- 98 Audi a6 aha Vag Com reading No response to controller
- mutifunction steering wheel installation for clarion auto radio in audi a4 b7
- ZF 5HP-24A Clutch "A" Oil Pump Used Parts, and Information
- Used Audi S6 Advice
- ZF 5HP-24A Clutch "A" drum variations
- A6 C5 Quattro 4.2 V8 Brittle Fuel Pump Hose Connections
- My 1.8T - but the turbo is missing...
- Audi C5 A6 4.2 V8 Fuel Pressure Regulator Replacement
- code P0106 map sensor
- Fixing a broken EVAP purge valve
- 98 Audi A6 2.8L AHA Is this limp mode????
- Fun with some Window-Sticker MSRP Math
- Aftermarket radio Installation
- Auxillary Fan Fuse Location
- Much louder engine when the engine is warm
- 2001 fog light grill
- 2004 audi a6 v8 4.2l
- MMI Software Update
- New Audi A6 Quattro 2.7t Owner
- 2004 audi a6 2.7t s line problems after front end collision
- Mechanic @ at a loss.... PLEASE HELP
- Swap 2.5 TDI from Passat B5 into 2.8 C5 Audi A6?
- Drivers door latch playing up
- A6 C5 Quattro 4.2 V8 rear exhaust questions
- Audi C5 A6 4.2 V8 Transmission Control Module Ruined? Maybe Not ...
- Are Mufflers required
- 2.5 tdi AKE uncommon problem...
- Transmission Control Module Salad: 4B0927156AJ, 4B0927156AK, 4B0927156FF
- Check out my Audi wagon project videos
- Audi A6 2006 / 3.0 Tdi
- front signal problems
- Check Engine Light
- A6 2013
- q3 quattro tyre replacement
- What Do you think is better The A6 Or A8 ?
- Removal of rear seat squab, front seats, center console, glove box, side trim, carpet
- EGT removal tips needed
- Replaced intake manifold and forgot where hoses go
- Indicators / Alarm goes off intermittent
- Camshaft Tensioner Slapping Down.
- Fire Damage in Shifter Area, Get Hammer
- Raised Toe: A Story of Improbability
- Audi C5 A6 4.2 V8 Case Study -- Fall from Grace
- 2001 A6 door locks and windows freaking out
- instalation of aftermarked alpine headunit
- 2001 Audi A6.
- **** really hit the fan this time...
- Rs6 sounds expensive? Is there another car better to modify?
- Misfire and Stutter engine
- i need help! Popped coolant tube
- H7 vs DS2 bulbs A6 C5 2.5TDI Quattro (2004)
- Link to A6 4.2 C5 platform front bumper removal
- A6 2001 4.2 Rear Window Frame Removal
- Audi C5 A6 4.2 V8 ART Error 17748 - P1340 - Sensor G40 vs. G28 Incorrect Correlation
- What is this sound coming from engine?
- AIRBAG light on after crash data cleared
- 2.7t rough idle + jerking and shaking when accelerating
- S6 c5 4,2 AQJ, Stuttering on idle and during acceleration. No fault codes!
- EGT codes/repair -- and stumble
- Prnd1 lit up need help
- Differential windup/binding on quattro - oil change?
- Motor mounts pissed out oil as I dropped the engine...slowly :( HELP
- How do you reprogram a key fob?
- Cost for replacing Catalytic Converter for Audi Q7 2009 Model?
- Audi a5 parking sensors
- LR window is dead!
- A6 3.0 multiple codes
- Car acts like key is still in ignition
- WHAT VIDEOS TO MAKE?
- Air con going to economy mode
- Transmission display help
- C5 all weather black floor mats for sale .....
- Dead ZF 5HP-24A transmission
- Temporarily disconnect ABS/traction control
- Power seat switches?
- 4.2 startup rattle (vid inside) how bad?
- flex plate bolts
- 2011 A6 S-line 2lTDI loss of power, engine management & emission control system light
- Misfire code P0300
- Loud Hissing Sound from near firewall - help
- Need some help
- Forum Article fixed my MMI Issues - THANKS a LOT
- Facelift C5 airbag to a pre-facelift C5
- Transmission problem
- Brake Light and Cruise Control
- transmission fluid sensor
- Some questions....
- Battery light on startup--alternator?
- 1997 Audi A6 AC compressor stuck
- 2001 A6 2.7t sport package shock replacement
- Rare 1993 Audi V8 Quattro
- wastegate sticking closed on passengers side turbo
- 4.2 PS system sucking in air
- Timing Belt or Timing Chain
- Audi A6 Avant 2.5 tdi AKE Quattro brakes update
- Rear Seatbelt Guides - Mystery Symbols
- Just got a 2000 2.7T, Wish me luck
- oil pressure in economy mode
- Exhaust heat shield delete
- Can anyone identify these wheels?
- Tales from the autoCrypts
- 2004 A6 quattro p0455
- dead battery: sunroof reset?
- 2004 A6 S-Line 2.7T Airbag Fault Code 014
- drive wont lock 1st gear on tiptronic transmisison
- MAF Sensor plugin connector
- What do all of these buttons do?
- 1999 A6 Help, relatively new to German cars
- N75 lines
- AUDI Q7 not pumping fuel to the engine
- 2001 Audi S6 from Japan
- Audi A6 1.8 20v 1998
- Car does not start..Engine-Transmission Data Bus: No Signal/Communication
- rear door sensor
- 1998 a6 2.8
- 2/26/2017 Brake Job
- 2001 A6 2.7T What is this?
