- what is vag-com
- What size wheel spacer
- Catalytic converter
- 98 A6 dies when driving then restarts by itself.
- Wowee
- Interior quality changes
- Flashing CEL upon starting
- Replaced OEM Hids to 8,000K now problems..
- HELP!!! with OBDII
- Will a RS6 Suspension Fit a Regular C5 A6?
- ABS DTC's
- think I may eliminate 1 rear 02 sensor
- LWFW Questions
- power steering pump
- New Member- 1998 A6 Help
- Crankshaft center bolt
- 2.8 Fault in Cooling system sign + temp needle climbing beyond the midpoint
- A6 4.2Q fuel milage question
- 1999 Audi A6
- Timing is off, but no valve problems??
- A6 questions on thermostat and mounts
- Avant rear latch issues
- 2004 A6 3.0 ICM position again please
- 2001 A6 gearshift problems - help
- a6 c5 rear electric window wont go up
- Cant find performance parts for my '98 Audi Avant
- 19x8.5 ADR M Classic on '98 A6
- Audi A6 Wheel Sizes
- Any body want to sell "The Audi Quattro Book by Dave Pollard"????
- Plasti dip interior wood trim A6 C5
- brake light electrical problems
- solenoid or switch?
- front bumper cover
- No K Line Voltage
- Tips on driving
- Stoney needs service advice ASAP: timing belt cost; motor mount sensor, seat motors..
- Pre cat Oxygen sensors replacement parts...
- My '03 A6 Avant keeps generating some fault codes...
- FUSE displayed in Trip Odometer
- Help Identifying Cut Electrical Wires 2000 A6 2.8
- Poor mileage - MAF cleaning and spark plug wires
- How to remove downpipes from exhaust mani.
- Rear axle seal question
- 2.7 revving, EPC & ABS lights on
- P1141 and P1129 soon after fill-up
- 2000 A64.2 starting issues
- Transmission Advice/Shop in the DC Area?
- Do I really need to replace all 4 tires at one time?
- Loose Brake Pad?
- throwing codes
- damn puddle
- Loud Ticking noise from the 3.0
- a6 4.2 wont start
- Should I reinstall crank pulley or can I leave it off?
- So as I was replacing my air filter
- 2.8 oem exhaust parts
- Power Steering Hose Question
- 2.8 cooling system capacity?
- Alternative to NGK BKR6EKUB spark plug
- Victor Reinz seals?
- New Coffee Table, lots of pictures
- This part makes a clicking sound. What is it?
- Constantly Running Fan Draining Battery
- False alarm - spare motor is now spare parts container
- 2.7t ignotion problem
- Knock sensor and O2 sensor
- P1347 after TB change - can I drive safely
- Dead Cylinder
- White Smoke!!! HELP!
- 02 - A6-3.0 Starting Issue - EPC
- APTuning Now a Dealer for Stern Mounts and Suspension Products!!!
- Does anyone know P/N for bottom hose on coolant T?
- Help with a 99 A6-No power windows no sunroof-no connection through vag
- More Helpful than the Dealer ? PLEASE HELP!!
- Octane... is higher ok?
- new owner question
- Cvt acts like spark missfire
- How to check Camsaft Pos. Sensor (G40)
- Brake pad wear indicator light still ON??
- Hot feet, no codes.
- Please help!! K04 question
- 04 S-line 2.7T - Stinky pig rich or something else?
- True VAG gurus speak up: is there a way to find engine history?
- WTF??? camshaft lobe practically worn off
- Need to depress the clutch really hard to engage starter.
- best spark plugs??
- Slipping/disappearing reverse gear - any ideas?
- 2000 A6 4.2L - Air Intake Tumble Flaps Frozen
- Head light mounting brackets missing
- Looking for parts
- Which Sport Shock Replacement Kit 2004 2.7T S-Line
- Hazard light not working. Replacing switch not does not help
- Parts getting ready for sale...need pricing advice
- Tiptronic Problems.... '01 4.2
- Touareg 4.2 vs A6 4.2 differences... help me gurus!
- FUEL TANK CRACKED!!! NEED ADVICE
- A6 4.2L Still has no reverse???
- Report on 2 CV boots, SS Brakes, and brake fluid flush
- Windshield wipers stuck in wrong position?
- Audi A6, V6 2.5 TDI, 2003, Multi Function Steering Wheel Addition!?
- a6 rear heated seat not working
- Re-circ Gas Odor
- suggestions for exterior mods
- Symphony head unit swap
- 03 A6 with loud steering noise
- werid noise after tb job and valve cover seal job
- Repair quote from the shop
- Help!!!! Oil Preasure light is comming on in intervals
- 2001 A6 2.7 ABS ISSUES
- help for shipping from States to England
- Ah *@!$ - front bumper got cut
- Ouch
- Will any Porsche Calipers / Rotors fit on a C6 A6?
- 2001 2.7t model question
- Audi A6 2.8 ATQ 2000: Fluctuating RPM while driving between 25M to 50M
- very poor quality parts
- Winter blues and now no heat
- Water temp sensor/sender - location and relation to..
- every time i put oul in
- fan clutch
- '01 A6 2.7T Coolant leak
- Recently picked up a 2004 A6 Avant
- how to disable auto dimming mirrors
- 2 tiny issues i had with my 01 A6 2.7T
- Newb question (front headlights)
- Possible clutch problem, ideas?
