PDA
View Full Version : Audi 5000 / 200 / V8 Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 [66] 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. Fule pump noise / cut out (X-Post from Audifans)
  2. alternator not charging
  3. Thanks to Black-Wolf and his girlfriend for the quick radiator delivery!
  4. "...What was that crank bolt torque again?"
  5. what size speakers fit
  6. Question about putting a BPV on a 1990 200TQ...
  7. Fuel pump fuse
  8. Bolt on Vortech for V8Q, interested?
  9. anyone want this (parts) car?
  10. need quick help, spark plugs for 89 100Q
  11. Strut mounts and bearings
  12. PS Pump Pulley
  13. i can never win with this thing...
  14. Adam Mowafy ... removing gas tank.
  15. Very Heavy PS Fluid Leak
  16. How to set clock in 5000TQ?
  17. How to know if alternator is charging?
  18. Anyone interested in gray leather seats from a 90 200TQ?
  19. Larger oil cooler for MC engine?
  20. 5ktq running good... except for CEL under boost!?
  21. what compression ratio should i run? (20vt)
  22. 86 5000cs clutch replacement (First Time) Help
  23. need a side shot of a stock 200 BBS wheel... tia
  24. buying audi 200 turbo
  25. Those of you with tinted avants, would you be so kind as to post pics?
  26. Vacuum assist Brake conversion.....any thoughts?
  27. Aftermarket parts for a 200?
  28. A little view of whats to come......
  29. BYE BYE Audi
  30. Failed inspection
  31. not a good picture, and by far the ugliest paper plate wheels ever, but side skirts on type44
  32. Anyone near SW Michigan have a radiator they want to part with?
  33. Audi Radios
  34. Replaced my MFTS today
  35. Ailing Electronics? And more...
  36. anyone replaced a windshield? got a crack in the 5k's today. price guess??
  37. Anyone have experience with fuel lines-corrosion 86 5k?
  38. 85' 5000 turbo ign-distributor fit an '87 5000 turbo
  39. paint.... What color is this? LY7Y (see pic in sig)
  40. (Sigh) Broke down and ordered a MC today....
  41. Brake problem
  42. Stupid Transmission Help
  43. how to locate/diagnose possible bad computer on 1987 audi 5000 cs
  44. now help again for me please !!!
  45. Audi V8 and Porsche V8? Hmmmm.
  46. ISV and hard start.........?
  47. Every year the week and weekend of Waterfest are just plain brutal! I even asked myself why we do it
  48. New car!
  49. Saying Goodbye to My '87 5KTQ
  50. The 'new' fleet :-)
  51. Bolt Pattern
  52. Congrats with thread #10000!!! :)
  53. New to this forum..... Just bought a 1990 Audi 200q 10v
  54. Price of '87 5000 paint job
  55. Connectors that go nowhere
  56. Anyone have a gray drivers side sun visor for a 90 200?
  57. 3" downpipe advice needed...
  58. Can you reset the ECU by disconnecting the battery?
  59. 20 valve fenders
  60. Still trying to put the S-car seats in the 5000.. please help
  61. anyone know when andrewrastetter is returning from germany?
  62. 5ktq stumble: FIXED!!
  63. Hey SteveJ, any warnings on r&r'ing alternator on TQs?
  64. shopping for KYB shock for rear of '87.............
  65. Are P/S hoses from rack to pump interchangeable between 5K and 100????
  66. Nice 26K mile 91 on ebay
  67. 15x7 w/ 35mm offset fit 87 5kcs without spacers or flares?
  68. Any URL's or techniques on lowering 1991 100
  69. I have a fuel pump relay problen.... I think
  70. Idle again
  71. anyone have a set of performance shocks for sale?
  72. CV SHAFT INTERCHANGE
  73. front lower control arm-interchangeable?
