- Whoo! Milltek exhaust installed! Impressions...
- What problems are you having at 7 yrs 60K?
- extended warranty covers coolant leak (aux water pump, R&R Intake) + Torsion Diff Seal Leak
- replacing factory bose in my 98' A6 quattro
- Does She or Doesn't She (Get a new DIS)?
- Oh my G, my rear brakes are rubbing agains the rotors when braking...
- If you had a choice of the audi A6 you have or a bmw 540 years1997-2001,what would get and why??
- New to A6
- LOL. One of the local Ford dealers will give me $1500 for my car in its current condition : )
- question about gauge panel.
- So the dealer want $600 to replace my (4) lower engine mounts..
- Need opinions on Bridgestone Potenza RE960AS Pole Position tires...
- What can cause my torque converter to leak only when the car is off?
- Anyone repaint the inside of their wheels to 'freshen' them up a bit?
- Paging RLG: Need some more parts (if you have 'em.)
- Key stuck in ingition - how to take it out
- Introducing the New Hartmann RS6-204
- -2.25 neg camber on my ds front wheel w/ lots of inner wear. Time to shop for CA's I guess.
- 4.2 / S6 folks -- has anyone run 245/45-18 on 18x8.5 et30 wheels -- I did search C5 and W&T foru
- I'm looking to get back in the game!!!
- If you are unable to get with someone who has a vag system....
- Vacuum lines 5/32? Can someone confirm quickly?
- Paging AKB....did you finally get the purge valve done? I've been off line a bit lately...
- If thinking about selling, check if you can get credit for your next car
- Ignition Switch
- diff between 4B0-035-195-J and 4B0-035-195-L for A6 symph II
- Related question: Will Audi do trade ins for cash, or do they only allow trade ins if you plan
- Check engine code??
- fitting 5x110 rims on an A6? Wobble bolts - anyone know
- Quick Avant Rear Wiper Question...
- clear corner mod any good links?
- Interesting cluster ebay mod
- APR Customer Appreciation Day and Grand Opening
- Spark plug replacement question
- Johnny's *important* Q of the day: Is it legal to sell a car that won't pass emissions?
- Following Thomas, I refinished my headlights as well...what a difference!
- that clunking noise
- cleaning storage room - misc. floormats available
- So I noticed something when I took a look at my fuel filter setup >
- Stock mufflers are back on. I cannot believe how quiet this thing is now :D
- DIY on my 69 camaro, but not this car. how hard is it? Can any inde shop do it?
- i know i should put this in the classifieds...
- high mileage 2.7T and oil grade choice
- clunking noise
- Need a new passanger side tail light
- Battery Issue Update #3 + A Dreaded Suprise!
- Anyone have any recommended spark plugs?
- 2.7t Tbelt job guys... where did you source parts from? OEM? PureMS?
- AudiWorld's Petit Le Mans 2008 gallery is live!
- In 4 service-they say I need replace aux water pump, engine seal, spark plugs
- C5 A6 reliability - better info - please sign up
- So what are your favorite ALL season tires?
- Torque specs Audi A6
- Show of hands please for 4.2 owners and maybe modded 2.7tt
- Where to buy '01 A6 2.7T clutch kit locally in MD or surroundings
- 98 A6 2.8 heater fan fuse #225, 226 location
- so who is feeling the market going crazy? someone in my job lost 13k in the last month in their 401K
- Can you get away with anything less than premium gas in the 2.8?
- Is anybody willing to lend the cam tensioner tool for the cam/tensioner seal replacement?
- A6 4.2 6spd swap?
- where do you buy the metal clips that are holding the headlamp housing?
- Is the 2000 A6 2.7T Quattro worth the buy?
- Clutch is done!!! Advice needed.
- Alrighty.. New fuel filter is here. Any special tips for install?
- Parktronic/Park Assist Sensor
- what is the ride height to the top of fender on an 02 s6?
- Can anyone tell me the correct rear rotors and pads for my car given my chassis number?
- indicator flasher
- replacing precat o2 sensors...need wiring for Car
- need help programming steering wheel controller
- Paging 5speed6. I've got a question for you on Recaro Interiors and Importing form Germany, etc.
- How do you enter the radio code? STFA and looked in Bentley.
- How many metal clips are there holding the clear part of the headlight housing?
- Water Pump 98 A6
- Anyone with any experience of Webasto auxiliary heaters?
- CD changer kaput...
- So what do you guys think?
- 2004 Audi a6 3.0 Trans Fluid
- 0-60 Times
- No hidden equalizer in Symphony???
- I have GIAC ecu for 2.7t s4 tip. is there anyway i can fit it on my a6 2.7 tip.? plugs a little
- Oil Leaks under the engine. Cam Seals ???
- my 2001 a6 v8
- Am I crazy?
