- VCD - Where to get them?
- Oil Level/Temp Sensor Short
- 2002 S6 Suspension Mods
- Audi A6 2.7L Quattro Biturbo
- AUDI A6 c5 downpipe not fitting plz help
- AUDI A6 c5 downpipe not fitting, plz help
- Where does the aux electric water pump mount?
- Need some help with a used A6 2.7t
- Audi A6 2.7L Quattro trans?
- Suspension lift? Ralley ish?
- C5 s6 intake manifold actuator diagram
- comfort control module
- Tires for 2004 A6 4.2 16"
- Vibration and shaking as you ho faster
- Vibration
- 2008 S6 Daily Driver
- APU vs ANB
- Water leak rear of motor
- Rear speakers and sub not working
- Looking for pictures of clean RS6s
- Difference
- Rear diffuser
- Front Gearbox Oil Level?
- Engine?
- Does the S6-00 have an airbag passenger switch?
- P1545 Error Throttle Position Controller Malfunction
- looking at buying a A6
- A6 C5 2.5TDI V6 AKN questions
- Vacuum leak!
- Looking for detailed Head Gasket Replacement Guide
- Factory Ground Points near Driver Fuse Box?
- Getting ground at power junction under relay panel under kick panel on driver side
- SE: A6 4.2 -01 | Fuel pumps?
- key(s)/pairing?
- P0411 code question
- Passenger puddle lights and floor lights
- New Audi owner
- Problem making/receiving calls IPhone/Audi MMI
- Parts Finder?
- Leather car seats air bag
- Audi 96 A6
- New Owner - A6 2.7t 2004 Part Identification
- Grinding sound after gearbox oil and filter change
- Extremely Disappointing
- Ran into a possible problem doing cam chain tensioner replacement job... advice pls
- Windscreen wipers not moving
- New Owner - 2004 A6 C5 Avant - Transmission Limp Mode
- UK: 4b 2.8 code ack swap to 2.7biturbo code bes. Help please 😋
- Auto window has to relearn constantly
- Large coolant leak above starter 2.8l 30v v6 Quattro
- Service manual a6 c5
- 2002 S6: New Owner/New Member
- Rear cv drive axel leak
- Can't find the hole!
- Automatic transmission stuck in fourth gear
- Workshop guide?
- Question about 2.5 TDi 132kw AKE Quattro
- 2.7T alternator,
- Turn signal/Em. Flasher board mod for LED
- Hvac blower stopped suddenly
- Transmission Safe mode
- Massive coolant leak
- Rear Caliper piston sleeve
- Shifter Problem
- Audi s6 c5
- diesel: speedometer/fuel gauge
- Driver side visor vanity light switch
- Central locking problem!?
- How to restore, clean and maintain leather seats
- What free software can I use to monitor AT temp?
- 01' A6 2.8 HELP
- Abs and transmission
- Audi C5 2002 3.0 Multitronic to Manual
- A6 2.7t oil leaking on cold side
- A6 4.2L Flapper Valve Stuck Issues
- 2001 A6 Quattro 2.7T hood strut removal
- 2.8 heads
- Water In Rear Passenger Footwell
- Can low transmission oil cause CV to break?
- Cluster going mad!!!
- Problem A6
- Did I Mess Up?
- Passengers side clacking from idle to 2800 rpms?
- shocking discovery: timing belt tensioner had quit but the belt stayed
- Audi A6 2.8L Auto Quattro ECU / Diagnostic problem
- 2.8 30v
- C5 platform a6 2.7t aftermarket performance upgrades
- Transmission problem
- 2.7t dump valves position
- Future owner: 2.7t 6spd vs auto or 4.2?
- NO: VP44 issues, diesel
- Injection pump
- timing overhaul questions
- 2003 A6 Fan Module replacement
- Problem with reving the engine
- Radiator Fan Relay location
- Audi A6 2.8L Auto Quattro problems
- OEM or OE Cam tensioner
- Timing chain tensioner or?
- What’s this part called?
- Just bought an A6 with a slight oil leak
- Oil Level Warning Light won't go away
- Coolant questions
- I need help diagnosing a Massive Missfire problem -- C5 A6 4.2
- TurboCharger Bypass valve open code?
- A6 Exhaust leak
- 1999 A6 Quattro Need Help.Thanks
- AU: Coolant System Pressure?
- How to set 2010 Audi A6 climate control armature positions correctly?
- Engine flush / Ceratec for 2.7T?
- Low fuel level sensor causing HPFP not to work?
- TIP to manual ECU Swap?
- Not full oil change
- RS6 coils & tune
- UK: Estate Load cover?
- New owner questions
- Audi A4 wheels for my 2001 Audi A6 2.7T?
- Valve cover 2.7t
- Help! Audi A6 2.7T
- Doors
- Passenger power seat not moving...motor runs
- Busted cylinder head tool!
- Found unknown part hanging does anyone know what this goes to?
- Sai Delete 2.7T AZA
- Heated steering wheel
- Oh Crap!
