- Radiator R&R
- Any turbo owners upgrade their cam?
- Throttle body
- a/c compresser question... does anyone know where .........
- Bad Gas mileage
- O2 sensor
- renting tools for wheel bearing removal
- Napa Hydraulic Hose
- Anyone looking for a V8?
- question about half shaft install
- Many thanks to Steve A. for the goodies.
- sometime stalls ...is this a problem?
- Head Gasket and other things
- Selling Audi 1990 200TQ Pearl White
- how do you remove the oem radio ?
- In addition to the other goodies.
- HELLO to all!
- Driveline '87 5000 QT
- Hy to all, do you know www.audi100-online.de ?
- 5k oil pressure?
- Does anyone know the exact size of the Type44 heater core, not counting endcaps?
- Front wheel bearing job....can't pull off lower ball joint...
- I missed this one ...
- Turbo Rebuild avail
- Clutch and other new goodies going into my avant....
- The needle of the speedometer oscillate....
- Zebrano wood ashtray and climatronic panel for 200 for Europe
- very happy day
- Neat. More money spent...
- Replacing 2 power window regulators, any tips?
- Replaced other side CV joint boots
- Retrofitted an oil cooler / Accessory radiator question
- v8 for sale
- shocks done, but uhh...
- Parting Out: 1988 5000CS Turbo (Not Quattro)
- Wipers with mind
- Dragging front brake...
- Custom Audi parts
- What kind of bulbs do my V8 and 200 use?
- One reason to drive Audi
- Moonroof making sound
- Starting Problem
- Codes
- O2 Sensor
- Sunroof, repost
- Bolt hardness issue at the calipers
- Ok ,I need help!
- just got these driving lights for the 5k
- Shipping 1991 avant from Cal to NY - help
- what are the symptoms of failing fuel pump?
- I've got a Turbo Quattro Wagon for cheap!
- Power for OEM Radio
- Anyone need any parts?
- Coil Program?????
- x post leather seat restoration
- Warning Buzzer
- sunroof, what/ where to grease & how to get at cables?
- Aqua Angel, do you still have Euro Lights?
- I am new here! probleemmm... sorry kinda long story.
- Chipping the V8 3.6.
- disc / caliper brake on my Audi model
- V8 anyone?
- Sometimes I wonder if this car wants to be sent to the crusher...
- Anyone want to take this 5000 off my hands?
- Starter problem and color question
- my project now begins...........
- Three days of hammering...
- Boost is Back
- 1st speed of my wiper problem
- Auto transmission .... some questions, needs Help!
- Found a good deal here
- Still looking for a fix for intermitent high idle, 89 200 tq
- Where does the trip CPU get its info for mpg on a 5K?
- Where to find console wiring harness?
- Right rear window stopped working...
- I learned a lesson
- Replacing Brake Accumulator on V8
- Change Those old Fusable Links!
- faded/milky wood trim...restorable?
- All red tail lights for a '89 100?
- Eruos installed!!
- V8 Hissing
- Forsale: 1989 Audi 200 Quattro Turbo 5spd- Pearl exterior, gray interior-Exceptional condition
- power window relay question?
- off topic, smog check for RX7
- Question about Blower Motor
- V8 3.6L vs 4.2L
- 5000 CS Quattro Starting Problem.
- for all you V8 guys....
- Audi 200TQ - Cooks off anti-freeze after running AC.
- Thinking about selling My V8
- My V8Q with the 20V 15 inch BBS's.
- HOLY!!!!... Everyone check this one out ...
- On the road again.......
- dash light
- Will an NG head fit on an MC1?
- Whoever thought it'd be a good idea to put a sheild of some sort over the pass. side trans mount
- Will this work?
- 89 200 turbo VS 90/91 200 turbo's
- Anyone need rings for an MC/3B (Tyler!!)?
- Trunk removal - '86 5KTQ
- 1990 100 A/C Fix Options
- Wanted - 5K heater BOX in good condition...
- removing rear center tailights
- A question to those using boost gauges on MC engines...
- Ha. Look what stupid thing I did...
- Need driver's door handle
- The day has come...
- V8 Tails
- 87 5kcstq ABS question
- caliper hell
- Seatbelt warning relay from 5000C work in 200Q?
- Which models had oil coolers?
- Audi 200 for sale
- What were type 44 production numbers?
- ac compressor and drier for '90 V8
- FREE H&R SPRINGS....trade for help! This is no joke...
- Surging 200
- so not fair....
- 200 20vt rebuild $$$?
- Getting screwed by dismantling company? Need advice
- v8 starter
- Should there be a 9th (ground) wire to cruise control unit?
- Peeling black coating at front jack point
- Do I have a KH motor?
- Man, I hate electrical gremlins . . .
- sucking and changing differential fluid
- junk in tranny filter pick up
- Stephen Ankney are you out there?
- does anyone have pics of a euro-spec 84 5000 ?
