- 2000 A6 Avant research
- chain tensioner
- Feels like ABS is kicking in when it shouldn't be
- Anyone done engine mounts on a 2.8?
- MP3 for free!
- Potential A6 owner
- Interminent start problem
- Replica wheels: anyone dealed with finishlinewheels.com or owwheelsllc.com?
- stock rear spoiler removal - 2000 A6 2.8
- New to me '02 A6 4.2 with a few issues
- Automatic headlights
- Normal Engine Temp
- 4.2 chip?
- replacing catalyst/ how to
- Water Leak
- OH NO! we've seen this before.. driveshaft issue
- 2002 Audi A6 2.7T - Does it have TPMS??
- Leak from gearbox??
- FOG LIGHT
- Secondary Air Pump Issues
- New to me '02 A6 4.2 sporting a few issues
- Need help, A4 or A6?
- **Temp gauge overheat fluctuates**pls help
- radio antena problem 2002 a6 3.0 l
- Passenger door wont close all the way
- Door Panel removal 2002 A6
- any tips on adding viper paper alarm with remote start?
- Sticky lock!?
- ecu reflash for o2 sensors?
- Cluster Repair
- Need help with door speaker resonance, aftermarket speakers 2001 A6
- Anyone need new rotors?
- Hotchkis sway bars on a S-line...
- Front differential oil
- Looking for help with abnormal tire wear
- occasional starting problems.
- Are they the same?
- Lots of 2.7t questions
- Battery problem?
- V1 Hardwire Question
- 99 A6 Avant Rear Hatch Unlocking by ItSelf!
- 6sp transmission oil cooler hoses mix up...
- How to remove brake booster from brake pedal
- Fair value 2.7T
- 2.7t Maintenance Questions...
- Need Body Shop recomendation in Albany NY area
- Installing crankshaft locking pin on 2.7T.HELP!!
- having trouble removing flange bolts rear output
- Audi Bose stereo - concert 6 CD changer
- Timing belt service question + trip computer VAGCOM question
- rear output shaft seal ?
- 1998 A6 2.8L Drivetrain ANYONE NEED IT?
- Best way to remove lower control arms.
- Help prove the insurance adjuster wrong
- Antenna base gasket falling apart
- mileage indicator
- Hartmann Euromesh Wheel Question
- Oil opinions
- a6 2003 3.0
- Front Left lower rear CA replacement
- Turn Signal Stalk Replacement - Help
- o2 ghost code keeps haunting me
- replace suspension?
- Fail Safe Transmission Mode
- Scary Transmission Problem
- Oxygen sensor code after other work?
- Quality of Blauparts TB kit components???
- I have radio code but dont know how to enter,'99 A6
- '02 A6 4.2L Wheel Question
- High Pitched Squeel at startup?
- 2000 A6 2.8 Aftermarket Exhaust
- Tsunami warning for California
- I am about to kill wifes A6!! Heater hose split
- just for fun and off topic
- Power Steering Fluid Flush
- A good Audi Tech at last!!!
- C5 A6 4.2 to 2.7T Swap....thoughts?
- Need Help: Click and Pop , Steering Play
- when wheel full turn i get this shake studder?
- on board computer
- won't let me provide parts for TB replacement?
- SE vs. non-SE rs6 exhaust
- Just got back home from a LONG road trip.. VT to GA in 1 day, then back after a day..
- Pease Help w/ Coolant
- Changed outer CV boots, now loud cluck
- Chip upgrade on 2004 A6
- 99 A6 Brake warning light on dash
- Oil Temperature Sensor LOCATION - 99 2.8L
- transmission leak and central differential (i think) leak with pictures
- A6 4.2 Quattro Wheel and Tire options?
- OK, got the following codes, where do I start?
- Power Lumbar Broken? How To Access?
- Timing Belt Kits Question...
- A6 4.2L quattro still Overheating!!
- i got 04 audi a6 quattro
- local tristate gtg - October 10th, 2009
- Driver side wheel vibrations at 55 mph
- front lic. plate
- check engine light on
- 2001 A6 2.7T Wheel Fitment Question
- Transmision problem
- Well, what do you guys think about this????
- Light switch replacement
- New to the Audi thing :)
- 2001 2.7t timing belt change, guess how much?
- Noob: Looking to purchase an A6, but question on 2002 vs 2001
- Turbos Fried, Need Expert Opinion
- need car fax if anyone has a sec to run 1 number for me
- true lower 2002 chrome trimed grill will not fit my 99?
- looking for some info and pics of aftermarket truck spoilers please
- Help me diagnose this vibration/rumble
- Help, I need a pic of LCD cluster fading
- 2000 A6 V8 ECP and high rev on cold start
- is your 2.7 feeling like crap?
- Removing radiator hoses 2000 2.7T
- 2000 A6 4.2 Vibration
- light on display
- C5 Quattro Front suspension "Clunk"
- Oil leak trouble
- Wheels
- audi a6 1997 computer reboot
- where to find
- 99 Audi A6 odometer problem
- 6 Disc Bose CD player only plays # three CD
- Any 4.2 owners had leaking gas tank issues at all?
- Missing bolt in Front Suspension?
- Coolant bleeding procedure not working
- Too Much Pressure in S4 Cooling System?
