- Stumped and desperate
- window switch question
- Coolant hoses part numbers
- Fuse 14 and central locking module.
- Looking at a 4.2, possible issues
- Doing ATF change this weekend....tips?
- Inconsistent/uneven acceleration
- CEL ON PLEASE HELP!!!
- Handling, looks and quality. The H&R A6 Catalog, from AWE Tuning
- Quick A/C question
- headlight weather strips
- Common C5 Airbag Problems?
- control arms - advice, whole kit or just two arms?
- "beefed up" transmission
- 2001 audi a6 4.2
- I need to either sell my 4.2L A6, or need parts
- when you just know it's going to strip
- 02 Xenon headlight part number question
- Used Oil Analysis - Just FYI
- Shopping for wheels :-(
- A6 C5 fuel and oil light
- Newbie needs some help
- ECU AND TCU CHANGE OUT Q'S
- 2.8 ATQ burned 1 QT~1.5 Quart vanished in 2000 miles
- 2004 Audi A6 2.7 t slight hesitation
- My new MY01 A6 2.5TDi V6 SE
- S6 door blades things to consider before purchase
- At a loss on this one...
- How was my car running properly with the cams off this far?
- Magnaflows on my A6 4.2L Video..
- Advice, the hard way, on timing
- Need new rear rotors for 2.7t
- ac overhaul...new evaperator?
- 1996 A6 Shift Problem
- Subframe bolts location for DP removal
- Removing DP's - unbelievable difficult
- Red Synthetic ATF fluid??
- 1998 turning but not starting
- code po741
- The BBS A6, S6, RS6 Catalog, from AWE Tuning
- Strut Mounts - F&R - durability
- ECU gets Hot
- 2004 Audi A6 2.7t windshield wipers? Where to buy?
- obd ii won't connect!
- N80 valve evap purge valve location on a 99 a6 avant 2.8
- 1999 Audi A6 avant throwing codes. Is this O2 sensors?
- Audi A6 2000 1.8t help with missing hose,high emissions and a fried coil
- New A6 Project
- 2001 A6 Avant for sale
- Am I going overboard with my maintenance?
- 2001 A6 Coolant on Carpet
- C5 Facebook Group
- Audi A6 Accessories
- 1998 a6 qttr - TCM Q's ???
- 4.2 Trans fluid help. What kind?
- surging of power?
- Waterfest 18 Special Starts Now - Get your detailing gear before the big day!
- Fault code P0322
- I think I messed up pretty bad...timimg
- ac compressor seized?
- A6 Crankshaft Position sensor
- A/C failure
- Intake Manifold Operation - Change over
- after timing belt, multiple misfires...
- AHA vs ATQ heads
- Headlight leveler problem
- Corners, be afraid: The Bilstein Catalog, from AWE Tuning
- bad valve gasket installation...re-use?
- G12, fuel filter, oil filter, which is best
- Laundry List and a Thanks
- help??!!! car throwing codes and need advise!
- 2002 Audi S6 Avant for Sale
- misfire cyl 1 &4 replaced coils---prob came back next day, need advice
- Tips to remove door sill trim?
- 2004 2.7 A6: 2nd Failed Alternator
- Bad Idea to tow 1600lb boat with 2002 Audi S6 Avant?
- 4.2 Trans fluid & filter change
- Faulty instrument cluster
- Fuel gauge issue
- Interior heat problem on 1998 A6 Quattro
- .:Eurocode Tuning:. APR Summer Sale!!! July 1st thru Aug 3th
- Menu Button below mirror adjustment
- New Member, 2000 A6 4.2 6-Speed Swap
- steering wheel controls with afternmarket head unit
- What is those hose for? PIC
- Serious problems With my 99' a6
- 2000 A6 C5 2.8L AC PROBLEMS
- July 4th Special @ Detailer's Domain
- Tuning a 2.8L C5
- is it possible to glue chip to steering column
- 2001 2.8 quattro won't start and more!
- Quick Valve Cover Question
- cluster
- A/C clutch not engaging
- Cleaned up my Center Caps
- Valve Cover Gasket Kit- Blau
- High Coolant Temperature
- amount of freon in system
- VAG COM Northern Virginia
- How are the cylinders numbered on the 2.7TT please?
- Concert stereo....wow!! But???
- Front fender replacement
- New Sponsor Introduction
- Intermittent Turn Signal Issue
- Installed Chrome Mirror Caps on 2002 Audi A6 3.0 Quattro
- 01 a6 windshield washer fluid alert constantly going offf
- Trying to isolate a clunk and found that my motor moves. Normal?
- 2.8 coolant leak
- Trashed calipers?
- New Transmission Output Shaft Seal
- Hi guys. Just taking the plunge again any tips??
- 2004 audi a6 s line 2.7t transmission problem?
- The South Bend Silent Design catalog, by AWE Tuning.
- Flashing cel
- Car and Driver on 2013 Audi S6
- Refinishing factory wheels
- 04 2.7T C5 A6 S-Line Question
- The benefits of stability, from AWE Tuning
- Torsen central differential
- Need advice for 03 A6 CVT repair
- removing downpipes/converter from turbos
- A6 trunk lights?
- Ride height
- need help
- number 14 fuse and central locking module
- Hazard Signal (Flasher) Switch Removal
- Looking at an S6 - coolant leak near alternator?
- Any ideas on what would cause this noise on acceleration? (video inside)
- Blue Smoke at startup
- New a6 owner - kinda worried. Did I make a mistake?
