- A6 (C5) Buyer's Guide?
- 2002 A6 3.0 Stalls
- Original A/C compressor manufacturer
- New to Audi! Need help!!!
- Comfort Module problem
- What are the most valuable parts on an A6 sedan
- Tuning chip for 2.7t
- New Member, A6 Project Car, Advice sought
- 02 audi A6 4.2
- Battery Drain - Cause?
- timing belt, chain valve tensioner c. 5-8
- Beautiful S6 Avant blew up
- Safety Recall 69P1 - Head Curtain Airbag Canister Certain 2011-2017 Year Audi Q5
- PCV valve
- 17 short to ground fault codes
- Audi A6 C4 1996 Radiator Fan Failure
- OBDeleven
- No Start issue
- Strange noise under car
- HVAC Problem
- 1995 A6 2.8 Quattro new purchase
- Rear door not opening
- 00796 - Fan for Interior Temp Sensor (V42)
- Boost leak or bad turbo?
- 2000 a4 quattro
- Timing or Sensors?
- how to find the key code
- Leva bloccata
- 2004 Audi A6 C5 3ltr S-Line rear coilovers replacement
- Video Captures of my 1997 Audi A6 C5
- Break Light
- 2004 Audi A6 C5 3ltr water leaking
- 2001 Audi A6 4.2 Headlight issue! PLEASE HELP!
- Turning signal wire diagram??
- Adjust handbrake
- what is audi symphony?
- Audi water spilling??
- Why won't A6 start when engine is warm?
- verifying after run coolant pump function
- black smoke and lost of power
- how do I disable the alarm siren on my 2004 audi s4?
- CLUTCH
- Is mine a C5?
- AVUS wheels on my S6
- My 2002 Audi A6 4.2
- Audi a6 4b5 quattro or not
- Refresh/maintain a 98 Avant for my daughter
- ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - Aug 28th - Sept 4th, 2017***
- Waterleak on passenger side
- Which oil leak is this?
- Secondary electrical fan not running
- Cost for 2001 A6 4.2 fender repair?
- ART Variant 4.2 V8 Timing Belt Change Blues -- Two Questions
- :: ECS Tuning :: ECS Lightweight Pulley Set 2.7T
- radio code
- Burning of Comfort Control Module of Audi A6 2000 model.Ref. No: 4BO 962 258D.
- anyone see this problem before
- Beast broke the spring...
- 1995 A6 Wagon Will Not Go Forward
- No Reading for Cat (46 Vag Com)
- Looking for parts
- 01 A6 C5 4.2 Exhaust System - No Cat
- C5 2.8l exhaust options
- Tracking Down Oil Leaks 2.7t
- Climate control blower motor
- Headrest will not go down
- can a fob be programmed to roll windows down on a 2014 audi allroad?
- want to bleed cooling system
- Topping off A/C refrigerant
- 2001 A6
- A4 2016 TFSI - winter white smoke
- Tcm location
- 2003 A6 Avante HID clip / ring is missing :(
- solar sunroof
- big boost leak
- No power to turn signals fuse N2
- AC questions: 1999 A6 quattro 250,000 miles
- Oil Temp Gauge Not Working...
- CHECK ENGINE LIGHT SIGN ON
- Audi 2003 a6 avant front control arm replacement
- Fasten power steering cooler coil
- 99 Audi A6 Quatro cam position sensor interuptor
- OBD Scanner
- 04 Audi A6 Rear window shatters when rear defrost it put on
- Worn springs?
- Audi A6 C5 2000 instrument cluster fire
- My A6 C5 presentation
- 04 A6 Rear passenger window tilts backward
- 04 A6 washer pump location
- The cds are stuck in my changer how can i remove them?
- Oil licking somewhere from engine
- Coil time; 2000 2.7T.
- smoking engine
- 2004 C5 A6 2.7t s-line 19" wheel upgrade
- A6 Avant 2.7 Quattro
- #1 Cylinder Spark Plug Blows Out. '99 2.8 Avant
- NO Tiptronic C5/A6 2.8L Quattro
- P1426 CEL but N80 valve seems OK
- Random misfires HELP!
- Alignment or tie rod end job affect cv joint?
- A/C not cooling the blower air circulation is perfect.
- 2014 A6 TDI stuck in M1 Mode?
- Pulling off
- Differences between tiptronic transmissions?
- New stereo install on my 2002 A6 4.2
- Sedan doors on wagon?
- A6 1996 quatro wagon springs compatibility please help
- 3.0 engine misfires (bank 2) - timing issues?
- dash lights ?
- Suspension for 2002 C5 S6 Avant
- 2.7t Valve cover gasket procedure
- cleaning combi valves
- can i put in a n on audi stereo with bluetooth and sdst nav and will it work with my
- boost leak miss issue
- 2000 Avant - Driver Seat Bottom, Melange Leather
- Does Audi do PPI's and what's the average cost?
- Just got a $500 3.0L A6
- what is this part of steering/suspension
- a6 swap 4.2l to 2.7
- Brake fluid leak?
- Best h1 replacement.
- 2004 A6 3.0
- My review of ECS Tuning
- Replace C5 2.7 turbo standard shift with...
