- red oil light flashing help
- Help please!
- Small Business Saturday Special!! Free GoPro LCD Backpack with Purchase of HD Hero 2
- Aftermarket Amp Installation
- I need help with purchasing cylinder head gasket kit.
- Looking for stock springs (or as close to stock height as possible)
- Thanks Giving.
- Rumbling Tiptronic in final stage of filter service. Ideas please?
- coolant leak heater core hose (return) near to engine
- Where is the "other" fusebox?
- 2001 Electric Brake Booster , SOS
- :: ECS Tuning :: 7th Annual Sale And Holiday Giveway!!!
- The AWE Tuning Holiday Pricing Event. Starts… Now.
- Been awhile but need some help
- RE: Remote key
- Awful noise when climate control is engaged.
- Black Friday Special at Detailer's Domain
- 2001 a6 2.7 fuel pump problem?
- few problems :(
- Just picked up a 01 a6 with 2.7t and have a question
- Solar Relay or Blower Resistor?
- Rubber Roof Molding Seals
- 2001 2.5tdi tiptronic 2nd gear slip
- FS: 01 A6 4.2 Sport 65k miles
- 2003 3.0 engine missing problem
- Correct Thule cross bar length for 2001 A6 Avant
- car shaking vilently
- New oil leak--ideas?
- A6 2.7T Constantly burning out EGT sensors - HELP !
- Torque converter clutch issue - cheap fix?
- Coolant leak hours after turning off
- The Brembo Catalog, by AWE Tuning. Updated for the C5 A6/S6
- DIY on Oil Cooler replacement?
- Oil Sensor help
- Timing Belt
- Anyone have any experience with aftermarket Catalytic Converters?
- :: ECS Tuning :: C5 A6/S6 ST Coilovers Now Available With FREE Shipping!!
- HVAC chirping noise
- Need help interpreting temp sensor readings
- timing belt 2003 A6
- Which is the best combo for reliability
- Anyone know the Diff plug torque specs?
- New A6 owner here, have some questions
- lower oil pan
- Replaced flex exhaust pieces, now air pump doesn't work?
- Weathertech cargo mats available for 2001 A6 Avant?
- symphony II
- Oil presure help
- airbag short to ground issues
- steering rack bolts question
- Colant Hose Location stuck
- Factory HID test?
- RE: Electric fans
- Transmission Flush In Manchester, NH
- 98 A6 "bucking" on light acceleration
- Where is Cruise Control on 4.2?
- Motor replaced, one error code and brake booster not working?
- need help trans problem audi 1998 a6 quattro
- stripped a bolt on the fan bracket :eek:
- What is the small cylinder thing on top of the engine?
- requesting oil tube o ring replacement info
- Speed sensor issue
- a6 trade in for A8?
- A4 component compatibility?
- Block/cylinder head crack??
- Low oil pressure warning
- 2003 A6 Rear Blind Install
- LED Lights for 2003 A6
- Here's a list of VAGCOM Codes with TIPS!!!
- Window, sunroof, interior light failure
- Need help with a potential purchase. Urgent!
- Body moulding to the rear of the door?
- Car is not strating, please help :(
- Throttle Position Sensor access
- New Member
- Strange issue with seat memory...backrest
- Oh dear what have i done - help with steering problem
- COI C5
- Instrument Cluster LCD Replacement
- Post engine transplant, notes and questions
- P0421, spark plug replaced, then ABS and ESP
- URGENT HELP: replacing vaccum lines, i think something fell
- Fuel Pump for 1998 A6 2.8
- abs/brake light flashing... beeping... too much torque?
- Anyone interested in unused H-Sports???
- 98 A6 Quattro 2.8 wiring harness
- cam chain tensioner seals without the tool?
- Crankshaft center bolt oil?
- My first curb
- Does anybody have any info on replacing steering pump on 4.2 engine?
- noobie question alert!!!
- 2003 Audi A6 - Rear Brake Replacement
- Broken LCD, can you read warnings with VAG-COM?
- Tires
- Need some help in Louisville.
- Cold start very difficult, 2000 A6 Avant Quattro 2.8l engine
- Valve Covers
- a6 2.7t help
- AHA and ATQ front crank seals different?
- Xenon coding value in VAG-COM?
- 2.8 lower oil pan gasket
- Leaking by CV shaft/boot?
- Our Annual SEMA Special at Detailer's Domain
- Doing front shocks--this doesn't seem right
- Air Quality Sensor
- Bentley '98-'04 A6 Service Manual?
- 2001 A6 2.7 Hands Free install IPhone?
- Loose connector
- Quick TB Questions
- Bull bar for A6?
- Doing tb and more tomorrow, order correct?
- 01 a6 2.8 jerky/hard downshift to 2nd.
- 2.8 TB Instructions - Which ones best?
- Is it the starter or the transmission??? Help!!
- Power steering squeel?
- :: ECS Tuning :: Save 66% On Symphony I Radios!
- So close to getting this back together, I think (I hope)
- :: ECS Tuning :: C5 A6 Trunk Lip Spoilers 63% Off!!
- Do rear mains really leak on Audi 2.8L motors?
- Front Sway Bar Link replacement
- Rust on the inside of the doors - is it repairable under warranty?
- Any DIY guides for tiptronic transmission mount change?
- 2000 A6 4.2 Technical Update Manual
- 99 A6 2.8 parts car found
- 2.7 feels slow at mid day and "strong" at night
- ordered the Blau VacHose kit: whats the clear teflon hose for?
