PDA
View Full Version : Audi 5000 / 200 / V8 Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. Here we go again... I just can't keep this car running...
  2. Chipset for 3b?
  3. taking apart the combination switch
  4. Headliner update
  5. To be or not to be: Decided to be
  6. Maximum boost on fuel system.
  7. maximum boost
  8. changing out stock air box questions...
  9. rad fan speed operation
  10. Searching for a ghost all day long, pesky TPS was to blame!
  11. HID in euros?
  12. what s next???? ingnition switch??
  13. clutch master cylinder removal question
  14. Anyone else ever run 205/65-15?
  15. Steering Wheel Question!
  16. electrical help - diagnose headlight circuit
  17. Hey jurq, the smoked rear tail lights arrived yesterday, they look awesome, thanks bro.....
  18. WTB:driver tail light for 1991 200 20v wagon
  19. wow....high/low beam stalk broken again...
  20. Props to the Type 44 from an A4 driver =)
  21. new 200 quattro owner
  22. Wanted: 1990 Audi 200 turbo quttro stick wagon
  23. Wanted: 5000 diesel or TD ... anywhere in the country
  24. How to compress Audi 200 rear brake cylinder?
  25. more on the roofliner
  26. Who can guess...
  27. RSS Feed
  28. Anyone belong to the white 5000cs I saw last night in Manchester Ct.
  29. Size of fittings for oil cooler?
  30. Just bought an A4 and parting out the 5K, Boxerfan chipped ECU and 1.8 spring $300. Let me know
  31. Idle jump while shifting
  32. BAD GAS
  33. Mit DTM rear spoiler :-)
  34. Mit DTM rear spoiler :-)
  35. damn. what happened to my headlights.
  36. e-brake dash light sensor? where is it located?
  37. Parting Out 86 5000 Turbo Wagon
  38. Is there a general FAQ/DIY page or links for 5000/100? Fuel pump R&R as a start.
  39. LED's in dash
  40. licens plate holder
  41. InMotion Chip for V8
  42. Help: V8 Oxygen Sensor
  43. rear subframe bushings
  44. Very noob question:
  45. How to make your Audi 200 a crop duster
  46. Searching for Zoran, and anybody else to meet in Tampa Bay.......
  47. MAJOR SCAM ALERT!
  48. ahhh, the magic word, SAGGING
  49. I am looking for a UrQ igloo. Anyone got one?
  50. NAC-You guys gotta see this home-brew muffler I snapped yesterday...
  51. Good deal on K24
  52. Might go out and look at a 1990 200 Avant this weekend
  53. N00b Question: Vacuum leak tester for 10V T Cars....
  54. Has anyone heard from Will Ng?
  55. I would like to Thank the "Audi Academy" for...
  56. '89 200TQ-which alternator? 110 or 90 amp...W connection???
  57. ISV vacuum leak
  58. What sort of shift knob was OE in a 1988 5000CSTQ?
  59. Initial thoughts/impressions on new A5/S5???
  60. would anyone be interested in LED converted dash bulbs?
  61. Hi guys, anyone have a pic of a 91 200 20v Q with urS4 wheels???
  62. Just an FYI, if none of you were there....IMSA 200's at Laguna Seca...
  63. Bentley view on lining ?
  64. Any brothers out there versed in 84 vanagoness?
  65. Trans is out! Laundry List...
  66. Just got the V8 out of the shop.
  67. voltage regulator or alternator?
  68. gonna put a new alternator in tomorrow any words of wisdom 1990 200 TQ TIA.
  69. Pre-purchase Help on a 1990 100
  70. Chipping 10V 200TQ
  71. Will bad relays make noise?
  72. Who's turbo project end-up like that?
  73. Interchangeable seats
  74. 875k... charging system
  75. 1990 200 QT (10V) Oil pressure question
  76. fuel pump check valve....checking?
  77. voltage reg. replacement walkthrough?
  78. Half of coldstart problem FIXED!
  79. Servotronic Steering?
  80. Quick Spring Question...
  81. The Audi 5000: its aesthetics, influence, and legacy.
  82. Linkage bushing?
  83. Almost got the tranny out....
  84. Shock Bump Stops
  85. How does the 1990 V8 quattro compare to the 5k or 200 turbo for power and handling?
  86. 89 200TQ-Alternator or Voltage Regulator...
