View Full Version : Telematics Discussion
- EUR RNS-E MMI to work with new US map DVD
- Audi Navigation system and MMI -- how good is it?
- Can't seem to check voicemail over Bluetooth connection w/MMI. What am I doing wrong?
- upgraded to symph II, in my '00 a6
- 8e1 862 407 A?
- RNS-E With backup camera
- BB storm update: pairs PERFECTLY with 2009 S5, including PB transfer
- Problem updating RNS-E to 0260 firmware
- iphone and OEM BT and having that audible screech?
- 04 A6 going BlueTooth - what phones are you all using?
- Converting Analog OnStar to Work in Digital??? 2004 A6 WTF??
- Any idea why MMI says "Replace" instead of "Answer" for incoming phone calls, when I'm not on phone?
- MMI problem: BT phonebook works, but "Import" and Directory options are grayed out for me.
- 2003 A4 V60 Cradle and Bluetooth Adapter for sale on eBay
- Anyone have the new Verizon Blackberry Storm? general comments, and how does it
- Asked similar ? before, but still confused:Bluetooth problems with 2009 S5- please help!!
- RNS-E Bluetooth and iPod integration for 2001 S8 (USA)
- ADR V1 install and some RNS-E info
- Converting Audi telematics into speaker phone
- does anyone know where to get those chrome- like buttons for the RNS-E?
- RNS-E - US/EU price and B6 Avant wire questions
- Another Q - is there any way to tell if my RNS-E unit is BOSE enabled?
- Newly installed RNS-E. The vehicle position on the map lags slightly behind
- Anyone ever hear of or see a HRS-GT5 to FAKRA adapter?
- Blackberry Curve GPS (telenav) Synch to Audi Bluetooth
- Is the Navplus site forum down or what?
- Just installed RNS-E. Having issues as follows:
- just installed rns-e
- Bought RNS-E from NAVParts and forgot my code
- Need some help with installation of extension cable for GPS sharkfin antenna to RNS-E...
- Difficulty with onstar to bluetooth swap in 2004 S4
- Help- call waiting not working properly
- HELP, xpost from navplus forum, RNS-E seeing zero sats, worked fine for 10 days, but no longer...
- Can I retrofit nav into 09 A3?
- PSA: if you need a phone that can survive a two story drop, Motorola KRZR...
- Getting a new Blackberry Curve (8330)...what kind of BT performance can I expect for 06 RNS-E?
- Samsung u706 and Bluetooth
- i-Phone 3G and MMI v. 2740
- about to have RNS-E replaced under warranty on 05 ar, should I try to get 07 B7 A4 unit...
- Is there any way to unlock an RNS-E without having the security code PIN or vehicle VIN?
- Trade Sirius receiver for XM receiver
- cleaning rns-e
- iphone interface
- Can the OEM BT unit be programmed to automatically close the sunroof when a call connects?
- Which Nokia to be 100% with Audi Q7 MMI??
- I need a single to dual antenna adaptor for OEM satellite radio.
- Best aftermarket bluetooth for iPhone 3G?
- Is there a nice RNS-E FAQ or wiki somewhere?
- Bluetooth Install
- Just bought a Parrot CK3100 Black Edition, but the body is grey and the buttons are black. Is this
- iphone bluetooth in 2006 s4?
- fyi: verizon treo 755p 1.08 update kills bluetooth
- If I wanted to add a dvd player to my RNS-E where would be a good place to look for
- where can i get the latest software and nav disc for the rnse?
- Euro to US nav disc troubles....
- how big of an SD card can the RNS-E read?
- FAKRA to GT5-1S gps antenna cable
- Has anyone retrofitted the Tire pressure monitoring kit from Kufatec in their B6?
- RNS-E
- Read this if you are using Samsung phones with Bluetooth (2006 models)
- New Motorola Phone combatabity Bluetooth BMW /Puck
- 2005 A8 + 2008 NAV Disc = Disaster?
- 2004 OnStar and Motorola Setup
- GPS disabled after BT install
- pin removal tips
- programming errors on nav DVDs released after 12/07
- Dension GW500 and iPhone
- Phatnoise Phatbox 20gig Media Player in classifieds.
- Are the TEL inputs on Symph I line-level?
- 2008/2009 US RNS-E DVD disables TV input
- 97 Audi A4 has no AM radio reception... HELP!
- Source for RNS-E for '08 A3?
