- Finally got some seat time in an RS6. I hate all of you that own them.
- Transmission Question
- Special Edition A6 4.2 on EBAY
- PSA: Came across a low mileage 2.7T 6 speed in MD.
- so what are my options on getting good price on 02 sensors
- Over half gallon of brake fluid flushed and brakes bled..The pedal isnt as rock solid
- Wow, what is going on on VA Tech!!! Link inside
- Calling Mike At AWE Tuning....
- Audi / ALMS at the Long Beach Grand Prix (30 pics - BWW)
- What's different between a '00 A6 2.7T TCU (4B0 927 156 BD) & '00 S4 2.7T TCU (8D0 927 156 BS)?
- My flashers are blinking on their own what is going on?
- The wife and I test drove 2002 S6 this past Friday...
- Risky tire size for C5 4.2? .
- ive read on the forums that you dont need to drain all coolant....
- Pin layout for mirror connector?
- anybody in here has HID fog lights? any pics. will the longer xenon bulbs fit
- Windshield Crack Repair vs. Replace ... What's your experience
- How many Racing Green A6's made?
- Just a rainy day picture....
- Why was that FEELER post erased?! :/ He put "feeler," not "FS!"
- Anyone know how much an coolant reservoir cap costs?
- Interior lights help???
- Strange question...in Tip mode in my '04 4.2, there seems to be a "stumble"
- Anyone know is H-Sport Sway Bars from an Allroad fit on my A6 4.2? Found a good deal and thinking
- C5 A6 4.2 Vin List!! Give me your Vin, Color, and main mods
- Why did VAG avoid multi-valve engines for the most part prior to this generation?
- Outer Tie Rod (driver side) replacement
- Philly style Noreaster: homemade linguine & clam sauce, Sopranos, a 'lil amore. Drive t'morow!
- My H-Sport Install(long) - Thank you to Robert Gedeon
- timing belt ??
- Long shot, but will my old 2.7t sport sway bars fit a passat?
- Quatto component fluids???
- I installed some Alpine SPS-17C2 6-1/2" 2-way car speakers up front and I can't tell a difference...
- Audi commercial
- Um, oops?
- Free stuff (if you come get it) :)
- Found these as fog light covers, but why is there a manual vs tip option?
- are these the S6 chrome mirror covers
- So monday i am trying to lower my ride :D i got Q:
- Pictures of tint on BLACK A6's please! Is 50% tint even worth it? Legal limit in Minnesota.
- So would it be possible to replace the crank seal w/out fully removing TB?
- Brake Light Switch
- best to buy coolant expansion tank?
- 2000 A6 HEADLITE SWITCH
- 2000 A6 FOG LITES
- Differential fluid--when and how to add/replace?
- Brake done by chain?
- Enough satay and durian. Heading back to the US. See you all in about 35/40 hours!
- Which "easily available" brake fluid do you guys recommend..
- Will 98-01 sedan fog light covers fit an 02-04 sedan?
- New high metal content brake pads..
- Wheel fitment question
- Beware
- Cup Holder...missing piece=(
- 2001.5 2.8 FWD brake pads... round or square connector?
- APR BBQ sale starts Monday April 16th at Achtuning.com!
- Rotor Fell Off!
- Is it me or is the new S6...
- Which one of you is this?
- noob question about brakes
- Does anyone have an oem Catalytic converter they want to get rid of?
- Please help with clutch
- Wasn't there someone here looking for BBS CH's for an A6 4.2? If so email me.
- Calling yrk2.7t@gmail.com
- Stock vs Stoptech Slotted rotor weight , Slight "Bed in" issue..Pics included
- DVs ect.. for chip
- quick Q - whats the silicone/glue thing i should use for clear corner mod in case i need it?
- Question, took my car in to the dealer for a code, the question isn't about the code though....
- Will headlights from 02-03 RS6 fit my pre-facelift 00 2.7
- Get bad mileage (4.2): 210 - 240 miles per tank
- Auxillary fan runs any time my heater or AC is on
- Will RS6 Exhaust fit in my trunk with seats down and front seat all the way up?
- It's that time again! H&R A6 Coilover Spring Sale! (one set down, two sets to go!)
- Lum bar Support--**Update**
- Recently moved, and found my old ECU w/ stage III programming...how much would something
- Replace Catalytic Converter at 50K miles? advice
- <for bac2h>TGIF Poll: What number owner are you for your C5-platform car (1st, 2nd, etc)???
- 20k miles on the DBC slotted/semi drilled and they are badly warped
- What, no TGIF poll?
- Has anyone had a good experiance with Meyle suspension? I always research everything but
- Aux cooling fan running follow-up
- LMAO!!!!!!