  74. 1986 5000cd - no start- timing
  75. some update pics of the V8
  76. A/C Compressor Clutch Q:
  77. Remove Center differential from transmission, help!
  78. anyone know what the black box on the drivers side just below the hood release is? on a 1991 100
  79. Need some help with pricing my audi's
  80. **REMINDER** August 15th
  81. 86 - 5000cd turbo "no start"
  82. Loyalty Discount
  83. AC Fuse for a 93V8
  84. Can anybody tell me how to get this alternator bolt free?! (pic attached)
  85. who all is in the kansas city area?? i am going tonight too
  86. This must indeed be the week for alternators; mine just went...
  87. (KC) Reminder - GTG tonight
  88. headlamps,you might read this
  89. okay so here is my current seat "dilemma".. i got a pair of power s-car recaros
  90. a little eye candy from a drive yesterday... seemed pretty smooth
  91. Is there part of the ignition that turns alternator on/off?
  92. anyone have a good source for the proper 3 wire O2 sensor
  93. Oli Pan Leak
  94. Is the ISV circuit one of these items?
  95. Anyone that needs a new front axle for a 5k 5sp. I found a good deal.
  96. andrewrastetter- you still around?
  97. Audi 100 A/c malfunction under engine load....
  98. Search for Bridgestone Potenza 17" OEM Tires
  99. What $ does a V8 5-speed get these days?
  100. No-Start Woes.....Long post
  101. 5ktq stumble narrowed down to fuel pressure, but...
  102. I might be getting a cheap 87 5kq. I am psyched. Winter rally here I come :D
  103. 90 200 TQ won't start - Please help.
  104. She's charging on her own again...
  105. What's the most useless / weird device
  106. Procedure for lowering A/C temp
  107. Does anyone's 5K do this
  108. need help with a starting problem
  109. 86 5000T Auto tranny issues
  110. audiqv8 hey let's debate a little
  111. NEW information HID kit level changed to 5300K for only
  112. tip of the day- final drive refill/suck out/check
  113. saga continues, transmission swapped no shift forward,help
  114. may be getting to free audis!
  115. Not so fun project...
  116. Because I'm a sucker for punishment...
  117. Fuel Pump is not turning on
  118. 3b v. AAN
  119. what are the fundemental differences mechanincally between a 91 100 and a 91 200?
  120. Idles fine, strong across the powerband but
  121. Sometimes, you're the bug ... sometimes, you're the windshield
  122. Three weeks left in the Audi Club raffle!
  123. Senna4life, big thanks your the man! 5KTQW drag race video at waterfest. enjoy.
  124. 5K Turbo Wagon Questions
  125. boost questions...
  126. inner cv boot on '89 200
  127. So I'm going to be going off to College soon...
  128. Radiator fan works with ignition off Audi 87 5000S
  129. High Speed Fan
  130. V8 dash lights question
  131. Playing with photoshop......
  132. wheelskins steering wheel cover
  133. tire pressure, 215/60/15
  134. Bummed...
  135. any suggestions on getting the piston on my frozen rear caliper open again?
  136. Help with 86' 5ktq fuel delivery.... long
  137. V8 leather seat patterns
  138. What bulbs are you guys using in your euros?
  139. no spark, after transmission drop
  140. Where can I buy new suspension bushings for a 90 200?
  141. hard start again ;(
  142. Newbie Questions (brakes, cruise, headlights)
  143. You know you've all felt this way at one point...
  144. im getting a pulsating brake pedal that is not rotor related....
  145. 1988 audi 5000 c5
  146. What Prestone says about phosphate-free antifreeze for European cars.........
  147. so heres the new deal... when i got my car i knew it need brake work..
  148. looking for a PS pump for 89 100
  149. phosphate free antifreeze,,,,,,,,,,is it better?????????
  150. Audi 5k performance parts for sale
  151. Stalls when hot
  152. Last Call -- 87 5ks parts --
  153. fuel pump
  154. Wheel offset 101
  155. Spoke too soon...
  156. alright to continue my post about the alternator, cuz i think ppl are missing the one below
  157. European roll call (who lives in Europe, wadda ya got and where?)
  158. Gonna replace my tail ligths on the wagon with...
  159. Any BTDT's on radiator remove/replace?
  160. Anyone know the approx. 0 -60 & 1/4 mile #'s for a 90 200 w/ the QLCC chip & spring?
  161. 5ktq is kicking my butt again...(numerous running issues)
  162. Some pic's of the ol' car...
  163. Anyone know where I can get clear corners for a 90 200TQ?
  164. Another bad day for the audi. two in a row.
  165. Any btdt's with replacing brake master cylinder?
  166. Audi 5ks ?86 - fuel pump and blower fan not always works.
  167. Still looking at August 15th at 1 pm at the top of East Rock Park....
  168. Electrical gremlins...
  169. Auto transmissions
  170. selling some stuff......