- Can't aim passenger headlight high enough
- Anyone know where this vacuum line connects?
- Dealer Service History Issues
- Strange Idle Issue in Park - Out of Ideas
- Stranded by massive coolant leak - 2.7T allroad
- Weekend suspension overhaul of my 2002 A6 Avant 3.0
- headlights not working?
- Airbag light help: 00588 - Airbag Igniter: Driver Side (N95)
- memory power seat dead.
- 6-Speed 4.2 A6 on eBay
- 2002 S6 Avant listed in classifieds
- Newbie Questions (2004 A6)
- 1997 Audi a6 1.8T SE shaking/vibrating
- Need timely advice regarding trans fluid
- Engine almost in, two more connectors?
- Allroad suspension into A6?
- Kudos to Ross-Tech and their VAG-COM tool
- suspension problems after overhaul......
- Anyone with ETKA help with part number?
- Deal of the day Save 70% off Uber All Purpose Towels at Detailer's Domain
- finding dropped parts in the engine compartment
- Does aftermarket sell complete carpet?
- Heater fan kaputt
- New purchase questions 2001 A6
- Rear Parktronic Question
- A6 2.8 Spark Plugs/Coil Unit Help Needed
- Need help diagnosing emission codes...
- 02 A6 issues
- Turn Signals On Steady/NOT Flashing
- After reconnecting a battery, what needs to be done?
- BLAU ATF and Filter?
- Deadish battery, starts with jump, but dies?
- Shorts (???) in Front Turn Signal 2000 A6 Avant
- Anyone know what these are/do ?
- Uncommanded door locks
- 2.8 Camshaft seals? Source?
- Electrical probem, help please.
- I was dreading this happening to my car, Arm broke
- The best tool you have!
- 140k mile service...
- A6 2.7t performance/economy chips and tuning help.
- Trick to putting on 2 coolant line on back of 2.8?
- Emissions - can I pass with one incomplete monitor on 2000 model in Virginia?
- *Sigh* No Start, Just a Click
- Part number for exhaust flange bolts/nuts?
- Too many CEL codes!
- In the middle of rear shocks--couple questions
- Vacuum Hoses: what sizes do I need to replace all of them?
- How do you remove the defroster vent from top of Dash?
- power steering issue after installing K04
- BAD Coolant Leak !!!
- Flex Pipe update ..
- Need help with C5 S6 dyno slip
- ticks at cold start 3.0 A6 2003
- From the "could have done without this tonight" files...
- 2000 Audi A6 Window Carrier Repair
- Experience with Febi Bilstein Control Arms
- Audi A6 all key lost
- A6 2.7t engine weirdness
- For Sale 04 A6 2.7T S-Line
- oil-ish/gas-ish smell in the cabin
- Front or center engine mount 2003 A6 3.0
- Help with Road Vibration
- Check valve near TB?
- What are these parts?
- Rear Door Light Switch Location?
- which o2 sensor
- auto window function back doors?
- 01 2.7t Heater core flush?
- Temp Gauge: does this happen to anyone else?
- AWX vacuum hoses
- P0422 Cat Bank 1 Help
- Peek under your A6 2.8 hood please? Need pics
- FINALLY putting my A6 2.8 together need tech help
- Getting behind the radio?
- problems with 2000 a6 2.7t quattro. Abs noise, speedometer, gas gauge, aux fan, etc.
- Passing on my experience: on caliper bolts; torque; and (not) pad deposits
- Which Cylinder is Supposed To Be TDC #1 or #3
- Radio safe mode
- Help: Weird Heat/Ac Problem
- electrical help needed - radio circut
- Window stuck, please help diagnose before I get myself into trouble!
- 4.2 transmission repair manual
- Not sure where to post this. Need front bumper.
- Should K04 shaft seals be air tight?
- Can stripped HID headlight be fixed?
- WTB sport 2.7T suspension
- Symphony Radio Problem
- looking to rebuild or replace 4.2 tranny
- New here from Iceland
- ANy A6 interested in the rear power sun shade?
- S6 C5 instrument panel, A6 compatibility?
- Help! My car is overheating!
- short throw shifter recommendations?
- will 245/55/18 a 01 2.7t??
- 2008 Audi A6 DVD Navigation Install
- FS: OE RS6 carbon fiber set for C5s
- Is my torque converter going?
- Fumes in the cockpit
- 2 requests please!
- Driver Information System (is it an option?)
- EPC light and P1676-35-00-- code, 2000 2.7t
- S6 C5 tyre sizes..
- N00b question about transmission and engine limits and general driveline. 2.7tt,6mt
- considering parting a A6 2001 2.7 quattro
- Should I buy a 2001 A6? Please help with known issues!
- 4.7 µF 110V- 120° Ground Capacitor, Broken Lead, Need Another!
- Help, my car died
- door ajar/lumbar support...
- Would a bad brake switch cause my a6 to go in limp mode on and off?
- Detailer's Domain: 15% off Orbital Polisher Bundles and Car Care Kits
- Instrument cluster swap
- SIDE INDICATORS & HAZARD WILL NOT WORK.
- Setting Seat Memory
- AM static
- Trying to pass Emissions WA State - Help with Vag Diag
- 2000 A6 Avant - Allroad body
- Car will not start!
- Wipers stopping and then restarting
- Car will not start/ starter maybe?????
- Coolant Reservoir overflow
- Total frustration with RHS down pie removal
- Flex pipe measurement
- Anyone in Southern Oregon with a VAG-COM?
