PDA
View Full Version : 4.2 V8 Discussion
Pages : 1 2 [3] 4
  1. 2001 Audi A6 4.2 Temp gauge increasing
  2. my 2001 A6 4.2L V8
  3. abs light on brake light flashing
  4. o2 a8l power steering pump howling
  5. A6 4.2 '99 Vacuum issue??
  6. xpost - question on rear main seal for a 4.2
  7. You may have heard this before but read on...
  8. Homebuilt secondary intake runner actuator rods made from steel
  9. Must you remove V8 ART engine to replace front & rear engine seals?
  10. A8 Conversion
  11. 2000 A6 4.2 Turbo
  12. Anyone tried the Unitronic Chip for the 4.2L?
  13. loud pipes
  14. making a 4.2 V8 from s6 similar to rs6 motor?
  15. Can't get the Lemmiwinks/Unitronics to have ANY effect on my A8 4.2L - WHY?
  16. V8 swap
  17. S4 Won't start or turn over
  18. A8 fuel pump
  19. 4.2 Cold Start Shutter/clanking noise
  20. Experts: School me on the topic of internal engine work...
  21. APR Presents Waterfest 14 **Inventory and Activity Update**
  22. light
  23. Need Some Wiring Help
  24. Chip for a 4.2 05.5 S4... worth it?
  25. NEED HELP
  26. Timing Belt Gone Bad.....need advice
  27. check engine light
  28. Hard work pays off
  29. where the hell is this pes supercharger at??
  30. '03 40K RS6 exhuast. E-mail for pics, just removed. OEM standard.
  31. Reliabilty
  32. has anyone tried to turbo their 4.2 using 034's manifolds and gaskets?
  33. Thought you might enjoy this video
  34. thanks you
  35. LIGHT
  36. I Think Battery is Dead...
  37. Cylinder Numbering 2004 A8
  38. 2005 Allroad 4.2 oil smell in cockpit
  39. if anyone is looking for a 4.2 project motor, check my post in D2 forum
  40. Oil Question
  41. Slipping tranny what should i do?
  42. New to S4 looking for some simple mods
  43. a6 4.2 engine swap to rs6 4.2 tt
  44. What spark plugs to use for tune-up in a 2000 C5 A6 4.2
  45. Rough Idle PLEASE help
  46. Some hesitation
  47. Some Problems on my 2001 European S6
  48. '07 A6 4.2 Engine Issue
  49. How long has Audi been using this engine?
  50. Sound clips of A8 4.2 with rear muffler removed and straight pipe.
  51. How is the reliability on the 4.2 V8 compared to audi's reliable V6's
  52. 1990 Audi V8
  53. 4.2 heads... nobody wants them?
  54. 5v ?
  55. PCV valve freeze up
  56. Gasoline
  57. 1992 4.2 AHB strange sounds
  58. Does the 2005 A6 4.2L have Timing belt or chain?
  59. 4.2 Break In
  60. Is somebody knows something for Motodyne, Robert Hackstetter?
  61. anyone know where exactly the oil pan is on the engine?
  62. im from over @ the 12v forum...what kind of power is the fastest car on here making? just curious
  63. BHF into V8Q race car - Looking for S4V8 info
  64. a8 vs s8 4.2l difference
  65. Need help with D2 project Car
  66. Hey guys, new to the board
  67. Top engine issues to look for when buying 2002 S6?
  68. A6 V8 and B6 S4 V8 - Knock Sensor Question
  69. CAT issues on 2000 A6 4.2
  70. No power
  71. APR Motorsport Vacation Raffle Today!
  72. v8 swap need the speedometer?
  73. ECU Part Numbers Desparately Needed
  74. APR announces 2007 Holiday sale and Raffle!
  75. 4 valve or 5 valve per cylinder
  76. upgrade camshafts for 4.2 v8 (5v engines) , also RS6...
  77. 4.2L v8 oil consumption
  78. 2003 A6 4.2L AWN Timing Belt Change
  79. 4.2 V8 Longevity?
  80. How was Audi able to get more power for the S4 rather than the A6 & A8?
  81. This looks like a nice place.... I should make myself home.. but will they welcome early 4.2l's?
  82. 4.2 bi turbo?
  83. 4.2 superchargers
  84. 4.2 s4 to 4.2 rs4?
