- How to remove rear seat back panel?
- Just bought a new car...
- Working fob programming instructions 1999 A6
- 98 A6 Quattro Double Din
- Spyder Hose removal
- Headlight LED wiring? (A6 Avant Quattro 2002)
- What manual transmissions can i use in an 01 a6 2.7t.
- What kind of metal brush?
- 2.8 and 2.7t exterior parts cross compatibility
- Received 3 Error Codes on 2000 A6 Quattro Wagon
- QUICK TICK SOUND THEN BATTERY LIGHT THEN SHUTS OFF?
- comfot control module symtoms but not it
- I think my buddy might be an idiot.
- 1st post on this section: Advice on buying an 00 A6 132K miles
- Very random 2.7t misfire
- Need help Buying a Used Audi A6
- Gas prefferences?
- Looking for front lock carrier(radiator support) got some ?'s
- :: ECS Tuning :: C5 A6 DICE Media Intergration Kits
- Sounds like my flex joints are leaking. Replace or whole new down pipes?
- :: ECS Tuning :: C5 A6 Headlight Restoration Kit
- Steel Wheel Spare 2001 A6 2.7T Quattro
- 2001 A6 2.7t auto trans question
- Wireless Vag-Com (Ross Tech)
- Huge loss in power, can't get past 2500RPM
- climate control audi a6 2006
- 2000 A-6 Front Suspension
- LOL---http://blog.fcpeuro.com/2014/02/17/how-my-audi-drove-me-to-drinking/
- The McGyver Thread
- rear seats pre-wired for airbag?
- 2000' 4.2L Quattro transmittion. $350
- 2002 A6 2.7t pvc vent
- ECU Cover Removal
- Detailed Installation Instructions for the Speed Sensor in a '99 A6 quattro?
- Hard idle?
- Is this the correct bar/pin for a 2.7t in a 2002 A6?
- A6 leaking
- front brake piston will not retract
- Buying a scanner
- Leaking washer fluid turned out to be the pump
- Not another problem!!! SAI issue!!!
- :: ECS Tuning :: Pipercross Performance Air Filters for C5 A6 2.7T
- clutch
- Sensors for the turbo?
- looking for c5 audi a6 4.2l bumper!
- For those that regularly drive in the snow...
- Jerky gearchange
- 200K tonight!!!
- Tiptronic stuck in first... Usually when starting the car warm
- valley pan / block breather cleaning on a 2.7?
- :: ECS Tuning :: ST Performance Coilovers for your Audi C5 A6/S6
- 2.8 cam timing
- key fob issues
- Feeling the winter time blues? Here is a 20% off Promo Code to get better.
- Electronic devices (VagCom) in car
- Need URGENT help. 99 2.8L Avant keeps stalling
- PLEASE HELP ASAP..ESP & BATTERY LIGHT STALLS
- Still leaking coolant....
- Oil leak and Check engine light. Help!!!!!!
- Weird ABS/ESP Problem
- oil leak from oil cooler housing/ now car wont start.
- vacuum leak/running lean
- noise comeing from front end
- Vibration when braking...
- 1999 A6 Rear Window Defrost Timer
- 2005 a6 3.2 battery died now won't start
- Yet another newby thread about changing transmission fluid. Sorry, guys
- 2001 A6 2.7T Total exhaust change
- 10% off at PURE Motorsport!
- AUDI DVD NAVIGATION SYSTEM MMI KIT
- Thermostat Replacement on 1999 A6 Avant
- smoke out the tailpipe and excessive crankase pressure... whats up with that?
- Tail gate problem on 1999 A6 Avant
- P0501 Code
- 99' a6 2.8 cam sensor/cylinder 1-2-3 misfire
- Long Crank
- A6 2.4 oil pressur
- CAN-BUS??
- White smoke POURING out of valve covers!! What did I do?!
- Will A8 20's fit well on a S6
- Indie Shop near Pasadena CA
- Fuel economy
- Power steering pump squealing....
- A6 4.2 Transmission problem
- Crankplug.... AHHHHHHH!
- Won't start. Fully charged battery. Just clicks. Help!
- help with clear corner mod?
- Airbag light on!
- windshield wiper switch
- Does c5 seats straight fit on c4
- Tire Recommendation
- Phantom Wobble any advice helps
- What makes a C5 "Wide Body" wide
- audi A 6 rear air console take apart?
- 2000 A6 4.2Q changed battery and seeing fault codes
- Brake light issue.
- Tensioning lever hole threads stripped
- A6-RS6
- Redline oil any good? 2002 A6 2.7t ~160k
- Squeaking (creaking) steering wheel when hot
- Restyled Interior
- Battery Question
- Wave Contour Rotors
- Audi Indy Repair in Central PA
- temperature sensor blue? or Green?
- Cam's out of alignment slightly? Calling Tester123 & jseklund + others
- Door Freezing/Stuck Open Under 10 Degrees F...
- misfire diagnosis help needed
- Complete Silver Alcantara interior S6 C5
- Cold weather woes
- Any VAG-Com owners in Worcester, MA
- I really need some help or suggestion
- HID Headlights-Expert wiring and electrical advise needed
- Front and Rear Defrost Not Working Properly
- Audi A6 Audio/Bluetooth Problems
- Bad HID Ballast?
- What would you do?
- hand brake compensator
- 2003 S6 Avant 6-speed manual for sale
- 2004 A6 w/ 17" rims - tires keep shredding
- '99 A6 Speedometer Malfunction
- stumbles at idle when hood closed
- Throttle Body HELP!!!
- Stock to stage 2 or 3
- 11.5v slow+intermittent electrical draw
- Suction pump on a 2002 Audi A6 2.7T automatic?
