- 2002 A6 2.7 Stock boost
- User manuals need
- Ok all you suspension experts....
- Just got 01 4.2 few questions
- Already in classifieds but.....
- The H&R Catalog for your A6, from AWE Tuning, alive and well.
- Cold start issues 4.2L
- Need help with error codes P1196, P1197, and P0134
- Any fix for plastic on sun visor?
- new brakes
- wheel offset question for 99 a6 avant C5
- WANTED: '03 C5 A6 4.2 E-Code Bi-Xenon Headlight Assemblies
- Rear shade mechanism issues
- temp gauge problem
- Audi A6 2.8L C5 Upper and Lower Oil Pan Removal/Gasket Change?
- 02 a6 3.0 fwd auto stumble at 1500-2000rpm
- Jerks as gas pedal is lifted (intermittent)
- Did 605 mod, but thinking of bypass switch
- options for shocks
- Brake Light issue, help?!?!?
- Fan Running
- A/C problems
- Is this right spot for jack?
- Bosch to Hitachi-Worth the effort?
- 2002 S6 Avant P0141 and P0161 HELP !!
- US style flashers, (Constant light)
- 2001 A6 4.2 - Timing chain tensioner cracked and chain jumped
- 2002 A6 4.2 Intake Manifold
- Vibration ..Solved !!
- Just Purchased Audi A6 2001 4.2! Need help with a few things! DVD Install
- HEATER CORE HOSE PROBLEM
- Front Shocks & 11 degree offset
- 98 A6 wont start
- Need ID help
- 2000 Audi A6 4.2 non-port for sale near Chicago
- Rearview mirror question...
- C5 4.2 Timing belt advise
- HELP: Smoking at Startup.
- Xenon headlights questions
- S3 in Nafplion, Greece...six we can't get it in US.
- 1998 A6 avant (c4) 2.8 timing questions
- Is my ECU really dead?
- Master Window Switch Replacement 02' A6
- I need to advise / thoughts!!
- What engine do I have?
- Mileage test
- Pipe/line with crack
- trunk lid supposed to pop up from keyless?
- Door latch question
- 2013 S6 - All Season/Winter Tires
- 2004 A6 3.0 TDi quattro Check Engine Light after long trips
- The annoying issues continue. Now it's the blower motor.
- I forgot what giggle machines turbos can be
- 2001 4.2 trans issue
- i cant find the reverse lights switch on the tranny!!... help please
- 2000 A6 2.7T Smoking at startup
- Please Help!! 95 A6 wont start
- 1999 A6 Q Camshaft Position Sensor
- quick floor mats question
- The joys of used car ownership
- Real world mileage on a 3.0 Avant? I'm getting 14mpg :(
- 2004 quatro rear end chatter??
- Engine pull required for head removal???
- Cam seals DIY - can you ease my confusion?
- Car bottoms out over bumps
- '98 A6 2.8 - MPG readings totally wrong !
- Windshield Wiper Question
- Sunroof detached from glass
- FCP Groton cv joints
- Odd Noise from front end
- Need to sell my s6 rims
- Coolant Catastrophe (Heater hose return, ETC replace, and leak)
- Took car into be Serviced and now nonstop check engine lights & the Brakes went out!
- Take advantage of the Fall Sale on G.I.A.C. Performance Software at AWE Tuning.
- Wheels/Tires
- '98 A6 - Left turn signal acting wierd
- So I'm Buying a 2002 Audi A6 2.7T...
- AC Evaporator Drain Valve-A6
- Steering Angle Sensor
- Transmission malfunctioning-A6
- Wanted: C5 S6 Lower Grille
- 2000 Audi Cluster Screen
- my Audi ///S6 4.2 V8 mufflers removed videos.
- Theils
- My Wit's End...
- Tire matching??
- Fresh newb in town
- How often do you guys change your oil?
- 98 audi a6 won't start, starter won't engage
- Thinking about a C5 A6 2.7T
- Wet passenger footwell - resolved! And kudos to The Village Glassmith!
- Coilovers?
- door trim thingie '01 A6
- New head unit installed, no rear speakers
- Audi ///S6 C5 from Mexico!
- A6 Camber Adjustment?
- pics of my a6 2.7t
- Door Open Indicator Extreme Weirdness
- 1.9 TDI refuses to start
- 2002 Audi a6 2.7t exhaust?
- The Brembo A6 Catalog from AWE Tuning
- Best place to buy an under engine pan?
- New guy here!
- Filter or Cold Air Intake?
- Selling a high mileage 2000 2.7t manual
- 02 A6 2.7T For Sale
- AIR INDUCTION C5
- HELP with 01 audi a6Q 2.7t codes please.
- 2002 2.7T (for toast!)
- 1999 Audi A6 Wont Start..
- Passenger side Rear view mirror dimmed
- front rotors
- Theils
- is it messed up to kind of hope your turbos go?
- Another Audi WTF moment.
- HID help.
- Brake Fluid Won't Flush!
- 03 A6 quattro - P0491
- Coolant temp sensor gone bad
- easy 2000 a6 owners manual question
- Cargo Net
- How to remove improperly installed rear Avant head rest
- ESP question
- bad oil temp sensor
- Could this be Problem pics! pics!
- Injuries suffered when using the A6 stock widowmaker Jack
- Labor Day Special at Detailer's Domain
- Driver's side drain Grommet Needed
- 2002 AUDI A6 QUATTRO
- My hood release in grille is broken...what next?
