PDA
View Full Version : Audi 5000 / 200 / V8 Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. Audi being sued
  2. Loud screeching noise at start up & AC compressor will not turn on. Is my compressor seized?
  3. Is $700 USD the going rate to have rear main oil seal changed?
  4. will a 2.3L, 20V, NA dizzy fit a 200?
  5. Lexus RX commercial...
  6. Will these bolt on right without mods?
  7. (KC) GTG on Tuesday Sep 21 in Westport
  8. Need trans......
  9. The TQA lives!!! Kinda sorta :(
  10. clear signals...
  11. Parts needed so far...
  12. Gas guage not Working!!!!!!!!
  13. 200 Quattro clutch pedal
  14. The Audi gods must have Alzheimers?
  15. Rebuild...
  16. All four doors for a 5000 for sale....
  17. are there common places/ways the tranny leaks?
  18. 81 Fuel Inj. problems????
  19. G38's for 5000 avant - G36 for sedan? Rears.
  20. Bought it... 1987 5000cstq
  21. HVAC Blower
  22. My free audi 100
  23. CV boot Replacement
  24. Found: '87 5kcstq 150k kms sat for 4 years...
  25. Treehunter... got your QLCC chip yet?
  26. Does anybody have any experience with this guy?
  27. Headlights
  28. 1991 200 20V
  29. engine cutting out and running real rough
  30. Adjusting the wastegate spring
  31. Leaking motor oil at rear engine seal........
  32. '87 5ktq rad. fan runs full blast with key out of ignition!!...
  33. What to do when the "BOMB" test fails....? on 200 20V
  34. Tonight was a sad farewell!
  35. i just got an "Audi Lineup" catalog from 1988,
  36. would the BRAKE light get triggered just by air in the lines??
  37. What brand are stock 20v headlights?
  38. At what 1/4 on the tempature gauge does the electric fan turn on???(86' 5ktq)
  39. looking at a 87 5000 cs...
  40. 85 5000s wagon >need help
  41. It runs!
  42. what is the going price for a 1990 Audi with 180K ?
  43. What's the going price for a used 20v intercooler?
  44. so ummmm....
  45. Parts Catalog
  46. A/C leak
  47. Last part of changing rear brake pads
  48. How much should I expect to pay for steering rack.
  49. Reminder: 9/25/04 - Audi Dyno Day and Get Together - Come Hang Out - near Hartford, CT
  50. ECS does not have the MM Hoses...
  51. While I'm waiting for my friend to help bleed brakes, heres the new lovely aluminum mc!
  52. soaking in PB Blaster for 12 hours, and a torch on it for 10 minutes, screw on MC wont come out
  53. Holy crap, Charlie46! You have me beat...
  54. Anyone ever blow a fuel pump relay pulling codes?
  55. Half Empty or Half Full?
  56. help me change the rear brake pads
  57. Where do you find those spoilers/valences...(front and rear), like the one on that 100 down there
  58. whats the cold side intake measurement on a k26 turbo?
  59. oil cooler... failure.. replacement??
  60. Radiator Fan Motor
  61. Pop goes the weasel....
  62. Didnt Mark Flywheel Placement when I took it off!
  63. X-Post: NE Ohio GTG - 9/18 @ Bunker's
  64. Need help with my timing after timing belt replacement...
  65. taking apart and cleaning throttle body etc.
  66. After removing ExM what else
  67. I'm so confused. Mainz 2004 picture.
  68. Pinging mid-boost...Why?
  69. Hey XcellR8edAudi
  70. Ack! Brake servo leaking Pentosin
  71. Fuel/Air monitor self made?
  72. +++ more pics from the Audi meeting in Mainz last weekend +++
  73. where/who can I sell my 1986 5000 Quattro Turbo too?????
  74. Somebody pleeeease buy this.....
  75. alright Wednesday- my plan is to install my brake MC.
  76. broken drivers side lock core?
  77. Will NG- thanks so much for your help lately.. maybe when my car is running somewhat normally..
  78. see.. where do they go? they are just wrapped around and hangin there
  79. frequency valve in the fuel line
  80. Car Audio cont.
  81. So I'm replacing my Brake MC tomorrow, so that will get me stopping again, but...
  82. Do these Waste Gate Springs fit our Audi's?
  83. Car runs only when timing is off a bit - any ideas?
  84. whistling alternator
  85. Powersteering motor crashes
  86. constant velocity joints?
