- Help with radio, rear speakers and sub not working
- Transmission linkage problem
- No front blinkers or hazards
- Blinkers not working (1999)
- Rear windows and speakers won't work
- Changing clutch slave cylinder A6 2.7T HELP!!
- Free parts for 2001 A6 2.7
- Driveshaft flange seal won’t budge maybe previous owner glued it in?
- Fuel leak
- alternatives to the junk yard
- front crankcase seal blown out
- Help A6 2012 C7 battery
- Screw in threaded Brake light switch adjustment setting
- Disconnecting SAIP (secondary air injection pump)
- 02 A6 2.7t starting issue
- 2016 electrical issue
- Help ! 2004 A6 Quattro 3.0 internal tank fuel lines
- Electrical connectors
- C5 A6 Quattro Transmission Swap?
- spark plug recommendations?
- AL: Transsmision
- Anyone Recommend Vendors for Audi A6/C5 ?
- turn signals not flashing
- '02 A6/C5 Drivetrain Mount/Bushing Replacement
- random line under car after jumping curb
- NO: A/C freece on low pressure side
- Fuel Line need for A6 C5 VIN in post
- P0023
- Ecm testing?
- 2001 A6 2.7t no ecu communication
- 03 C5 RS6 fuel guage not working low pressure Fuel sender unplugged
- Fuel Tank again!
- Can you clean the A/C evaporator drain from the underside of the car?
- Wire dangling from unknown quick connector
- need harness plug info
- 2004 Audi A6 2.7T bi turbo - Oily residue
- Weird voltage readings
- Was just wondering if anybody could give me a little input how?
- 6 speed swap experience
- Auxiliary water pump missing?
- 2002 S6 Timing Belt Failure: What's Next?
- C5 S6 A/C Blowing hot when car comes to a stop
- P0341 need help!
- 2004 Audi A6 Quattro 2.7l
- High Pitch Squeal on A6 2.7T Stage 3-
- Audi A6 2007 3.2 s line Quattro short
- 2002 A6 4.2 control arms
- S6/4.2 - Cam installation Issue at TDC
- about service time period
- PDC 8Z0919283 on audi 1998 without CAN-BUS
- low oil light
- Audi A6 Repair Manual
- WTB - Front Bumper Cover for 2002 S6
- Easiest way to bypass factory amp/ rear speakers
- Key Selection / Adaption
- A late A6 stage 3 upgrade, is it worth it?
- S6 Camshaft Adjuster/Tensioner Help Needed
- Starting my 2.7T that hasn't been used in 2+ years, recommendations before startup
- A6 Has a Problem Starting, Dealer Hasn't Solved
- From B4 to C7 via C5
- Intermittent AC fan
- Won’t start!!!
- Please someone help! Need part number for clutch hydraulic line
- HVAC blowing hot air on Econ/LO, no codes
- 2001 audi a6 2.8 c5 reuse timing belt?
- Door Lock Problems
- 03 C5 4B0614517R Schematic/Pinout
- Rear springs on quattro
- SWAP? radio
- Water in rear fog light housing
- REPLACED COILS WITH 2.0t STYLE AND CAR BARELY RUNS - HELP
- Rattle noise when doing only Reverse
- Cam Position sensor- stalled while driving- no start
- Engine installed, no crank
- Master Cylinder reservoir screen removal?
- NO: Rear vibration
- DRIVERS DOOR LATCH ASSEMBLY REPLACEMENT
- Cranks strong, but no start. 02 A6 2.7T MT 180K
- PCV/Vacuum Squealing - 4.2 S6
- triple square screw on door latch
- subframe section of service manual
- hard start
- Turn signals blow fuse immediately. Thinking relay at this point....
- Need serious help with P1745 TCU error code
- Need help identifying this connector
- C5/EKX transmission needed
- Map update
- Service in Reno/Sparks
- Fuel feed and return line
- 2004 a6 s line starts then stall
- hard starting
- Camshaft wiring replacement name of part?
- HELP audi a6 c5 2,4 v6 BDV
- Tired of the "delay then surge" when starting from a stop. Any solution?
- Location of ECU in an Audi 2103 A6?
- 00575 and 17090
- '02 C5 2.7 sedan, steel line caliper to hose damage.
- P1545...Advice!
- No crank what am i doing wrong?
- 2004 A6 4.2 C5 shifting issues after engine warms up
- A6 2009 2.8L - can't find power control module
- Where does this connect?
- need emission connection diagram
- HU: No cd changer and not working parking assist
- Pioneer radio
- HELP!! 2.7T Timing Belt...Cam alignment plate moved!
- Help Audi S6 2000 4.2 V8
- instrument cluster
- Trying to find 8-slot fuse box to find fuse for front and rear window
- No wires to #43 ato 5 amp radio fuse
- 2004 A6 rear speaker static popping noise
- 2.7T to 2.8 swap?
- AL: Audi A6 2001 CVT TCM Reprogramming?
- oil around plug threads
- ‘01 A6 2.7t bellhousing bolt removal ??!??
- 2000 A6 Quattro 2.7T Automatic jerking
- SE: New member, old car
- A8 guy slumming on A6 forum
- Torque Converter question '99 C5 engine
- A6 c5 tdi engine swap
- 2004 a6 s line ecu chip tuning?
- A6 C5 2.5 TDI AKE 00562/00667/18043 Fault Codes
- 2001 audi a6 2.8 c5 head engine block
- Potentially Buying C5 RS6...Need Advice
- Apple Carplay Not Working after iOS 15 update?