  85. V8 ART vs AWN engine code differences?
  86. low rpm engine vibration
  87. 4.2 spun bearing at 60k
  88. APR and Jim Ellis Audi present Petit LeMans Customer Appreciation Weekend
  89. My Audi S4 is dead! Please Help!
  90. When to change TB on 200 A6 4.2 My mechanic says 105K miles???
  91. V8?
  92. oil temp goes to high a6 4.2 2000 100k miles
  93. Temp gauge 100-110
  94. I have $50,000 to spend on an engine and transmission, going into a b5 a4 what do i do?
  95. A8 Manual Conversion
  96. Is the Audi 4.2L the same block as the Porsche 4.5L? What are the differences?
  97. intake plenum change over valvestuck
  98. engine trouble
  99. power steering problem
  100. I checked the FA, and am a bit cornfused about the correct ol filter for my 2000 my 4.2
  101. Timming belt for allroad 4.2, does anybody know if the timming belt
  102. New engine break-in?
  103. b6 s4 tranmission issues
  104. which s4 should i get? an 02 or an 06?
  105. RS6 Engine vs A6 V8 Engine - Manual Conversion
  106. 2001 4.2 AWN - vag engine fault codes (how to diagnose)
  107. Anyone lived or heard of living with Long term Oil Consumption??
  108. B6 S4 - Been sitting for 3+ weeks in garage - any special precautions before start-up?
  109. 4.2 V8 Engine noise at start up
  110. help! 4.2 really hot, physically but gauges ok
  111. how to get the rs4's engine in a s5?
  112. Blue smoke from left exhaust on restart when cold - B6 S4
  113. Thinking of buying an A6, 4.2., are there transmission problems???
  114. Need to know where can I get a Oil Cooler Kit
  115. Need help!!!
  116. Does the computer need to be reset with a spark plug change?
  117. S4 V8 - changing spark plugs help needed
  118. To chip or not to chip?!?
  119. HELP! One exhaust tip is very black with carbon, the other pretty clean
  120. 2001 4.2 Oxygen Sensors
  121. S4 B6 4.2 V8 engine noise when hot
  122. Throttle Hesitation
  123. Good Engine parts supplier for 2000 4.2 V8
  124. recomendations
  125. [x-post] what chips are out there for the D1 4.2 liter (ABH) engine?
  126. 4.2 CAI?
  127. Parts to rebult a 2000 A6 4.2 Engine??
  128. 5 valve
  129. differance between b7 s4 and rs4 4.2
  130. oil filter location S4 4.2 V8
  131. Valve-cover gasket oil leak @ 25k--->
  132. 16826 EVAP Emission Control Sys: small Leak
  133. Can anyone help a newbie?
  134. V8 in A6
  135. Transmission Fluid Leak
  136. SELIING 1998 AUDI A8 4.2 ENGINE COMPLETE.
  137. 19" sevas Staggered Fitment
  138. Coolant leak, not from water pump !!
  139. De-restriction Again...
  140. Twilight Zone nightmare
  141. S8 with slipping reverse?
  142. New Member in Need of Help in NY
  143. Thanks Re Rings and Oil Consumption on 00 with 72K. Update & Big Question
  144. Rings Gone on 72,000 mile 4.2 A6 HELP
  145. S4 4.2 versus S5 4.2 FSI - supercharging question.....
  146. Phisherman Fakes the Funk with Bogus Email Scams
  147. O2 Sensors
  148. Oil Filter Location
  149. Chicago New Audi Owner A6 w/4.2 V8 (2001) Questions . . .
  150. oil leak
  151. TSB RVU Engine Control Module Update (I3)
  152. Chip / Software upgrade recommendation for this V8?
  153. brief tapping at startup
  154. 1st bad intake, 2nd bad ecu, 3rd bad left head---WTF
  155. 4.2L With Manual Transmission
  156. A8 Injector fail has blown Engine Computer?
  157. Are A8's flex fuel ready?
  158. Need an information
  159. Q7 4.2 FSI Engine - Interference?
  160. Headlight Plastic Cover
  161. 2000 A6 4.2 Valve Guide Seal Problem per my Mechanic & Extended Warranty
  162. Oil Leak more info after getting under the car in 15 degree weather last night
  163. My car wants to keep going faster! Any ideas???
  164. Oil Leak Help!!
  165. RS4 4.2 FSI issues
  166. 1990 quattro v8
  167. When is it time to do a fuel injector service on the 4.2?
  168. Coolant temp Sensor 4.2 engine
  169. ECU
  170. 11.3 Quarts?
