- Got my HCT tip tranny...going to rebuild myself.
- headgasket replacement
- Oil pan bolts part number/size?
- 2003 A6 3.0
- Euro plates Mounting
- coolant temp sensor but no codes?
- How to loosen prop shaft bolt or remove u-joint
- Broken rollover valve on gas tank - $2500!
- how to reset TCM with VCDS
- Failed J299 Relay
- Instrument Cluster Removal
- :: ECS Tuning :: Alzor Wheels Style 628 for Audi!!
- Can I use rims 7JX16H2ET45 for my A6, 2004?
- axle question
- Mystery Connector 2001.5 A6 2.7T 6 Speed
- Time for PS Pump?
- a6 3.0 160k
- having trouble setting obd2 monitors
- mirror cowling on drivers side
- Read this about suprise hard brake pedal solution
- Please identify and help with this trim piece
- Mysteery oil/smoke??
- OEM seat covers
- Performance questions after major repairs
- what goes in this hole??
- Tie rod broke last night...
- Need advise on '01 A6 2.7t
- 16487 maf signal too high
- OKAY everybody fess up - Post cat O2 sensors ( 2.8)
- 3 cylinders misfire at low RPM. Help!!
- inspected tops of pistons and cylinder walls with camera
- way to turn off reverse sensors?
- What kind of oil?
- Driver's Side Mirror Replacement
- A6 alignment target with HR coilovers
- Left vs Right Front CV Axles
- Oil temp gauge not registering
- Heated Drivers Seat
- 02 S6 Avant Donut 'stolen'
- It has been a fun time....
- ABS lights, rough idle, hesitation
- Radio for a 2000 Audi A6
- Aux Input Hard Wire Trick?
- :: ECS Tuning :: 2.7T Maintenance Service Kits!!
- wiring info for heated steering wheel.
- Trailer hitch for A6 C5 Quattro Avant
- audi a6 windows
- getting rid of my 2 c5 a6 project cars
- Accuracy of vag-com performance timer?
- how many of you have done this mod to your Symphony - adding 3.5mm
- 2000, audi A6 2.7T /battery gage fluxuateing when using my controls and switches.
- Valve Cover seals removal
- Steering issue
- 04 Audi A6 Signal Problem
- What I've gained from my poor experience with APR
- C5 w/ Bose Symphony LOC hook up
- Video "Honey, i shrunk the car"
- 03 Audi A6 Quatro droning, vibrating
- Audi s6 6 speed slight hesitation
- Custom aluminum expansion tank?
- Disappointing ongoing issue
- Need Help with another one...!
- Rotor rubs on caliper, any ideas?
- Transmission upgrade parts
- Remove Ignition Cylinder 65 A6 Quattro
- HID Headlights don't stay on
- adding a 6 CD changer to an exciting Symphony 1
- Quad S line Exhaust Tips
- Guess the oil leak - AVK 3.0
- Resurfacing dual mass flywheel
- 01 2.7T tip to manual swap questions
- heater hose to head coolant pipe leak
- Audi A6 Quattro 2001 won't start - need advice please!!
- Any write up for how to set the tining on a 3.0 engine?
- H&R Springs. Dropping. One week only.
- What is happening to my car? Help please?
- I need a "manual selector valve"
- Crisis following front pads and rotors
- Can anyone tell me what this is?
- New Leak (input shaft seal?)
- Loud whistling noise under hood
- Solar Panel part number needed
- Cabin filter cover?
- Should I buy? CarFax: Damage to right rear pillar --- 2002 Audi A6 3.0
- Power Trunk Lid Switch on Driver Side Door for 2000 Audi A6
- Removing the Pulley from Fan Clutch Bracket
- What is the CEL operation cycle 'polling' interval?
- Variable inlet manifold, when does it open
- The right side light , right tail light and right fog light not working.!
- Anyone want "the Definitive Aux Lighter mod" for a 2.7T?
- Anyone want a pair of Hella smoked tails for a 2004 2.7T?
- A6 1998 which position
- Sup dudes?
- 02 S6 Avant whining while heating
- Looking for some Cup holder buttons for my 2000 audi a6
- 2000 A6 2.7t starting problem
- Armrest cover
- Need HELP ASAP!
- High RPMS while in Drive
- are exterior mirrors repairable
- Going to rebuild my own tranny
- Electical Fire!!!
- Going Lower on Bilstein
- President's Day Sale at www.DetailersDomain.com
- Part # for paint touch up kit?
- 2000 A6 2.7T Questions
- Engine removal problem- it is stuck!
- Wiper Blades?
- Rough shift from Reverse back to Drive after highway
- Wacky Window Issue
- Oil in pcv valve from camshaft cover
- transmission / clutch problems
- Just got 2000 A6 Avant - HELP!!!
- Headlight buzzer on continuously
- "WHITE SMOKE UNDER ENGINE"
- p0341
- Issues w/ 2002 S6 Avant- HELP
- 2000 A6 2.7T Wont Start
- replacing HID
- Central Locks Unlocking by themselves! Help.
- Anyone tried rare parts .com?
- how to disable brake warning with vagcom
- Rough idle and white smoke
- BBS Wheels with special pricing, at AWE Tuning
- Upper Control Arms
- squeaky back seat finally solved
- DIY rear bumper cover replacement A6 C5 Avant
- For those of you that know me7logger and ecuxplot...
- Parting out 2000 A6 2.7t with 169k
- shock absorber disassembly/reassembly - impact wrench?