- Broken gear in MMI retraction unit, A8 2004
- Noodles
- Parrot MK6100 & iPhone
- VSS location and wire color for my B7, yes, I searched
- Hard wire Install of V1 Detector-Chicago area
- Still can't do bluetooth in my 2004 A8L
- What is this connector, and where can I find the pinouts?
- curious post-MMI update anomoly yesterday with directory
- Im looking for a V60 Cradle to suit my 2004 A8L
- 2004 A8 voice command module language change
- telematics stuck on red
- Wife got an 08 TT w/ Nav; can I burn a copy of her DVD to update my 06 A4?
- Please help me locate a V710 cradle....
- Hands Free Phone
- I updated the SW to 0150
- Any C5 RNS-E units for sale?
- Samsung Gleam and Bluetooth
- Replacement Antenna
- AMI Question
- 2000 A6 Symphony radio compatibility
- Just activated Bluetooth...
- Just FYI, Phone List recently updated at AUDIUSA
- getting a RNS-E into my car, what do i need and where can i find it?
- Replacing battery in Audi A4 (B6)
- Does anyone have that mp3 card edit program for the RNS-E?
- Has anyone put an RNS-E into a car w/ factory BT and iPod?
- 2007 S4 bluetooth compatible phones....???
- Learned a new BT trick...
- Hmm. RNS-E problem
- Can the OEM BT module be configured to format phone numbers better?
- Anyone know if you can update the software on the rns-d?
- RNS-E: whats needed to watch DVDs and how much is the part required?
- Lemme guess - there aren't GOING to be any more map updates for RNS-D?
- iPhone question
- Question about OE C5 S6 Nav (Yes, I STF)
- Does Audi 2007 S4 have prewiring for nav install?
- 2007 or 2008 Nav DVD
- iPhone w/1.1.2 and Parrot CK3000 not connecting
- Does anybody get 3D map with MMI in the US yet?
- Control Knob malfunction
- Navi+ problem
- Which is the best Ipod connection for Navi plus?? CD Version
- Does any one know where I can get the unlock code for Navi Plus??
- BT Retrofit - Dialer not working
- Paging TeddyBgame! TeddyB are you out there?
- I was on a major hwy, yet Nav showed "off road." Re-starting did nothing, then
- upgrading nav disc
- Parrot Bluetooth with steering wheel control
- What goes into this port?
- help
- Laser Jammers
- Where have people installed their BT controllers (aftermarket) I'm looking for stealth...
- RNS-E fuse location
- If I have an A3 w/ Bluetooth but no Nav, will the BT unit still work if I add an RNS-E?
- Questions about different BT kits
- Telephone is not Activated
- What do I need to get I-Phone to work with MMI on a Q7? No Bluetooth....:-(
- AMI retrofit available, dealer confirmed it today
- Sirius radio question
- What do I need to get an auxillary video feed to display on 2007 OEM RNS-E screen.....
- Where can i get a Navi-cd Adaptor for 02A4????????
- which Nav system do I need for an 04 Allroad... and is it plug and play?
- ATT 8525 ROM software upgrade (WM 6) available
- Google's Android
- '06 A4 2.0T Tech package...possible that bluetooth was omitted?
- running cables from the engine bay to the passenger cabin on B7
- firmware update for 07 s4 ???
- After market alarm upgrades
- GPS - After Market Installations
- A6 Bluetooth aftermarket install
- What do I need to do to get my Phonebook to download?
- May be old news...But it's news to me
- Q for those with aftermarket BT kits and OEM head units....
- Any way to get an external video signal to feed onto NAV screen?
- Bluetooth volume
- will either of these work for my car so i can hear xm radio with my j-version rns-e.
- Questions about using a BMW BlueTooth Upgrade Module in an Audi
- APR and Jim Ellis Audi present Petit LeMans Customer Appreciation Weekend
- Does anyone have a CS number for Navteq?
- Bluetooth connection chime?
- Looking for advice from the masters on RNS-E upgrade from D Navi w/TMC
- Blackberry 8800
- will my stock nav controls and dash display work with RNS-E
- I dropped a SD card inside my RNS-E and it wont open.
- S8 and 8525
- Can I use the OEM Nav antenna as an external antenna for a different GPS unit?
- Bluetooth in A8
- Parrot CK-3100 loud noise wired up to RNS-E
- BT volume issues
- Need help...Motorola Bluetooth Install
- I guess I should have posted this in here, xpost regarding GPS Hardwire help
- Does MB V60 work in Audi?