- Urgent help needed on brakes
- Audi a6 2.7t won't move in reverse
- Electrical terminal circuits
- Radio doesnt work
- Lock-up problem with my tiptronic
- Dashboard change
- Disconnected cable in the central console
- twin turbo 4.2
- 2.5tdi 180hp from automatic to manual
- Master brake cylinder mistake
- Swapping pieces
- Adventures in transmission replacement 03 a6
- Fenders A6 C5 1998
- A difference between the AZA, AJK and ARE 2.7 twinturbo motors?
- turbo crush washwer removal
- Where does this connector go?!
- 99 A6 Quattro. Engine shuts off after start
- 2.8 auto swap.
- Technical Question for swapping
- A6 Quattro BRAND NEW H R REAR SWAY BAR $275 cash nib
- HELP!!! 2001 audi a6 4.2 s line wont start!!!
- RS6 2004 Wiper problems
- first stolen fog light grill on my 01 2.7 in 20 years
- SSR AUTOBODY ♖ | SoCal's #1 Source for Quality European Collision Repair!
- Unwanted water questions
- ISO C5 A6 CCM Wiring Diagram
- transmission help/advise please
- Stock torque converters painted or not?
- 2002 Audi A6 4.2 Cranks but wont start
- 2004 A6 4.2 cranks but won’t start
- Drop that subframe
- How do I fix this?
- 2016 A6 3.0 bogging
- Alldata
- A6 Fuel Consumption
- Heater hose connector leaking
- Audi A6 hesitation and jerk from stop
- N 205 intermittent
- 2001 a6 avant
- Soon to be Audi newbie.
- 2.7 air leak explained
- 04 Audi a6 2.7t falling in and out of boost! HELP!!
- New engine which turbo?
- Installing used transmission. Preventive maintenance?
- Power Source Rear Window antenna amplifiers
- Crankcase ventilation
- Trans fluid color?
- 04 A6
- Disconnected instrument gauge cluster- now no start
- Fuel gauge on E when tank is full
- S6: Transmission issue question and Shop recommendation [Brooklyn NY area]
- CEL ON. Bad cat, please help
- Transmission noise
- Headliner Fabric ADHESIVE
- Stereo change, tripped immobilizer?
- C6 handrest
- C5: My car doesn’t know when I open my door!!
- Can’t find interior bulbs for my 2003 Audi a6
- S6 2002 enhancement tips
- 2014 Audi A6 TDI Check Engine Light When Fuel Tank is over half full
- Audi a6 (Project) Oil pressure
- Stiff clutch pedal
- 2.5 Tdi Allroad wont start
- Bulb access on Drivers Side BiXenon?
- 4.2 downstream O2 sensor bank 2
- Success with aftermarket cats?
- Intake Gasket Sealant Needed 2002 A6 2.7t
- Window Making a Snap/Click Noise
- Bad crankcase breather
- Engine transportation Hatch
- Engine Heating Up
- Torque specs
- 07 A6 no start problem solved
- Bentley C5 Service Manual listed in Marketplace
- CCM or wiring fault?
- MMI LANGUAGE
- 2001 Audi A6 Radio Wire Function
- Procedure to Replace Lock Cylinder on C5
- 07 A6 3.2 no start but lights radio alarms seat etc work
- HELP needed. A6 C5 boot lock cyliner and motor remove ?
- Free: Avant rear sunshade.
- 2003 C5 CCM wiring harness.
- Drain fuel from C5
- Front dome light connector(s)
- Motor Mount and Manifold Actuator
- Armrest replacement.
- 06 A6 Avant shift solenoid interlock connector
- Jerky at 2000rpm. Fine on Idle and revving static
- Need help with 2004 audi a6 2.7
- Looking for 01e output flange shafts for 6sp swap. Help needed, last piece to finish
- Steering wheel swap
- Advice for Possible New Audi Owner
- Coolabt Leak HELP!!!!!
- Looking for a good shop in/near Brooklyn, NY
- Humid in the tail moffler
- Can't find replacement molded coolant hose
- Tip Transmission swap/replacement
- 2003 Audi A6 Quattro 4.2
- Code 00290 Left rear abs sensor
- 100K Maintenance A6 S line 2.7
- where can I find these plugs?
- 2003 A6 Rear Window will not roll up all the way
- reprogramming a key FOB
- 2001 Audi A6 Quattro 4.2
- Need help with cooling issues
- Always check the thermostat
- 2004 Audi A6 3.0 wont start but will crank
- Updated link to this....
- Quick Question: Will this fit on the '02 S6 engine?
- Hydraulic oil
- Radio Help
- C5 A6 Avant water in spare tire well
- 2.7T compression test
- S6/S7/S8
- Remote control not working
- LT: Fit H7/H7 headlights to an audi c5 that has H1/H7?
- Clutch Master 'snapped' in cold - 2nd time!
- 2002 C5 S6 Shift Lock Failure - Need Part# and Install Recommendation
- Audi revolution
- Need codes for radio
- 2002 2.5 132kw/180hp cooling system issue
- 2002 A6 ECU issue
- Ai Bag Inflator
