- Oil leak--valve cover or front cam seal?
- Sluggish feeling + white smoke (need help...again!)
- Blown Amp? why no sound from stereo
- HVAC Flaps bad, or climate control module bad?
- 2004 audi a6 3.0 cylinder 5 misfire. Help
- Black Friday Special @ DetailersDomain.com
- 2001 A6 Quattro Automatic gearbox problem....help needed asap!
- Happy Thanks giving
- Requesting help on Door Lock removal
- Motor mounts on 02 S6 Avant
- Spark plugs clean but have whitish powdery coating
- 2001 A6 Avant 2.8L - no start, no codes...
- A6 C5 white smoke problem //Please help!!!//
- new need some insite
- :: ECS Tuning :: 9th Annual Customer Appreciation Holiday Sale & Giveaway!!
- Pre-Black Friday Deal - Buy Sonax Polymer Net Shield Get Sonax FE Free
- :: ECS Tuning :: Save 10% On ST Suspension Through 12/8!!
- Audi A6 2001 2.5 TDI - Radio problem
- Door Lock
- Audi FOBS
- fuel gauge / temp gauge problems
- New new clutch suggestions....
- 3.0 Starting Issues Possible Timing
- 2000 Audi A6 2.7t transmission problem
- Avant from sports to normal suspension
- Stubbornly Leaking Injectors
- First Mod on my 2.7t Audi
- Audi A6 Violently Shaking
- WTF stereo stopped working...popping sound then no sound..please help
- Troubleshoot rear speaker/sub
- Strange problem with FL speaker
- Steel winter wheels for 2000 A6 2.7T
- 2001 a6 2.7 exhaust/downpipe change
- LED brake light/tail light ??? Part #'s
- 2001 a6 Brake Pad light and abs after replacing speed sensor
- new owner 2002 a6 2.7t
- Latest recomendation on brake pads
- A6 C5 2003 facelift halogen to bi-xenon
- 2000 A6 interior lights stay on? dash show doors open
- audio test CD-disc?
- Old plastic…2K4.2A6
- Leaking coolant - hose clamps not working
- 03 a6 engine help or new one needed
- 3rd row seat
- Front seat removal
- Flashing MIL and misfire on start
- Maybe not as controversial as oil preferances, but a battery question.
- 2.8 cam chain and tensioner replacement
- Happy with new speakers for 02S6, front doors so far.
- Fuel Brands recommendation 2002 S6 Avant
- S6 cranks quick but sometimes needs extended time to catch
- :: ECS Tuning :: Alzor 18" Style 640 - Split 6 Spoke Wheel Sets!
- Aftermarket Headlights Questions
- Parking Light Wiring
- possible problem with n80 valve
- 2003 A6 2.7T auto - switch in driver side door
- How the heck do you put these doors back on?
- Well.....ANOTHER shirt is available. This one is for all 2.7 guys though ;)
- 1998 a6c5 2.5tdi v6 pressure build up in top engine
- Anyone replaced pass side cv axle?
- Aux fan wiring diagram needed, a6 2.8
- 2004 A6 3.0 sickening engine noise Help!
- Stiff steering... back at it again...
- At last…here's an idea for LED running lights on C5...
- 99 audi a6 quattro - improving ride
- :: ECS Tuning :: Alzor 18" Style 050's - Muscular Five Spoke Wheel Sets - 57.1 CB
- Pressure testing
- Alternator rebuilding...
- :: ECS Tuning :: Save 10% On Forge Products Through 11/25!!
- Searching for 5-spd manual trans Audi A6
- P0304 Fault Code - Cylinder 4 Misfire
- Strange leak on 4.2 auto trans...
- interior trim
- Rough cost to rebuild your 3.0
- Blauparts ATF kit...
