- A6 allroad air suspension issues
- S6 C5 exhaust on an A6 4.2 2001 model
- mystery
- Getting into a locked trunk?
- Intake Manifold pipe/hose - where does this go?
- Need y'alls expetiese please
- Dash Lights not working
- A6 Avant 4.2 with self adjusting rear suspension - lowering?
- Front axle codes...
- 1999 A6 2.8 Heater Hose Replacement Resources
- Cooling fan always on with engine
- how to change the servo pump
- V6 serpentine belt tensioner
- Replaced engine and transmission now no start
- 2002 a6 c5 avant
- heating element
- ESP; Fault codes 18265 and 01119
- Mechanic local to Spokane WA area??
- audi 2002 allroad 2.7t
- Installing a new waterpump, should I swap in an aluminum thermostat housing?
- 2003 Audi S6..... Biturbo install?
- 2.8 cooling system springs a massive leak
- Battery Replacement
- Tire question for 2000 Audi A6
- need service manual input
- A. Tiptronic 6 speed shift problems after new fluid change .
- Negative temps causing a no start
- Indicators not flashing
- Driver and passenger door issue
- Constant chime noise
- Stereo Upgrade
- Check engine light, again.
- Audi A6 X Reg 1.8T
- car is limp mode
- 2004 Audi A6 2.7T - Aux Water Pump Replacement
- 2001 A6 4.2L codes + CAT, EVAP, AIR, O2S...
- Steering Intermediate shaft broken at only 30k miles
- 05 A6 tailgate courtesy light
- Crank lock pin write up for the 3.0L eninge
- Windows and interior lights not working
- Wining Noise coming from engine 2000 A6 2.7T
- headlight controller
- Outside air temperature unit location?
- Cold caused injector leaks?
- Headliner Removal
- Audi A6 Avant auto to manual swap
- 2001 audi a6 2.8 quattro auto to manual swap
- 1999 Audi A6 Quattro Base with 2.8 l Engine Oiler Cooler Replacement
- Can someone tell me what this is?
- Heater Core Fin = 2000 A6 2.8
- DOing my timing belt service I have a question about the cams
- Manual gearbox swap donor car
- The dreaded sunroof repair
- Seat Wiring Diagram
- Happy Holidays
- Webasto aux heater controler pin outs
- Timing belt change 2.4 A6 C5 2002 BDV
- What spark plugs do you recommend to use?
- Crank seal i think
- Point of clarification
- Audi A6 water in rear passenger footwell
- where is the top dead center on audi v6 2.8 2001
- Okay boys n girls...got a weird one, cars been up n down 4 months now...Input Plz
- Door not closing tight
- 2012 A6 3.0t prestige help
- resetting caliper piston
- Weird problem with rear wiper motor, pls help
- please help - strange noise coming from both front wheel wells at idle
- what platform?
- Trunk triggers alarm now car won’t turn over?
- ECU Pin Data A6 2.5 TDI 2002
- Valve cover seal and cam shaft seal REPAIR COST
- AutoTrans Code errors
- anyone need a set of keys?
- A6 2.5 AKE quattro no start no codes
- Audi C5 2.7t block power
- Special Bolt
- Sunroof
- What differences with German VIN 2.7t?
- Pulling right + memory steer
- 96 A6 sunroof, manual close
- Transmission disengages with turn/acceleration on a down slope
- What happens when you put an extra gallon of oil in 2.7t
- Considering A6 purchase
- 2001 A6 2.8 Quattro Exhaust "Flex Pipe?"
- 2001 A6 Ignition Switch???
- Problem with the gearbox
- Turn signal dim / not hazard relay problem or signal stalk
- please help i would like to know where the TCM is
- Audi A6 2002 Q transmission Control Module
- 2001 A6 C5 instrument cluster not working (everything except the right blinker)
- Audi A6 2002 Q transmission conttol module
- Bose Symphony II Bluetooth Connection
- Air injection system codes (2001 A6 2.8L Quattro 95K miles)
- stored restart help
- Finally found and fixed buried boost leak diy
- 2000 Audi a6 4.2
- Overheating
- Trunk noise when opening
- Flashing Check Engine Light
- How do I replace passenger side sun visor
- Audi A6 2004 2.4L doesn't start sometimes for 2 days then eventually starts
- 2.7t Toy build?
- Econ... climate control
- 1999 A6 Engine Codes
- cv joint vs whole axle replacement
- Anyone know how to test a 2002 a6 3.0 camshaft pulley
- A6 Quattro 3.0 no go
- RPM problem
- 2002 A6 2.4L misfiring and running rough
- where is the esp duo sensor located on a A6 avant
- Torque Converter Seal
- A6 Allroad (2004) Emissions issues - Help !
- HELP! ABS Light abd occiasional brake lock up
- C5 A6 Climatronic Controls
- Is There a Way to Eject c/ds From Dead Symphony II
- Sliding over to the A4/B8 forum
- New owner in need of assistance
- 2002 A6 - finally got codes help please!!