  87. so regarding the wierd BOGEs i got in the mail...
  88. update of my brakes, bomb, issue... HELP ME!!!!!!
  89. +++ Big Audi meeting in Mainz (Germany) last weekend +++
  90. Any body have any history with Blau 272 cams on a 10 valve turbo motor?
  91. Wanted : QLCC chip.
  92. AHHHH my car is so annoying- the BRAKE light with the red triangle is flashing on my dash..
  93. Any BTDT on a rounded out 8mm bumper bolt?
  94. for those of you that didnt read my post a few days back, i met a guy with a 200 20v sedan
  95. Any tire recommendations?
  96. Why you should always use new crush washers when changing the fuel filter.
  97. grrr.... I know this has been covered but someone please set my mind at ease.
  98. Audio Question
  99. Has anyone tried...
  100. Kent Falls, CT gtg/bbq...Saturday, Oct. 9th
  101. so u guys were telling me that i ordered the wrong BOGE's for the rear and that the yellow cartidges
  102. Results of my weekend headlight project >>
  103. Signal Lights ?
  104. Hey philip200qt....
  105. My new "find"... Dialynx EM
  106. best software for rs2 spec 20v
  107. any cheaper alternatives for exhaust system????
  108. do i have to remove ps belt or alt belt to remove my timing belt cover?
  109. ha!
  110. 5k cdq fuel pump check valve
  111. climate control keeps reseting itself
  112. visiting from 4k forum with a part request...
  113. Anyone know what fuse 28 on a 5000s is for?
  114. Is there a preferred, heh, "Schrapnel Knobben"???
  115. clutches......
  116. Brakes Problems
  117. Blaupunkt 5.25" components installed - 200q20v
  118. AC/dash vents not opening
  119. Well it's that time of the year again...
  120. v8 bumper fit directly onto 200's???
  121. how is the reliability of a 200 with the rs2 upgrades
  122. No Fuel to Injectors......Please Help :-(
  123. Argh! Door latch cable is broken
  124. Q, wires to the multi sensor, which is blue?
  125. O2 sensor prices
  126. How does V8 Quattro do in the Winter?
  127. HELP? what do i do? Sell it or keep and fix it?????
  128. 5KTQ clutch replacement, tranny advice
  129. Tranny Sensor (maybe Speed)???
  130. loud buzz/hum from right rear of car?
  131. oh great.. leaky transmission.
  132. Ran out of spares, do door handles from any other VAG cars fit type 44s?
  133. 1986 audi5000s start problem no spark
  134. Timing belt replacement
  135. Audi-fansite type 44 picture gallery BWW [edited]
  136. Indicated max boost stock = 1.3 bar on dash unit correct?
  137. Headlight condensation -- any suggestions?
  138. this isn't the right thermoswitch is it?
  139. Euro model,autobahn winter package,1990 4.2 V8 tune up parts
  140. I cant beleive its been ten months already????
  141. My car wont run
  142. I was gonna wire in a switch for my radiator fans so i could leave them on all the time or whenever
  143. so when i do my suspension, i just need to replce the bearings in the strut mounts?
  144. NON-AUDI, please help if you can though... sorry
  145. anyone know where i can get an ashtray for a '84 5000?
  146. does anybody have 18's on their 20v 200
  147. did all 1991 200's come with sport seats?
  148. can anyone host a small video for me? i have a short clip of my car
  149. Need BDTT input on exhaust and stuff in a huge way
  150. climate control problems
  151. Continuing Cost/Benefit Analysis
  152. hanging out with a friend... :P
  153. MMmm Mmmm Mmm.. she sure cleaned up well today.. cant complain for 17 year old paint!
  154. so i have H&R Springs ready to go in.. and Boge rear turbogas shocks-
  155. finished my oil cap...
  156. Gas gauge
  157. transmission dipstick
  158. New V8 owner
  159. Is TAP still in business?
  160. karaoke in car .. feedback please
  161. Just finished a euro headlights installation! Amaizing!
  162. Cold idle
  163. so 5000 speakers are preamped as well? my 200 was, so i had to get all new speakers
  164. Fixing delaminated mirrors - some ??'s
  165. question; preparing for water pump gasket replacement
  166. a great paint site for all cars.
  167. just stopped for a quick shot in the rain...
