- Hey, this beats putting car up on jackstands
- Clockspring issues
- V8 Oil in Intake Manifold...
- Sunglasses holder for c5 s6?
- 2002 A6 2.7T No Power to Climate Control
- SOS Please.
- Oil leak from hell and other questins
- Stereo wiring harness...
- What is this plug for ?
- Members Previous Car??
- 2003 Allroad third brake light row has a bulb out... Any fixes out there?
- A6 at Buttonwillow
- 2002 A6 2.7T stuck in park
- Just got A6, having an issue,
- 2003 Audi Allroad :Should I buy it?
- Air flow flap Position Motor (V71)
- Maintenance issues when Transmission is removed
- Broken hood release cable
- Compression readings after loss of coolant
- o2 code trouble
- Heating/Cooling Problem...
- Door locks on 1998 Audi
- Help! Instrument Cluster Trouble!
- Coolant leak?
- '01 Bose system
- 2.4Q Tiptronic-issue. Hard shift 1-2-1
- AUDI A6 2006 USED CAR TO BUY
- 2001 A6 2.7 purchase help
- How to reset the yellow Oil Level Min symbol in instrument cluster Auto-Check Display
- :: ECS Tuning :: 50% OFF CYBER MONDAY ONLY! Audi Ziza Master LED Kits
- Need help clutch fan delete on 2003 S6
- STUCK IN 4th GEAR!
- Heatercore replacement.
- Wheels ?
- Question regarding MAF wiring
- 2000 2.7t wont start
- Black Friday/ Cyber Monday deals from Car Parts Discount
- :: ECS Tuning :: 11th Annual Customer Appreciation Sale|Save up to 25%!!!!!!!
- Audi a6 tiptronic issue
- 2003 A6 Quattro
- Prices
- Difference between A6 and S6 4.2 V8
- Is there any reason no one will help with this question?
- Crosspost: WTB 2000-2004 A6Q 2.7T M6T
- smoke pen…wonder how this would work with a little air pressure...
- FLOWMASTER EXHAUST
- Audi C5 A6 avant PDC
- 1998 Audi a6 quattro 2.8l. Code p1423
- No voltage at Coil connector A6 Avant 2.8 L, 30 V Quattro
- 2.7t mt6 transfer case fill plug, where is it???
- A6 Avant 2.8 L, 30 V Quattro - NO SPARK
- :: ECS Tuning :: NEW!! ECS Wheel Spacer Fitment Kit
- 0101 - 0441 codes but everything seems in working order.
- Leaking 5hp24a
- Good code reader for 2000 a6 quattro 4.2
- RPM Difference, Vagcom vs Tach
- :: ECS Tuning :: C5 A6 2.7T ECS 2.0T Coil Pack Conversion Kit
- The Potential Death of My First Love, The 2.7 T
- Passenger Side Wiper
- :: ECS Tuning :: C5 A6 Winter Preparation Essentials
- smog delete… 3.0
- Were can i find new lifters??
- Audi A6 intermittent start problem
- Rear driveline question 2002 a6 2.7t
- New to Audi...looking at A6
- Weird Key Issue
- Please help with knock!!
- Wear on inside of front tire
- Special promotion for Audi World Forum members
- 2003 A6 3.0L 30V Automatic No reverse lights.
- Audi A6 Avant front wing removal problem
- Problem solved: Door switches
- Interior lights problem
- Anyone here know transmissions really well?
- modules
- DRL
- Twelve year "limited" warranty against corrosion perforation
- GEAR SHIFTER STUCK
- Is my local indy shop liable?
- power steering hose (return)
- car got water inside car
- Oil soaked '06 A6 3.2 coils help!!!
- Stock fuel psi A6 avk 3.0
- PES Supercharger in A6?
- New non auto leveling DRL headlights…Dynamic Headlight warning
- 2003 A6 heater issue
- Rear Caliper Seized. Where to get rebuild kit?
- I need help with my 4.2 A6. Please. (Transmission)
- Low battery causing sensor malfunction?
- 135K and still going strong
- About to buy a Audi A6, Questions
- Starting issue 1998 2.8 Quattro - video link inside
- Forum group buy with Car Parts Discount
- Help with a 2000 Audi A6 2.7T, please
- :: ECS Tuning :: C5 2.7T Fall Service Kits
- couldn't pass on this car
- Audi a6 2.7 engine oil smoke
- Power Steering Leak Help
- 00 Audi a6 transmission wiring question
- drivers door light and under feet wont go out
- Audi Care Plus
- Having Trouble finding a Front Caliper Bracket for 312mm rotor
- :: ECS Tuning :: NEW!! C5 A6 ECS Carbon Fiber Mirror Housings
- A6 2003 3.0L Oil Pressure Warning Light Issue
- :: ECS Tuning :: NEW!! C5 A6 2.7T ECS Billet Aluminum Dipsticks
- broken radiator flange. stuck in hose
- Steering fluid and "feel"??
- Advice on Replacing Defective Breather Hose?
- A6 ABS Traction Control warning after Clutch master changed?
- Please Help? Smoke oil and leak
- Cam Tensioner gasket or Camshaft Seals?
- AC PROBLEM
- clicking and hissing sound
- ABS and ESP Lights On
- A6 fuel pump issues
- Audi A6 brakes with a grinding sound while foot is on the gas pedal.
- Rotor/brake/ locked wheel question
- control arm pulled sleeve out of upright
- VAG Diagnostic
- 2.5 tdi not starting
- Help trying to identify radiator part.
- 01 2.7MT ABS with ESP module question
- Turbos Going Bad? Strange Situation.
