- 1998 a6 2.5 td codes?
- I'd like some opinions on my overheating problem
- can i see some 2.8s with rs6 wheels 5 spoke or the multispoke
- Signal light issue - Can any one help?
- Servotronic Boost Relay wanted
- Cat converters are causing the engine
- Bose Sound System
- Positions of Cylinders
- 2004 Audi A6 W12
- I know this is crazy and wrong but...
- Wahoo! New brakes, oil change.. Happy car!
- Need Help
- Hella Headlight Turn Signal Bulb
- Will running different wheel diameters damage quattro transmission?
- 2001 A6 avant headers
- 98 a6 130k 2.8, hard start, replaced ect and everything ok..
- Daytime running lights conversion
- PES G2 Supercharger for the 2.8
- Wheel repair/refinishing experience?
- Another coolant leak ?: what are possible sources based on the puddle location...?
- MPG Averages
- 2.7T Model changes from 00 through 02
- AUdi 99 mirrors
- 8 DTC codes... Help!
- positive side battery cable..
- A.W.E. releases Gen2 downpipes with massive price drop!
- Can't program my new key
- Front end squeaks, but no visible wear, no play
- Help with bumper part # 4B5 807 511 D
- 19x8 et30 on 2.8 quattro avant
- Help - Car wont start
- Best Aftermarket CD Player and
- Help! I'm always bottoming out!
- 2002 S6 Avant for sale - moro blue/light grey, 79K
- Power Dilema
- Combi valve & Secondary air injection
- Heavy Sputtering - '02 A6 2.7T
- Pictures of 18" or 19" rims? BBS CH?
- 0000 0001 Readiness, whats wrong?
- Anyone wanna sell their exhaust
- Where did everyone go?
- I have a friend who is buying a set of Size: 17x7.5" Bolt Pattern: 5x112mm Offset: 45
- Vag-Com help, or "Help, I'm melting"
- Anyone buy from discountoxygensensor.com?
- I have a small rust spot on my right front door.
- Very Slow Coolant Leak..
- where to get a catalytic convertor?
- Coolant temp light on briefly only after sitting?
- Has anyone used these
- HELP! trading my 02 A6 and found...
- Can I get a free CARFAX anywhere?
- No high beams, turn signals, fog lights
- Cylinder Open Circuits
- Xenon Light Assembly needed
- 605 servotronic mod problem, odity
- Check Engine Light -
- TCM, "Limp Mode" Problems...Help!
- BBA reman clusterpox repair review
- 2001 A6 Radio Antenna booster?
- Help With Tip
- Indy shop/person in Orange County..
- Help and Recommendation needed
- battery cable replacement...
- Would this wheels fit on my non-sport 2000 2.7T?
- Battery light ... strange smell....help.
- Frustrated with site Oil change help
- 00 a6 2.7 ecu
- Sirius Wires For Navigation???
- Check the home page; re: Jason Teller
- whining while turning steering wheel
- Selling/Trading my 02 A6 2.7t Sport (68k miles)
- 2000 A6 recommended brakes
- What is the best oil for a 2000 A6 4.2l...
- Help - BBS RIM size QUESTION
- Is it my car or al the A6 sit just a tiny bit lower at the rear?
- Anyone with KONIs on the A6?
- Pulled a Tommy Boy
- A6 2.7T Secondary Air Injection System Insufficient Flow (P1423 & P1411 codes)
- Doing the timing belt on my MY2000 A6 2.8 ...
- How do you know if you have Leather or Leatherette
- was there a year to avoid when looking for a 4.2 (tranny probs?)
- Which size spacers for stock et45 wheels?
- after market parts
- Help! My 2001 4.2 gets 250miles to a tank!
- 2001 A6 - Polyeuratheyn Mounts
- Overstock TRE Sale!
- how many km can u do on a tank 4.2 and 2.8 guys please post
- Question about MPG and Fuel on a 4.2L
- Pls help, where to buy rubber molding around headlights
- 2001 Audi A6 "POWER WINDOW ISSUE" HELP!
- Coolant system malfuction
- Small spot of Coolant on Garage floor
- Price Opinions
- misfire cylinder 5
- Help! Low Compression 1-3
- Battery Charging Issue?
- S5 Wheels on C5 A6: XPost from Wheels and Tires Forum
- rear brake change problem. Flat brake..
- New buyer eyeing silver 2K A6 4.2 with extras
- Car vibration issue with new aftermarket rims
- 2001 A6 automatic tranny tiptronic 5sp reverse only slips
- front bumper flippers
- Remote start A6 Quattro
- HELP ME PLEASE!!!!!!!
- Northeast A6 owners........
- I love my car...its just the little things...
- A6 Navigation
- c5 a6 2.7t boost gauge solutions
- Both Front door lock need adjustment
- Handbrake cable seized
- RNS-E navigation with Sirius module, RS6 pedals, and RS6 seats all for sale in...
- symphony one to Rns-d
- Secondary Air Pump
- alternator question.
- C5s selling well below KBB value??
- Low beam/blinker issue
- Had a momentary flashing CEL... any thoughts
- is A6 Towbar the same as VW Passat
- Exhaust clip... *FINALLY*
- 2.7T A6 FROM 2000 EPC LIGHT ON CAR IN LIMP MODE ANY SUGESTIONS
- why shouldn't I use the X-pipe with my set up?......
- differences thru the years 2.8 models
- First Post, First Pics - My new 4.2
- 2006 A6 Reliable?
- GIAC Tip Chip for '99
- Slipping tranny
- New headlight for 01 Audi A6 2.7T
- Radiator Leak
- Where to buy timing belt and transmission fluid kit?