- AudiSport GTG at Pacific Audi, what a blast! As a prelude to the Long Beach ALMS
- Magnetic Drain Plug for 4.2
- 3 Q's... one about tinting, one about brake pads, one about tires
- So, Guys, are we driving a "chicks" car?
- Another A6 glamor shot:
- Boston Driver, where did you buy your center caps?
- Is there any difference in headlights between FWD and Quattro cars? Just wondering bc they have
- Timing misfire under spirited accelleration (have chipped)
- Any experiance or thoughts on solid tie rod ends compaired to oem rubber filled ends?
- Emergency help needed in Youngstown Ohio
- wheels
- RS6 fender liners - installed last weekend
- H&R A6 COILOVER BLOWOUT! (one down, two to go!)
- The never ending search to get rid of my vibration problems (long) with questions at the end
- Edge trim for but out valence
- Does anyone have an OEM sport suspension set-up they'd like to sell me?
- Phatnoise questions.
- Tailight Replacement 1998 a6 avant: Where to buy?
- Paging Just Me (trans fluid question)
- 99 A6 2.8 Transmission Shift issues - Seeking assistance
- So today i installed Auto-folding mirrors and auto-folding switch
- New owner here
- coming to terms w/a bad cat......
- Radio gremlins - changing randomly by itself
- Noob help
- Help on alternator
- Anyone have a custome painted A6? I'd like to see some unique colors
- After three long years...
- I got a new german license plate
- Want to install Eibach Spring and H-sport swaybars. Help.
- Has anyone on here upgraded to auto dim side mirrors?
- FYI - For anyone wondering if 18" BBS RS-GT's will fit over HP2 calipers.
- Help in Auto Tip Solenoid Diagnostic
- Climate control question: excessive delay on startup?
- How difficult is the control arm kit install?
- sunroof making noises....
- Wasn't someone here looking for BBS CH's? Buff Daddy maybe?
- Even though its 50 and soon to be raining I still have spring fever and just ordered...
- So the local Remax guy appears to be doing very well for himself...
- Belts and Tranny, Some questions after S'ing the Archives
- AAAAAwwwwwhhh CRAP! Car overheated today on way to work....
- Engine noise - Have searched the archives - still unsure...
- Will A8 monoblocks fit on my S6 ?
- who has the best Tip-chip out there?
- does anybody attempted to remove downpipes from 2.8 V6 ?
- Faded Instrument Console
- Anybody want a project S6? (Not my car) Why does this smell so funny?
- Some new ETs for the A6-->
- Happy Birthday, and R.I.P. for Oliver Kenkel aka "Audiablo"
- Oil Lines to turbos, F-hose, APR Bipipe, piggypipes, questions. About to chip
- Fixing instrument cluster
- Just thought I'd share my almost finished 240sx =)
- My "new" A6 2.7T tomorrow! Questions
- STFA, but these things change a lot. Where's the current cheapest place to order H-Sport Sways?
- ok,ok,ok......I got rid of the stickers on the side windows....
- Does this sound like the right fluid for my trans? Pentosin G052162A2....TIA
- Looking for A6 Avant tuning recommendations
- End of Lease Options (C5 A6 4.2)
- Hands-free mic and speaker.
- Well.....this is what's left of my engine-driven fan : / >>>>>
- Hello all, considering joining the C5 family...
- Navigation in a C5 A6? 2001?
- took a pic while at Northshore Audi, might be my new Sig.....
- Safety inspection before CPO warranty expire
- So I'm driving my 'new' 03 A6 2.7t 6MT home from Denver... (very long post)
- spent $244 At the dealership for a full trans flush $100 for the service, $120 for the fluid...
- Looking to buy C5 2.7T with manual trans.....
- POLL: Wheel dilema... black or chrome.... you guys decide
- Mintex, PBR, or Hawk brake pads??
- RNS-E telephone volume
- the chicago club is proud to announce registration for our first autoX is now open
- Installing new front brakes tonight.....
- brake pads with sensors
- Someone stole my wing mirror
- Questions about repair of ABS module
- Buying new Rotors and I was asked...
- out of curiosity......whos has stage III now?
- Anyone have a recording of an R10 in either MP3 or .wav they want to share?
- Pictures of Eibach Pro System installed.
- Issues with the classified section
- Who is running what summer tires (S6), 18x8" wheel, not finding the load rating needed.
- Where do fuel leaks occur?
- Started to Fix the lumbar support today...onto getting parts tomorrow
- Dropped my car off to the paint shop today....
- Anyone know where I can pick up a headlight tab repair kit besides from ECS? TIA.
