PDA
View Full Version : Audi 5000 / 200 / V8 Discussion
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. Anyone know what car this is?
  2. 3.6PT Blown head gasket. I hope
  3. UHO--Unidentified Hanging Object
  4. Could pull codes one day, and had fuel pressure, now neither...
  5. Where do people get the Viton injector seals from nowadays?
  6. power window diagram/small image
  7. power window wiring diagram
  8. 1987 5K speedo issue
  9. C3 Catalog and Magazine Review PDFs
  10. identify wires/5000cstq
  11. identify part/5000cstq
  12. 86 audi 5000 CS TQ - Rear Brake Issue
  13. audi 200 avant power door locks
  14. audi 200 avant
  15. V8 lambda ohms
  16. voltage weirdness
  17. V8 Steering Pump
  18. emergency brake/5000cstq
  19. Clearing Fault Codes
  20. Trouble with extremely hard rad hoses pressure problem
  21. custom exhuast shop
  22. V8 engine problem, video
  23. PS Pump leak - 86 5000CS TQ
  24. warning light <1>
  25. I got a V8 arm rest for my 100.
  26. HAL 9000?
  27. 87 5000cs tq
  28. 1990 3.6 V8 Motor Mount Source
  29. Thanks/new question coolant type
  30. 200 20v Fuel System Layout?
  31. '89 V8 Body Trim Removal...?
  32. Audi 5000/200 Typ 43 repair panels
  33. '91 100q after run fan check
  34. Brake pedal at idle
  35. 200 20v no start...code 2113 (Hall Sender)...round 3
  36. 86 5000 CS TQ - power windows have no power
  37. v8 injectors
  38. I wanna check my cold start valve.
  39. My car caught on fire, and then burned to the ground..
  40. Extra-strong hood struts
  41. coolant/air purging
  42. how to post pic?
  43. Warning to all V8 Guys
  44. 5000cs turbo oil line leak
  45. 91 200 20V Sedan Rear Brake Caliper brackets
  46. bellows bumper/identify/5000cs
  47. 5000 tuning
  48. Question on checking the codes on an 87 5KCSTQ
  49. UR for sale
  50. I tinted my windows.
  51. Hello all!
  52. V8 Power Antenna Replacement -- Wiring Question
  53. Check engine light at 3000rmp
  54. What are you doing this weekend? How about Audi Anarchy 2010?
  55. Broken Motor Mount
  56. Do '92-'97 sun visors fit '89-91 100 cars?
  57. '90 V8 Plugged Cat
  58. Trailer hitch
  59. cold start issues on 1990 100Q
  60. Loosing breakfluid but dont know where from
  61. Purchase of a C3- what to look for?
  62. 5kTQ engine rebuild ?
  63. Suspension
  64. Need help finding a good technician, SoCal
  65. Banjo Bolt
  66. Audi 200 Transmission code? model #?
  67. Jesus
  68. '90 V8 coolant capacity
  69. rad fan issues on 1990 100Q
  70. K Im Back Lol
  71. sunroof and windows not working
  72. 1990 V8 Windshields Availability
  73. Great Parts Car - '89 Audi 200 TQ
  74. 1990 TQ 10V sticking brakes
  75. V8 Draining Batteries
  76. Need 5000 turbo ECU/ISV controller info
  77. Braking issues
  78. New 200 Avant owner!
  79. Vinyl vs Cloth Headliner from Joann's Fabrics
  80. replacing E brake cables
  81. 85/86 Non turbo auto axle fit 85 5kt auto?
  82. '90 200tq - RPMs jump when shifting, poor throttle response?
  83. A/C Condensors that will fit into an 86 5KT
  84. Key stuck in ignition
  85. V8 washer jets - removal?
  86. e brake cables
  87. V8 Shedding Headliner
  88. a/c compressor questions
  89. Sunroof removal - how do I take out the sunroof...
  90. WTF
  91. < One month to go until Audi Anarchy 2010 - The premier NW social gathering for Audi
  92. Anyone here like Volvo 850s
  93. Long starting when engine is cold
  94. wheel bearing & ABS sensor on 5KQ
  95. Start / stall issue with '93 v8 quattro
  96. Bad bomb?
  97. 1989 Audi 200 TQ - Parts Car $1000 OBO
  98. 1991 200 20V for sale
  99. No idle increase with the A/C on
  100. terminal blocks / auxiliary relay panel.
  101. V8 Loses Power When Hits Puddle
  102. Is the sunroof switch in 100/200s lit red?
  103. another new guy
  104. hi, im new here...
  105. 1993 15" Original V8Q wheels ""FREE""
  106. High Under-Hood temp, Cooling Fan on......No Start....cont..
  107. ISV idling problem
  108. WTB Idle Control Valve 1986 5000S
  109. Adjusting The Rear E-Brake Cables on 1990 V8
  110. Manual seats for '90 200TQ?
  111. older transmission ?
  112. Looking for a part
  113. How can we fix the missing segments of a digital clock?
  114. C4 clock in a C3
  115. Newbe w/V8 Q and some issues
  116. fan comes on multiple times after car turned off
  117. hey everyone, newbie with a 5k
  118. 86 Audi 5000 CS TQ - Overheating
  119. Who does transmission swaps for a V8 in the new england area?
  120. Does C4 instrument cluster fit into C3 dash?
  121. V8 engine - hybrid
  122. 1990 V8 (3.2) Rear Drivetrain Howl
  123. Somebody know the fuel pressure values for a 93 v8 quattro
  124. how do i remove headliner and center armrest from 1989 quattro 200
  125. '91 100 airbag spiral spring
  126. '93 v8 quattro intermittent no start and engine died
  127. 1990 100Q cat & 02 Sensor
  128. 200 20v no start
  129. UK Accesory Retailer
  130. I love my Audi
  131. iPod running off a Gamma radio in a type 44. Can it be done?