  168. 5000 starting & electrical problems : need your help
  169. Why can't you use GL-5 in the gearbox?
  170. WTF?!? part II <<much shorter this time>>
  171. so how good are these cars reallly in the white stuff
  172. clunking from drivetrain while turning
  173. 9/25/04 - Audi Dyno Day and Get Together - Come Hang Out - near Hartford, CT
  174. Brake Accumulator
  175. mmmmmmm...
  176. Is this do-able? (Post was lost in the shuffle down below...)
  177. Ive got a chance to buy two more 5000's
  178. A/C compressor and performance
  179. 1987 audi wagon problems - kinda long drawn out
  180. before and after shots... did a little body work myself today..
  181. Will Ng- Not the same but close on my oil cap :P Gotta love a little touch of billet aluminum
  182. 88 5kTQ wagon for sale (WI) - $2000
  183. ANY good BTDT tips on a clutch slave job?
  184. random shot of today... little roll action..
  185. Check out my rear end...
  186. 1994 100S Wagon overheating
  187. Sigh, I might be buying a Honda CRX.
  188. Anyone replace a windshield lately?
  189. Auto Transmission problem
  190. Any Idea????
  191. Need help with finding an exhaust for an 86' 5ktq...
  192. left rear brake locking up
  193. r u kidding me that all30 of the white plastic nuts have to come off when removing rear chrome trim?
  194. 5000CS shift linkage
  195. Wheels
  196. Anyone here changed a steering rack? Rebuilt one?
  197. 200 20V Quattro - Transmission maintenance question
  198. paulfern2000 .. BBS rims on the V8.
  199. New 86' Audi 5000 Owner.......... Help!!!!! The Car's stuck, won't move!!!!!!!
  200. hey roster
  201. How bout one more cuz you guys know u like what you see :P
  202. so i stopped at a random shop driving through a town a few miles away..
  203. anyone looking for some parts?
  204. anyone have tips or tricks on removing rear bumper?
  205. hmmm.. looks pretty nice
  206. Brake Bleeding Q:
  207. any BTDTs for changing the thermoswitch for the fans?
  208. random shots of the day...
  209. 85 5000s radiator
  210. Pentosin misunderstanding?
  211. Have extra DS euro H4/H1 lense and tub
  212. Door locking snap?
  213. Modifying the back taillights
  214. I've done it! no more link. audi content for your pleasure
  215. Anyone interested in headlight relay upgrade kits ????
  216. Ok, WTF?!?! <<super long>>
  217. dashboard christmas lights are blinking
  218. V8Q Fuel Pressure Regulator, who's got them cheap?
  219. TCU Code 1231 Transmission Speed Sending Unit. V8Q
  220. Ticking noise from the engine after warm up...
  221. QLCC guys...
  222. 100 no start condition... quick help request
  223. Anyone have a extra driver's side headlight for a 1990 200?
  224. Black fouled spark plugs..Reason anyone?
  225. anybody want a mint condition 1991 200
  226. ooo, lookee what i found! 200 with some dual round headlights doing some drifting
  227. will ng- where are u located?
  228. Where is the headlight warning module located on 5K?
  229. Changing a type 44 air filter....4 hours.
  230. Going thorugh a bunch of paperwork in my glovebox.. found an original reciept
  231. G60's off a 93 S4 in good shape with rotors and pads worth anything to you guys?
  232. I'm thinking the average quality of 44s out there is actually improving
  233. I need Pentosin oil
  234. oil pressure sender location and diagram anyone?
  235. anyone in here on the forums actually bought their type 44 new? or does everyone have a preowned one
  236. Leaking motor oil at front of block.........
  237. SVX and the 5000
  238. clutch slave bleed
  239. Any idea what a MC weighs? or engine conversion idea.
  240. set of 5000 springs just sitting... how to determine between front and rear?? quick help!
  241. Anyone have the part # for VW's pop can shaped oil seperator?
  242. Need: Original Bose Tape Deck for '90 V8Q
  243. Electric fan on V8Q update
  244. Will Ng- here's another shot of the wheels... thanks so much for all your help..
  245. ABS Relay Fuse on 1990 V8Q
  246. Brake Job - 1989 Audi - Need to turn Rotors?
  247. Air conditioner compressor
  248. 200TQ starter screchees
  249. these showed up on the doorstep finally. a4 sport wheels... Looks much better IMO- what u all think?
  250. Any V8Q owner bought the Bentley CD?
