- Wheel size
- 1991 audi v8 for sale or parts
- Strange "short", need opinions - 87 5kCS TQ
- tick tick in the glove compartment
- wheel bearing update / yawdi
- Hey... Is that Moly-Lube stuff for stud assy dry? or more like a paste?
- 2/11/06 - CT/NY Audi Group Gathering & Dyno Day - XX Tuning - E. Hartford, CT
- Brake Bomb alternatives: what pressure is spec'd for this system?
- Need a good procedure for flushing the power steering fluid on a '87 5k Turbo
- Chip Questions
- Has anyone ordered parts from from www.custom-auto-craft,com
- warm up regulator?
- hey everyonee....
- 1990 100 for parts
- Freaking starter question??
- New Trrrrrrbo arrived today:)
- 20v intake flange finished
- euro side markers
- Should have never commented on someones clutch post yesterday..... audi-gods must be mad
- 3B Timing belt content...
- [SoCal Reminder] Saturday January 21st -- SCC Audi's Pines to Palms Drive/Poker Run
- First sparatically glitching AutoCheck now dim dash lights. Opinions appreciated.
- Cant find coolant sensor PN
- how does the ignition cyl come out on a 90 200 ? TIA
- Can anyone recommend a good stud insertion tool?
- Wheel offset question
- FYI: Re WG...
- German hookups?
- Unbelievable the crap people will bid on in ebay...
- noob
- Another Newbie Question (rotor button)
- 1991 Audi 100 4-speed Automatic W/ ABS--right CV shaft.
- stuck brakes
- question
- Still working on my IM...
- 1990 v8 quattro oil drain plug
- Thumbs down to Mr. 200Q20v !!!
- 7 down, 142 to go!
- 200 20V Bucking at 5.5k RPMS and only reaching 1.2-1.7bar of boost...
- X-Post: 034 Motorsport 80tq Thunder Hill Videos and Photos...
- Anybody here ever use Leatherique?
- clutch pedal on the floor, help!
- Bucking when hot
- I hate the banjo bolt that holds the high pressure hose to the rack.
- Any posters in the Buffalo area? I need a favor.
- If you're replacing the heater core and want to quiet the car a bit . . .
- Another question for you turbo guru's
- Anyone have a spare 91' 200 20v(3B) coolant manifold to sell me?
- X - post
- advancing distributor timing on an NF engine.........I have a question....
- Will a 20V 7A clutch pressure plate work with 3B flywheel?
- boxerfan or anyone else who has made their own chips
- Couple newbie questions. (pictures)
- Best thing about coming home after a long drive.
- Anyone need parts?
- Very minor thing that's bugging me ('89 200 TQ)
- A new bomb rebuilder?
- Anyone here with UFO's?
- Question of the day ? please provide you answer /
- Is the intake manifold the same piece for MC1 and MC2 motors? TIA.
- Need a new light switch set for my 86 5000 NA
- 1989 200 Q/T Bugs
- Slow to start problem....
- New Radiator cost
- Succesfull blower motor replacement - thanks for pointers!
- wrong fluid in power steering what should I do.
- Replaced WGFV
- Just saw a new version of the ski jump ad. WICKED!
- is this unusual
- Parts car or repair...?
- Local guy is parting a 1991 V8... anyone want anything?
- Photos's from 1/14 CT/NY Audi Group Gathering at EPL in Stratford, CT (BWW)
- Anyone have a MAC11C they'd like to part with?
- Has anyone had an intermittent speedometer?
- adjusting e-brake after installing new rotors
- Rear brake calliper suggestions
- rear brake hose replacement... 200 20v
- Can I bleed the brake booster? '90 200q
- MPG or fuel economy
- Parts quest - success!
- 85 5000S Fuel problems...Pump relay?
- 087 trans leak
- swapping a 4.2 V8 into a 91 V8q
- 1990 v8 performance
- Heater doesnt want to turn on when first started. Either a couple minutes or when driving...
- Turbo Headlight lense cracked, replacement options?
