- Please provide link where i can order correct valves cant seem to find the right size
- 2003 A6 3.0L Rev in all 5 gears
- Fan fuses
- Assistance needed! Car sluggish from the start
- Motor Oil 02 A6 3.0
- 2004 A8 lose power after warm
- 2000 C5 A6 2.8 Intermittent Dash/Climate Control Failure
- A6 C5 2000 dashboard bloated
- Odometer quit working
- No heat at all and its the middle of winter
- my audi a3 2006 key remote not letting down my window anymore
- Kindly requesting help! Audi A6 3.0 2005, cant turn on after reconnecting the battery
- new FCM & still overheating
- 2.8 Alternator replacement from underside?
- Urgent help Need
- Replacing interior fuse box
- looking for insight on doing EVAP leak test with smoke
- Notchy gear shift
- Keep Blowing the fuse #14
- Burning Smell coming from air vents
- How to fit the viscous fan?
- Windows / Central Lock / Alarm / Interior lights problem
- Valve size for a6 v6 30 valve 2.8? Aha motor code.
- 2010 S5 Audi outside temperature sensor
- Quattro and different sized rims
- A6 1.8t to 2.7t engine swap
- Accessing fan control module
- My rear biew mirror fell off while I was cleaning windscreen.
- 2006 a6 3.2 engine swap?
- Helping a friend of mine with swapping seats and running into issues, help?
- P1392 code
- Air conditioning vent problems
- Fuel Consumption constantly rising when stopped
- Need help deciding what service to do
- fuel pump fuse
- Interior lighting electrical problem
- CVT Service
- AUDI Q7, 4.2, 2007
- Clutch replacement saga
- 2003 Audi a6 3.0 CVT transmision slams when coming to a stop
- 2001 Audi A6 2.8L
- Audi A6 2003 Repair Manual
- Headliner Reupholster?
- Rotorlab 17Z kit installed on the allroad!
- ***WannabeRacer.com | Norcal/Bay Area Vinyl Wrapping Tour - July 30th - Aug 3rd 2018*
- concert stereo bose
- A4 wheels on an A6: rubbing issue
- Possible transmission issue
- Replacing coils and plugs 2001 Audi A6 4.2
- Timing chain help
- C5 Central Locking/CCM Parasitic Drain
- C5 RS6 parts that fit on an A6
- 2001 audi allroad 2.7
- Dang Door Strip!
- C5 Avant Third Brake Light Intermittent
- New to A6 Quattro
- 2007 A6 3.2- code P2007 (not vacuum)
- Audi S6 manual upgrade help
- new bosch rear 02 sensors don't work
- 2005 Audi A6 4.2 Engine Noise
- 4 Amber waring lights on at same time A6
- gearbox module location for 2005 A6 3.2 fst quattro
- 99 audi not nunning right after sitting without battery
- 2005 Audi A6
- P1848 fault code, abs ESP Lights on.
- Replacing brake servo and MC
- 2009 audi tt electrical issues
- Audi A6 strange electric fault
- New Audi owner! I finally pulled the trigger!
- 02 allroad missing subframe bolt and spacer
- I have A 2001 allroad That won't start
- '98 a6 2.8 a/c compressor bracket
- 2011 audi A6 avant 4F C6 wiper motor not working
- How to drain gas from 1999 A6 quattro
- 2004 audi a6 quattro wont start
- What dose this mean?
- Smoking clutch
- Oil and temp warning light
- How to drain freon and depressurize air condenser?
- Sluggish MMI, audio cuts out every few seconds
- Long block swap
- AC relay or other issue. Where and who is it?
- 2002 audi a6 avant
- DMC III - Microphone not working
- bigger turbo for mk1
- Having trouble with Lucas floating calipers on an A6
- AUDI 2003 A6 S-Line ABS BUS no communication
- Replacing strut shocks
- S6: Muffler delete without drone?
- Should an oil be added to A/C system after full freon recovery?
- REcommondations on Swaybay for 2001 A6
- 2.7t BES pre-cat o2 wiring to ECU replacement
- Transmission Oil Pump Clearance
- New 2.5 TDI embarking on European Adventure
- Anybody got a pdf og the manual 1999-04 mod?
- 3.0 Timing issue!
- A follow up on "40V Intake manifold fix for stuck or sluggish flap pivots"
- AC issues even when freon is fully charged
- relay location
- Starting/Eletrical Issues
- Febi control arm creak when warm
- Coolant leak form left side of engine
- Secondary air injection cleaning
- Audi A6 2001 Tiptronic TDI Wiring issue.
- C5 Avant Headliner Differences
- 2010 A6 starting problems
- Turbo Pre-install
- ABS and YAW sensor codes???
- Thinking Blower Motor Failed
- Voltage Meter in cluster not working
- Pressure switch code problem 00819-30.00
- locked
- Not sure how to address Error Code P0322
- Code Help, Please
- S6 ANK Aux fan problem, no ideas left
- C5 A6 Quattro 2.8L Auto Transmission Limp Mode No Crank
- “A” camshaft position actuator circuit p0020
- 2002 A6 Avant 3.0 Starting Issues
- Audi a6 c5 1999 model Abs module
- Problem with auto gearbox.
- For sale. Five 20” wheels by Hartmann.