- new member looking for small upgrades 2004 a6 2.7 s-line
- Looking for an Audi
- Exhaust and intake system?
- Rear Brake Caliper Tool
- A6 cranks wont start Please any help
- 2000 A6 2.7T Aftermarket Rim Size Question
- Need Passenger Side Cylinder Head for 04 3.0l A6
- Crankcase Breather System - parts list & any guides? (2.7t)
- Help Please!!!!!
- BUYER BEWARE: SAM at 517trans
- codes 16684,16688,16090,16689
- code 18014 ABS
- Aux water pump part # and location question...
- OEM HID replacement of conventional headlights
- CRAP! Camshaft moved?! Possible to figure out TDC again?!
- Hi, new here, considering buying a 2002 S6 Avant
- New Member Oil Sensor, climate control, shift lock and Power mirrors all failed Help?
- Does anybody in california hate their Insurance Campany?
- Troubleshoot consistent misfire in cyl.s 2 & 4?
- Heat won't stay were set
- Got ripped off..What would you do? 2002 avant A6
- Front Bumper Cover / Air Dam - Repair or Replace?
- How to remove brake caliper
- Anyone know console part number or have one?
- Idle down.
- Oil pressure switch
- C5 A6 Door Unlock & Windows Go Down by Themself
- HELP! 2+ hours to remove crankshaft access plug, CAN'T put in special tool...
- hard shift into reverse and drive
- accerleration very slow
- radiator leaking by transmission
- Oil Smell from 02 A6 2.7T
- Low oil level...burning oil? Please help!
- 2001 Audi A6 2.7L Biturbo Quattro.
- Help Please! ABS Light on, OBD issue, Airbag light on and Park Brake light flashing!
- :: ECS Tuning :: Vaico Complete Front Control Arm Kits For C5 A6 -$249.95!!
- Can you help me ID this hose on a 2.7t?
- Brake pad deposits on rotor
- Power Steering - here we go again
- what type of vavle body has filter seal installed
- 2.8 Motor Died, Won't Start
- Blue Smoke!
- Are these problems connected?
- Remote Start for 2011 A6
- New H2O Pump & Timing Belt Installed But Now Noisy PS Pump!
- quality parts for cheap??
- 2011 S5 purchase
- Thinkg of buying an Audi
- Motor Mounts?
- auto scanner reades not supported
- A6 Advant problems/possible fixes?
- Window Regulator Carrier - Options
- A6 2.7T Tiptronic: Motor and tranny out without taking downpipes off?
- Wiper arm swap? (2002 Audi A6 Avant)
- '03/'04 A6 S Line trunk lid spoiler
- water pump gasket, metal or other?
- 4.2 retired, C6 here I come...
- stock car?
- 2001 a6 4.2 fuse box diagram
- Rear view mirror
- Do HIDs lose brightness over time?
- 2002 A6 3.0 Cylinder 4, 5, and 6 Misfire Help??
- Time to Treat Yourself - 15% off and Free Shipping over $50 - Happy New Year!
- single cylinder misfire at idle
- A6 ABS fault
- 04 2.7T S-line Turn signal issues
- Transmission Issues on 2.4L V6 (A6 C5 2001)
- parts car
- Rearview Mirror
- A6 Auto Transmission - Can I Add ATF?
- Leaking water pump issue... after only 60k?!
- MY 2001 AUDI A6 4.2 DOOR LOCK ISSUES
- New valve cover gasket--is the "V" too large?
- 2000 A6 Quattro Avant Wagon Cargo Cover
- Good Source for Replacement LCDs
- Module Masters vs CheapABS.com
- Audi Chassis Codes?
- Avant rear windshield washer leak in motor
- Stereo Install Issues Please Help!
- Antifreeze reservoir
- Resurrecting My 2000 A6 - Need Advice
- '01 A6 2.7T Oil Change
- Lowering '02 A6 3.0 to '04 A6 S-Line stance
- Merry Christmas all!
- not heating properly audi a6 1,9tdi , 1999
- My transmission
- 2000 A6 4.2 V8
- Coolant Level warning on but tank looks almost full
- 1999 A6 4.2 with Magnaflow cats?
- S6 Avant airbag woes
- aftermarket head light fit
- 1999 audi a6 2.8 crank but no start
- 2002 Audi A6 2.7t Turbocharger replacement.
- post CAT O2 sensors
- 2.7t 6spd manual gear oil
- Brake Questions
- 2002 A6 4.2 Timing Belt Question
- Helpppp lol
- '03 A6 w/ misfire & P0346 - need help please
- 2000 a6 2.7t tranny help!
- Long cranking issues
- Cam Timing On Bank 1 Cylinder Head (Pass Side)....Wont Line Up with Notches HELP?????
- engine management light
- Replacing Passenger Headlamp
- upgrading my intake manifold on 4.2L V8
- Holiday Pricing at AWE Tuning is officially underway!
- Need advice on where to buy new TCU
- Int Lights/ elec prob/ key fob
- Headlight separation anxiety?????
- APR Website Chip? whats he benefit?
- Rear Defroster broken A-6
- hiss or air leak sound coming from in the dash
- audi red anti-freeze?
- i need help
- Fixed vacuum leaks...aghh BMW solution
- fuel/temp gauge problems
- Proud new (2001) A6 owner
- Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - December 16th - 21st 2013
- 2.7 chip
- Royal Purple power steering fluid vs Audi hydrolic fluid
- 2000 A6 Avant - Cold Heat?
- HELP! Starting Issue
- Hi everyone! I'm a new member.
- Can someone help me ID these wheels?
