. in -17C weather...
  231. '90 200 loses power bogs down and spits out alot of smoke plz help
  232. 20v crank lock is on the way....
  233. Considering picking up some used (40k) built V8 heads
  234. Help? (V8)
  235. Ripped the P/S front seat out of my car today(See what ya started Jim!!!) thought you'd like pics
  236. Compatible?
  237. What is the capacity of the centre differential fluid?
  238. Has anyone repaired an after-run coolant pump?
  239. V8 taillights on a 200 Avant...
  240. Thinking about making an exhaust or buying CAC, V8
  241. '91 V8q in Stoney Creek, Ontario for $800
  242. porsche 951 K26 turbo... decent upgrade for a 10v? I know itll have a bit more lag than...
  243. 1991 200 TQ in Utah... don't know seller etc etc...
  244. "You are so........" WHAT?
  245. 200 TQ Avant For Sale in NJ - SALE PENDING
  246. Does anyone have an '89 (or equivalent year) 200 strut housing that they can measure diam. of easily
  247. Hey all you v8 peoples :D
  248. the wonderful city of boston kicked my ass...
  249. Solved
  250. would the ign wires from a 3b fit an mc-1?