  87. Deutsche Plate!
  88. someone at Chevy's PR machine is getting fired for this
  89. Finally got some pics of the new (old) 200 TQA
  90. 5000 Ansa Sport Exhaust
  91. Hey Vee8 ran across this picture on audifans
  92. Perfect CO weekend to clean up the new car...
  93. Has anyone swapped a V8 or 200 dash into a 5k?
  94. Cigarette lighter - Blown Fuse?
  95. New to the 200 forum
  96. Piston soak w/ "Witch's Brew"...worked pretty well.
  97. OK Codes???
  98. Oil can warning light? '89 200tqa
  99. Front bumper problem
  100. And so it begins.... <edit>
  101. Is anyone familiar with.....
  102. is there any time where testing an alternator with a machiene
  103. V8Q Telephone
  104. 1990 V8 - Opening Front Hood w/dead battery???
  105. another symptom - Check lamp
  106. alternator bad?
  107. Ok, going to get serious abt the roof/head lining.
  108. Need Help Removing Front Bumper
  109. thinking of selling my 85 euro 200 tq
  110. Is there a pre-filter underneeth, near the gas tank, on my 1991 100?
  111. I need a blower motor spring
  112. What's with the HVAC fan? Delayed turn-on, intermittent function???? Is there a temp sensor?
  113. &*#@ roll pin in dah slave!!! I gave up after two hours...
  114. loading some videos of the V8 as we speak. :o)
  115. TBand WP replacement questions
  116. 1987 5000S Q crank.cam alignment
  117. I'll be selling a 200 20V soon
  118. Haven't driven the 5000 since the new year... bought a new nissan frontier and
  119. 400,000 Mile Report (Warning - kick up your feet and fix a cocktail)
  120. New Bosch Idle Stabalization Valve for under $90
  121. You guys were right..
  122. How to remove the hazard/trip comp/wiper stalk for V8?
  123. Timeing Check!!!
  124. Who loans out special tools for a V8 T-Belt job?
  125. keyless entry /auto check
  126. BPV Anyone?
  127. Pulley removal tools
  128. any V8's for sale
  129. 200 20v voltage and fogging issues...
  130. So, if HVAC programmer is out but fan will function w/hot wire, why not leave it hot-wired?
  131. injectors base seal replacement......few more details....
  132. Price Drop on my 200!
  133. need a left mirror
  134. Oil/ hyd fluid recommendations please
  135. It's times like these...
  136. humpty dumpty sat on a wall; humpty dumpty had a great fall; all the kings horsemen and ..
  137. so wheres the water pump on 87 5k?
  138. Lots of snow here! anyone else ?
  139. You Guys gotta see this....Audi Love
  140. Replacement BPV, 200 20V
  141. Source besides dealer for V8 Antifreeze
  142. 86 5kcstq - Rebuilding the Rack. Has anyone done this themselves? How difficult?
  143. is there a GB right now for bronze dist. gear? for 200 20v
  144. Pics from the Snow Cross we had sunday:)
  145. Engine rpm noise in none-BOSE system - any ideas?
  146. Fixed the ABS, or Why I hate cheap splice connectors
  147. Questions about IA Stage III+ 280 hp chip.
  148. Finally gonna get some snow here in NE!
  149. UPDATE..Brakes fixed..
  150. The saga is finally coming to a close
  151. To fix or not to fix...1992 100CS Tranny
  152. Hoses and Waste Gate Bits...Where to buy?
  153. Re....OK Codes
  154. I have a working Delta Bose radio, works great, no code
  155. Talk about bad luck... *WTB* MC bottom end
  156. if the battery light doesn't go on, the alt won't charge?
  157. 1987 5000cs Turbo Quattro....What have people done to their stereo systems in these cars.......
  158. Cold start trouble, STFA'd, still some questions.
  159. OT: funny youtube audi videos
  160. PART1: My Official Report on How to "Replace the Rear Main Seal" on a V8.
  161. 86 5kcstq Starter R&R Post.
  162. 1988 5000, 5 cyl gas
  163. Delta Radio Unlock - Is mine "Soft-coded" or "Hard-coded"??
  164. 87 5kqt Avant Tonneau Cover
  165. V8 Tally Sheet. Post your name under which motor you have.
  166. Sudden Rear Wheel Noise - Wheel Bearing?
  167. Rear window roller blind
  168. Pillar gauge pod for 200?
  169. 1991 Audi 100 5 cylinder
  170. The UrS gets a CSQ big brother!
  171. Red Tag Vs. Green Tag PS Pump
  172. intermitent start!
