- Rear electric sunshade won't go up, just clicks twice. Any ideas? How can I access...
- NE1 ever order from Vast Performance?
- '01 2.7T grill options
- Audi's new interior
- First problem on my new 99 A6 avant. long
- HVAC Blows Hot no matter what temp is set - 5 fault codes, can anyone point the right direction?
- Can transmission failure cause a bunch of ECU fault codes?
- Replacement clutch recommendations
- 2000 2.7T upper oil pan leak
- Let's get ready for spring...
- Towing capacity/capability for a 4.2..
- Paulroad im pretty sure my grill will fit on an allroad....
- Looks like I'll be an Audi owner for a little while longer.
- Purchansing brake pad question
- Anyone Seen Quinton Ray in the headlines lately on CNN FOX?
- Timing "alteration" related to CEL light? LONG
- INDY here in Georgia quoted for Timing Belt/ Waterpump WHOA!
- 98 A6 newbie questions
- Brake pad worn indicator light...but the pads have plenty left...I'm sure it's a loose wire, but
- 2.8L timing belt replacement
- Here we go again...FREE NO.RADAR
- Getting it up- same as 96??? Search gets conflicting results
- Changing Auxilary Coolant pump...What else?
- DON'T order anything from COMPLETEEXHAUST.COM....
- Just dropped off the A6 for 96k maint... timing belt, water pump, brake fluid flush, oil change...
- C5 A6 features that we love, but are almost never discussed
- 4.2 to an RS6 continues
- Metal Trim on Lower Trunk Lid pitting
- Hrs to remove drivers seat?
- So whose A6 2.7t did I have a street light derby with last night. (Stenton Ave, Philly PA)??
- high beams & fog lights -simultaneously
- Thanks to all of you for your thoughts and prayers. We have here a true family
- Drivers Side CV Joint Boot Removal and Install
- Stumbling after Timing belt/ water pump replacement
- 2000 A6 4.2 WATER PUMP AND TIMING BELT
- 17" Tire/Rim question
- Audi Recalls
- Buying 2000 A6, 60K, 17G's , mint body, Good Deal???
- Just a note to Sirius Subscribers
- Roof racks: Anyone with a Yakima system...
- Aftermarket Bumpers
- need a black rear license plate surround...I have a black 99 a6 and tired of looking
- Looking for a new ride. Anyone know the scoop on this one?
- A6 gotchas?
- Well I thought I was done but "every time I think I'm out...they pull me back in"...
- It still runs!
- I need a front bumper cover (A6 V8 or RS6) where to find??
- oil leak question
- J-SIN, how do I go about getting a grill like that?...it would match my lower grills nicely! :)
- These are some of the upcoming mods of mine.....anyone want to count?? Ha!!
- Questions on brakes... Different sizes at ECS Tuning...
- transmission hesitates from 1st to 2nd ?
- If only replacing brake pads, is the "bed-in" procedure still recommended?
- How can I get a paint code when it's not for a car I own???? (April?)
- 4.2 to a RS 6
- heating system noise, can anyone help?
- Locking door: no more beep/light flash
- A6 Wagon
- Wonder how an Audi can be stolen
- Glove compartment noise...
- Those with upgraded snub mounts...
- Powder Coated exhaust tips installed...
- stoooopid question: cabin filter
- Manual transmission fluid change?
- How many of us have replaced ignition switch on MY2000 A6?
- Any 'Gotchas' on a 2001 2.7T that my wife may buy? It has 63K on the odo.
- Power steering making noises
- 2005 A4 S4 Alloy Mirror covers
- Rear latch actuator on the Avant is what failed
- Anyone close to Eden Prairie, MN willing to look at a car for me?
- A followup about my brothers illness
- 99 A6 Bumper Cover Source
- Damn you guys and your blinker fluid!!!
- Since you all have criticized my list of mods...
- What's the latest on warranty replacement of worn switchgear faces?
- Official press release; Nemo purchase
- Rain/Light sensor
- multitronic CVT box - Should I be worried??
- Pics of the Sierras
- 99 A6 2.8 power window panel removal...help...please....thanks!
- Did a search but the post are 2-3 years old: Anyone rebuild/replace their 6sp transmission?
- Do any of you have Avon RS4 motor mounts laying around that I can have pretty cheap? E-mail me.
- I remember the days of intensive modding....