- RNS E Issue-
- Help with Bluetooth Install
- Anybody upgraded their B7 to RNS-E and have a Symphony II+ (not II) they want to part with?
- Double Bluetooth?
- Steering wheel interface with sony ericson bluetooth
- Symphony I Coding and Bluetooth...
- Retro fit bluetooth 2006 A6 3.0 TDI
- Any experience with TellPhone 5000vi?
- What is the difference between US and Euro Bluetooth units?
- Can I put an RSN-E in a 2004 A4 Cabriolet? any tutorials?
- Just bought a 2001 A8L - Nav disks don't read.
- Does anyone have a Parrot CK3200 handsfree bluetooth module running with an RNS-D? Also...
- help!!!
- Has anyone found a way to delete old contacts from OEM Bluetooth?
- Apple Iphone works with RSN-E/Bluettoth
- Question: retro fit an oem cd glovebox changer with RNS-E onto an A4 (B7)
- 2004 A8 NAV update
- Looking for BTDT's on RNS-E, Ipod Ice Link, Blackberry Voice Dial via BT
- BT installers
- has anyone tried motorola t605, for handsfree bt phone and music?
- parrot ck3000 volume issue
- 2008 Navteq DVD available
- telemute help
- Are the Navplus forums down right now?
- Anybody with nextel two-way?
- Symphony I, car came with the phone package. Any way to get my SDA w/ BT connected?
- Bluetooth in an '04 A8
- Delay hearing sound from BT to speakers - CK3000 with BOSE system
- Nav sometimes on't allow me to enter a street number
- NAV not working
- AT&T (Cingular) 8525 ROM upgrade :^)
- AVIC D3 Help... Nightmode won't initiate.
- Which fuse for Parrot ck3100 Install ?
- Help: B6 A-Pillar Reassembly
- Just installed OEM bluetooth
- 6th Grade Question in a Post-Grad Forum: Newb to Nav...?
- Audi V60x needed!!
- Sat Radio w/ Navigation help!
- Parrot CK3100 volume issue with Bose Symphony
- Samsung Blackjack
- Retrofit Bluetooth in RNS-E equipped cars...
- Cingular 8125 and Bluetooth pairing in Audi Q7
- Is there a SDHC Software Upgrade available for the DVD RNS-E??
- Phatbox Battery Drain with RNS-D
- RNS-E telephone help
- Looking for a good stereo shop around San Diego, CA that knows what they're doing
- Wont connect to BT any more
- Installer recommendations in SoCal for OEM BT module for B7? (xpost)
- rns-c versus rns-e
- RNS-E Ground/speaker problem
- Concert I retrofit into C4 question
- Tap, Tap, Tap,....Is this thing on?
- TREO 650 vs. 700
- Don't like OEM phone/nav speaker
- What is the latest software version for MMI?
- how do I convert an A3 A4 2007 nav from europe to USA programming?
- OEM bluetooth kit installed...
- Motorola Car kit installation w/ factory Mic?
- Treo 700wx
- 07 A4 BT with Verizon Motorola RAZR
- Navigation Plus updated firmware
- telematics to bluetooth question..
- problem with nav DVD drive
- C-navi vs. D-navi
- How do I add Bluetooth and MFSW to 2004 A4?
- Does anyone know if the Q7 will ever have a 3D nav aspect. Look at the new A5 pic
- Is there a "Alt. Frequency" radio setting in RNS-E? cuz I can't find that in my unit
- Is anybody able to help me...please
- Would you buy an AMI with your next A3/A4/TT/R8?
- Motorola BT -> Symphony II integration
- OEM BT problem
- Help with Motorala HF850
- Need Help MMI with Samsong I730 Phone
- Question on the operating controls of BNS-d NAV on an '01 Allroad
- Anyone have problems with Parrot repeatedly muting the radio to search for BT device?
- s/d card question
- BT volume question
- What BT phones work the best with the 07 A4's system? pref. nokias
- Radio Symphony II don't wakeup and don't illuminate
- MMI telephony bug after pairing w/ BT phone - MY2005 A8L
- Is 2007 A6 Tech Package possible in 2001 A6 2.7T
- 2007 A4--can it use the OEM XM module
- Help: Radio Mute switch from Aux out jack?
- How do I connect to the car......
- Hi, needs help on pairing Telus mobility Motorola V710 to 07 A3.
- Telematics & phone troubles
