- Help Please, Part for 1990 V8
- New to me 200
- Suspension Question
- Towing Question: Anyone with experience towing a 200 using by disconnecting the drive shaft
- Clutch questions
- Hey! has anyone tried putting an A8 tranny in the V8?
- "I Love GOOOOOLLLLLLLDDDDDD!!!"
- 91 200 20v cruise control question
- My EFI'd 5KTQ is being parted. Posted on Audifans.
- Detailer's Domain 15% off sale for Labor Day! Get your stuff for the weekend.
- Update on my "new" 200TQ
- Differential lock help needed. xpost!
- Cross Refrencing Question
- Help needed: Flywheel meassurements
- still looking for vacuum leak
- 91 100 4 speed auto question
- Buying a 83 5000S
- quick post with more to come later...
- heaterbox removal??
- Ok I need opinions here. Two monster motors I could build......but which to build
- Early 80's 5000 electrical problems
- odometer and belly pan
- '875KQ 347K miles, Intake Vacuum Leak
- 1989 Audi 100 5v
- Thinking about 1990 V8 (pattern failures)?
- Maybe an odd question: anyone have an old front 5k driveshaft nut, the real big one? Email me at...
- my wheels and tires on e-bay
- '94 V8 != '94 100cs wagon
- audi 5000S
- CRAPOLA. So the recently acquired 200q avant...will probably be parted :(
- Spotted: Pearl V8q in Ohio, I-80 turnpike/77n 10:30am
- What is the size for the cooling hose underneath the expansion tank ?
- Looks like I'm switching to 20V turbo. *Sad news*
- erratic no start symptoms on my v8.
- exhaust front pipe disconnecting while HG change..
- 2 Treser 5kt just came up for sale on my local Audi board
- Dashboards and compatible yrs?
- Importation #'s on the '92, '93 & '94 V8q's?
- Last chance to save an Avant before it goes to a motor swap project
- Looking to sell my 91 200q
- Same old Same old now making only 1.6 BAR of Boost after making 1.8 can't find leak...vuesa da'
- Does anyone know if the V8 headliner...
- Anybody had vapor lock issues with a v8?
- 200 T/Q up for grabs...
- Diff Locks don't work
- Stock offset on a Audi V8
- Got the 20v well sorted this weekend...
- Goodbye to everybody... well, kinda...
- ecu?
- Found an interesting little motor, figured maybe a history buff might know something
- Broken engine cover and missing intake tubes
- Been gone for a while...
- sway bars for 20 valve wagon
- NIce 200 for sale, only $450K...
- A/C Difficult to switch on?
- air temp
- Just in case you were wondering, the 90q20v turbo is still for sale:-)
- Parting out '89 200 turbo quattro Avant.. posted on Audifans
- Are all the 86+ 5KTQ's fully galvanized?
- 5000tqa Oil Leak
- Roof rack options?
- For those keeping track...another 91 V8 5spd 4.2 is prowling the streets of New Joysey ;-)
- WTB, 4.2 or 3.6 rear muffler box
- Quick brake question
- A couple of quick questions...Hose coming out of valve cover...Where does it go??
- Anyone else had their turn signals or windshield wipers die?
- Blown Turbo in a 1991 200 20v
- Ignition switch questions
- Plug gap on '90 200 10vt?
- Definitely a repost.
- Turbo gauge newbie
- Aftermarket intercooler sources for 20v
- Brake Boosters..... Are these common failure parts?
- OZ Cronos anyone??
- Problem finding MM Hose. Part number at dealership non-existant!!
- Just bought a 1990 200Q, overheating and smoking brakes. Help?
- New to these forums
- 2 1985 AUDI 5000 Wagons for parts.
- Recomendations for good source for CV Axles?
- Waste gate and turbo boost issues - long -
- 91 200 20V
- intermittently 200 quattro not starting + buzzing???
- Anyone have any experience with this seller on ebay? Good Part?
- Headlight alignment
- Calling Suffolk....
- looking for some parts
- Lookie-- Audifans Ad: 1993 V8 5spd FS
- anyone here good with the wiring on the factory radios from 200's?
