View Full Version : 4.2 V8 Discussion
- B6 s4 rattle when warm and low rpm
- A8 4.2 overheating when...
- Cayman engine swap
- Blown piston? or valve smashed into piston?
- Is this valves hitting after timing belt change
- Radiator Help 2004 S4
- 2014 Audi S6 air intake
- 2000 A6 4.2L ART with Timing Belt rub noise at cold starts
- Audi S5: P2006 P2007 P2004 P2005 DTC for Intake Manifold Runner
- 2005 S4 standar code 300, 306, 307
- where does everyone get there parts?
- 2007 q7 off throttle noise
- S4 B7 Engine Humming HELP
- Differential Questions, good or bad
- 05.5 S4 4.2 Oil Drip
- 2005 s4 4.2 timing chains
- Good tech'l summary of 4.2's?
- 2008 q7 overheating
- Is it bad????
- 02 S6 Just died
- would a failing torque converter be heard ?
- 4.2 B7 questions for a new guy
- Direct injection
- 2002 audi a6 4.2
- Removing 4.2 FSI Rocker Cover
- Auto to manual trans swap question
- Audi A8 2000 transmission issues
- Gear shift sways
- 4.2 v8 Transmission Problems / Swap
- VCT modulation
- HELP Q7 4.2 FSI Misfires
- how would u go about finding
- 07 Q7 with 4.2 HEEELP!!
- Motor type?
- rs6 c5 avant gear box
- 2001 S8 misfire
- B6/B7 S$ engine differences
- timing belt
- Car dies when pressing in clutch
- Cam tensioner tool 3366
- Intake cam tensioners and trany stuttering
- 4.2 v8
- 4.2 Misfire, engine shake. ....
- Q7 2007 4.2 head gasket failure
- Any Easy Way to Check Fuel Pressure Regulator ( FPR)?
- timing belt replacement
- P1130 , P1128 ; can it hurt the car?
- What's the difference between the 98 4.2 and the '02+ 4.2 (Swap question)
- C5 01 4.2 engine knock at idle
- A8 2000MY 4.2L Engine failed due to blue smoke from exhaust
- engine hesitating
- Help please!!
- Yo! I'm new!
- Temperature gauge stops working
- 2007 Q7 4.2V8 sensor issue?
- 4.2 manual gear box info please
- Removing 2004 S4 Engine???
- 4.2l A6 vs S6
- Code 17691 ???
- serpentine belt routing for 00 a6 4.2l?
- Engine Blocks cracking?
- Need opinions for repair
- 4.2 Cam bearing cap bolts and cam tensioner bolts replace?
- 07 s4 4.2L .. power steering diagram
- 2001 audi a6 4.2l
- Need a mechanic in Michigan!
- :: ECS Tuning :: Schwaben European Essentials Tool Sets!!
- :: ECS Tuning :: Pentosin - Superior Fluids For Your Audi
- Cracked engine block
- 02 S6 Avant - 4.2: Odd throttle/acceleration issue
- Audi A8 4.2 - shuddering...
- 04' A8 what is correct vacuum line plumbing routing/placement
- 2004 A8 Quattro, Loud Engine Knocking and oil sludge
- Parting out a motor
- UNITRONIC SOFTWARE FOR 4.2 V8 ANYGOOD??
- Comparison of Meyle and Hengst Air Filters
- head gasket
- RPM Audi A6 4.2 V8 300hp
- Timing Belt Question
- Weight of a 4.2 V8.
- Help! Paging Engine Management Gurus
- Q7 4.2l maintenance?
- Tranny 2006 A8L
- 2006 A8L
- :: ECS Tuning :: New Pig® Mat & Dispenser Combo Pack!!
- 08 S5 In need of some help...
- Place that has all the engine block codes?
- Anyone port match their intake manifold?
- 2008 Q7 4.2L Torque convertor squeak.
- Megasquirt 4.2l ABH V8
- 4.2 Engine backfires/sluggish/unstable when accelerating
- :: ECS Tuning :: D.I.Y - VIN Decoding!
- S4 Engine Rattle
- exploded view / screenshot
- Anyone have an exhaust vid...one without resonators and muffler? and.....
- 04 allroad w/ 4.2 starting problem
- Few questions regarding power mods.
- 4.2 and FWD 5 speed
- Excessive oil usage
- 2010 S6 exhaust on a 2010 A6 4.2
- Intermittent hesitation while driving
- V8 4.2 S6 C5 supercharger sound at hi rpms! wtf!
- Oil pressure light
- Transmission problem and code p1476
- exhaust setups
- Curious Misfire...
- Chrome flake in oil pan - should I be freaking out?
- 4.2 transplant
- Coil pack hassles.. argh
- Looking for '99 d2 4.2 engine wiring diagram
- Excessive use of engine oil
- Oil Level warning light, but oil is full!
- '06 S4 rpm fluctuations
- Fouling Plugs 5 & 6 Cylinders
- Just got B6 s4....a few problems...
- Need Engine Overhall -New York area
- One of those, "died while driving"
- 02 Audi A6 4.2 o2 sensor replacement
- Best ECU Flash?
- Loud power steering pump
- Need advice and parts
- B6 S4 vs B7 RS4
- CARBONIO INTAKE: VERDICT
- MAF issues B7 S4
- B6 S4 starting issues
- All Carbonio Carbon Fiber Intake Systems Currently In Stock and On Sale at APTuning!!
