- How do you tell if you need new struts - front tire wear issue?
- Valve train noise, worried!
- :: ECS Tuning :: C5 A6 2.8L Avant Rear Aero Wiper Conversion Kit
- Transmission fluid leaking... now what?
- 2008 S6 Front License Plate Bracket
- '01 A6 2.8 No start
- Four new errors...
- Where do you get your coil packs
- ABS Speed Sensor - Error
- cam belt replacement
- Airbag Fault - Yet another thread ...
- goodbye to all
- Coolant Temp Sensor Stuck. Ideas???
- Worn Climate Buttons
- Received my Ebay Vag
- Key won't start car.
- mirror switch?
- car wont start please help!
- Tiptronic Use
- Need Help Getting Rear Seat Cup Holders Out
- Car idles rough, usually dies after startup (I have VCDS codes)
- Electrical (Sensor?) Cable disconnected/cut.
- 00 4.2 for sale
- Front Passenger Axle Symptoms?
- C5 A6 2.7T w/ 170K Miles...To Rebuild or Not?
- HVAC keeps changing to Centigrade
- need passenger side mirror
- Singleframe bumper conversion
- :: ECS Tuning :: C5 A6 2.7T ST Performance Coilovers - $100 Mail In Rebate!!
- 2003 AR - door not closing
- New steering rack fitted, all assistance left, hardly any right??
- S6 Owner's manual
- A6 4.2 Oil Cooler
- BLAQUE DIAMOND WHEELS || 2013 A5 on BD-4's
- S6 no AM radio reception
- Turn signal issue
- :: ECS Tuning :: C5 A6 Ziza Interior LED Lighting Kits
- Corner with confidence. Special pricing on H&R Sway Bars from AWE Tuning.
- AC, headlights, turn signals, wipers all stopped working
- Difficulty Getting into 1st Gear
- An Alternator puzzler
- aux pump and oil leaks
- MPG and other stuff
- 2000 A6 2.7 Quattro Biturbo shuddering
- ignition key won't release?
- ABS Active when stopping
- How do I achieve a more aggressive shift?
- Time for new exhaust
- :: ECS Tuning :: C5 A6 Borg Warner K04 Turbocharges With Installation Kit
- 2.7T no second gear.. help!
- New C5 3.0 owner...
- :: ECS Tuning :: C5 A6 4.2L Blind Spot Mirrors
- BLAQUE DIAMOND WHEELS || New 2014 Collection
- Troubleshooting A6 C5 Cruise Control
- SPC Arms
- **Don Nguyen | Gloss Black Vinyl Roof Installed - White Audi RS7 Sedan**
- Removing plugs from the CCM
- 3.0 asn fault code 17522
- s-line with fat five wheels?
- 99 2.8L a6 overheating problem!!!!no leaks
- Should I proceed?
- My new Borla Catback (Video)
- transmission won't go forward
- Opinions needed
- New downpipe for c5 tiptronic finially
- **Don Nguyen | 3M Dinoc Matte Carbon Fiber - Wrapped Interior Trim**
- 2004 A6 Symphony not working
- So, What's going on here…. ODB Codes & Battery / fan issues a month later..
- I see two fasteners on the timing belt tensioner pulley/assembly, which to remove?
- Lower radiator hose won't budge, stuck to radiator?
- o2 spacers?
- Wheel tire combo
- 2003 A6 Avant "drivers open door" sign not working
- Power Steering
- :: ECS Tuning :: C5 A6 H&R Sway Bars
- 02 A6 quattro 3.0 water on passenger side
- 2001 A6 transmision
- 2002 2.7T - ATE FNR-G60 Front Brakes Retaining Spring (Clip) How To Remove/Replace
- No CEL... Finally!
- spider hose issues 3.0 asn
- Rear drivers side suspension griding noise.
- Coolant in wire harness
- 02 A6 C5 3.0 Engine Failure - part-out or sell?
- I'm changing motor and tranny mounts this weekend, any DIY procedure will be helpful.
- Oil and coolant temperatures 3.0 30v
- Centering Pins Dowels
- what happened to format
- Newbie with tranny question
- Rubber Plugs A6 ZF5hp19FLA Transmission
- 1.5 litres and I still have a mushy brake pedal
- Intake runner vacuum diaphragm/bellows/actuator/etc info
- Got the interface and VCDS-Lite. Won't communicate with my car...
- Extended maintenance schedule? Getting tired of "fix it when it breaks."
- A/T low voltage input
- well I'm back :0)
- Does this timing belt look old?
- Transmission leak??
- Check Engine Light - Three Codes Displayed
- Need some control arm help
- Water pump leaking, cam tensioner in trouble
- 2001 Audi A6 cabin air filter location
- Best way to test 2.8 engine and trans mounts.
- Reduced Power - Lots of codes --- Help!
- :: ECS Tuning :: C5 A6 2.7T APR Spring Sale!!
- best source & price for O2 sensors
- Let's get low with H&R. Spring Fling starts now, at AWE Tuning.
- It is ALWAYS one bolt
- Exhaust Manifold A6 Quattro 2004
- secondary air injection
- Does this look like an oil pan gasket leak?
- O2 Sensor Fix Gone Bad...
- :: ECS Tuning :: C5 A6 30v V6 Timing Belt Kits!
- Vacuum Leak. Need help identifying part.
- 2002 allroad 2.7T
- 2000 A6 4.2: B2S1 O2 sensor removal
- A6 Wont start
- dynamic headlight range control
- Interesting solution for rebuilders...
- can't bleed brakes and get a hard pedal
- Power Steering Help
- Think it's time to scrap it.