- offset and spacers
- Just Bought a Used Audi -- Worried
- wanted to know more info on a s-line cars
- Both Rear Window Switches Not Working
- 2000 2.7T continues to run hot
- No Brakes? Replaced MS, Bleed, still... No Brakes
- 35mm offset enough?
- 02 S6 Avant 70,000 mile service - anything else that should be checked/replaced?
- WHAT SIDE IS B2 S2 O2 SENSOR
- Exhaust Flex Pipes
- Stereo decides to be difficult before a roadtrip tomorrow...
- filling tranny after filter change?
- C5 Avant Changing Rear Rotor Observation
- VAG 5053 sample arrived.!!
- Hoses on back of Intercooler - what are they?
- 2000/2001 A6 Avant vs. 2001-03 BMW 525i wagon
- Too much transmission fluid.
- What kind of gas mileage is your C5 gettin?
- REPLACE VEHICLE SPEED SENSOR IN A6
- Thoughts on the '01 A6 Avant
- Help!! Picking up new 06 A6 3.2
- 2001 A6 Avant !
- Problem with cold Multitronic?
- please help me and save me a headache.
- catalytic converter
- Cheap Blown Turbo Fix!!!
- Does it makes sense to have 16.7 mm offset rotors on a 2004 2.7?...
- 99 A6 won't start
- 98 A6 2.8 CD/RADIO Headunit
- Fog Grille
- Will 19" x 8.5 / 20mm offset wheels fit '03 A6 3.0?
- Trunk does not lock
- Pics of Turbo/Head on left side of engine
- Hsports for $350+ shipping
- iPhone 3Gs in our A6's
- Running Poorly
- From the "boy am I glad I can fix this myself" files...
- Cooling Fans?
- how to delete day time running lights on 99 2.8 canadian car?
- Hiss from back speakers...
- LATCH retrofit
- Navigation???
- 2003 RS6 Brembo brakes on 2003 S6?
- new A6 owner, help!
- Ack! P0431 and P0118 codes... Any ideas?
- Would you do it? Trade my '98 volvo V70R for an '03/'04 A6 wagon?
- Coolant Temp Sensor help!!
- Stumble then C E L
- lower front grille M.I.A.
- S6 Tranny Repair Options
- suspension
- 2002 aux coolant pump question
- S6 Avant with 90-100K miles
- am i missing sensor under backseat?(foto)
- Screeching/Grinding after lowering... wheel bearing?
- 2002+ 2.7 bi-turbo
- Possible new A6 owner...some q's.
- Turbos sending me to the Dentists, The first sign of turbo failure?
- wagcom code crash sensor
- is there any oem mudflaps around besides dealer?
- Ok. Keep it or trade it.
- A6 Understeer/ Suspension
- chatter noise underneath vehicle...
- High temperature on 2000 2.7T
- engine light shows on the dash
- Can someone identify
- 1998 A6 2.8 coolant temperature sensor
- woot. removing the amber strip and modding the headlights alittle
- 2003 A6 with 42k miles
- 2000 A6 2.8 Quattro manual fuel filter
- lots of wind noise from closed sunroof on 01...
- cluster light replacement
- Anyone tried this crazyness?
- combi valves + control valve.
- 99 a6 2.8 same filter as vw?
- 1998 A6 side mirror replacement
- 1998 A6 trunk problems
- Thermostat housing--aluminum vs. plastic
- Really odd power steering leak please help
- Some interesting vibrations in steering wheel??
- A6 Control Arm Torque Specs?
- A6 C5 transmission issues typical?
- Transmission problem
- 2001 A6 4.2L transmission problem...
- Need help with heater valve in 2005 Audi A6
- how to locate cigarette lighter fuse
- oil capacity?
- need oil capacity check please bentley not in till weds
- New Here Please Help
- 1998 A6 2.8L Auto Tranny Problems Leaking Fluid Bad
- WTB - Nose for 99 A6
- 1999 A6 w/ bad Alternator
- Random Hot Air in HVAC
- K04 turbos
- best rear rs6 rep trunk spoiler to buy from?
- 4.2 Owners - Tire Rack Closeout on Blizzaks $78
- PES Supercharger Free Install
- change stereo but 2 antenna?
- 18x7.5 or 8 oe 9 spoke wheels
- Heat coming in on high rev??
- How much i can get?
- Start up problems.....PLEASE HELP!!!!!
- :: ECS Tuning :: ECS C5 A6 2.7T / 2.8L / 3.0L Control Arm Kits - Free Shipping !!!
- :: ECS Tuning :: ECS C5 A6 Ultimate Timing Belt Kits - Free Shipping !!!
- Ideas For My 98 A6?
- 6 codes car starts then dies
- Need 3391 cam lock tool in N. Va
- 2000 A6 2.7T WONT START WHEN RAINING?
- Radio Static After Turning On Rear Defroster
- Control Arm Kit (S6)- who sells a good one?
- Who wants/needs a VAG 5053?
- Vibration diagnostic
- Should i chip it....
- What's the easiest way to get at the thermostat?
- Tie Rod End and Control Arms Boot
- Tires for 18" wheels ( 235x45x18 or 235x40x18)
- please help with downpipes for allroad
- taking my car in before winter