- differential leak
- Would a k24 from an S6 fit the same as any k24 on my 5000. need quick answer cause it's on ebay:)
- Well, got car back from body shop but.......
- torque settings on k24 turbo...
- Need advise on wot and car is stumbling
- Hey folks... now really trying to get rid of my car =]
- Rebuild underway...
- Bad Bearings
- 20 Valve Turbo. Volvo vs. Audi?
- 86 5000S, sounds like a vacuum leak - any thoughts?
- Recharging the brake accumulator
- "89 200 turbo isv------------>>>>HELP
- V8 Quattro auto to 5-spd conversion?
- Audi-3 points, ebuddy-5; overheat resolved!
- Where are the color code stickers in 88 5K wagons?
- major need help rings/pistons/bearings
- Heater blower motor - HELP
- Went to ZF's Transmission Rebuilding Facility Today (x post)
- Can I please have some opinions?
- Finally some pics of my car
- will synthetic oil help quiet lifter noise?
- I buried a fuel pump today. a moment of silence please..............
- Prob with a friends 5000 This is what he said:
- 91 200 instrument light problem
- I Won!! ! Won!!!
- Bumper
- please dont tell me I need a new fuel pump.........please
- i may have asked already, but sway bar question
- Steve A and Jim B......
- White Gauges for ya
- Hall sender intermittant failure,
- got a new goodie today....
- Missing something at the tank 84 5000
- Has anybody heard something about Crotext?
- update....
- More MC1 Setup Opinions
- Bleed the brakes
- Ebay...
- Ack..Calipers are warped..
- aqua angel....
- MC1 tuning options, other assorted ruminations
- Steve and Koop
- Does anybody need an alternator?
- alignment problem
- From Quattro@audifans. '04 Volvo, the new beast
- installing extra gauges... questions
- anyone looking for four 5x112 BBS RX 17x8? not mine but...
- What is Best Oil Additive for Clicking Lifters
- still messin w/ coolant system...
- Ok now I'm confused wether GL-5 is bad or not......
- If the first pedal on your brake is soft
- Where do i get one of those cool turbo guages in your vent? I want it built in.
- Turbo Question!
- Light and Turn signal switch cluster drama
- where and when is waterfest? Is it strictly audi's?
- Anyone have a 200 wagon that the rear side window weatherstripping gets all curled & shortens?
- Has anyone ever changed out a front fender on their 5000?
- After run pump missing
- Audi might be for sell
- auto tranny questions
- Upholstry/carpet cleaning...Prosolve.
- Anyone buy piston rings from Blau?
- finally found cure for car buying bug
- Anyone want to "crew" for me??
- Bulldog keyless door lock system
- Door handles for Steve
- V8 no heat....HELP please
- Is it worth while buying new tires in the US vs. CAN?
- Rust Alert!
- Took a few shots of the timing belt install.
- whistling noise 1990 200qt
- Dist. rotor??
- I just checked my throttle linkage to see if it is adjusted right and....
- Help needed...(my quattro WILL come back)
- v8 clunk help
- They grow up too fast
- who here beats on their cars?
- So , we got drilled w/ an ice storm last night and .......
- Which lube viscosity for TORSEN diff?
- ATT! 89 100 Quattro needs help!!
- Kewl, trunk will open
- swapping parts
- pentosin leaking on exaust V8
- 1991 Coupe Quattro for sale. anyone want more info?
- Carpet stays damp all year. What can I do about the damn smell?
- I've asked this question several times before, and a few have tried to answer it...
- Window = no go up!
- I've got a lot of scratches on my hand!
- has anyone ever had a sticky window on a 5000???
- Who here has a V8?
- Passenger side door handles needed...
- Upcoming projects...
- Call me lazy, and the barcardi+coke is flowin...but
- my view from work
- 82 5000
- Poll: How much boost do you run?
- Can anything be done to correct the 'sagging rear look' that nearly every Type44 TQ I've seen...
- what anti-radar devices do you all own?...detectors? jammers?
- here is a pic of my newly waxed baby and the guard dog.
- I hear a high pitched sound coming from the pass. vent by the window...
- I can hear the air escaping...I think
- 88 5ktq overheating...
- insurance for multiple cars
- 88 5kqt back running strong...
- car dies when starting
- would one of these turbos be worth the money?
- bleeding brake
- Most Road Noise Gone
- Does the oil pressure warning system sound for high pressure?
- Hey, 10VTurboPower, how do you post pics off Ekta?
- Nothing earthshattering
- The little gear inside the odometer is broken..anybody know where to get a new one?
- i think it looks sick wicked :D
- high idle -- cleaned throttle body!
- Hay, can somebody lend me $5.50
- I hear metallic sound in the back
- I want to put synthetic gear oil in manual trans, but what
- I got a fuel filter from Junk yard
- V8 and O2 Sensor
- Won't Idle