- s6 lower control arm bolt?
- wow what a project!!!
- :: ECS Tuning :: C5 A6 WeatherTech Floor Mat Collection
- Will these rims fit on the car without rubbing?
- Can anybody tell me what this error on my dash means?
- :: ECS Tuning :: Schwaben VAG Professional Scan Tool By FOXWELL
- engine block drain plug
- mutiple short to grounds problem solved-please read.
- Engine Swap??
- A6 1999y, 1.9tdi avant FWD air springs replacement.
- Side door mirror
- Anyone have 00 A6 4.2 (ART)?
- Some Diff questions
- Estate/ Saloon Vs. Avant/ Sedan
- TCM problem
- Tracing wires, Standard colors?
- Question about fuses, cruise control and steering wheel
- Audi Avant Quattro replacement air shocks to standard shocks
- Headlight rubber trim
- Assistance w/ O2wires
- C5 vs C6
- 2001 A6 2.7T upgrades
- sorry if this is a stupid question, how bad or good is this?
- Pinion pre-load access.
- Audi Guru/Master: Help with Transmission
- 2004 Audi A6 2.7T tiptronic - CCM flooded - rewired
- Vibrating and leaking
- 30 psi compression?
- Overheating 3.0
- Don't Laugh I Could be in BIG Trouble!
- Won't start, and RPM fluctuating
- Flasher Module repair
- Replacement exhaust?
- EGT Deletes for my 2000 Audi A6 2.7T
- Humming noise in the rear
- temperature dependent O2 sensor
- Upper control arm camber centric.
- I am a picture pimp, sorry. Detailed RS6
- 95 a6 fwd 2.8. rec'd services @ 100k ?
- TBB from 034
- timing code after rebuild
- Boost gauge mount?
- Missing/Hesitation Issue 2000 Audi A6 2.7T
- Hood latch disconnected from cable.
- P1177
- Coolant temp gauge reading incorrect.
- Help!!!
- sorry for teh total NOOB question changing form H&R springs to ST coil overs....
- tranmissiom problem
- A6 Turbo Help
- Are S6's know for eating CV boots?
- Anyone know what this is? Tuning port?
- Cheap EGR Valve from Amazon ... worth it?
- Clutch is not fully disengaging
- Can 00604 - Potentiometer Positioning Motor for Air Flow Flap cause no heat?
- How do you launch your S6 or 2.7T?
- A/C Replacement advice 2002 A6 2.7t
- tranmissiom wont go in park help me please
- Just checking to make sure I'm seeing what I think I am.
- how much ATF fluid do I need?
- Introduction and pics of my new love
- Looking for a left fender end cap
- Clear stone/chip guard for the sides??
- S6 manual transmission conversion..
- brake servo (booster) - is it worth to get a used one?
- Replacement Antenna?
- 2003 A6 Avant Quattro Trunk Spoiler
- can you Identify this part
- A6 Avant Quattro 3.0 RPM high?
- 01 A6 no crank
- requesting experienced advice: 2.8L AHA A6 cam tensioner
- Genuine Problem: Several Fault Codes Pertaining to Camshaft
- Replacing door lock latch mechanism
- Seized Engine
- 2000 Audi A6 Quattro 2.7t fuel type??
- Im sure this has been asked many times...
- C5 A6 + 19" S6 Rims w/ Blizzaks + H&R springs... fit issue?
- Looking for brake recommendations
- Anyone put a threadsert in a 4.2 spark plug hole?
- DRL
- Should I Run? Used 01 Allroad with 110K for $1500
- Wheel wont fit on car properly HELP
- Bolt fell in transmission...
- 2000 A6 4.2L ART with Timing Belt rub noise at cold starts
- Outside dimming mirror issues
- T17r connector?
- Canadian DRLs
- New to Audi and have an issue with oil light
- :: GruvenParts.com Billet Intake Manifold Linkages, Oil Cooler Tubes, and More for A6
- Wiring Harness Questions
- Am I "safe" changing transmission fluid and filter at 85 K?
- Acceleration
- HID Fog light Problem
- A6 C5 where are good floor jack points? Im chewing up my scissor points :-/
- Tail lights diagram - parking sensor installation
- exhaust compatibility
- Clutch pedal weird feel and light noise
- Excessive smoke!!!! 2001 2.8l
- Audi A6 Quattro 2.7T 2002
- 2001 Avant Exhaust help
- Source for Service Manual
- ABS module and dash display
- 01 2.7t Starting charging issues
- 02 Audi a6 3.0 stalling problems
- :: ECS Tuning :: C5 A6 2.7T & 2.8L Timing Belt Kits
- Special promotion for Audiworld members
- 2003 Audi S6 hot engine start problem
- 2000 C5 A6 2.7t Rouge Connector (near P/S Reservoir)
- Date,year n time won't change
- Possible Torsen Issue
- Replacement Exhaust Clamps
- How much is the cost repairs and maintenance in a 5-year (years 10 to 15) ownership
- need help with what to do next
- 4.2 to 2.7t bottom exterior door trim
- A6 2.7T Warm Start Issue
- Aux Fan
- heater hose repair from core to block? i need sum help.
- Intermittent start, 2000 A6, 4.2
- Need Help Please!
- '99 A6 Quattro LED display high temp
- Problems after clutch R&R
- A6 radio wiring.
- :: ECS Tuning :: C5 A6 Roof Rack Necessities|Yakima & Rockymounts
- Drivers Door Lock Cylindar swap
- Door blades from Poland
- Allroad seats - need more side support
- P0604 Internal Control Module Random Access Memory (RAM) Error