- 91 200 20V Clutch pedal seems to engage too close to floor esp when in traffic and when stopping it
- Water in trunk -- ONLY in pass. side small compartment (1988 5ksq). Plus...
- stereo wiring help needed
- Running Like a Lion... THANK YOU!!! 1990 200 QT....
- rear defogger
- Anyone need those V8 cross-motor fuel lines discussed a few weeks ago?
- My "new" early-'89 200 TQ sedan---love it but hate it :o(
- Anyone had any luck with repairing leaky gas tank seams?
- [SoCal] Saturday January 21st -- SCC Audi's Pines to Palms Drive/Poker Run
- Advancing timing on an '87 with NF motor........
- brake issues.. bad BOMB?
- Any source for the European T44 bumber?
- 5000 clutch issues continued... replaced master cylinder, can't get slave out.. more...
- What are you turbo guys running for FMIC?
- V8 Tranny F.S.
- Hey Guys... 1990 Audi 200 QT Cont.... Idle Trouble: New Development 1/12/06
- Heater fan brush fix.... one solution at any rate...
- 86-88 5kcstq Dash Replacement?
- 90 100 starting problem
- Looking for 91 200 SPORT seats in Black. Mine are non sport and too soft.. Where??
- headlights for 5ktq..
- u'll love the pics in this auction, hahaha
- Can anybody give me a diameter for the input shaft for an 016 manual tranny....
- Strut Interchangeability---5ktq/100/V8
- 1993 V8 Hydraulic line from pump to accumulator
- Gonna take advantage of the nice weather tomorrow/need advice...
- RS2 Manifold for K24 Turbo, is it worth it?
- No Start Update, AARRRGGG!!!
- Baddest T44 5 cylinder EVER???
- Anyone have the Import Vision 5k lights?
- 1/14/06 - CT/NY Audi Group Winter Gathering - EPL, Stratford, CT (Updated info - Pizza!)
- Anyone got a couple MM hoses they want to move or cheap-ish source on new?
- Need a source for functional fender vents
- Hey V8ers... Price for a rebuilt tranny?
- How long do you warm up your 20v turbo on a cold morning of 48F
- what do YOU carry in your trunk/glovebox as spares ? ( here is my list )
- rough idle
- I need a NA 10v Distributer . Got one?
- It's been a while, 87' 5K is not starting, need help !!!
- Mr Ben.. don't feel so bad, my car died 550 miles away from home :)
- coolant loss in a 200tq 20 valve
- Billzcat1 short shifter
- Brake pedal travel question - opinion needed
- Success with Questions!!!
- Blowing Dash Light Fuses
- Oil temp. gauge hasn't worked since I got the car so yesterday I put in a new sensor & it ...
- Had a fun and productive garage day with my avant
- 2142 knock sensor code
- RE:Where to Begin: Idle Trouble: Update
- The reassembly of FrankenAudi has begun... again.....
- Wurth Lacquer - Where get?
- Bought my new 200, but cant get into the trunk? I dont mind breaking the taillights if I have to.
- 5k died on the wrong end of a 750 mile trip [long]
- EFI computer problems...I think
- Audi 5000s conversions
- Looking for black leather shift knob in good shape
- This may seem stupid but could someone explain to me......
- FS: Roll Cage For A 200... $400 OBO
- Bad Master Cyl.
- Selling Audi 200
- 5000tq clutch issue...
- Audifans is back on the air. That took a loooong time didnt it?
- 1981 5000 diesel
- Anybody in the pacific northwest have the following major parts from a 200 they'd like to sell?
- V8 Rear seat bolts
- Warning: Lock your Rack Bolts
- 3spd auto slipping after install
- CEL fixed!!!
- hose kit question...
- Mann Filter Q:
- Playing with radios today...
- Alarm Troubles, 200QTA
- Double Trouble
- pentosin hoses
- how much
- CD changer remote stuck on E, changer is full but error on remote doing nothing
- unloading more turbo stuff
- 200 20V shifting is starting to take lot's of hand pressure. Not sure if this is a clutch sign?