- s6 wing mirrors C5
- PCV Intake part nr help please
- '02 Audi A6 4.2L
- For the love of &%$ can some one tell me!
- Just got a new C5 (2003) Audi A6 2.7T
- Stereo/Light Problem PLEASE HELP
- Whine when foot taken off gas pedal / during engine braking? [LONG]
- Transmission Slipping and Throwing Code
- 2000 A6 4.2L TCU problem
- Part number request (fog light bracket)
- 2.7t Low Oil Level - but level is fine + new sensor
- 2001 2.7T with problems - advice?
- 2004 A6 Avant - iPod/Iphone and Satellite add on?
- Instrument Cluster LCD screen
- A6 Avant 3.0 Whine
- C5 1997 (R reg) Climate Control noises
- wheel/ tire issue...HELP 225/45/18's rubbing
- Flasher Relay driving me mad!
- looking for super charger
- Beat the Winter Blues wtih Detailer's Domain - 20% off.
- Looking to put turbo in 2001 2.8
- Brake pedal suddenly pushes further down, then goes back to normal....
- Level Ten torque converter fix ofr 0745 & 17125
- Excessive Tire Wear - 2004 2.7T Sline
- Help! - Engine Misfire Diagnosis
- valve cover clean up!
- JHM FMIC Kit
- Audi Torque Converters-New pr Remanufactured
- Crankcase Breather to IM part nrs -Pic incl
- Fuel pressure regulator
- allroad s6 front end conversion?
- a6 2.7 secondary air pump delete?
- New cv boots on my '04 SLine...
- 2002 a6 4.2/ 2002 s6 differences?
- Does the A6 30V have a ECU relay?
- The infamous EBAY Cable
- Porsche
- 2000 A6 2.7T quattro took a dump, any idea what i can get for parts?
- Audi A6
- 2000 A6 2.8 Transmission...
- axle replacement
- Transmission Problem HELP!!!!!!
- Cheap way to add vibrating seats!!....or just a rough idle.
- 01119 - Gear Recognition Signal intermittent. Please Help diagnose! 2003 Allroad
- Understanding differences between Audi A6 clusters and the compatibility issues
- JOM Suspension Coilover
- Tiptronic problems! Fuse??
- 2.7t Auto Trans Issues
- Subzero Temps killed my A6
- Lambda Sensor B1S1 Internal Resistance Too High (Intermittent)
- Snow day! It's quattro weather today!
- Please help me decide!
- Rear valance for dual exhaust
- brake light come and go
- ABS Brake warning light and beep
- Windows rolling themselves down every night
- white residue on dip stick
- C5 A6 Bushing/suspension arm kit purchase?
- 179k birthday present to my A6 - new rear brakes.
- Koni FSD are they any g00d
- Transmission sticking in lower gears
- Strange clutch-problem
- Bose Audio System in '02 A6
- What piece goes here?
- changing front and back suspetion
- Coil Pack Problem? Window Problem too?
- Tie Rod End Replacement: Tips for removing the cross bolt
- Los Angeles repair shops?
- n00b help with VAG-COM lite!
- 2.7T Audi A6 starting problem when engine is warm
- Moderator
- Power loss!! Can't figure it out!!!
- 2000 A6 electrical problem
- A6 3.0 water pump going bad?
- 1998 A6 overheating
- Is there another trunk release button hiding somewhere?
- Moving on...
- Quick brake question
- ABS Issues? Vag-Com
- new 19" satin black tsw wheels!
- Audi A6 won't start, then eventually does...
- Anyone looking for a RS6 SE exhaust in the South ?
- New Wheel advice
- Why does this stage 3+ A6 not make power???
- Knocking After Timing Belt and Valve Cover Replacement
- New (for me) 04 A6 Avant Owner
- A couple AC related questions
- 1999 Audi A6 Quattro
- Need new battery
- Audi A6 4b TV antenna amplifier
- Fuel and temp guage going dead at once
- timing belt and cam seal
- Broken sun visor - help please
- CE light ON loosing power what now ????
- Flushing brake system, bleeding master cylinder and ABS pump (w/ ESP)
- doors not auot-locking when car in drive and at speed???
- new wheels, thinking of painting satin black, thoughts?
- Curb alert
- Engine Noise when warm 2.8L 30V
- HELP! Need CVT transmission for 03 Audi A6 2wd...
- 2000 A6 Tie Rod End Replacement
- APTuning New Years Timing Belt Install Special for Virtually all VW/Audi Models!!!!
- Automatic headlight adjustment
- 2002 A6 xenon ballast
- V6 2.7 T - NGK 6458 vs NGK 6418 ?
- Spark plug Gap on 2.8 ?
- Aux fan
- 2001 audi a6 2.8l running rough. please help!
- A6 CVT Transmission same for 2wd & Quattro models?
- I need a headlight assembly
- EBC Redstuff Overkill??
- Anybody else suffering cracked rims?
- NEED HELP ! ! !
- it just keeps cranking
- Power Steering Pulley
- P/N Help 4B5 513 031 R
- where can i get a axle rebuilt????
- Audi A6 TSB List
- guess what santa brought!
- 3.0 V6 intake actuators easily removable?
- EGR VALVE 04 c5 2.7t
- Superior Water Pump (C5)?
- Vag com Problem with TB adaption