  132. 90 V8 Quattro
  133. Ugh! 86 Audi 5000 CS TQ - Power Windows
  134. New b ???
  135. Loser
  136. 86' 200 ingnition coil problem
  137. Fuel pump ?
  138. 200 v8 corner marker lights needed
  139. 200 20 v hot start issues
  140. Wheels not centered in Wheel well?
  141. 86 audi 5000 CS TQ - AC Random Shutoff
  142. Brake proportioning valve?
  143. Any opinion on these projector headlights for a 100?
  144. Does anyone have an extra drivers side euro lens
  145. Where is the Bose relay under the instrument cluster...
  146. 4.2 liter into a 200 Avant
  147. :: ECS Tuning :: 4000/4000S and 5000/5000s - Radios - $93.95 43% OFF
  148. wheels bolts
  149. Sensors Colorado
  150. Serpentine Belt
  151. '87 5KSQ gas tank removal
  152. parts
  153. new problem
  154. New guy from SW mich (PICS)
  155. Rear break calipers
  156. New England Forest Rally
  157. Fried (?)
  158. Fair Value of 86 Audi 5000 CS TQ?
  159. '93 v8 Quattro torgue setting for intake manifold nuts????
  160. thousands of audi pictures....
  161. A ghost in the machine ...
  162. Went to the dragstrip
  163. need help identifying engine part on '93 v8 quattro
  164. New Car
  165. alt. belt tighten HELP
  166. Superdaves Audi Fleet (picture)
  167. hey
  168. OK dont have manual so will need help with intake manifold removal.
  169. Broken hood cable on 5000 CS. How do I open?
  170. ABS Sensor issues
  171. Cooling Fan on....No Start
  172. Another V8 Problem
  173. 1990 v8 front bumper removal
  174. no power to fp relay
  175. dont want to sell the v8
  176. audi 100 automatic to manual
  177. might sell
  178. I love this tiny flashlight
  179. How to check an inner CV joint ?
  180. list any and all causes of high HC you can think of
  181. 93 v8 quattro engine surges
  182. wiring diagram
  183. inertia switch ???
  184. Brake Fade
  185. can someone help me identify these wires?
  186. is the serpatine belt tensioner called something eles?
  187. Fuel Pump Screen
  188. looking for 91-94 200 and V8 Q rear calipers
  189. Ignition wiring
  190. I have changed my Signature ????
  191. V8 quattro 1991 throttle pedal / door handles
  192. Alright may have found problem
  193. Ecu Grounds
  194. Trailer hitch
  195. new independant vw and audi site underway
  196. thought you might wanna see my first mod on the avant
  197. Well I did It...New 1990 200 Avant
  198. Ecu Fryed ???????
  199. Selling the 200 Avant
  200. No Fuel Pump Prime
  201. Please help with electric cooling fan!
  202. Hoo - Hoo.. All Quite on the AW Forum
  203. Diff lock in the 200 q
  204. Parting 1990 V8 Quattro 5spd
  205. Carlisle countdown (rambling)
  206. V8 3.6 fluids and other basic service checks
  207. Problem Car Is Pretty Much Stuck
  208. New to teh forums withs oem questions
  209. squeak
  210. A few pics of the Avant at the beach today :)
  211. idle problems
  212. wiring diagram 'lights on' chime relay
  213. Seized brakes, cheapest solution?
  214. Looking for power window relay for 1986 CS 5000 Turbo
  215. 86 audi 5000 CS TQ - Windows working "Backwards"
  216. 86 audi 5000 CS TQ - Big blue Coolant Temp Sensor ?
  217. Easy removal of PS reservoir hoses ?
  218. 91 Audi 200 PCV hose - where to buy?
  219. Strange Leak
  220. Roll-your-own fuel line fitting?
  221. 87 5ktq for sale maybe
  222. Rear differential
  223. Trip computer retrofitting to a 100
  224. anyone got a parts car?
  225. free 1988 Audi 5000 turbo quattro
  226. V8Q iterior in the dark
  227. Power loss above 5k and a brake light warning?
  228. New Pump Regulator relay i hear pump spark to but no start
  229. 1989 Audi 200TQ - For Sale- Needs Work
  230. Rack N Pinion Removal
  231. Good place to run wire through the firewall?
  232. Audi 91 200 Fuel pump question
  233. Just picked up a 91 200 Wagon - pics inside
  234. Car buying advice 88 5000 S Quattro
  235. Codes for 90 audi v8
  236. car starting sound
  237. Rack n Pinon Leakin
  238. Fuel Pump housing bottom Strainer ?
  239. 1987 5000 avant vs 200 avant hatch
  240. fuel pump housing cant get the pump to stay put
  241. *puts the white cloth over the 5000S* It's dead jim.
  242. Installing newer gas tank.. What hose is this??
  243. After all of those months and spent money (ALOT)-still misfire.
  244. Sound treatment of doors
  245. No fuel pump strainer
  246. Fuel injection problems....
  247. 'tepid start' problem
  248. fuel pump wires
  249. Diffrent Fuel Pump Wire Up
  250. Fuel Pump Change ?