- Driver's Side Mirror
- Condensation inside headlamp plastic cover
- Wanted to give this opportunity to my Audiworld friends before posting elsewhere.
- Looking for some detailed threads (w/pics) for the Darintake procedure..
- did someone need a center pop up cup holder next to mirror switch.....
- Is this a good deal?
- HELP! Just drained the power steering fluid and realized that the dealer sold me G004000 instead of
- 2.8 has intermittent issues starting
- Engine Performance (lack there of)
- Another one, so far I have seen 3 Recaro interiors
- Recaro Interior, Ebay.de
- Poor CD fidelity in Symphony
- Familiar A6 now being sold on Ebay
- Great info resource, I use it all the time
- *FYI* Gas Tank Leak-recall
- chicago area a6 owners, have you gotten your center diff seal changed?
- I need to sell my Alcantara (suede) Headliner. Any Takers or know of anyone that may be interested
- Inner socket Blues
- off to ft. lauderdale for the weekend to see the folks and take in a footbal game
- rear view mirror
- Does the fule filter have any role in gas mileage?
- Limited supply of RS4 - K-04 turbos back in stock at Achtuning, $2,599 shipped!
- last bumper post i swear: are all narrow-body (front) bumpers the same?
- 2004 Audi a6 3.0 AWD Auto Tip
- Hazard flasher removal - quick question
- pic of the hole in my bumper from last night... follow up: this will need
- Lets talk chips why not yeah?! Question for chippers....
- Injection of SeaFoam
- RS6 install tips?
- I want to be a new (to me) S6 Avant owner. Any thoughts
- Need help I have a 17799 camshaft position sensor Bank 2 G163 : Short to ground P1391-35-00.
- So let's settle this question--who is OEM for valve stem seals??
- Friday Poll: what is the worse add-on, hookup, mod etc you seen done to a car - plz provide picz....
- I am sure this is a repost but DAYUM this thing is Fugly!
- Rear spoiler for avant?
- Q: What causes temp gauge to move past half way? A: All of
- Fvcking school parking lots! 3"x4" hole in my front bumper tonight, right on the corner
- Hartmann Wheels Blem Sale
- Does anybody make a true CAI for 2.7T A6?
- Insurance for A6 Avant higher than for allroad???
- Hi after advice on removing instrument binacle to fit chrome rings around dials
- What's that groan?
- If possible, I'd appreciate an answer to the "MAF" question that I posted below.
- Any member get-togethers around Yardley/Phila/Trenton areas to talk cars?
- after i clean and polish my headlights, i did the same with my golf shoes like new again ;o)
- POLL: What should i make carbon fiber on our cars?
- frd m-sport wheels
- I know some people hate them, but I love the headlight treatment on the A1. 2 colors and the shape
- Ignition key locked
- Sold my A6 Avant 2.7T Turbo Quattro today, heading to the dark side I'm afraid...
- Anyone here need a really fast Taxi ? :-)
- Here's how to leave your Audi parked if you don't have a garage ;-)
- S-FLO
- How it all was in 2001
- rear brake disk replacement
- "Quattro, what's that?" Two salesman stories...
- Chrome mirror auction ends in 4 mins...
- My wallet is about to be emptied...
- grill badge
- Fvck. Only 50 miles of driving, and the CEL came back on :/ >
- Oettinger`s Fall into Winter Sale Starts October 1st
- anyone have any issues with blauparts control arms recently?
- Battery Dilemma Update #2
- Does any one have any info to pass along to me. I have to remove the rear door panel to get
- wheel balancing
- Just added an RS6 center muffler section w/resonators (looks to be 3" pipe), and kept my Magnaflows
- Question on Gas....again.
- Windshield replacement
- C5 A6 4.2 manual transmission conversion
- New Member with a new 2008 S6 (need brochure)
- 0-60 comparison of my 3.0 Vs the rental 2.7T from dealer
- How do I remove the concert radio if one of the internal tabs is broken?
- 2000 A6 4.2 Hydraulic Fluid Capacity?
- G. Cluster says "BRAKE LIGHT" How to change bad tail lamp bulb?
- what is the trap speed of a stock a6 4.2? all the years if possible.
- I've said it before...60 degrees, SC w/ exhaust 2.8 = audi bliss, man what a fun car -
- Is my transmission on the way out?
- My ABS light came on my 99 A6 Avant - HELP!!!
- Your last chance to get Bilstein Shocks and Coilovers at the current price
- Odd noise and steering wheel vibration
- Sweet. The rest of my parts arrived : ) Now I need some help >
- PSA...5speed6...you around?? I emailed you yesterday...thanks!!!
- Starting Issue? Help!
- Thanks to those you posted info on the turn signal relay!
- New clutch perfect - after break in...few hard runs and now notchy trans
- Anyone know where to install 3M clear bra. My patient wants to do his MB SL. TIA
- root cause of cv boot to fail ?