- Cracked lower oil pan
- needs some opinions
- A6 2.7 Downpipes Needed
- darn headlight dipped...need fix for tab issue
- 98 audi A6 aha 2.8l timing belt replacement
- 2001 C5 A6 4.2 Refresh/build thread
- 2001 a6 2.7 brake to floor
- Interpreting VCDS engine measurements
- Neosapian's OEM+ Build Log
- Interesting intermittent miss 134 on V8
- 2004 A6 Avant wagon liftgate problem
- :: ECS Tuning :: Color Key Fob Covers - Back In Stock!!
- to cut or not to cut. exaust resonator
- Auto transmission in limp mode
- 2 ohm or 4 ohm replacement bose system?
- any vag-com owners in orland/sanford area?
- Anyone need glovebox for 99-04 A6 grey color?
- New owner: 2004 A6 Avant 3.0 Need Help
- Replacement cost of my turbos 2.7
- fuel filter replacement issue
- 15% off for the next 48 hours at DetailersDomain.com
- P1128 and P1130 codes
- ECP problem
- Hit it or quit it? 04 Audi A6 Avant 3.0
- Engine, Trans, & Gear Oils...
- 99 A6 Steering rack leak
- ABS/ESP Problems 2.7T A6 Help!
- New headlights? advice
- Help I have a part left over!
- 1998 A6 Quattro Oil Leak, Axles, and Speaker Size
- Car judders in 3rd gear and more if 4 people and on hill
- Kleen Wheels for A-6
- 2003 A6 2.7T auto - ABS code - Brake Pressure Sensor 1 (G201)
- Newbie needs S6 Avant Purchase advice
- Columbus Ohio Audi Mechanic Recommendations??
- 2.7t "Diesel" Engine Noise After Timing Belt and Valve Cover Gasket Replacement
- No heat... again
- Proper Manual Transmission Fluid
- 10% off all H&R Suspension Components, at AWE Tuning
- sound system overhaul
- Coolant? GONE!
- Rear window problem
- shift solenoids
- headlight switch recall info.
- Help!!
- 2003 a6 quattro oil leak
- 3.0 AVK with Auxiliary water pump
- Rumbling underneath when starting from stop
- Whining noise coming from the engine
- 2000 Audi A6 Trunk Release button won't work
- Wow...new HID headlamp assemblies!
- 2003 a6 2.7 turbo grenade
- **Don Nguyen | Vinyl roof wrapping, tail light tinting, black out chrome trim install
- Joe at axismotorsport still around?
- 2002 3.0L Shaking At Idle
- Help Please!
- FS: Pass side Lucas HP2 brake caliper $75
- Can't find oil leak.. Input needed!
- Haven't posted since 2006, but still have my A6. Only $10,000 spent on repairs
- Where is this drain plug?
- 2000 A6 C5 4.2 reverse won't engage
- Hitachi maf upgrade
- MTM wheels in US
- Wheel spacers
- Newbie - 2004 Avant 1.9
- Audi A6 SE CVT 2.4 2002 Judders on 1500 RPM.
- ECU swap; does this erase remote entry other settings?
- Change cam tensioner pads?
- Cam shot?
- Door switch not working.
- RS6 Wheels
- CEL comes on after gas fill up with cat code
- New owner of 2004 A6 3.0 engine...is my car front or rear wheel drive?
- :: ECS Tuning :: Remote Transmitter Buttons - .99 Cents!
- 2.7T Will not Start
- Oil cooler "8" gasket..
- flex exhaust leaks and cat codes
- What happens when your 01 A6 gets hit... and you're stuck fixing it yourself
- New Lights
- Pic of 02 S6 horn placement?
- A6 purchase advice?
- Cam seals or Timing belt first?
- 04 2.7T A6
- 2.7 Allroad misfire....confused.
- timing issue
- strange engine roughness...