- Hows it going
- Timing belt deflection limit?
- Front Outer CV Joints
- Installed my new headlights with LED DRLs
- Help finding my O2 sensor relay
- Brake Light Switch 2003 A6 2.7T
- A6 engine noise
- These are the brakes: The Stoptech C5 A6 Catalogue from AWE Tuning.
- So I need someones opinion
- 02 A6 01v Transmission Install, Major slippage. Why?
- Vag Com Help Need-Yes I searched
- Should I be worried about this, (with pic)?
- Cooling Fan / Overheat Problem
- Do I have an amplifier with Concert Radio?
- Yet Another oil leak question
- Need help, 2000 A6 4.2 - gas pedal non responsive
- 2000 audi a6 2.7t misfire
- Vag Com / Diagnostic Help
- Oil in spark plug threads = leaking valve covers?
- Drivers door won't stay locked with key fob
- A6 Quattro Allroad Vacuum Leak, Know the name of this part?
- Replace O2 sensors?
- Considering an A6 4.2
- :: ECS Tuning :: 2.7T Exhaust Temperature Sensors. 27% Off And FREE Shipping!!
- Power steering hose routing question please...
- NGK BKR6E For 2.7t Autozone says is a NO GO
- Two Extremely Insane Deals on Sonax Full Effect Wheel Cleaner 500 ml Triggers
- TB and valve cover gasket change questions.
- rearview mirror fell off
- How do i turn the "air suspension" idiot light off?
- Replacing Audi Symphony 2003 A6
- starting problem - crank times getting longer
- Is this a leaking valve cover gasket?
- Ebay LED Lights for 2002 A6 Quattro
- 2000 2.8L CAM SPROCKET MARKINGS
- Forgot anti-seize on plugs
- REPLACING TAILGATE FOGLIGHT TRIM??
- 2000 A6 4.2 Cold Air Intake
- 98 Quattro Starting Problem
- Epic Fail...
- 1996 A6 Runs rough, no power, any ideas?
- 2.7T heater return hose quick connect
- Rear brake light (one side) always on
- Crisp's A6 2.7 (Member Journal)
- A/C question. VCDS log attached...
- P0421 and Gas -- anyone had similar story?
- The Bilstein Suspension Catalog, from AWE Tuning.
- 2003 A6 Alarm Module
- Hydraulic Tensioner Failure, Photo Evidence?
- Trailer Hitch Electrical Help?
- Slow Speed Vibration
- Portland, OR area - A6 Avant needs new home...
- Audi A6 buzzing noise
- Any suggestions for international shipper - transmission
- 2002 a6 4.2 doest start when warm
- A6 refrig retrofit?
- cam chain tensioner
- 2002 A6 3.0 Wagon Lateral Acceleration Sensor (ESP) Warning Light
- 1999 A6 2.8 starts then stalls
- Power Folding Mirrors Replacement Procedure
- Sun roof not working
- Water? in ECU plug
- White Engine Smoke
- Electrical Gremlins, Communication Issues.
- Alternator ID???
- Breather hose issue for A6 2001 AWD.
- Where to buy? Avant rear molding
- New owner
- Power steering stiff no whine from pump
- How to reaim headlight washers?
- 1999 Audi Sedan - Wipers stopped working......
- Got a sick LED audi badge . (the right one)
- Got a sick LED audi badge.
- Central Locking Module causing communication issues? Location?
- PLEASE HELP! Coolant sensor retainer clip
- 4.2 front wheel bearing
- Performance Brakes 2003 2.7T A6 and Rotors
- clutches and mounts
- V8 4.2 Timing Belt Pros....?
- Compression on one side only?? 2.8l 30v
- OEM Sharkfin Sat Radio Antenna Question
- Vibration noise on braking over 50 mph - Audi A6 2003
- Arm rest/box replacement?
- Shifting in anger results in separation of handle from transmission, and other tales
- 2.7T leaking coolant from rear of passenger oil pan / alternator with pictures
- The BBS Catalog, from AWE Tuning
- "I think" I need a new transmission
- Oil in spark plug tubes, please help!
- BIG problem! Need help!
- A4 or RS4 wheels on A6
- Boost delay
- Beating a dead horse? Number of chainlinks between cams driver's side 2000 A6 2.8L?
- Antenna amplifier
- New brake system issue, vacuum ok, leaky master?
- Aux Pump Replacement: Mission NOT Accomplished
- Workin on my '98 a6
- A/C Fan Replacement -- Gates/Valeo?
- Alternator Issues
- Remove exhaust bolts in cramped space?
- Clutch? Slave Cylinder?
- Recent owner of great 200 A6 4.2
- Aftermarket Bumper?
- Aux Pump Replacement: Mission Accomplished
- 2001 2.7TTmisfire. Codes attched... help please!
- O2 Sensor Question
- Rebuilt Transmission Installed, A6 4.2 Won't Start.....
- Questions regarding transmission/driveline
- steering column paint color
- C5 issues
- A6 C5 ECU blowing fuse when shift into Drive
- Replacing my Symphony Head Unit
- 2002 S6 Avant CV joint replacement cost listing
- Doing cam tensioner seals--couple questions
- To those with Symphony II and an iPod adapter
- ttime to replace the timing belt 2001 a6 2.8l
- Timing belt is loose and frayed
- Oil coming out if forge splitter valve
- 2.7t common problems
- '01 2.7 alternator almost dead