- Central Locking issue; Scanned with VCDS
- Ecm not communicating
- Getting engine rebuilt. Next step?
- P0421, P0431 after replacing Purge valve
- OBDII Adapter & Customization
- Walk me through the 99 a6
- CV joints for 2.7t racecar
- Code P0507
- Tyre change causes hydraulic fluid dash fault
- Proper Vacuum Pressure, Numerically
- android auto
- 2001 Audi A6 2.7t Valve cover gasket questions
- complete wire diagram
- Dad Wagon Video Series
- New A6 C5 Avant owner - Vagcom?
- Serpentine belt tensioner
- Color DIS upgrade
- Fuel pumps continuously primes
- Rs5
- q5 oil temp sensor
- Replace valve seals or not?
- Not the normal interior light problem
- interchangable
- Independent Mech. in SF Bay Area
- Engine Temp Gauge Stuck on 'C'
- Audi A6 front problems.
- Thinkng of buying my first Audi
- heater hose leak
- Busted plastic coolant return hose
- Audi Allroad C5 fog grill fits on S6 C5 ?
- central locking activates when boot/tailgate is opened
- Exhaust Rattle
- Need help finding the right C5 S6 Torque Converter
- Replacement roof top antenna for 2002 S6 Avant
- Trans. housing interchangeable FAQ to FAL
- Camshaft Position Sensor (G40) 3.0 AVK Engine. HELP
- Replacing factory steering wheel with MFSW
- differential and transfer case oil
- Front cigarette lighter repair
- Audi a6 c5 1.8T 20v Big problem
- Oil temperature gauge not working
- A6 C5 Aircon Display mailfunction !
- Audi 2001 A6 C5's subwoofer and rear speakers stopped working
- Going to go see an 2001 A6 that should not exist?
- 2001 S6 Quattro 2.4L Power Steering Rack
- PR Code Label
- A6 Allroad ZF 5-HP EYK transmission w/ metal chips
- Latest problem @ 240, 300 miles
- Swap driver seat with passenger..
- 2002 a6 4.2 with bad transmission.?
- 02 Audi A6 3.0
- Switch Wiper Arms 2003 Audi
- Looking For someone to Tune out my SAI pump and CAT O2'S and Millage correction.
- 05 AUDI A6 Quadro S-Line trouble shooting
- 98 audi a6 2.8L coolant Leaking in back of engine
- ARS upgrade
- audi tt 2006 front seats
- AUDI JERKING
- Door open ?
- Just Aquired an A6! Check Out My VBlog
- DOOR TRIM REMOVAL (rub rail)
- Decision Time A6 3.0 290K ??
- Windshield washer problem
- Cruise control missing?
- 2.8 beast build***money makes monsters...
- 2001 a6 2.8 replacement motor starts up then dies within seconds
- Remote Starter For My '16 A6
- ARS upgrade
- Tranny swap 4.2 into 2.7T
- Paddles
- Wont go past 15MPH or 1500rpm in park 1998 Audi A6 C5 2.8L
- APR stage 2 upgrade
- Audi torque converter fix 2001- 2009
- Car won't start ...
- headlight question
- Rear fog light bulb
- quality refurb torque converter?
- Fuel rail hose
- NEW D1s/2s/3s Xenon Bulbs | Front Turns | Error Free Reverse LEDs | Interior LEDs!
- Power Steering Rack
- A6 c5 trunk stuck
- Help how bad have I hurt my car???
- Unichip what do u think about it?
- 1997 a6 overheat and coolant leaking issue
- New Guy in Town
- Did I screw up my transmission? HELP
- Bent tie rod? Passenger side rear.
- Interior push lock piece
- alternator not charging
- Audi A6 Quattro 1999 S/W
- P0345 + P0021..question...
- Need help
- Opinions on aftermarket lights, oem, halogen, Xeon, led...,
- hi i have a b7 a4 with a blown 2.0t engine
- Changing interior bulbs...unplug battery??
- Care to share some knowledge?
- What are some possible issues with my 01' a6 2.8
- I have a 2001 audi a6 quattro 2.7 with bad oil cooler and bad hose.
- 2002 Audi A6 3.0 Front Cap & A.C. Compressor HELP
- Happy New Year!
- Need help with engine mounts and rubbing noise when truning steering wheel please :(
- Locks Acting up
- Multiple Codes - Surging Idle and Dies, but Restarts
- Whining noise on 2000 Audi A6 2.7T
- Can't open rear passenger door from inside or outside
- Door Lock (not actuator) assembly
- 1998 A6 2.8 purchase-questions
- Bare wires on CPS and P0172&P0175
- Possible axle/cv failure?
- 01 A6 2.7T CCM Wiring help?
- Transmission Doesn't Go Into Gear. (1998 Audi A6 DOHC)
- It's that time again or later. Winterizing tips.
- Help, I broke it! Not sure what it is....
- How hard is it to replace a transmission mount?
- Muffler delete
- a6 misfire issues continued
- 2001 A6 - problems with the electronics
- Audi A6 2000 2.8l quattro fuel gauge problem
- Transmission Misterious problem! audi 2.5 tdi
- Transmission related question
- 2.8 misfire issue continued
- Question about Central Locking System
- Looks like I'm off the C5 forum. 02S6 totaled.
- 2nd audi
- ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - January 1st - 7th, 2017***
- What tire chains do you like? SC1040?
- Egr/sai question
- 2.7T: Which is the correct O2 sensor?
- Which Battery (Dumb Question)
- How to replace a coil pack and ignition wires
- what became of Prospeeder
- Need help regarding rear quarter panel