- Main bearing driveshaft support...
- cost on heater core?
- last call for parts
- Need part number, name, and price of this.....
- Cold Weather Issues/Transmission Problem
- 1.8bar Wastegate Spring Group Purchase...
- Tune up done! Whats with the plastic tube on the spark plugs?
- paging 5000CDQturbo/dave.
- Talked to the guy shop that threw in the aftermarket cats for me - still running rich, still hard to
- Heater
- For the V8: UFO to G60 swap Questions...
- speaking of snub mounts. I'm looking to unload this one.....
- 034EFI snubmount install questions....
- Finally got an intercooler on, questions
- paging A talk
- Installed new thermostat
- Strut insert questions.
- Intended Acceleration chip?
- The German b!t$h is at it again! >sigh< Any ideas ??
- Polished Intake manifold
- Anyone know anything about diesel rabbit pickups?
- Can somebody with a 100q Bentley Manual please looks something up for me?
- Possible Europrice domain and email issues upcoming...
- Audi V8 "Racing"..
- Need help with t-stat replacement on 20v. Had trouble getting to the lower bolt.
- Anyone had the hood release cables on a V8 break?
- turbo ?
- heater problems
- its been almost 2 months sice I last drove the Audi:(
- whats it worth???
- Paging Jim Bush (or anyone else with decent 215 60r15's)
- recirc flap spring fix....
- Speedometer/Odometer not working
- Speedometer (or cable?) howls when cold
- Let's compare Audi "to do" lists... <edit...#2. >
- Alternator Belt keeps breaking (New Alternator)
- Strut Bearing Removal
- Deers keeping me busy
- Audi headrest cushions survey
- Valve lash adjustment
- Time to do some spring cleaning......
- 20VT loosing power at 5.5k rpms. Suspect vaccuum leak, Anyone have diagrams?
- 1989 Audi 100 is eating up the alternator belt and hard to start when cold
- well i think the car is for sell....
- HAPPY NEW YEAR! and may your Audi's have a new resolution(run flawlessly) :)
- Boxer or others on recirc flap in heater
- k-24 Turbo Rebuild kit?
- FOR THE LOVE OF GOD!!!!!!! why will this not start now
- EPROM reprogramming
- Anyone have a set of spare MC exhaust valves?.......also....
- Drive axle diameter
- Holiday Free Audi Parts
- Audi 5K NEEDS HELP
- Interior windows fogging up............
- Location of Fuel Pump Check Valve
- V8 smelling of fuel leak...
- On road trip, looking for a fuel pump relay in Denver...
- Question for 5000CDQturbo
- Source for Hella E-code H4 rectangle lamp housings?
- Stereo and Heater Problem!! Need Help.
- 1/14/06 - CT/NY Audi Group Winter Gathering - EPL, Stratford, CT (Updated info)
- type 44 forum's new banner car?!?!?!?!
- recommendation request
- Audi A6 C4 5 Cylinder 2.5 TDI Interior Heating problems - HELP!
- Audi PDF's
- Steering wheel and heat
- Where to begin??? Need Advice...
- Looking for some Platinum color UrS4 seats....
- WGFV? MAP? ECU? WOT? WTF?!?!
- HELP! Need to know if I am heading in the right direction...
- 200 taking longer to warm up, I'm thinking thermostat.....
- i cannot get any audis to start .
- alternator belt....
- posi-lock connectors
- Anyone still using built-in carphone
- 91 20v Steering wheel / airbag options ?
- Fuel injector cost for 91 200 20V? Where to buy? Will it improve MPG? Here are the symptoms
- What gauge wires required for doors rewire
- treehunter - get on MSN so I can update ya about that goldie
- anyone want a few CIS / quattro / 5k pdf's?
- 5-cyl injectors, questions!
- My new years gift from my V8...
- Boost gauge in. How high can the stock CIS go?
- Need fittings on fuel accumulator!
- Stock wheel width on 91 200tq 20v?