- Need recommendation for Audi Service guy in St. Louis Area
- 19" wheels on Audi A6 S-Line
- :: ECS Tuning :: C5 A6 2.7T Valeo Single Mass Flywheel Conversion Kits
- A6 head light bulbs
- 6 Fault Codes.
- Audi a6 quattro c5 4.2
- Help what kind of car do I have???
- Please help
- A6 C5 2.7t MT Clutch advice
- unidentifiable module
- Bose Symphony
- Cangate adapter cable
- Valve Cover & Associated Gaskets, '04 2.7t
- Recommendations?
- Transmission Issues
- A6 TCM OR FUEL PUMP ISSUES
- P0112 code effect scanner monitors?
- VAG diagnostic tool
- 2001 Audi A6 Pre or Post Facelift? 02/01 MFR Date
- 2002 C5 3.0L Catalytic Converter CEL Question
- Control Arm Kit Options
- :: ECS Tuning :: C5 A6 2.8 PCV Service Kits
- Test Driving a 1998 A6 TOMORROW...Help!
- Shift cable adjustment...
- options\advice on a 2002 a6 with a dead CVT?
- Front End Alignment Issues
- For a limited time Sonax Full Effect Wheel Cleaner 500 ml - $12.95!
- vacuum diagrams
- Power Steering Leak
- A6 tranny problem
- 2nd timing belt service plus waste-gate repair - fell in love all over again!
- Cylinder 2 Misfire
- A6 C5 2.7T USA market owners - Please help
- Plant your car this spring. H&R and Bilstein coilovers for lower, at AWE Tuning.
- 2002 S6 4.2L Oil change procedure?
- Cannot engage any gear (mometary), 2.7T, 6spd manual
- :: ECS Tuning :: Bremmen C5 A6 Center Armrest Lid - $59.95!
- Serpentine Tensioner Replacement - Advice Appreciated
- audi a6 c5 2.8 1998 trany problems please helppp
- Epic Tuning (ETG)
- Check engi e light .
- 2000 A6 driver door won't open
- Daughter's '03 A6 3.0L accelerator too sensitive, any adjustment?
- '01 A6 Quattro might be haunted?
- Dash lights
- Throttle Body
- Headlights
- 2002 A6 C5 AC not blowing cold
- H&R Sport Coilovers strut replacement... $358.99!!!!
- new s6 owner. what is normal time to get to operating temp?
- Audi A6. 1.9tdi 2004 saloon Ashtray
- New to Audi and the AudiWorld any advice?
- 2004 a6 sline what tires can fit????
- HID - Scam??
- passenger side mirror replacement
- Suspension Issues - Opinions Wanted
- Temp Sensor
- Let's slow things down with special pricing on StopTech, only at AWE Tuning.
- :: ECS Tuning :: C5 A6 2.7t Timing Belt Kits
- A6 Trunk Latch Opens Manually while anti-theft alarm system is activated
- Hose
- Pulley wobble
- headlights won't come on
- Bleeding brakes / abs problem ?
- Service Center says my Audi A6 needs a new engine
- What sets the higher idle on cold start?
- 2.7 vs 4.2 interior dimensions
- :: ECS Tuning :: C5 A6/S6 LED Reverse Light Kits!
- 1999 A6 2.8L, engine problems
- ABS Light Intermittent
- Cassette-Headphone Jack.
- Having issues - instant power loss/ heat loss
- Transmission fluid leak - 2.8 quattro auto - not oil pan
- Power Steering fluid change.
- Teach me about alternators for the C5 A6...
- 2001 a6 2.7t overheating
- bitte helfen Freunden - with pictures - a6 transmission overhaul
- my audi crank but not start after jumpstart my wife's jetta.
- Suspension overhaul kits, any suggestions?
- Minor Questions Tht may or may not have Been Asked.
- Hi! New C5 A6 owner here, and I have a few questions:
- Holy cow, new issue?! Car felt like it was going to blow up...
- Recomemded DOT4 vs DOT 5
- Where do I find a good spring kit?
- 1999 audi a6 quattro vacuum hose help!
- Spring Therapy @ DetailersDomain.com - 15% off and shipping promos
- A6 vs s4
- Need opinion on transmission
- fuel filter and trans fluid?
- Clutch master cylinder change issue
- plastic clicking?
- Need opinions. Can't torque control arm correctly.
- Audi a6 quattro bi turbo with high miles
- Headlights
- Compression
- A6 Shifter Issue
- I give up on the combi valve!
- RNS-E Installation 2002 A6
- Umm…$16 connector for $.88?
- Any after market wiper blades that fit the Aero style on A6??
- Fuse 37 OK - No Power at Radio or Amp
- anyone need a C5 bellypan? It's a bit used and abused, but it's FREE - Seattle
- 01 A6 3.0L Engine timing
- 2004 Audi A6 2.7T S-Line wheel fitment
- Broke Down Today
- Belly pan install help?
- EGR valve curse...
- Vibration during deceleration, and as suspension cycles over terrain.
- First audi...
- AWE Tuning is welcomes KONI to our performance portfolio, with preferred pricing.
- Noise
- 2.7t allroad slow to start
- missfire
- '97 A6 quattro won't start
- Very sluggish for first 10 miles or so
- Aux fans and water temp gauge issues
- Uneven Headlights
- Name for the dealer installed hose clamps?
- KL.15 supply(control unit)
- Please guess my coolant leak from this video!
- Bumper compatibility
- Anyone replace wastegate actuator?
- Interior Lights
- Advice needed 2002 S6 Interior swap
- 2001 Audi A6 Transmission issue
- Need A DIY....
- A6 (C5 Platform) Ash Tray Removal - Help please
- Audi mechanic in Hartford, CT area