- I've said it before, I'll say it again, PureMS.com is top notch. I over ordered, they caught it.
- Paging Gedeon: Fuel pump expert
- Did any C5 Avants come in stick?
- oil leaks
- Just looked at my car - and it looks from the back that right side rear tire sticks out more
- Finally installed my suspension this weekend...
- Hey those new A3's have some giddyup!
- I have done my research. Now its all in your hands..Which one should I choose.
- Carcover
- brake pad question........
- coolant expansion tank.
- Anyone with Denison Icelink? My stereo is making a weird noise.
- What is the size of the downpipe on 2.8 V6 is it 2.25" or 2.5 " ?
- lol.. I feel like an idiot for asking this, but where is the coolant temp. sensor on my 4.2?
- Just for the hell of it, here's that CF hood you were looking for ninjaed 2.7 ; )
- HOW TO: Whiten remote buttons
- Bentley procedure for removing airbag module
- drivers door hadnle not working!
- Pollen filter comparison.
- Upgrade your front swaybar? Think about changing your front endlinks.
- Anyone know if HID headlights from 00-04 A6's will fit my 99 A6? I'm looking for a replacement
- There's a nice S6 on eBay right now. Two-tone int + Tip buttons on wheel...
- Question for anyone with the "warm weather" package
- Radiator questions (boring, I know :P )
- Squishy brakes revisited, looks like the previous owner dumped oil in instead of brake fluid....
- Tinted tail light film from ebay......
- A good news, bad news kind of day... (BWW)
- avant cargo carrier recomendation?
- Just installed H-sports on my Avant... boy what a difference! =) Much less lean>
- traded 07 A6 3.2l for 03 A6 4.2
- Tire rubber fill in compound?
- anybody got 4.2 5 spoke sport wheels collecting dust?
- True independent fogs for Xenon cars- JN recall solved
- NYC roads suck! Extreme Contacts rule!
- Wheel poll
- Just tried to see what was wrong with my lumbar support....how do you remove the seat back
- VR - can you post about your experience with Saxco?
- ABS Controller
- Thanks - SCC/ACNA Audi Event, Spring Mtn., Nv
- OK, who really really wants a postcard from Malaysia? I have about 20 stamps left
- installing torque converter
- Extended Warranty - Chicago Area A6 4.2v8 with 98K miles.
- Test Drove the Amazing S6---Questions
- Will I throw a code if I disconnect the cam-adjuster connectors?
- anyone looking for a 6MT?
- Audi to launch new advertising campaign next week.....
- Anoyone have a picture of a C5 on a Floor jack, I am having a tough time finding a
- Ok everyone, it is time to pull the trigger. Please cast your vote! BBS CH or RS6 5-Spoke Rep's
- Phisherman Fakes the Funk with Bogus Email Scams
- FTW!! Look what fell out of my wife's uterus!
- PureMS :-: Free Shipping on 2.7T TB Kits!
- Air filter?
- AWE Tuning Package Special for April
- Audi A6 reliability - how does it truly compare?
- Damn those A3 3.2's are fast.
- Anyone interested in the Pope Mobile??
- PAGING TOM Mc*** of Burlington/Waltham area AVANT owner....
- Friday Poll: When you purchased your C5, what other cars did you consider?
- TGIF Poll: Lots of abbreviations used..what do they mean? ie..BTDT=been there done that..
- Finally !!
- Let me get this straight......
- Quick question concerning the sensor at the base of the oil pan>>>
- chirping sound heard inside car changing pitch with rpm
- Paging A6Sport : ) Everyone I talk to (ECS, etc.) says that my rears are 269x22mm. I know ...
- RS6 Mirrors part number?
- Alignment question????
- Drove the Alfa 156 GTA from Ipoh to KL (Malaysia) - 3 hours. Holy freaking cow!
- Cross post from wheel forum- Confusion about correct offset
- R8 exhaust sound...55 seconds.
- Not what usually comes to mind when I think of BBS rims. Performance & Pickup?
- Vibration w/new tires
- '01 Audi Symphony system keeps "self-adjusting" bass & treble settings to 100%? no see in archve
- Robert got the t shirt man. thank you very much after all these years......
- Answer to the occassional "what other car would you buy" polls:
- I just found this old pic from the track a 10 second snowmobile! Can you imagine.
- How much weight do you cut by putting on a carbon fiber hood? Worth it?
- Someone around here is becoming a real post-whore...LOL!
- Vehicle Service Record
- Will 312mm rotors (with stock '98 calipers) fit with my wineglass rims?
- Actually, I just bought my pads and rotors from ECS - no probs, except