- Goodbye, so long, auf wiedersehen...it's been great!
- DIY Wheel Bearing Replacement
- Stalling, what does it do?
- :: ECS Tuning :: Miro Style 368 - 18" Wheel Sets!!
- Headlight Restoration
- Bad new temp sendor or other issue?
- Transmission expert needed.
- weird symptom loss of power no cel
- Winter wheel set (smaller size)
- EGT sensors
- Help picking a cat-back exhaust
- HHO Generator
- P0421 already replaced cat
- Wipers, Someone Plezse Help.
- 04' a6 2.7t 116k miles
- 2000 Audi A6 2.7T (150k) 6 spd Transmission Problem
- front wings removal
- 2000 Audi A6 2.8 AHA misfire
- H&R Coilovers. Lower, for lower. For one week only.
- recurring DTC 65535
- ccm failiure? 40 codes in vcds?? I need help,quick!
- Headlight washers not working
- Help with esp/abs on a6 2.5 deisel
- coolant T connector under reservoir
- 2002 2.7t best valve cover gaskets?
- help water in rear footwell in a6
- Need to decide quick! 1998 A6 2.8 with leaking valve cover - 900$
- Hopefully something easy....
- oil cooler leak, replaced, now leaking enging oil
- 2.7t boils water out the overfill on the coolant res.
- bought an audi a6 4.2l 2001 with tranny issue
- 2002 front bumper cover on 2000 A6 2.7t
- FS OEM Speedline 4.2 Wheels $200 OBO
- Audi A6 Quattro Manual 5 Speed Transmission (EFC Code)
- i am in need of this bad
- HID FYI "The Truth in Engineering"
- 2006 a6 steering controls not working when cold
- abs kicking in below 20 while barking
- enabling DRL on a 00 2.8?
- New Mods Since Purchase - HIDs & ST Coils
- C5 Xenon Hid / Halogen Lights for sale
- Repair of warning sign panel latch on inside of rear S6 avant rear hatch.
- No oil in the head after replaced valve cover and tensioner gaskets
- Little off topic - video
- Different inner CV Joints?
- Misfiring; Timing Chain Tensioner
- Poor am radio reception
- Transform your Audi, with G.I.A.C. Software and AWE Tuning performance components.
- Torque Converter Works When Cold?
- Slow day at Ridgemont High
- May have wrecked my Power steering, HELP!
- 2001 2.7t a6 codes and misfire, Where to start?
- 02 A6 2.7t Stuck In Park!!
- What to look for - Rebuilding Auto Transmission
- 2004 A6 Quattro 3.0 L - Camshaft Position Actuator
- 03 3.0 tranny swap, info
- Whaddaya think?
- help with 2001 a6 2.8 ecu not giving live data etc
- OK to tow about 20 miles in neutral?
- Random Misfires
- Just purchased 2001 Audi Avant
- Think I screwed up big time Cam Chain Tensioner
- Quick question
- Seat Exchange Question?
- '01 A6 Door Blade
- Correct wheel locks
- Wheel/tire/suspension saga
- Why would you want to delete emmisions from ecu?
- 2000 A6 2.8 Camshaft Adjusters
- Quietest Performance exhaust?
- Winter Special: 15% off for the next 24 hours at Detailer's Domain
- audi s6 '00 roof rails
- larger injectors automatically equal worse mpg?
- Audi C5 Facebook Group
- Let Bilstein keep you on track, from AWE Tuning.
- VCDS Lite service indicator reset ?
- 17522 - Oxygen (Lambda) Sensor ADVICE
- Facelift Conversion Questions
- My 420whp a6 for sale
- 02 S6 Avant Engine Oil Cooler needs to be replaced!
- Selling Porsche Cayenne calipers/LW slotted rotors & pads
- 4.2 oil filter change tips?
- Help finding center caps
- sub woofer causes rattle noise in rear deck
- HID headlamp replacing
- Oil/warning lights flash abs comes on transmission malfunctions
- 2001 audi a6 2.8 valve cover gasket replacement problem
- 01 A6 4.2 Radio Symphony 1 (Random mode)
- 2000 A6 2.7T sudden knocking from top end & won't run
- Please help ID blob / ZF 5HP19FLA transmission oil change / P0741 - 17125 codes
- Advice
- Are these the same as the rs6 wheels?
- Avant high mount stop lamp (LED unit)
- strange issue with headlights
- Missing wire on Voltage Regulator
- Quick question for the mechanics...
- yet another speaker issue
- 01' A6 Drivers Door Will Not Open.....???
- A6 c5 forum is so much better that a4 b6 conv
- Wiring diagram S6 instrument cluster
- :: ECS Tuning :: 3M 1080 Series Black Carbon Fiber Wrap for Audi!!
- Oil leak suddenly got real bad....help
- 1999 cats compatible with 2000?
- 2003 A6 rear sunshade not working
- 2002 no start with weird symptoms
- Suspension problems, need help :/
- Had my coolant flushed (and overfilled???)
- Neep front bumper...
- Suspension Upgrade
- Seat memory key fob issues
- immo disabled but can I stop the blinking light?
- 2.8 A6 catalytic converter replacement source
- 60 mm Projectors
- C5 A6 ENGINE LIGHT KEEP COMING ON
- What size wheel spacer stock rim?
- 1999 Audi A6 - WHITE SMOKE!
- Old Toy, New Interest. Now to address the problems.
- e85 tune?
- Happy New Year Audi Members!
- Headlight washer pump not working