- Update on my A/C draining problem
- is it normal for an A/C line to bust? put a hole in one of the a/c lines
- 1989 200 20VT hot start, idleing problem
- Spitting Reservoir, Lumpy Steering, Flashing Light
- what time is it?
- Choices on performance chips, Now that I have it tuned, new spark plugs, spark plug wires,
- V8 Bumper on 200 20v
- chaining motor mounts
- 1990 V8 Transmission Lock Out
- anyone got a power window relay kicking around?
- YAAF
- 1991 200tq N75
- Question to the guys who also own or work on bmw's
- Acquired Sputnick - a '91 200q Avant. Thanks Shawn.
- Size of spline key to unscrew the cylinder head bolts
- any good macgyver style fixes for a lazy sun visor?
- anyone ever get bored and run their 200q20v open downpipe?
- audi v8 quattro eletrical problem
- Looking for a used 5ktq ignition dist.
- Road trip in an Audi R8................
- Finally got my 1.7-1.8 BAR of boost on my '91 200 20v TQ
- Hey guys i just purchased an AUDI V8 (1990 3.6 5 speed)
- I hope it doesn't rain tonight....open window issue....
- Need some quick help, please
- Anyone in Reno area want a 5ktq w/ Fuchs?
- Id this audi?
- anyone ever use the CRC mass airflow sensor cleaner? i just bought a can at work
- Re-installing the front swaybar on a '90 200 TQA
- Indicator Light shorting out
- what's a good source for upgraded pedals (Al/brushed, etc) (inc dead pedal) for V8Q 5-speed?
- 84 4000S For Sale
- Anyone have a good used 5000 speedo sensor?
- STUCK throttle >>93'V8Q 170k
- source for after run sensor?
- Instrument Cluster repairs (NorCal)
- 5cyl longblock engine weight? anyone know?
- This seems like a good deal. No affiliation, yada, yada yada
- removing ABS sensor '90 100 Q
- 200 20v No Start-Thoughts? *Longish*
- So my gf just called me up saying her car ('90 100) jusr randomly died....
- Any tips for a timing belt change V8 in Connecticut??
- Oil Warning Light - Audi 100 '93
- How can I remove PS pump?
- Audi 5000 performance parts
- Audi 5KTQ repairs
- Saw this on AudiFans...
- the start of the transformation...1st step interior swap.
- K26 turbo disassembly
- Rant on my 91 200 20v Avant...
- battery splice....
- hot start problem
- where is it
- Burnout, Russian style (notice that *sweet* Euro front bumper...)
- 1990 100 Q brake system problem
- A/C leaking water in car.....
- Got a value question on the early V8's
- My 1990 Audi 100 idels rough at start for a min.then runs fine
- anyone have any tricks for recovering coolant
- Headgasket question 3B block 83mm pistons
- axle cv joint bolts
- Only making 1.1-1.2 Bar of boost...."91 200 20vTQ
- For anyone interested, I've got a 3B drop in Adj FPR for sale.
- Testing air temp sensor question
- WTB: One OE 16 inch A4 7-spoke "swing" wheel
- Removing and Replacing Turbo...one bolt!
- Overboosting on MC2 1990 TQA
- Clearing Error Codes, 1989 Audi 100
- performance issues with I5-t in my 5000
- For Sale 1988 Audi 5000 4 dr. Low Miles. White. 5 spd. new Wheels, No AC. $450K or best offer
- Leak @ the MC-Booster Junction
- 83 or 81 5000T distributor? ETKA shows a change in 1981
- Power steering hose replacement... How to?
- Fuel Odor
- Hey guys. Can anyone help me with identification or fitment of a headlight?
- Car will not start - No crank
- hot day - hot motor - no start - open gas cap - started right up
- great start to a project
- '90 V8 sunroof - best way to lube system
- where do i find silicon throttle body hose for 200 20vt
- Fault code questions
- Alternator bearing replaceable? or do I buy rebuilt unit
- more and more strange problems
- 1990 V8Q for sale (in Philly)
- Is there an OEM stereo head unit with CD that will fit/work on '87 5KCSTQA
- 5KQ door lock thingy
- ABS ring gear on 5KQ
- 91 200 20V
- rear amp on 91 20v - soldered vs. 6 pin?