- Help getting gas out of tank for pump change
- Up Grades
- Install FIS on a car without FIS
- 03 A6 2.7t coolant temp sensor connector
- Oil pressure lamp
- coupling
- speedometer stopped working....WTF
- Mass Air Flow (MAF) question for replacing
- C5 A6 Low Cost BBK - Touareg 4 piston calipers and MB rotors - install and other info
- Misfire on #4, now gone...what could cause this?
- APR Allroad 2.7T Low Boost Request
- Anyone know how to force readiness for emissions?
- Cooling fan '02 S6 Avant not turning
- Free...New Wix 24866 cabin air filter
- 288 front rotors to 312 swap bolt in?
- the "what are the chances " thread
- SAI pump on 2.7 6spd manual
- Brakes hot - need help!
- Timing belt - Cam Lock Tool question...
- Xenon Headlamps
- TSX-R Projector lens swap (cut off beam problem)
- want more power, what to do?
- C5 A6 4.2 little things...
- Anyone know the names of these rims? Are they Audi made?
- 1999 A6 Suspension Identification
- Just bought a 2000 2.7
- New owner of a 2004 A6...how do you operate ipod controller?
- Front Drive Shaft Oil Seals - Auto 5 speed Quattro
- Need help wtih Diverter Valves & vacuum leak
- Audi Ball Joint ? HELP
- help have intermit engine not starting problem
- Valve Cover Gasket(s) and Cam Tensioner Tool
- Replacement climate control module not working
- Transmissions Service question...
- Setting readiness - O2 sensor tests and engine speed
- PSYCHO Transmission no forward, has reverse
- P1411 and P1423 after air pump replaced
- New tires, new location (SoCal)
- I am a new guy with a 4.2 part # question
- door bit size ???
- What size rims are you all using? S6 Avant
- Hunting for more power.
- Rear Seats Heat not working WTH!!!
- 2004 4.2 A6 with 'RS Package'??
- 1999 A6Q Problems: Multiple DTC Codes
- fixed 16805 P0421 with O2 extender
- What years fit what for doors???
- Pearl White paint match L0B9 paint code
- B2 S1 no communication after replacement
- :: ECS Tuning :: C5 A6 Platinum (Grey) Sun Visors Are 87% Off!!
- 1995 audi s6 coolant leak - upper hose that goes into cabin?
- 2.8 Fuel pressure tester hookup
- like to rebuilt front driveshafts
- ANy luck in getting Audi to help with cat replacement?
- Help...my 1999 A6 2.8 quattro Avant won't start!!!
- engine speed sensor bad?
- Error Codes p1118 p1114 p1423 p1411
- Parking System 2006 A6
- Another S6 tip to manual trans swap I need some expert advice
- Wiper blade removal
- Mystery Ground Wire
- Just bought a 2002 S6 Avant. What now?
- General advice on Timing Belt Service
- How To: Remove and repair Solar Sunroof Relay 385/Fix interior blower fan
- Help!! Fuse keeps blowing for windows etc
- A6C5 over charging above 15V
- 10 miles @ 50+ mph with the e-brake on
- Oil Pressue Warning during HPDE?
- Highway RPMs
- Coolant sensor inhibit start Yes or No?
- Another 2.7 that wont start - Any ideas please
- anyone else warp front rotors easy?
- Oops: 2001 4.2 Oil Cooler Housing Reseal Disaster!
- 4.2 upper control arm issues
- ABS issue
- Acceleration hesitation issue
- A6 2001 not charging while idling
- Any resolution to the weird inner front tire wear?
- Found replacement Rear transfer case SEAL instead of 40$ dealer part..
- So I got a little rough with the fuel rail and now I have a mystery vacuum hose?
- Is it normal that my fan turns on right away
- S6 not turning over
- a number of C5 S6s are on car and driver website
- Help 01 Headlights
- What the heck is this?
- Brake Problem
- These don't look like Audi Cat converters?
- 18" Alzor Wheels :: On Sale :: $349.95 Per Set - Save 13%
- How Many is too Many ( miles ) ???
