- Picking up new Avant in a day or so. Advice needed...
- Anyone know a phone number for Tantrumwerks?
- Looking for RS6
- Bigger Family, Bigger Car Needed...Thoughts?
- A6 4.2 or B6 S4?
- will a cargo cover from a '99 avant fit an 02/03 avant/S6?
- longevity of 2.7 engine
- Replacing central locking module?
- Hello from Hong Kong!
- TIP is broken. Does this mean my scratched silver TIP plate gets replaced?
- Autobahn details on the History channel now!
- Do Japanese make better light bulbs?
- Can I "activate" this feature?
- My 2001 Audi has a clicking noise coming from the steering column
- 2004 A6 2.7T vibration question
- Driver door lock stopped working
- Body Shops in OC
- to extended warranty, or not to extended warranty...
- Forming--TEAM RONAL--Silverstate Classic--May 04
- Quattro/ESP question
- POLL: Which cat-back exhaust are you running?
- BG Quick Clean...anyone ever use this
- Manity - YGM on Nav+ units.
- Window tint, double window seal & such
- FYI: First Warrantech claim approved. $1500 for tensioner seals and rear diff seals...
- My Audi 4.2
- Is my clutch about to fall out of my car?? ...
- I have heard that new NAV cd's were going to be avail 1/2004.
- Does anybody know what does AoA consider max spec for road force tire balancing?
- Question for all regarding 4 way stops...
- Front end work required, please read and reply if you can help-->
- VAG-COM Recoding the locks and Radio
- Audi sees output rising to a million vehicles Reuters / February 04, 2004
- Prestige or Prestidigitation Update from 1/15/04
- Hunter 9700 roadforce
- Advantage A6 has over A4 or A8. Thoughts, please.
- Headlights are not adjusting
- Clutch pedal "clicks" on release...
- Stolen A6- They found it in a parking lot, damaged(long)
- i am thoroughly convinced that Exxon gas gives you the best mileage
- More details on new A6 - sorry if this is a repost
- is it just me or are there a lot of B5'ers joining our forum here? nothing wrong , but looking at
- sorry, forgot to add to my previous post.. but the owner of the body shop that i dropped my car off
- to anyone with ADR M-Classic wheels, I need your assistance
- Best/cheapest source for Bentley service manual (paper)?
- My Wheel Choices //// Pick One
- Long post about a road rage incident that happened to me.
- Oil Leak Update >
- Rattling noise on 4.2, at idle when cold or at very low speed when cold (more) ...
- OT I need a little help with this loss of value thing if you have a accident. I did a search but ...
- Made a quick trip to Boston today (Yeah Pats!) and on the way
- Retire A6 2.7T Does this mean the car isn't worth much in the future?
- Best ECU Chipt Tuner?
- 3500 miles in S6
- Halle-freakin-lujah!
- Trade-In Value for '01 A6 2.7Tq 6-spd?
- Audi S-line HP/torque specs from manual
- wheels gurus: I have a 00 4.2, what do I need to do to fit ET45 18 x 8 wheels w/ 235/40R18 tires?
- Reckless Driving Charge: Court appearance and outcome.
- How much time do you guys spend on AudiWorld each day??
- Headlights? '03 Xenon, when turning lights on they used to point toward ground and
- 10mm or 15mm spacers with S4 18" Avus wheels..
- Audi of Huntingdon Valley, PA
- You dudes should enjoy this: January '04 BMW Sales down 18-21%....
- How much do dealers charge for the 2004 Nav DVD Disc for the West Coast region?
- CD ERR Message: What sort of "coding" must be done using VAG-COM to
- dropped my car off at the shop today...i had to drive it
- A6 4.2l problem, I need your input
- New wheels needed.
- Advice on noisy brakes
- A question about helmets...
- Qcrazy this is what he said... mine is early 1999, or so germanautoparts.com said
- Looking for a Bose Sub for my 1998 A6 concert.
- are the head lights on a 1999 A6 an H1 mount or H3 mount?
- Repost: Achtuning 19" Wheel/Tire package Group Buy!!
- is the part # of the N75 valve on the s-line car the same as on the other 2.7t's?
- Random thought: Audi should have offered the 2.7T in the current A4.
- 2004 2.7t engine?
- Do I have the Wrong Springs?
- How long do the OE suspensions last on A6's
- ok ok, stupid question. but i have been thinking about this for a few days
- Does anyone know what causes a car not to hold its idle?