- A6 Air suspsension (self-levelling) removal advice
- Brighter D1s/2s/3s Xenon Bulbs | Front Turns | Error Free Reverse LEDs
- Stuck in 4 the gear only after put in reverse
- 2001 Audi A6 not starting
- Idle drops momentarily once warm
- 03 C5 RS6 interior light issues and more-please help
- Need to replace an 01 a6 2.8 ECU
- Price for Alternator Belt
- 200,000 miles on 2002 A6 4.2
- Transmision
- ABS Module question
- Powersteering pump going at full speed?
- A6 C5 Avant with A8 wheels?
- Intake Manifold 2001 A6 C5 4.2 V8
- Whining/howling tiptronic...sounds like an unhappy wife!
- Fault codes - white smoke
- getAudiparts.com | Genuine Audi LED Puddle Lights Sets!
- Bosch 5.7 ABS module coding w/ Foxwell NT510 VAGCOM
- MFSW heated Retrofit A6 C5
- getAudiparts.com | Genuine OEM Audi Parts + FREE SHIPPING on Most Orders $299+!!!
- A6 2001 2.7t engine shaking
- Random multiple misfire
- No start
- S6 Driver side bank not firing
- Help me Tune My Audi A6 c5 2.7t Quattro 2002
- Checking in ... life, and 2000 A6 Quattro 4.2 ownership
- 2003 RS6 Fob button help
- '08 4.2 Engine Speed Sensor location
- stage 3 a6 2.7 really rich.
- O2 sensor sinmulators...
- 2000 A6 4.2 Wheels
- 2001 audi a6 quattro biturbo wont start
- Seat Swap Advice
- Seat Swap Advice
- Electrical issue, wipers, sunroof, HELP!!!
- getAudiparts.com | Give a little TLC: Genuine Audi Car Care Products!!!
- 2002 Audi A6 3.0L Hard Start Issue & Coolant Leak HELP!
- can the ECM be programmed with VCDS to ignore O2 sensor 2
- G40 n 17880 EVAP short to ground
- Transmission problems
- Help 2002 A6 Quattro v8
- Help
- A6 C5 Avant Exhaust From Single Pipe To Twin
- Making the front more mean.
- Brake pedal goes to the floor. Why?
- Interior Lights.....beating dead horse.....a mystery.
- Tried Snake oil for 2.7 oil consumption issues
- Headlights Xenon A6 Quattro 4.2 V8 - Replace
- getAudiparts.com | Got Fluids? Shop Genuine Audi Fluids!!!
- Output speed sensor
- Windshield wiper trouble 2003 Audi A6 Avant 1,8T
- Technical Tips for A6 (C5 Platform) 1997-2004
- Key fobs not working and won't reprogramme
- I need some basic assistance with my A6 Quattro 2.7L Turbo!
- Engine Swap into a C5 Wide body
- C5 4.2 Transmission Issues Advice/ Insight
- battery change out not possible
- Replaced Heater Core Hose - Now have Radiator Leak
- A6 Front End Cover Bra
- Limp mode
- Audi MMI Connect Android App
- Diff from B6 or B7 to C5
- Stereo auto off question
- Audi A6 TDI 2014 Catalytic converter
- Need turbo purchase suggestions please
- A6 Fan Trouble
- Need new driver seat for a 2000 a6
- Instrument cluster repair...
- Are seats from 2002 2.7 A6 interchangeable with 1999 2.8 A6?
- Audi A6 won’t shift from park, brake lights work. TCM?
- Boost leak or plugged cats
- Brake pedal.. fine one day, to the floor the next
- Audi A6 1.9TDI won’t set off smoothly
- 6MT Conversion, 2002 S6 ahhhhh yeah!
- '98 A6 & '99 A4 automatic transmissions same?
- Replacing Ignition switch 2003 A6 - ?computer reset?
- power steering doing wierd things
- Loved my RS6, like my new S8 a bit more!
- Transmission issues or ECU
- Audi S6 C5 4.2i manual transsmision conversion
- Terrible sound coming from engine (2.7T) with videos
- Help haunted odometer
- steering clunk not rack
- While braking the ac turns on.
- S6 Avant body question
- Touchy Throttle?
- Valve cover stuck
- Strange problem with central locking and remote key adoptation - Audi A6 C5 2003
- facelift after 2000
- Powering my house with my C5
- Fuel Pump Mystery....
- 2003 DIS
- Car wont start
- How to properly torque Control Arms???
- Roof antenna
- Sound and sensation of something slipping wheel attake pff.
- Fuel Injectors seals and rings
- A6 HAS A VERY VERY BIG PROBLEM
- Cam sensor
- 2003 6MT A6 Quattro wont shift into reverse! And clutch issues.
- Help meee!! Crankshaft problem
- 2000 4.2Q got hit, parts question & is it worth the battle?
- Open Hose Question
- flexipipes blown off
- Tuning C5 A6 Self Tuning
- 2017 S6
- whats causing this tire damage?
- Rust?
- Gremlins???
- Camshaft tensioner solenoid/valve seals?
- oil cooler water supply line replacement
- Need beer and garage space
- 2003 audi a6 interchangeable body panels
- New "short" fuse 15 blows, "fuse" over odometer, Battery Icon
- Catalytic Converter Questions
- A6 C5 Avant 402 mod
- Timing Belt- Major Question!!!!!
- Rear window heater, lights and central lock problem at same time
- rough idle
- ABS and ESC lights intermitant
- 04 allroad abs esp lights on and break light blinks\
- where is it?
- Shuddering around 20-30MPH
- How to access the secondary air pumps relays/fuses
- Is it just gremlins?
- The vehicle went off several times