- Was EMP a transmission code for 2000?
- Service Advice Requested 01 A6 2.7T
- Strange noise - I'm stumped
- Help- noise question
- Seat Back Netting
- Dead Rear Window Defroster
- 2002 Audi A6Q 3.0 Brake Issue Any help
- Friggin Tire Shop
- I put 93 octane in my car this morning (usually use 91). Is that considered a mod? (read on.....)
- strange idle @ startup '00 2.8Q
- Anybody have pics & specs for Jeff Bipes dual switch...more
- Any other sites as good as or better than 1stvwparts that allow you to enter an Audi/VW part number
- How do I get the visor clip off? I pulled the plastic surround, but before I break something.. anyon
- Quattro in Snow - better than the rest?
- LED Tail lamp??? is it plug N play?? how about the brightness?? Pix would be great!! TIA
- Stoooopid quest: STFA already but.....
- LED brake light project
- Thanks Boston Driver!
- Big thanks to whoever creased and scratched the driver's rear quarter on my wife's A6.
- Poll: V1 mounted below mirror - which hardwire method and why?
- Intake Air Temp During Winter?
- The A6 may be a fat pig, but boy if it ain't still fun to drive.
- Short question. You guys think this would work out good for my Flip Key Remote?
- You could be the first to fit this mod to your A6
- Anyone programmed their own key?
- Naughty BMW
- please help
- Looking to purchase 98 a6q, need advice
- Does anoyone know if 17" OZ Supperleggera swill fit my 2000 2.7t?
- Question about letting a car sit for 9 months without driving? How important is it to start or move?
- yesterday i seen (last 30min) movie with S.Segal Submerged :o) with Audi A6 C5
- ACNA 2-day track event @ Buttonwillow Raceway coming up on March 27 & 28th (Mon/Tue)
- Which side is Bank 1 for O2 sensor on 4.2?
- I think the number of ads has finally reached the obnoxious level.
- 16" Wine glass rims-any resale value?
- Used A6 Advice
- Does anyone have a B&M shift knob they don't need?
- C5 pre-facelift grill the same as the Allroad?
- Reminder: This Sat, 2/11/06 - CT/NY Audi Group Gathering & Dyno Day - XXTuning - E. Hartford, CT
- Hey BD.....thought you'd like this post.......
- Personalized Plates
- Independent mechanics in D.C. metro?
- Ronal wheel-tire sale
- $1100 for timing belt and gaskets (labor only) in NJ???
- If anyone is familiar with Google Earth...This would be sweet!
- 40k Service Questions...
- I finally did it.. I put the S4 tips on my A6...
- Rolling fenders on 2.7T
- Sport Series Front Spoiler?
- One last wheel fitment question (I promise... i think)
- 4.2 owners: have you replaced your catalytic converters???
- Does anyone have experience with the MTM ECU Chip for the C5 S6?
- MTM Bimotos
- Yea Steelers!!!
- Signal light problem! would like to know if anybody else has had the same problem....
- Nemo interior colors
- LOOKING FOR TEDDYBGAME>>>>R U HERE ??NEED UR EMAIL.
- CONTEST!!! List my mods...
- ? Question about audi concert II ?
- Do we ('01 2.7T Q Tip) have the same trannys that B5 A4 have? Or any other Audi's? ...A8..?
- Anybody have pics and specs of Jeff Bipes dual switch ......for a Phatbox & Changer install ????
- Last warm day in NH for awhile. I washed, detailed and debadged
- Tranny problems with '02-03 S6?
- Installation Notes: Comfort Turn Signal from Euro-Parts Mod
- Show me your red A6 with tinted windows... Does it look good?
- 4.2 17" sport wheels on a 2.7t?
- O2 sensors. Anyone knows about them? Titania or Zirconia? Are they different spec or.....
- Poll the Audience.. How much is my 2000 A6 2.7T 6 spd w/ 116k miles worth?
- chip mod.
- Looking for a wheel trade...
- Need wheel/tire advice
- Purems Snub Mount Install! (Mod weekend)
- 2000 A6 2.7T Upgrade Parts
- Old Nav control knob?
- Install of Phatbox & Cd Changer in trunk together ...I know...... [more]
- Oh the irony! ;-P
- 3.0 vs 2.8
- How much...?
- So, we had a dyno day today............
- My next playtoy?
- steering wheel questions
- Power seat release?