- Just got a $500 '98 A6, no compression
- audi A6 2,4 v6 front light
- A6 2.5 TDI Fan Control Module
- I think it's the AC compressor, AC troubleshoot
- Central Locking Module
- Radio issue
- Where to locate the microphone
- Audi A6 (C5) 2002 3.0 Issues
- Crank sensor
- 2002 S6 Avant a beauty for sale
- EOBD code reader no go on my A6
- 2015 A6 Quattro F/R Brake replacement recommendations
- Power steering column swap possible?
- Gear box drain plug removal
- 2005 audi s4 bent valve ?
- outputshaft(driveshaft) bolt removal
- Instrument cluster code 1179
- 2003 A6 2.7t Auto part out
- Engine code contradicts my information
- AC!!!AC!!!AC!!?
- Tale of my Avant
- Strange Parking aid system problem
- Audi C5 A6 4.2 V8 Camshafts and Sprockets -- Overview
- Help!!!What's wrong wit my car?
- Need to get rid of car
- 03 A6 Quattro Audi Doors wont open at all... even unlocked
- Alternator problem?
- Tail pipes have dropped-4.2L
- RH fender liner for 2002 S6...$20+ shipping
- C5 allroad/S6/Avant cargo cover $200+
- FIVE C5 S6 Avus 17" rims with new Conti DW 255/40-17 tires.
- ?does an 3.o A6 avant and sedan use the same front bumper covers??
- Audi C5 jacking points
- Best choice for display module
- Stumble on deceleration
- C5 A6 4.2 engine tick (video included)
- 2004 A6 2.7T Q power steering fluid
- rear fog light cover crack
- 2001 A6 2.8 sounds like a diesel
- S4 B7 4.2 into a S4 B5..
- Drivers Side Rear Window Issue
- B5 passat v6 4mo tip to 1.8t 4m manual swap
- 2001 Audi A6 drivers door lock cylinder spring
- How to not Pinch a Valve Body Wire and Dent the Oil Pan on a ZF 5HP-24A so it Leaks
- Running car with oil too low
- Cluelessly Reading a Bentley Wiring Diagram
- Q7 noisie problem
- Big problem after automatic transmission swap
- Is this noise normal on a A6?
- Manifold Lever Connection to Runner Flap
- Check Engine Light and "Add Oil"
- Can You Help Me Find These Parts?
- 2011 Q5 Audi SUV 2.0t
- problems hot starting
- Light Throttle Hesitation
- ac condenser removal
- A6... got cheep, now o see why
- auxi pump
- Driver's Seat Help
- Windows, Power locks, and Interior lights not working
- Audi A4 Ambition 1.8 T: Remote roll down/up of windows
- 2004 A6 S-Line 2.7t quattro secondary air system
- FUSE shows in instrument cluster and the volt meter stopped working.
- This car is F'en Evil! Now, oil leak :(
- Audi a6 3.0l 2003 camshaft help needed
- Rescuing Almost-Dead C5 Audi A6 4.2 V8 Cars
- New Alternator @ 247,845 miles
- Back-up Sonar Failur and Alarm on 2002 Audi A6 Quattro 4.2L
- 2002 Audi TT QUATTRO ALMS
- 1997 A6 automatic tranny slipping in D
- Temperature gauge malfunction
- 2.7 T A-6 Turbo replacement
- increase fuel efficiency 2004 A6 2.7TQ
- cheap parts
- Head Gasket replacement
- Mobility Vehicle- Not For Retail Sale
- Airbag
- AUDI A6 3.0 UNIDENTIFIED BUTTON FUNCTION
- leaking valve cover gasket question
- audi a6 avant y reg
- Alternator Problems/Questions: Please Help! @ 247,841 miles
- Intercooler shrouds removed
- Audi C5 Auto Dim Mirror
- Under carriage engine oil pan wash???
- Turbo
- PLEASE HELP
- Radio locked in SAFE mode - 2001 A6
- Steven
- Windsreen steaming up
- Brake light issue. Please help 07 a6 4.2 v8
- Comfort Control Module questions
- Audi s6 c5 MAF Connector
- What do these tubes connect to?? They're just hanging their and it doesnt seem right
- Opinions on buying this low mile S6?
- owner of A6 V6 30 valve
- 2002 Audi A6 help!!!
- 1999 A6 2.8 & 2002 A6 3.0
- A6 Coolant leak
- A6 Coolant leak
- Main Fan jammed!!!!
- k line init failed
- 2001 2.7t OEM firmware/ECU updates?
- Help finding the right alternator
- Hard-Earned (not by me) Pictures of my Silver 2000 A6 Quatto 4.2 V8
- '01 A6 headlight problems
- S6 C5 ANK coolant hose leak - need MPN!
- I asked earlier today....about a 2002 S6 with 158XXX miles on it....
- 99 a6 wont start
- Help! I need somebody Help! Not just anybody! Help! Obd2 info
- Deal on an S6 Avant 158XXX miles...?
- Help a fella out please 2003 a6 quattro 4.2 timing
- C5: Engine oil light
- Front wing (fender?) removal A6 Allroad C5
- test instrument cluster without tester?
- Repair Manual: Where from?
- Quirks with a recent purchase 2004 2.7t S-line
- C5 A6 Quattro 4.2 V8 Fuel Lines Mixed Up -- How to Test
- A/C performance and heat issue...
- Oil cooler Pipe 2005 audi a8 base
- Audi A6 3.0 Quattro skid plate
- Just bought 03' A6 3.0. Need some help!
- Red oil can dummy light from hell
- Audi A6 Quattro 4.2 V8 Air conditioning reality check request, and some questions
- overheating oil in the radiator