- Working on my A6 , rim got stuck. Wasn't the first time a vehicle did this wanted 2
- 2002 A6 will not roll at all
- Transmission issue 2018 A6
- Upper radiator hose - 4B3-121-101-J
- Compatible Models
- Oil Cooler Replacement
- Oil spray jet plug
- 2002 A6 C5 2.4 Auto transmission fluid
- Radio code
- A6 purchase?
- Can't get unlock/get into car
- LT: How this fuel pump work?
- 2001 a6 2.7T..resetting the tcu as shown on youtube
- LT: Air intake hose on 2.0 petrol
- Number 29 fuse keeps blowing
- Ecu after swap
- FI: Missing power 2.5 TDI V6
- C5 ignition/starter switch replacement
- 03 Audi A6 3.0l c5
- Radio wiring harnesses
- a6 c5 NOT allroad - rear air suspension.
- BG: a6 2.7 biturbo transmission
- 2003 Audi S6 Avant
- Replacement Front CV Axles
- Used lower grille center
- FI: Rpm jumps during cranking
- New C5 S6 Owner, just wanted to seek a little advice.
- Avant Owners - Do you have broken cargo cover end caps?
- Cluncking and floating and ABS when no slipping
- Blower motor
- 4.2 Oil Pressure light and inconsistent temperature
- BG: audi a6 2.7biturbo question
- NO: Coolant leak Tiptronic?
- A6 C5 2003 light problems
- 3.0 ASN camshaft position sensor
- UK: Audi A6 change Engine problem !!!
- Wierd heater problem
- Audi a6 2.0T or 3.0 supercharged
- dtc 00588 airbag intermittent
- comfort unit and driver's actuator problem
- Brand new Koni Sport shocks for RS6, A6.
- Transmission problems
- Help Audi A6 C5 4B 2.4 Petrol Automatic Gearbox DES 5HP-19 Tiptronic FWD
- Issues with braking
- Need help with the Driver Information Display
- UK: N200 passenger airbag igniter
- ZW: Audi A6 C5 2.8L Quattro transmission range sensor problem
- 2000 A6 4.2 Alignment
- Both 02 sensors?
- A6 C5 odd lock behavior
- I need help figuring a hoses on the back of the intake disconnected
- Audi A6 Climate Control Module
- Red backlight on buttons
- 2000 s6/c5 avant mirror control module location
- ZA: Help needed with audi a6 1999 model
- 2010 Audi A6 Prestige SPEAKER ISSUE
- 2002 A6 Quattro Avanti 3.0 Wagon
- Is replacing radiator coolant hose too difficult ?
- Changing thermostat/ Overheating
- Fog lights?
- Cam Chain Tensioner, How does it work?
- 2001 A6 2.7 rear suspension needs a lift?
- Confusing Airbag On/Off switch position
- Dash Warning Lights
- 1999 Audi A6 - Brake Light Switch
- C5 A6 Avant -- Parts/Project Car
- Help, A6 cranks but won't catch.
- Central locking, power windows, interior lights and sunroof dead
- Climate control not working.
- Coolant dosent hold at all.
- Gifted A6 Avant with Throttle issues?
- 2003 A6 issues and questions
- Sunroof jammed
- 2005 Allroad AC Recharge
- Audi got me feeling mentally prison shanked. Any help?
- Limp mode
- ESP LIGHT ON AUDI A6 4.2 QUATTRO V8 TNG PROBLEM
- Need help finding a Reman Auto Trans for my car
- audi a6 nav update
- Cluster not working (2001 pre facelift)
- TTRS transplant into c4 a6-s6 avant
- Overheated, cold start?
- TH: There is no volatage at Taillight bulbs
- Audi s6 transmission Ecu problems
- 2013 A6 service intervals
- subframe description
- AU: Allroad 02X swap crank sensor issues
- Mysterious misfire on cylinder 5...changed everything
- audi a6 4f 2005
- interior door lock button unlocks instead of locks
- To pull or not to pull engine/tran together?
- 02 Audi A6 Crankshaft out of timing
- TR: A6 c5 1998 2.8v6 Quattro vogtland springs
- Supercharged Audi S6 V10 FOr sale After a year of building engine right
- Head Gasket leak- suggestions needed
- Audi 2.7t clattering
- After replacing the battery, car won’t start. 1998 Audi A6 C5
- Horn does not sound when locking doors or using panic button
- Wiper assembly removal
- PS: main ecm relay location Help
- Audi is back on the road
- 3.0 AVK crank timing marks
- Interior light and ABS issues
- Charlotte NC - Local Audi Club?
- In need of A6/S6 C5 4.2 oil cooler replacement pipe
- Heater hose flange
- Auction Allroad "Runs and Drives" Transmission Issues
- Intermittent failure to start
- KYB or Bilstein
- Coolant seepage and rattle on morning start
- A6 v8 swap
- Water Leak Driver Side
- 2000 A6 2.7T power steering line leak
- -- HELP/ADVICE -- CODES P0171, P0174, P0300, P0301, P0306, P0302, P0305: 2003 A6
- Intake issue - throws codes / Lean and mixture
- Alternator light wire 4.2 v8
- Audi A6 C5 Cold Air problem.
- 2012 Audi A6 Quattro Error Code P275300 ($15k quote for repair??)
- Puddle light & footwell light not working
- Auto head light adjusters
- 2001 A6 2.8 Quattro SAI Pump Hose Problem
- O2 sensor Codes