- looking for oem sport suspension and sell my H&R springs
- So, it seems my 2001 is the sport package
- where to buy sport springs
- 2002 Audi A6 Leaking Coolant
- What things can fry an ECU/ECM?
- Oil temps
- 98 A6 FWD - NO ECU communication with vag. or OTC or OBDII- of course ABS light on
- Outer Tie Rod End Replacement
- Well, it's a done deal. 2001 A6 2.7T 6MT Quattro is mine
- Get your A6/S6 ship for free. Courtesy of AWE Tuning.
- Rear window shade not working
- If anyone is looking to buy an 034 x34 intake or heatshield only, PM me.....
- Cupholders
- '98 2.8 with boiling coolant (old problem)
- Audi A6 2002 3.0L esp on and engine
- RIP Neil Armstrong
- Audi pre-purchase question 4.2 quattro
- 2002 4.2 Overheating. Your opinions please!
- Coolant Leak on A6 2.7T
- Still without a car almost two months later...ecu?
- Hoping someone can help with a few codes/issues.
- rear wheel bearing 4.2
- Spark plug gap for stock 2.7t 2002 APB
- Vad com rental
- 2.8 timing help
- OEM Factory parts buying, low prices, great service.
- Valve Lash
- Spider Hose / Breather Hose / Vent Hose
- 2001 A6 4.2 Cam Chain Noise (Need Help)
- transmission engagment
- 2002 a6 2.7t quattro makes a whining sound
- Disable master window switch for rear windows?
- A6 Headliner Droops
- temperature gauge reading faulty
- camshaft sensor
- 2002 A6 3.0 surge
- module recoding
- "High Engine Temperature" Issues
- LTFTs: B1, 3.0; B2, 7.0. Why?
- VAST out of business?
- Interesting 2.7T stick shift For sale on Classified
- Have 2 Good coin/card trays $40
- vag-com communication
- Xenon headlight issues
- Compass not displaying in rear view mirror
- Cooling problem - help!!! 96 A6
- Haven't posted in quite awhile. Have 2001 2.7T questions.
- Tranny Computer Compatibility??
- Lambda O2 sensor engine location? V8 4.2!
- Avant flex pipe repair
- 4.2 Xenon Headlights
- ELECTRICAL ISSUE
- Bringing back to life
- 96 A6 Quattro Sunroof
- new to the audi
- Wiper Problems
- exterior rocker trim removal
- Rattling noise on the outside of the car when drivng
- 04 A6 Q 3.0L: How to jumper A/C Pressure Sensor (G65)?
- Asking for some help, I know it's rare.....
- Audi 2001 A6 2.7t broken vacuum tee in emissions circuit
- St Coilover / S6 Avant update
- Tape deck problems
- Programming Lock & Alarm
- PAG oil quantity
- adjustable oem shocks?
- ST Coilovers in 2002 S6 and Many Thanks
- O2 fault code HELP!!!!!
- A 'what is this part' thread.
- Anyone in Denver have a VAG-COM for a 99 A6 Avant???
- TWO WEEKS until S-FEST West! Register now to ensure your spot & door prize!
- 2003 S6 Avant
- Jumped the car, radio died
- Need backup key...little help?
- :: ECS Tuning :: C5 A6/S6/Allroad Rear Differential Service Kits!!
- front end vibrations/harsh ride
- Need help fellas,whats this sound? Video
- 2001 C5 2.7t Random Loss of power when under pressure. Here is the Vagcom Codes
- Better Gas Milage with APR Chip?
- Ross-Vag K 1 ground fault
- Strange issue with hid levelers. And a couple other things.
- Nav DVD won't eject ; sort of...
- Received my tranny but what do you know! FUL instead of FBD
- Low Oil Pressure Light
- Two coil packs out in short order?
- massive ac leak...PAG oil under compressor
- What to check with these O2 faults (2000 A6 2.7T)
- Possible Module or electrical trouble
- Leaking Oil. Need Info
- Damaged water pump
- Serpentine tensioner install
- Turning ignition key, dash lights come on, otherwise nothing
- My little trash talker goes cruising with me.
- generic immo reader
- Did I blow my rear caliper?
- pressure tested turbos and hoses....
- Sorry, another question. Can you tell I'm new?
- Quick ABS question
- :: ECS Tuning :: 2.7T Timing Belt Kits!!
- what paint code am I?
- ABS is bad, but no wheel sensor?
- Valve Cover recommendations please....
- 2003 Audi A6 misfire.
- Oil Consumption Question
- Reputable audi tuner/mechanic Chicago/Milwaukee area?
- HID Kit for audi a6
- New Skid Plate Help
- would 255/55-18 fit in my 00 2.8ATQ?
- Ross or Vag for rent in Denver? anyone have???
- 2000 Audi A6 TCM transmission Question????
- trim/paint question
- purchasing control arms...sources?
- Door lights, foot lights + air in fuel system. 2.5tdi 132kw quatro.
- Having trouble cleaning your wheels? Not anymore - Wheel Woolies are here
- 1999 2.8l 30V - electric cooling fan running
- Car completely disabled...suggestions
- second day of driving - stranded at a resturant
- Starting problems. Idle Issues.
- Opinions on Diverter Valves
- Any exp with VAS 5054A