- Update on purchase of 99 Avant
- Engine temperature
- MTM Supergharger
- My suspension transformation has begun...
- HELP..... Can't find part
- Indy mechanic recomendations near Brooklyn, NY
- I'm now officially stage 2!
- Anyone heard of a 2.8q with a 5 sp manual?
- anyone know how to burn RNS-D cd's....I'm doing them the way the original directions indicated
- So i wash my car and open the hood ...then this wierd sound come and my hood won't stay open :o(
- Repair CD's
- General reliability of the 2.7t
- Need help from A6 owner about your stock 16" rims
- Something we knew all along
- possible warranty issue on ' 02 3.0...
- 2000 2.7t transmission cannot be
- Follow up to "First Car" poll: I have never bought a brand new car. Anyone else driven only used?
- Rookie A6 question: I did some searching and saw people talking about how an RS6
- Quick A6 Owner Poll: What was your first car?
- Black box under dash. Finally figured it out......
- Cam Adjuster Seal Replacement
- Audi R10 vid :eek:
- Is it a bad idea to get an 02 S6 that isn't CPO?
- Part # Request Help Please...
- Had a chance to see and sit in the new RS 4.........
- OK, my next daily driver will almost certianly be a B6 or B7 S4, but this C5 2.7 is still a pretty
- Talk about loyalty. Cool story from Audi Newsletter.
- turbosmart bov for a6 2.7t
- I'll put this in the detail forum too, but what are you guys using on your glass to get it clean
- man... i want one
- Wear Red Today, Feb 3rd...National Women's Heart Awareness Day....
- Sunroof drains
- paging TEDDYBGAME
- cashmere grey..how common?
- BostonDriver's next mod...shows off Alcantara trim nicely---->
- Towing with an S6 Avant? Bad idea??
- Benzworld.org Gem o' the Day.
- Just got an A6 S-Line, had a hell of an experience
- 2000 A6 bulb??
- H-sport sways fitted!
- Front Bumper Cover Retainer
- Just a little flashback. Page 1388 (first) of the C5 forum.
- 2.7t Engine Cover help
- Ohh,and i'm going to remove that servotronic relay now.Wish me luck! ;) I'll share feelings later...
- Could somebody please look-up how you open the passenger seat in Bentley's CD?.. TIA
- Anyone know how the 30 Valve is set up?
- Sometimes I wonder which direction Audi is going...do they have something cooking we don't know
- Best Audi Dealer near Stamford, CT?
- trans service help, 2000 a6 2.7q
- First mod for this year will be an oil cooler
- so I got to spend some quality seat time in my A6 today....
- Alcantara headliner and trim for sale in Sweden
- ok i ordered EBC greenstuff pads for the A6.. before I go order ROTORS... who here with a 4.2 is
- WTF? $62 for a 4.2 oil filter at the stealership. Wow. I've had poor luck
- 2/11/06 - CT/NY Audi Group Gathering & Dyno Day - XX Tuning - E. Hartford, CT - 3 spots remain
- Machine Warriors - spectacular Brera ad
- Bling for gals
- New Mercedes C class
- Amazing website... any like this for Audi's?
- Buying a 99 Avant - here's the inspection report
- Honda says no
- Kinda OT, but have you seen this Honda ad???
- Help with water in front passenger foot well, I have searched the archives...
- Figured I'd post a few pics from our recent Pines to Palms drive... (kinda BWW)
- Navigation unit for a 2001 A6 4.2
- Thank you Mike@purems!!!
- BryanR2.7T- What tire size are you running on you 9" wide wheels?
- Cluster Repair
- In the Market for the ABS Electronics.....
- Yay! Car is in the shop getting service done, and they tell me 2 torn CV boots!!!
- A6 4.2 Transmission Problems
- Fun morning for my A6. Leaking fuel...
- Tell me about the height drop difference with springs. I was leaning to Votglands but my installer
- Okay, another bulb question, and yes, I did search, but got conflicting info...
- Brake Pads and Rain
- The 'Rocking front seat/Rear door ajar' connection
- The latest 'must-have' for all who desire that extra bit of go.....
- RNS-E installer in So Cal?
- Simulated Wooden Door Trim
- X-post anyone know about these wheels?
- Air bag question
- 4.2 owners: Where can I find recalls?
- rear brakes
- ABS electronics fix.....
- a6 wheels