- does anyone have any AKB intake manifold parts? - need the intake rod with plastic piece
- Fried foglight relay update....
- So.. What conditions must be met/how many miles must be traveled to run the evap monitor?
- Hmmm. 2000 2.7t tip with 50k on it. Hit/skip?
- Massapequa Diner Meet Long Island NY 8:00 Tonight
- It's out. If wasn't for those PITA Audi clamps, it would have taken all of two minutes to remove.
- 02 2.7 T Sport Pack, paint question...
- Anyone have experience w/ AWE S-Flo Intake (w/ITG cone Filter)? I have had a ton of problems
- Control arm replacement...
- Need help.. The new charcoal cannister is here, but I don't know how to install it..
- 2000 2.8 V6 - stuttering under light throttle
- so my driver side rim got nice coat of grease, the boot failed
- Latest Vag Comm Codes: TC issue
- So five guys in an Audi.....
- what do you guys think of these rims?
- So I found out why my coolant was low...
- stupid question day, for A6 4.2 owners only...
- Discuss: Would you consider the Hyundai Genesis to an (audi content) A8?
- Audi A6, 4.2 S-line with harsh suspension
- Rear differential leaks--need a little perspective...
- All Season Tire search
- Remove top dashboard on 02 A6
- AT rear seal HELP NEEDED
- Crankcase breather hose
- Wow.. Someone's parting out a B7 RS4 in the Classifieds. I wonder what happened to it..
- My POP up Cup holder by the E-brake is shot, anyone have a used one?
- was working on my headlights from 11am -> 8pm (i finaly have some time to do it)
- tranny and diff oils
- Dear Mr. Ming...
- Car Battery Question
- A legend has passed. RIP PL, :(
- Smell Gas
- Driveshaft force balanced?
- /03 a6 winter tires
- Ordered the Pure MS suspension kit yesterday.
- VMR Wheels | FALL SPECIAL - RECEIVE FREE MOUNTING AND BALANCING!
- Anyone have an oppinion about Mandrus Millennium wheels? Good/Bad look or quality?
- if anyone has stock a6 2.7 4.2 shocks and springs if you do PM me thanks
- HELP: source a reman & wrrntd Pwr Str Pck: '01 2.7T w/ servotrnc
- We have some RS4 K-04 turbos coming back into stock next week at Achtuning!
- RS4 wheels. what cars will they fit on?
- About to find a 2007 A6 4.2 and now I see the V6 Supercharged coming out
- Broken timing belt aftermath: Update
- 07 S6 49999-turns out to be an AoA buyback-new engine at 19k miles
- A6 Quattro 2.7T Snow tire and rim question
- friday pole(poll), what's your favorite Candy bar
- The time has come!
- In my battle of keeping the A6 vs. getting something new, I checked out Acura's new Gen 4 TL..
- Radio keeps turning off. WTF!!!
- Repost: PureMS.com Summer Coupon Codes!
- Removing Catalytic converters for test pipes? benefits
- Looking at purchasing 2004 A6 2.7T SLine - Questions
- Wheel fitment question for you guys, polished A8 wheels on a 2.8q? I searched and only really found
- 02 S6 Avant...how to change CHMBL bulbs...from inside or outside?...before I start prying...
- a good bluetooth
- 99 Audi A6 Steering Wheel Problem - Pulls hard to the left on its own?
- Power steering Humming, fluid level Low. No leaks, Add or Flush??
- Anyone know of a place for me to get a new drivers side mirror?
- do the secondary O2 sensors have any effect on how the engine runs/perfomance? (post cat)
- Extended Warrenty advise. Just got quoted $558/month (for 5 years) for a 5yr/100K miles .
- Ok... I need to find a place that carries gas caps for our cars. No luck with the
- front bearing R&R update
- Speaking about reliability, I can't believe how unreliable my 10 year old car is... The paint is....
- Holy crap Batman!!! Went through my "Audi" folder this morning..
- PArted out Avant?
- What to do? '01 2.7T 70k mi with Blown Transmission. Junk or fix?
- Ok guys (and April..) I need help with something >
- Which pre-cat O2 sensors are the best ones to get? Which ones came OEM in my 98 A6 2.8L?
- Out of complete ignorance I had a great scare today
- I'll be re-finishing my headlight housings this weekend...my q is how the heck
- Seat memory modules
- '00 Avant: Windshield reservoir seal and pump locations/part numbers?
- What is the precentage of drivetrain loss and the curb weight of a 2001 4.2
- I've got up to $500 to spend!!! Any suggestions for mods?
- front bearing R&R
- A6 4.2 C5 Eibach and Koni Sport Installation - Complete
- 5speed6, you have voicemail.
- Can anyone give me an estimate on how many hours these repairs need?
