- Anyone want parts?
- Had to ask before I tempt fate.....
- Car wont run (leak?) 87 5000cstq
- There's something wrong with my brakes.
- '86 5K Starting Problem.
- Large (german/english) docu website renamed and enhanced!
- 5000QT - Speedometer Not Working
- Alternator trouble? - '90 200qa, 200k
- 5000TQ Wagon - Problems with Locking Diffs
- quattro care
- Car wouldn't start today...
- Had a good time at the SCCA Pro Rally this year:)
- Need Silicone Hoses - Any Suggestions?
- Hello Guy's and Girl's...It's been awhile....
- Yup...it's that time...broken studs on exhaust manifold...
- Audi turbocharger question.....
- bleeding cars with ABS
- 91' 200 tq
- Chip wanted, Help Needed !!!!
- Boost creeping into overboost cutout !!!!
- Installed IA Stage 1.5 last night..Works good..
- Is there a washer inside the upper wastegate? 88 5KTQ
- Whats a fair price fo rused signal/light switches?
- slight steering slip
- Well lads... got stung today.... instrument cluster lights this time.
- Will '94 100 wheels fit a '87 5ktq
- Winter Car, '87 5KTQ, Need opinions/advice.
- Anyone have a rear light panel for a 200 avant?
- 1989 Audi 200TQ MC1 vs MC2
- Installed E-code lights, but there is a problem...
- Wobbling on the highway
- need a rad help ...
- If you need a cheap 5000 shop manual, here's your chance:
- bad wheel bearing symptons - different?
- Just got a bunch of new parts
- low power in 2.3 NF
- Got a set of 15"x6"? steelies ..also some tires... don't need 'em, you want 'em?
- Selling some type 44 parts - inside -
- Anyone know a good place to get fuel injector line for a b3 90?
- alright.. so i was corrected and found out there was a V8 Lang, also made into hearses... WAGONS tho
- how do you get the wiper switch out?
- HHA HAH you guys have to check this out!!!
- Ignition Cylinder Help?
- Tire Size Question, 16" rims,
- Tranny Making whirling noise after clutch replacement.
- How plausible is it and does anyone in Europe have....
- has anyone added an external fuel pump?
- last week someone posted an online repair manual
- Hey Philip200qt did you fix that overheating prob?
- Cruise control does not work on a 1990 Audi 100, left signal continues after turn also....
- wipers/fan/climate control system off with start system?
- hoses, hoses, hoses
- V8 Quattro Euro Headlights wire harness kit
- Cooling fan--back to the drawing board
- loose connection at ECU is causing pressure transducer to peg the boost reading
- anyone got a source for peirburg pumps? Brdmanmt?
- Well put the doors on ebay today.....
- anyone got a working used fuel pump for sale?
- I got cocky and the Audi gods got me again. [long]
- Trip this weekend: Calgary>Salt Lake City>Las Vegas>Palm Springs
- still overheating :(
- 1991 100 Gear indicator stuck on D
- argh. stupid brake warning.
- My car is still screwed!
- Arrrggh! Dammit! So i was having the long cranking, no hot starting problem- So today
- I Can't wait .....
- So last night I was watching "Tuner Transformation".....
- My new turbo gets REAL hot
- Big Brake upgrade
- suggestions for oil cooler for project vehicle
- Wheel offset sizing question. V8Q
- injectors test?
- Still uneven idle, have tried idle switch and control valve
- Burning Right Marker Light fuse, Trouble finding short
- Mmmm, winter (bww)
- Look at all my little type44's! Actually not inexpensive.. but they are neat and detailed!
- ok... im lookin at a v8.
- anyone here with a blue 200 w/ newer 16" OEM 5 spokes?
- Wheels FS...
- $500 5Ks quattro for sale in MA.
- Pics of my "new" 200q20v and the new turbo!
- brand new thermostat isn't opening
- my after-run fan wont come on with 80c thermostat any ideas?
- rpm or ign sender?
- Supplier for 5-speed V8 clutch disc & pressure plate recommendations?
- Any good websites for 10vt replacement parts???
- need some tranny help with an '84 5000
- Anyone know a good place for a headlight relay kit?
- Paul: How's that Twin Spoolin' V8 coming along?
- cherry bomb or stock muffler???
- Seat stitching splitting
- Oil in MM hose, and black plugs..Reason?
- ummm something isnt right here..
- Colorado Springs Audi Nuts?
- Good Bypass Valve
- BC Audi meet this Sunday Oct 24 @ 1pm
- Another dumb cylinder head question...
- A few problems with my 5000 S quattro
- cold start valve same on 87 5000 Sq and CSq?
- disable rear brake proportioning valve?
- 235/45-17 on 17X7.5 with ET30 offset fit 91 200 20V?
- More fun w/ audio
- need gauge covers
- ha HA. I passed emissions!
- Looking at a '92 100
- first snow
- Wiper Motor
- Looking at a C4 tonight
- you would think i know how to work on these audis better now..
- anybody have a picture of what the brake pad sensor looks like? i need a bentley.
- Could someone please explain the procedure for......
- where is my cold start valve located? the bentley does not have a good shot of it...
- OT: Type 44 drivers who golf?
- so i still need that rear camber link passenger side.. this is what i want right?
- Sell?
- Did the "bomb" test and OK, but......
- ebay Germany ?
- 200q20v hitting some kind of cut-off causing bucking.
- whoa.. found this online- installed nav, check out climate control location now..
- Price Check: Cold Start Valve for 87 5kcstw- anyone got a used one.
- boost mod and outo trans ???
- So I havent had much luck getting answer on my type44 problesm.. it seems like everyone is having em
- Woes weekend. {LONG} any ignition switch BTDTs?{SHORT}
- 85 5000 turbo block heater?