- Marble Sounds
- S6 V8 2000 VCDS label file problem
- 2003 Audi A6 4.2L Xenon Headlights
- 2005 4.2 timing set up??
- Back In Stock: B8 Carbonio Intake Systems @ APTuning w/ Free Shipping!!!
- Replacing Coolant Temp Sensor A6 4.2 C6 Body
- help!
- Need New Engine
- How to get a 4.2L V8 into a Turn Key for a swap.
- A8 D2 Overheat Temperature Question
- A6 V8 2001
- S4 b6 start fail
- LOST MY TRANSMITION!
- serious Cat failure
- Engine Teardown manual
- ABZ to 016 Question.
- 2004 B6 S4 Oil Consumption
- Tiptronic - 2nd gear jerk/clunk
- B7 RS4 Twin Turbo from RS6, Possible?
- S6 compression test results inside
- audi A6 V8 wining sound?
- Check Engine sorry i'm new with audi
- Need Opinions about Moly Fuel Additive for my B6 S4!!
- Replacement Engine 4.2
- Cam adjuster question 2002 A8L
- 2000 A6 4.2 Purcahse opportunity
- Dip stick stuck on 4.2 AR?
- Vibration under power
- front crank seal leak
- low oil pressure
- Checking out sources for new battery for 1998 A8-D2
- Sourcing Bentley's 1997-2003 A8 repair manual CD's
- misfiring
- Engine failure after timing belt change
- Overheating and minor oil leak
- I NEED A TRANSMISSION MODULE !!!!!!!!!!!!!!!!
- Audi 4.2 V8 Stock Bottom End
- Paint Peeling from valve covers
- A6 4.2 back on the road after 15 months
- Timing - Questions
- how to replace starter
- Independent Audi mechanic in CT for Cam Shaft Tensioner
- Upgrading Engine HP
- 2000 A6 4.2 0441 code
- '02 S6 4.2 misfire
- what is "high milage" for a Audi 4.2L V8
- Camshaft Tensioner Cylinders 5-8 and RPM sensor cylinders 5-8 For sale Audi A6 4.2
- Revo Technik Spring Sale Marth 27th - April 11th 2010
- Coil issue, not being covered by Audi....
- CYLINDER MISFIRE
- 4.2 40V V8 - Rebuild with forged pistons?
- 4.2 engine noise
- Major Vacuum leak
- a8 4.2 quattro 1996
- Replace 2.7 with 4.2?
- potential 07l supercharger buildup
- APTuning/APR Holiday Sale Has Begun, Nov. 23rd-Dec. 31st!!!
- 2002 A6 4.2 Cam Chain Timing
- 4.2 Cat Replacement
- ABZ into 91' Toyota MR2 conversion
- NEED HELP - Looked like a coilpack failure but is much worse – Long Post
- PES Supercharged Touareg
- B7 S4 TuneUp
- Loud "tapping" noise after oil change. Video link included
- 4.2 Ignition Modules S4
- Found this ad in Seattle Craigslist if anyone's interested.
- Supercharger
- Do Cold air-intakes really make a performance difference on audi 4.2s
- '04 S4, bad cam timing adjuster?
- best method to cleaning engine bay???
- Transmission HELP - PLEASE! ASAP
- codes 411, 414 and 423
- Bad noises... 97 4.2l
- anyone change their PCV valve? is it worth doing at about 70k Miles?
- A6 4.2 1999
- APR's Spring Into Power Sale March 9th- April 10th
- Is it possible to upgrade my S5 4.2 to the B7 RS4 4.2?
- Hyper Flow
- 2002 4.2L engine codes
- Q7 4.2 ... timing belt or timing chain?
- NE1 know about a TSB for the gearbox that drives the AC shaft?
- New Purchase
- Cylinder Misfired!
- 4.2L V8 Secondary Air Pump System . . .component help needed . . .
- Cam timing the hard way!?!?!
- FYI cam locking tool for 4.2
- S4 Cold Air intake
- AYS Crank position sensor
- Does anyone know the outer diameter of the Mass Aiflow Sensor?
- Speed Signal Generation for the A8 ECU
- 4.2 PCV valve froze..........................AGAIN!
- The 4.2L V8 -
- new comer to this forum building satin i swear:
- engin clicking???
- Robotic Sound from back after parking the car
- 4.2 no start
- timing info needed
- allroad 4.2 /04 / 99K Km-oil leak while driving to Lake Louise.
- Can Anyone Help me URGENT
- RS6 Full Custom Exhaust Video Clip - All Angles
- Help me understand planetary gears and Torsen T-3
- 4.2 Replacement
- FYI, PES is now accepting applications for G4 testers
- UPDATE
- Oil Leak
- I don't frequent this forum, but thought this would be of interest - PES G4 is almost ready
- ABZ Tech Talk
- 2004 4.2L engine (same as S4) reliability for allroad???
- Schema ECU 4.2 V8 [ABZ] (need)
- overheating part 2
- coolant question
- S4 4.2L won't start...dead in my garage
- new thermostat
- a6 4.2 vs s4 4.2
- 04 A8L (how to change ingition coils)
- stock rs4 cams
- overheating
- Anyone know where I can get factory literature on the 4.2 in my S4?
- relibility
- AEC Motor Question
- Fluid leak from my 4.2
- 4.2 prob. Getting a 4.2 misfire cel... replaced the coils on 5 and 6 and all plugs still getting cel
- Full GMG World Challenge B8 S5 (Number Two - Black) Get's done up at GMG