  171. Parting Out 82' 5G TURBO DIESEL
  172. Dash bulbs
  173. FS: Two V8 headlights, and a 4.2L rear muffler...
  174. My Home Brew Single Pass Intercooler
  175. I need help bringing a friend into the audi fold.
  176. Anyone know if wheels from a 1998 A4 will fit a 1990 200?
  177. Timing belt replaced, W/P, pully, belts replaced...
  178. Who will claim this car?!
  179. Fuelpump capacity ???
  180. 5kt has never left me stranded until tonight :(
  181. what the F! Car was running awesome the past two weeks now this..
  182. advice on buying a 91 v8 quattro
  183. hey guys... just a question from a newbie
  184. Clicking under load at high RPM
  185. pulled codes on '87 5000CSTQ
  186. OK...I've searched the archieves and read the "directions"
  187. I guess "Klaus" retired......
  188. Spotted this about 30 minutes away from my house...
  189. Two cars... both 91 200TQs... both hitting 1.4 bar on stock gauge... Q's....
  190. anyone selling a mc-2 or mc-1?
  191. new coolant leak....question on certain metal tubing.
  192. Goddamn it... Help? anyone?
  193. have 86 5K, need A/C evaporator unit..........
  194. 88 5ksq
  195. Hey Toxcheap!! Email me of forum, I'm interested in how the old black auto 100 is doin
  196. Some quick help, hazard lights
  197. 1989 200 Avant reliability? MPG estimates?? Is 10V more fuel efficient than 20V?
  198. Squeeling noise from back of engine?
  199. sway bar/lower control arm troubles
  200. Could a faulty speed sensor throw a V8 tranny into limp??
  201. considering a 1989 10V Turbo 200 Wagon? Reliability? Price? I think he wants $5500? 100K on odometer
  202. Taught myself how to re-key trunck lock tonight...
  203. hello guys and girls...its been a long time since I have posted....Still have Audi though.
  204. ok suspension fun time
  205. Anemic idle and . . .
  206. So now I'm REALLY back in the club, not even a week and the first problems...
  207. I still have these 85 T wheels for cheap...any offers? I'm in ...
  208. 86 5kTQw FS in CO
  209. Avus Wheels... Questions.. please help me out..
  210. quick! removal of orange "reflector light" how to? i pulled the chrome trim and don't see any screws
  211. trailer hitch for audi 100
  212. Want to see some Audis move on your screen? Check out this site!
  213. Electrical issue question
  214. V8...wiper problem
  215. How much HP can a factory clutch take. 5KQT
  216. 91 Audi 90 20v
  217. did 86 5000 quattro come without turbo?
  218. X-Post: Targa Breitenbach - July 31st
  219. Intermittent stalling on 1988 100 - HELP!
  220. how long will a 200tq last?
  221. Stock 200q20v VS. chipped 10v 5000/200
  222. Anyone intalled a circuit breaker instead of fuse for radiator fan?
  223. How is a door panel removed from a 100????????????.......
  224. 3rd gear syncro
  225. Stumbling and stalling 5ktq...
  226. New 44 project, pics to come!
  227. Sunroof lubrication - How?
  228. co adjustment
  229. Finally! Got around to taking off the pinstripe..! What do you all think?!
  230. what would slightly RAISING the compression ratio do on a turbo?
  231. Need to borrow/buy a trailer hitch...
  232. 3B questions!!! please help!
  233. injectors
  234. Tinted euro lights for 89 100 Q
  235. 89 100 Quattro 5 speed
  236. What octane gas does everybody run on their T44s?
  237. Big thanks to Gruppe5!!
  238. VW eggheads get busted on camera heading to Waterfest!
  239. 1989 200 Quattro a.c. compressor clutch control unit ??
  240. 1991 20v turbo: compression test specs?
  241. Is electric window winders the same amongst 5Ks and 100s?.........
  242. brakes and howling noise
  243. Anyone need a 1985 5k turbo engine?
  244. Who had insurance problems like this around Febuary? wanna give this guys some advice?
  245. Another Headlight Question
  246. Does anyone have diagrams of the final drive assebly of 1990-92 V8? TIA
  247. Some EVILWGN dyno videos
  248. Headgasket renewal..Which one is the best?
  249. CV boot tore on the 5kq, so no auto-x for it this weekend...
  250. What size wastegate for the 200q20v?