  173. V8 picture thread.. those who have one, lets share the love :)
  174. Anyone need a wastegate diaphragm
  175. lots of snow :-)
  176. The V8 goes under the knife tonight! Hide your women and children, its gonna getting ugly!!
  177. 1987 5000CDQT 5SP Must Go! Make Offfer!!!!
  178. Anybody know what color Ned Ritchie's 200 avant is? Is it dark or light blue?
  179. How do I find Ben Swan?
  180. Braking system step 1?
  181. Performance parts
  182. battery voltage is supposed to go up when started / yes or no?
  183. good place to get crank sensors
  184. voltage regualtor..
  185. Q about a 1990 V8 Q...auto trans as delicate as those in the 100s?
  186. 1990 quattro v8 stall problem
  187. ICE trials this weekend in WI - preregister now! Only $30 for whole day!
  188. Well.. blower motor replacement was a success! but now my "cat" light is flashing..
  189. Where is the O2 sensor in my 1988 Audi 100(5000)!!!
  190. gasket kit
  191. Ohh goodness it's been so long...
  192. most likely cause of overboost
  193. SCAM on Audi PAGE EvilBay
  194. auto check
  195. My power steering and power brake assist saga seems to have ended happily
  196. Who was looking for a body kit?
  197. Car identification help in ETKA
  198. Recommended Audi for my youth
  199. yippee , got my heated seat fixed , nice quality element covers the entire seat cushion unlike
  200. Correct full throttle switch Adjustment
  201. Ok Confused, ICV question
  202. very cold start problems..
  203. does the mobil 1 atf trick affect brake booster or clutch slave?
  204. has anyone put the ABH motor on a dyno?
  205. blown vacume hose?
  206. Looking for part# - Bosch Fuel Accumulator..'87 5ksq
  207. 1988 5000 CS Quattro stall problem
  208. Cold weather/starter issues question.
  209. Computer Question???
  210. OK Codes???
  211. 875kcs So that braided line going to wastegate can be clamped to
  212. Blink code 2111, RPM / Engine speed Sensor
  213. Anyone have a writeup on interior door panel removal for 200/v8q? I've STFA, and....
  214. OK, pressure bled brakes..Now they work, but descending pedal..
  215. Airbag power reserve missing.....
  216. 91 200 20v. Outer CV joints. Is it true that there is no after-market supplier?
  217. Snow Cross this weekend in the U.P
  218. Tail Light Panel Sealant for 200-which color tube is used? TIA.
  219. Anybody have pics of cylinder head removal? or maby a diy?
  220. ETKA 7 if you're looking for help....
  221. Pump to Bomb Hose Leak
  222. Props to local CT chapter of Audi Fools and work on 200 20v...
  223. Looking for a used Fuel Pressure Accumulator..87' 5ksq
  224. anybody know how to check a waterpump?
  225. anyone know where to find crank bolt tools
  226. Spare 3b ECU in the Seattle area???
  227. Gauges out: Oil Temp, Oil Pressure, Volts
  228. battery voltage question
  229. 4 wire Bosch 02 sensor # 13275
  230. What do you guys do with old leaking radiators?
  231. Someone here has GOT to jump on this...
  232. Anyone with a K24 they want to sell?
  233. Rear hatch stuck shut
  234. Having problem with loading ETKA 7...
  235. No heat in cabin problems (noob to the 5000)
  236. '93 w/ ~62k miles - $8995
  237. 1991 v8 quattro wont start
  238. Can i replace a 3 wire ICV with a 2 wire?
  239. ne1 do som volt metering on hall sender? what were the values? I'm getting 5.5v from wiring socket
  240. Bought a new brake MC..Not 100% same..Can I use it?? Pic included
  241. Fan Queation/ Heated Seats Question
  242. Boost gauge install
  243. 1987 5000S Quattro 342,000 miles
  244. topic: Un-fried my motor tonight
  245. still no start
  246. urgent help car just died! fuel pump wont stop running ulness i pull the battery cable!
  247. Steering without pump etc
  248. power steering pump o-rings
  249. Boost leak check... '89 200TQ
  250. 200 20V Rich Running-One for the Motronic Gurus Out There!