- is $50 a good price for a blank key fob off ebay??
- is this guy on crack? $37500 for a 35,000 mile 2.7?????
- Anyone know what the bolt pattern and offset for the 2000 A6 2.7T is.
- Impromptu NorCal Audi Club lunch on Thursday @ 11:30 at St. Johns Bar & Grill in Sunnyvale CA
- Will I need to lower my A6 4.2 ?
- What's the best trunk/cargo liner for an avant?
- Does the Phatbox have RCA out in the back of the unit........
- Will VWAG have the Radio Security Code??
- Oil Consumption - 2000 A6 4.2
- OK, I'm now officially pissed.
- pushing 4 years on OE battery. Can it make it through the summer?
- Carolina sucks!
- Finally got my dream car! 2002 A6 4.2! Yeah Baby!
- Any lister in the DFW area that can help w/ a pre-purchase walk around ?
- Light bulb question.. What light bulb have you found that closely matches a Xenon
- how do i know if this key will work for my car??here is the FCC number they give
- Newbie...Heavy exhaust smell
- Dealer found different car sans 17 inchers...
- RS6 conversion availability
- WooHoo - All of the Nav+ units are here. Time to take a pic and test tonight :)
- Impressions of my 24 hrs. with a Phaeton W12 (very long!).
- Why I dont want 17"'ers
- Upcomming Mods....
- Deal is done! New Avant! But ONE more question...
- Audi A6 mentioned on Fresh Air with Terry Gross today as an object of obsession....
- BOSE SYS.........
- dealer just called me that i need rear brake pad after 30,000miles since i changed last time
- Will the RS6 type steering wheel retrofit on an S6
- What I did this weekend
- Yehhhhhhhhh i did it
- sorry for all the newbie questions, BUT ESP....
- The source of my oil leaks
- Just gave my notice at work! I am free to bike race!
- coilover problems
- I leave for Hong Kong in 4 hours! Special thanks to CARGASM2.7 for housing my 4.2!
- Since there is no RS6 Avant available in N. Amer, are any S6 or avant owners....
- 8 CD Changer (Panasonic) on Concert Stereo
- Concert stereo in German or some other language
- A6 Avant boot release broken
- Stock A6 4.2 sport wheel weigh?
- question for the experts
- Reminder/Warning about Audi "Monster Winter Mats"
- RADIO "SAFE" appears in window
- Need suggestions on replacing my front plate holder with something nicer...
- New to the world of Turbos- want to make mine last...
- Do they make OEM 18inch RS6 5 spoked wheels?
- telephone interface in A6/S6
- The new Dahlbäck site...
- engine noise
- Heading to Big Bear Lake, CA tomorrow morning......
- anyone wanna trade? i have the oem rs6 taillights, I am looking for someone to trade
- Congrats to the Patriots!!!
- The new plates...
- So dirty...
- Victory by Design (w/ A6 content)
- My boys win the superbowl!
- Day 1-2 with APR's new allroad chip 2.7T --S+R ECU
- When do you folks think that Lexus/Toyota will get the german feel down?
- H-Sport Problems
- Tiny leak in vale cover gasket - should I replace now?
- Can't remove fog light housing - Any tips?
- ABS seems poor on ice/snow
- Is there a non-Audi brand power steering fluid that is OK?
- roof rack....
- New 2005 A6 Spotted? Here at noon I just saw, what I ...
- Oil Leak all of a sudden>>
- help! advice needed - A6 Avant
- ok...your suggestion needed, BEST 18" wheels for A6?
- AMT4SWA: RS 6 stock in Scottsdale...
- They stole my A6 in New Jersey...
- What are primary model year differences between 00, 01 and 01 A6 4.2??
- cam chain adjusters
- Would modifying the suspension void the insurance?
- OK, all this chip talk is getting me hotNbothered. I did a search 4 APR and ...........
- Freshened up the suspension bits at 38,000 miles. Through the H Sport front back on with new strut
- ABS + ESP Light + BRAKE Light(beeping) Came on..
- New Winter Setup...Merry Christmas to me...(I love my Winter tires!!!)
- Gotta ask...What is the best price for 00 4.2?
- vibrations
- Last mod, before 2.7Twins bet, finally installed
- some a/v pics .................
- 2002 A6 3.0
- $2,000 separates me from a new audi avant...