- Surging engine....Tip slipping
- High Idle then stalls
- Water pumps fail after 10 - 12K miles on 3.0L
- Boil up
- convert 1 din to double din stereo unit
- Interior lights not working
- P0491 and P0492 Codes
- Now Available Techtonics Tuning Downpipes and Exhaust
- Interior Temperature Sensor, in Instrument Panel, static open
- Headlight Switch
- Need help, fuel consumption very high. (Fault codes included)
- ambient temperature sensor
- where in engine is the power steering pum located audi 3.0 2003
- 2004 Audi A6 3ltr idle
- need help with finding snow tires
- 2005 A6 4.2 Quattro Cylinder 1, 2, 3 MISFIRE
- 2001 A6 4.2 Quattro rear bi-lateral thumping
- OBD II/VAG COM Eault Code Reader Compatibility
- Will these wheels and tires fit
- 2.7t Quattro Leaking coolant
- New owner with a 2004 a6 2.7T
- Driveshaft vibration
- Motive Power Bleeder Hose Warning
- Audi C5 Tuning compilation! Check it out!
- 99 Audi A4 1.8t wont start
- Audi A6 C5 LCD display fading
- No transmission gear displayed in LCD
- fluid leaked out dunsmission rae to loose line
- Finally an Owner
- Coolant for 4.2
- Audi A4 2L
- DIY PCV Breather System Test?
- oil level
- The P on my A3 sometimes flashes.
- How remove drivers side door panel
- Multiple Misfire After Changing the Aux Water Pump
- Coolant leak and Keeping coolant system depressurized
- 2004 A6 2.7T Quattro CEL Came on After Mild Road Trip
- White smoke when start up
- Audi A6 2000 & 2004 OBD-2 protocol
- 10% off FrankenTurbo C5 2.7T turbo upgrades! Ends 10/31/2017
- chasing down a miss
- Audi A6
- 99 a6 awd tcm pin out
- A6: Cold start shift problem!
- More BOOST! Frankenturbo 2.7T F21 Turbo Upgrades
- Comfort control module of Audi A6 Year 2000.
- Convenience comfort control module.
- Wiring issue with Range Sensor?
- Some C5 questions for owners
- A6 , 2001 MODEL . BOOT LOCK .
- 99' A6 C5 White smoke passenger side.
- 1999 A6 2.8 oil leak above crank
- 1998 A6 C5 Avant 1.9 AFN instrument cluster upgrade from non LCD to LCD
- Code P0018
- 2001 audi a6 c5 auxillary water pump
- Having difficulty finding replacement fog light bumper trim inserts
- Codes
- Is this a fair priced A6 3.0T Prestige?
- A6 2.7t Clutch and flywheel
- put in wrong code
- Oil sensor leak?
- A6 failure
- Wifes car didn't start this morning..looking for help..thx
- Shark fin
- Hazard switch not engaging
- 2000 A-6 4.2 transmission problem?
- The Lure of the Four Rings - Advice Needed
- Just a comment about P0420 Code
- Error codes feedback?
- Audi C1 to C7!
- Window dropped now dashboard constantly live
- Audi C5 A6 Interior Plastic Molding Colors: Black vs. White
- Audi C5 A6 Quattro Front Seat Informal Tech Notes
- 2.7t Vacuum system?
- ethanol gas
- 2000 Audi A6 C5 Quattro 4.2 V8 Race Report: Virginia City Hill Climb
- :: ECS Tuning :: SALE 20% OFF APR Software | C5 A6 and allroad 2.7T
- Audi A6 won't start - again..
- ***WannabeRacer.com | Boston and New Jersey Vinyl Wrapping Tour***
- Need Audi Indy repair near East side of Milwaukee
- S6 Brake job
- Front park sensor failure
- Voltmeter at max
- A very strange issue: lights, blinkers, wipers only work when the car is off
- audi RS6 engine mounts
- OBD2 scanner compatible with Q5
- AUDI A3 STARTS BUT HAS NO REVS
- Warning Light
- MMI failure
- Camshaft posion sensor help!!
- Feedback - possibly buying C5 sight unseen
- 2005 Audi scan tool
- What is causing thhs??? (See video)
- What is different about the Valet Key?
- Just installed engine/tranny back in, no start now
- Can someone identify this?
- Axle replaced 3 days ago - now hear gears grinding & car won't move forward
- Why is Fuse #13 blowing all the time?
- Is it worth it?
- Bentley Repair Manual Expensive?
- Radio switching stations
- A6 transmission filter
- Coolant Temp. Too High! WARNING
- a6 c5 instrument cluster no power?
- Very bad news/noise....
- Disconnect MAF
- Slow acceleration, no faster than 10 mph@1500
- Replacing an 1.8t ANB engine
- How do i bleed my clutch fluid on my 2001 Audi tt quattro roadster?
- What did I do wrong
- interior passenger light comes on after opening car but then stays on whilst drining
- Audi A6 -04 CAN-BUS or not?
- UK: Multitronic CVT filter?
- interior smell
- 2003 A6 outside door handles
- 1999 A6 Avant 2.8 engine quits
- Turn off the alarm system A$ cabrio 2006
- 01 A6 Quattro 4.2L V8 -- ABS diagnostic help please
- 01 A6 Quattro 4.2L V8 -- Timing issues help please
- 2000 Audi A6 Quattro 4.2 V8 Road Trip Pictures
- Transmission Question?
- 2003 center console pop up coffee cup holder bracket replacement
- service manual recomendations
- Hazard Lights 0n the Audi A6 Keep Flashing
- New to site - First Audi
- Audi A6 (2004) 4B (non quattro) PRNDS flashing
- mobility vehicle-not for retail sale