- Replacing my front cross member - questions...
- Wheels
- ok, what the hell just happened?
- Reverse woes
- So if the temp gauge always reads low (70c) then..
- V8 oppinion
- German cars have to run on German Highways
- Where to find...
- Can anyone Help my 87 5kqt has a stalling problem!
- car use to start great, then has added more cranks to start every time over the past 4 months..
- rear camber? (long and hard to read)
- I must be cursed. Brake woes again.
- '86 5000 cooling fan runs forever with ignition off
- its getting cold.. WTF is wrong with my seated heats.
- What are these wheels called?
- Loss of brakes, then magically self restored.........what gives???????
- climate control blower motor brushes source?
- Question for RockinV8Q - Shockproof Light
- Question for Adam Mowafy, (or anyone who knows about getting oil lines fabbed)
- does the MFTS send the temp info to the cluster gauge?
- CHEAP CHINESE THERMOSTATS!
- 5ktq v. 200tq
- i missed the link for the right rear camber link for 60 bux or whatever.. cant find it. post again!
- MC1 wiring harness and Kostal connector
- Huh...
- Anybody near Beverly, MA????
- Is there a bushing somewhere in the clutch pedal assembly?
- Exhaust manifold, there's got to be a better option...
- Welding Noob Question
- totalled the 89
- AHH I just got pullled over for my inspection sticker...! I wont pass because I REALLY REALLY NEED a
- ECU codes available on 1985 5000S (no turbo) ?
- got a spare 200QT manual cat?
- will this A8 fuel pump work in a 5000??
- Check engine light coming on......
- Thinking of parting the 5kcstq or selling it...
- Changing the bulbs on the Dash display...
- Someone put meet out of my Audi misery. :-)
- Funny ebay post...
- lower conrol arms,front$$$$$$$
- 1991 200 20v What to do now?
- What size is the injector insert in the cylinder head?
- Audi 100 more power??
- How can I lower NOX emissions?
- Washer Nozzle
- Car will stall from 2000 rpm's....
- hmmmm interestinggg
- Water Injection (from a few posts ago)
- Anyone have a mac14 ECU for a 1990 Audi 200 to spare??
- Throttle Body
- 10V---->20V
- Good/bad
- Audi 5000 diesel, under manual gear shift boot in the interior...
- Lake Superior Pro Rally...OCT. 22-23
- a.t. ?
- tach not working??...........
- Need a fuel distributor for a early 86' 5ktq
- Good Price for a '90 V8 in Great Shape?
- non-audi sorry in advance
- My 5000 cdqt weekend
- Two Problems
- X-Post: 2nd Annual Cuyahoga Valley Fall Cruise and Clambake - 10/16
- ran my 200 the other day... (gotta pull that engine soon)
- "Clunk" uncovered.... <blush>
- 1991 100 avant Stalling at Idle and running like CRAP
- Any turbo owners using water injection?
- Anyone know how this all goes back together?
- Anyone running Eibach 1529.140's?
- Sneaky peaky at my Avant project.
- Re: A GM 350 into my Type44, just thinking
- low end speed
- THIRD car with ignition switch issues!
- need upgrade information for 89 Audi 200
- Anyone want my 5kt for free come get it soon.
- Where can I buy replacement shocks for my 1990 200TQ? Nothing great, just replacements...
- MTM 200- Mmm Beautiful... Theres a great video on the nurburgring site on this car.. sounds evil :D
- which BBS's does Dan have? not 200 BBS's....????
- Well my car is finally running on 034 EFI stage Ia.
- Alright, so Type 44's in movies.. what do we have!?
- Ordered the parts for the cylinder head...
- all of you who have rs2'd or similar to a 20v 200
- Scam artists still out there scamming people on used car sales........
- OK, what's this rubber part?
- damn blown fuse is pissing me off...
- Congrads to the birdmanMT for winning his class this weekend, no better way to start off!
- Boredom + clean car + night-time mode on camera =
- Random Shot from today's drive to NH and back..
- WHere is the air boot located?
- Thanks guys...
- 5000CS tranny compatability - '84 or '87 5k trans in '87 5kCS?
- 5000 no start - stumped
- freeway shaking (longish)
- Will NG, ToxCheap- I'm going to be in NH tomorrow.. (Sunday) If you wanted to meet up?
- V8Q RPM Sensor/Crank Sensor Heat Plate
- My 5ktq...
- Cant shift!! Need help quick!
- automatic 1991 start problem
- Adjusting CO and Idle, MC-1 engine
- Well, a wire cut and a trip to the track...
- I can think of better ways to spend $150.....
- What have I done now?!?!?
- I need a replacement transmission
- (important) More on my popped out control arm/ ball joint
- where is intake air temp sensor located on an 89 200
- need some help on a part.......
- overheating problem may be related to radiator fan
- Last reminder: Kent Falls, CT bbq is tomorrow (10/9)
- Removing downpipe from turbo...
- Anyone going to the Tall Pines Rally, Bancroft Ontario?
- Engine refresh
- How hard is it to...
- Hey Twisted5000, I just saw your post below about boost cut out.....
- Noticing a significant clunk...
- ABS OFF light troubleshooting
- Best place to buy a power steering pump...
- Holy Crap-Lost a ball joint 5 minutes after 95mph on highway!
- 5000 exhaust manifold
- ATF sub for pentosin...
- My Audi proved well yesterday
- Holy Cr*p! - 8.4sec S2
- 2 long pins on clutch side of flywheel
- Good News... and not-so-good news for me
- Do I really need a Auxillary Water Pump?
- water cooled turbo leak
- Last few things after a clutch replacement on a 5ktq
- sllloooow motion wiiiiiipers