- Need Your Help (RS6 Wheels vs)
- custom magnaflow exhaust
- Help "Steering Rack"
- Bilstein Struts for 1999 A6 quattro
- wire color for brake pad light
- Alarm did not go off during entire wheel swap task...
- How to get to this switch
- Egnine mis-fire (even at the idle)
- california 2.7t just shipped to n.y.
- need mods advice for the 2.7 i just got
- Nav extension cable...pull the headliner?
- What are differentials?
- Thinking about buying...
- About to buy an A6 2.7T Quattro
- 2001 a6
- i find with my s6 i get so much exhaust moisture on my hatch...
- Audi A6
- 00 A6 Avant-need help replacing liftgate lifters
- Folding o/s mirror issue
- 2000 A6 4.2 Quattro Purchase Advice
- boost issue?
- anyone want a brand new lower control arm
- A6/S6/RS6 Speedometer Question
- Kumho SPT's. Not bad for the money.
- Discount on euro synthetic oils
- Two 2002 S6's for sale (silver 62K mi, blue 78K mi)
- Help! High pitched low volume sound coming from engine
- happy easter everyone....
- Semi OT.. Got a new Impact gun.. From home depot.. [photo added]
- Finally Some Good News on Good Friday/Passover
- Stuck with dash lights on, car won't start/turn off
- Cam Adjuster Seal Help
- 2000 a6 calipers? advice on seating piston
- Engine Rattle
- 6 spd trans problems
- my registration crashed with this new beta
- 2001 A6 4.2 Auto Window & Roof Vag Com Code
- ABS and ESP lights both lit.. no brake warnings, no beeps, no CEL's
- Car alarm--Audi 2000 A6
- 255-40-17 on S4 wheels, on A6 2.8Q narrow body. Works?
- Here's A Little Bunny Humor for Easter - I want you all to do this with your A6!:)
- How can I clean out the motor?
- 2001 A6 rear sunroof drains?
- Waterpump blew @<30k - had to replace fast..
- Has anyone had any success with this repair manual?
- is there a write-up for DIY timing belt on a 4.2?
- New Tires for 2005 A6
- ABS and Brake Lights are both on
- A6 2.8 yellow goop while changing the oil
- what specialty tools do i need for a timing belt change on a s6?
- 1999 a6 2.8 Q immediate help please....
- O2 sensors
- Eurotech Wheels...Audi 630 style wheel...
- APR chip experience in A6 2.7T tip
- Need feedback on which type of suspension set up to go with..
- 1999 A6 cluster for sale?
- Dashboard Display went out? Help?
- good race against a white A6 2.7T on I-96.....
- Tiptronic
- Need Help, Wont Start
- Special Tools
- Airbag Light Still on after Airbag Control Module was Replaced
- where to buy timing belt kit? ecs or blauparts?
- bumper bolt
- Anyone replace a knock sensor before?
- My gauge cluster shows MPG instead of miles to empty. How to change it?
- 2.8 Flex Pipe
- Flex Pipe 2.8
- Engine misfiring, oil on spark plug electrode 99 A 6
- Thanks to Module Master, my cluster LCD (DIS) is repaired...
- Avant 3rd Row Seat
- Chrome Exhaust Tips on a 99 2.8
- How do I get the fog lihts to be day time running lights
- 01E 6 speed Manual transmission
- ESP Problems on 02 2.7t A6
- Best Way to Clean Headlights
- The *most* annoying power steering rack creak when steering from left to right
- Anyone ever managed to take the trunk chrome lip off intact?
- Anyone ever run S4 springs up front?
- I hate pinch bolts...why?
- 99 A6 Avant Engine Swap
- What’s with the AW clock? GMT or Betriebsanleitung?
- coolant tank not holding pressure...
- Will removing 605 relay affect the whole power steer mechanism?
- p0421 and mileage. Piggie effort worh it? (poll)
- Bilsteins for an early-2000 A6 2.7TQ
- Need to drain gas tank
- Think paint is expensive?
- Updated Europrice Sale - STaSIS Engineering Parts 10-15% off...
- OT--- Happy Birthday April/Verdegrrl!
- A6 3.0 'Limited Edition'?
- 1-2 Shift collar issue?
- Should I be scared or feel lucky?
- Did Audi make an A6 S line with a 3.0?
- Someone in the DFW with a Vag-com?
- Cheapest shocks replacement? Someone's got some for sale?
- CEL - again after fitting a new primary O2 sensor....
- Shock advice for 99 A6 Avant.
- Brakes are engaged and won't let go!!
- ok bout to give up...how do i get the rear bumper off???
- Is there a way to change the fluid in the torque converter?
- 2000 A6 2.7T headlights wandering....
- Woohooo! My first search attempt on vB.
- Temperature Sensor Confusion
- 6MT 2.7T 2000 A6 Quattro Trans Gear Sets?
- Silver A6 C5 witha black roof....
- Trying to change an alternator on a 2002 A6, typically how long does it take
- clutch slipping only on take off
- New Stern Pro-Mount Motor Mount Presale Ends Today!
- 2001 A6 Rim options
- Quick Q, has been bugging me
- New 2003 A6 3.0 owner, few questions
- Just passed 180,000 on the clock tonight
- PSA: Garmin GPS 45 LCD doesn't work on our clusters
- What does your telescoping steering wheel do when you shut off the car?
- Finance Rates for A6: What Gives?
- What is the going rate for a RS6 steering wheel...
- The new look of A6 C5 model.
- 2001 A6 - window control lockout button stuck in "lockout" mode
- Thoughts on overheating engine?