- relay 447 959 875 got one?
- Okay GT Style... I took your advice!!
- BLT4SPD: Email me on my personal email addy. Somehow it didn't go through.
- sexy beast
- Who has $450k USD?
- Bearings on 5000
- '91 100 Air Conditioning/heater Fan
- Headliner repair question..found a place to do it reasonable..
- 1991 200 20v - Turbo / Exhaust Upgrades
- Quick boost questions..
- Turbo Noise - '91 200 T
- Looking for a V8, preferrably 4.2. any one know of one??
- Opinions needed (and no laughing please!!)
- As far as model years go..my v8 says it was made in 6/89 is this a normal date or on the early side?
- spoiler
- What size full-size spare will fit in the '86 5000 spare tire well?
- '91 Audi V8 A/C Blows Only Slightly Cold - Suggestions?
- Carbon cannister solenoid valve question
- 87 Audi 5000S For Sale/Part Out
- 100 C3 Power seat surgery
- Wheel size question....87 5KCSTQ same wheel & tire size as 89 200TQ?
- 5000tq Avant Rear Hatch Glass
- Who's white ride from WaterWagens?
- Brake bomb question
- Topped low diff with 80/90w..did I mess up? will this hurt or should I drain all?
- any good sources for new not rebuilt cv & axles
- MC1 turbo coolant line needed
- CHEAP Bentley's for sale!
- ABS sensor plastic tip thingy part # anyone? Dealer only and they can't find it.
- Those with ETKA, I need a part number ...
- I'm looking for a good right rear quarter panel and rr suspension parts
- Cleaning house .. have some good parts available.
- Could use some help from anyone who's done a cold air intake on 200 10v...
- 200 Avant (speedometer and tachometer not working)
- New Wheels for the 20v Avant
- 1987 5000cs Turbo Quattro...
- Regarding the 1990 V8 I am parting out
- boxerfan-rooster 2-Adam Mowafy input!
- 91 Audi 200 20V Avant - sorry for the long post
- Cylinder Head Bolt Torque and Order for Audi 200
- Who bought 94 V8 Quattro?
- 1991 Audi V8 Quattro - A few questions...
- oil drain plug, not able to remove by vise grips or chisel..Suggestions?
- Need help on finding a cv flange gasket asap..pls read
- Went to relight the ashtray light and found no wire, socket or light bulb.
- 1991 100 alarm problem
- 1991 V8 timing belt question
- '87 5KQ ABS sensor problem
- '87 5KCSTQ on the local Denver Craigslist. Not mine, no connections, etc.,
- Brake fluid
- 5cyl turbo Megasquirt users....
- On a 91 200 what was the intended use of the square low output lights inboard of the headlights?
- AC experts please unite. I've got a question for ya
- V8 in Toronto Craigslist.....wow, prices have plummeted...
- 86 5ktq window issues
- Trailer wiring... the answer...
- Check this out. . .
- What should a healthy '90 100 non-q be getting for gas mileage?
- ETKA Illustrations... how to save and print external to ETKA?
- AAN engine in Audi 200??
- bad luck
- What is going on?
- 1990 v8 trans maintenance questions for long life..any tips?
- Anyone parting an Avant? <edit> Link to pics of required part added
- Q, Do front drive shafts from an automatic fit a quattro?
- transmission mounts
- replacing the a/c compressor on the V8. doh . got a different kind .. but i've got an idea
- Where to find a shop to rebuild a turbo for an 81 5000
- I'm going to be removing my reciever hitch off my V8 soon. anyone interested?
- I left my manual down at my mechanics... trailer wiring help needed.
- What is HP and TQ specs on 5000 KZ engine?
- 91 200 20V Avant on craigslist in Seattle
- 1986 5000cs auto steering pump up for grabs
- '91 200 QT 20v blue bumper