  171. c5 4.2 manual question. can i do it?
  172. heater fan whining noise
  173. AMD Tech chip for RS4
  174. Performance improvements 2004 S4
  175. 4.2 cylinder head problems.
  176. Best 'performance' spark plugs for 4.2 S6?
  177. 4.2 Rebuild?! Engine loosing water. Pointers of traps appreciated!
  178. Picking up a A6 4.2 - Any common issues I should address?
  179. Dual in dual out muffler ?
  180. Perfornance Chip Choices for B6 S4
  181. APR Holiday Sale and Stage 3+ Giveaway!
  182. need 4 speed
  183. Supercharger for the new V8............
  184. Engine upgrades...where to start??
  185. compression figures for S6 Avant
  186. Thermostat replacement
  187. AWE Tuning NON RESONATED CAT BACK vs. Resonated Cat Back
  188. 4.2 Tiptrpnic Milltech Downpipes
  189. 4.2 reliability/repairs
  190. dead battery
  191. floor mats, wiper blades, other accessories
  192. Anyone installed a Miltech exhaust on the 4.2?
  193. V8Q - no acceleration poor top speed
  194. Engine Differences
  195. No goin back...
  196. '02 A8L 4.2 getting warmer and warmer...
  197. Random Misfire Under Load
  198. I thought you guys might like to see my VAST performance built A6 with S8 motor 6speed
  199. S6 Avant valve train noise
  200. Do they make a chip for the Q7 4.2 yet? If so, what do i get from it?
  201. B6 S4 Intakes...which one
  202. Dual Stage Manifold - Passenger side is binding - Broken Linkage
  203. 4.2 V8 Chip?
  204. New Audi Parts!!!
  205. '97 A8 Transmission Nightmare
  206. Does anyone know the part# for 2005.5-S4 Coil-packs???
  207. RS4 V8 REAL CRANK HP FIGURES
  208. 4.2 into 91
  209. Anyone know if I can use a vag-com to see if the intake manifold is
  210. Speedware puts MTM s/c on us s4
  211. Has anyone had high oil consumption?
  212. Opinions wanted: What upgrade did the most for the least $$$?
  213. Converting 4.2 V8 to RS6 style bi-turbo is it possible???.....
  214. which transmission?
  215. Looking 4 Supercharger
  216. Aftermarket Modifications - shortening life of engine?
  217. Timing Issues. 97 A8. Marks all aligned, camshaft position sensor error, p1392, followed Bentley...
  218. is my 2002 S6 throttle by wire?
  219. P&P and 5 angle valve job
  220. Spark plug wires - how to remove them without damage?
  221. New Water Pump Leaking?
  222. 2001 4.2 Oil Filter/Mobil 1 Extended mileage Oil Reviews
  223. Audi Expo 2006 - Come be a part of history again!
  224. Vibrating V8
  225. Timing belt change
  226. A8L / 4.2 Liter Ping / Predetonation
  227. 1993 V8 Quattro Service Manual
  228. HELP! Did I buy a lemon? 4.2 Misfire
  229. Audi Expo 2006 - It's coming!!!!
  230. Engine surge/stumble A8Q 4.2
  231. I'm dissapointed w/my 2005.5 V8 engine, what can I do to improve?
  232. New B7 S4 -> Anything I should know about the engine?
  233. Torque HP and Weight equation question
  234. H&R Coilovers systems sucks in new jersey
  235. RS6 turbo motor available!
  236. Just bought a 2001 4.2, couple questions
  237. total noob question....
  238. e85 fuel
  239. PES Supercharger for A6 4.2 release date pushed back a little
  240. Too lean code
  241. audi v8 swap
  242. Got a problem!
  243. Some figures required
  244. Anyone want to sell their RS6 Exhaust???
  245. Centrifugal Supercharger question
  246. To convert 2001 A6's 4.2L engine to S8's specs, I need...
  247. Will the s4 V8 and trans, from the b6/7 fit into a b5 A4
  248. CEL for 2ndary air too low? I've had 8!
  249. Memory power to ECM getting lost PLEASE HELP
  250. Are the crank and pistons forged in B7 S4 4.2? How much HP can the stock block handle?