- Help! Audio Install Issue (XM/CD Changer)
- fixed my window clips....cool story
- What causes a headlight to intermittently work...and not work???
- 01 A6 Avant 16804 Error
- And now it's time for EVERYBODY'S favorite game show..."Would You Buy This Car?"
- cable for phatbox in avant
- Lowered car + Miltek Exhaust = Bumps and Scrapes on ice
- Audi Dis-Loyalty Advantage (Part II) (long)
- How to get into the memory seat buttons..2001 A6
- Tempting S4 on Ebay, Buy it now $52,000
- engine change from S4 2.7T
- WooHoo - Almost half of the Nav+ units are here :)
- I have a question for all of you A6 folks
- Any recommendations for Smog Cert. facility in Long Beach California?
- I'm vain, I'm vain. Just got new personalized plates.
- 2.7T smokin' real bad
- Rear foglight question.....
- Slightly OT, but discussed frequently here: More Bangle news...
- What's up with faulty O2 sensors...?
- Paging LMGotts. You were my mentor at taking pictures. Some of my pics went in a magazine!!!
- Need Body I.D. Codes for Sport Package on A6 4.2
- reliability of A6 1.8T
- Help! I smell fuel...
- Used symphony avail?
- Picking up Phaeton W12 tomorrow for 24 hour test drive.
- 5 RS 6s now at my dealer...damn, I wish I could swing it...
- OK..so now what do I do. Replace w/'01 or '02 bumper?
- 2.7 exhaust
- just a quick question
- Off Topic but I had some good Chinese food today
- Transmission fluid/filter change made my drive train quieter!...
- where can i find the sentence "Lifetime fluid, never needs changing" on Audi website??
- Creaking seat
- Coin drawer for 2004 A6
- OK, so I've had the car repaired twice by the dealer for a leaking Valve cover gasket-->
- interesting reading from the S4 guys
- 2.7T Question
- All you V8's....here's a cool mod - twin turbo!
- 97 Quattro wagon
- Local VW dealer has Phaeton W12 priced at $88,500
- Spark Plug Questions...
- HELP!!! Choosing between two A6 2.7ts...
- Post from RS6 board, I saw the last bidder names was Finman??? Could it be our Finman?
- is it hard to change the door extendion to s6 ones?
- has anyone heard of an A6 accelerating without your foot on the gas petal?
- Bought a 2000 A6 Avant today! Am I in the club now?
- tranny fluid change...no filter change!!
- 2000 A6 2.8 maintainance schedule
- Are brakes more likely to warp or fail when it is really cold.
- speed limiter removal?
- Anyone know of a pre-purchase auto inspector in NC area?
- Tire rotation
- When to clean fuel injectors
- i want the wide fenders for my 2.7t....
- 2000 A6 4.2 60K service
- Anyone go lemon law/buyback with AoA that was leasing their Audi as opposed to owning car outright?
- Tire recommendations...
- instrument cluster question?
- Problem with the Auto-Lock and Keys not Working
- Great Service experience
- 2004 A6 2.7T (manual) APR Stage1 Chip by pass pipe problem
- Is it possible, and if so, how hard would it be to retrofit NAV+ into an A6 without the factory Nav?
- probably a re: but yea, new a6
- RearEnded Again...2nd time in 2 years
- Replacement of Rear Side Window, how much?
- So tonight I shall be doing the infamous Finman tape job in preparation for going to the track:)
- 2005 A6 Pictures.....
- I received my division assignment today. Looks like I'll be on the Newark side
- Will achtuning's 19x8" RS4 wheels with ET of 35 fit the a6
- About to buy new...Need advice
- Norway today
- Nobody has commented on this yet. Does the BMW experience translate and
- It can be done!
- So how'd I make out at the service dept today?
- Say it ain't so, Joe.
- if you have a 2.7T non sport with 18" RS4 wheels w/o suspension mods...could you post a picture
- Cost to Paint a Vehicle-DuPont Business Review Series
- Why I am choosing not to buy an RS6...
- Dash display: Screen fades
- Has anyone tried the Autobahn Gas Additive? Happy with it? Other suggestions? TKX
- Anyone have any input on the Stasis Rotors?
- I thought we were getting a new A6 graphic up top?
- 2000 A6 4.2, what would you pay?
- Will 16" A6 wheels fit on 00 4.2?
- A small observation (almost not worth posting) applies to the old 5 series as well.
