- Anyone in Southern Oregon with a VAG-COM?
- 2004 Audi A6 2.7 t Symphony radio ipod connection
- Rear Parking Sensors not working :(
- ABS/Brake light on slipping back in?
- Did piggies, used nonfoulers but now both rear are short to ground...
- !!Help!! I broke a hose and need to identify!
- Steppted on breaks hard...Beeping wont stop.
- 2002 A6 2.7TQ High Pitched Whining Noise on cold start
- HELP PLEASE!! Limp mode A6
- IAT sensor (Intake Air Temp) location S6 4.2 liter
- Vag-com
- increase oil capacity or heat exchanger?
- Coolant Leak from Front-Passenger Side of Engine (Possibly Thermostat Housing?)
- My take on Darintake
- Cold Weather's Comin. Failed Heated Seat Back and Steering Wheel
- Need professional opinion on A6 engines
- Alarm not working after HU install
- Computer Modifying Software
- Help with Aftermarket Head Unit Install
- 2.7t tiptronic problem (BIG THUD) please help
- Coolant temp gauge suddenly reads 50% lower
- 4.2 Engine, long term issues... o2s, cats, etc..
- Tranny Swap
- NAPA sale on Mobil 1 Euro Formula
- 01 2.7t....PCV Breather replacement
- Radio removal
- Celebrating 20 Years of Performance. Special Pricing on the AWE Tuning Catalog.
- Auto Trans Shifts HARD into Drive - 2.7T A6
- Maintenance Position and replacing Viscous Clutch
- Limp mode and a slew of VAGs
- 2001 A6 2.8 Is there a way to know if this timing belt has been replaced ?
- ANOTHER odd problem.....
- new diverter valves.
- Starting trouble starting with no warning signs.....experts help!
- S6 Owners: How to Connect New S6 Intake Manifold Vacuum?
- 2001 Audi A6 2.8L (2wd) - Oxygen Sensor
- Need Help!: doesnt crank sometimes.
- Own a part of A6 history! The most famous custom made C5 A6 stereo install bits are n
- Lambda Sensor Error
- 04 A6 Quattro 3.0 opinions needed
- mortor mount issuse
- Rims
- Engine shuttering when turned off.
- Still confused on Bilsteins for sport suspension
- LEAKS
- Tips/Suggestions Audi A6 4.2L V8 Quattro (2000)
- Normal for the rear of the transmission to be covered in rubber coating?
- A6 won't start, please help.
- best roof rack for 2001 a6
- anyone need wood?
- electric fan passenger side
- installing front subframe mounts
- 2001 AUDI A6 2.8L (FWD) TROUBLE CODES
- RS6 bumper on an A6
- S6 transmission codes
- A6(C5) Aux Fan won't run??
- Steering wheel maing a slight pop sound when turn hard
- Weird blinker?
- FREE leather shift boots and more for Your Audi!
- '02 A6 Radio Blackout....
- 2001 A6: Winshield Wiper No Fast Speed Problem
- A6 - TIP: TCU / TCM Circuit Board Alcohol Cleaning
- Dash display repair in GTA?
- Rear Pass. side-floor leak
- 2.7T HELP! SAW WHITE SMOKE! OIL COMSUMPTION QUESTION! BAD TURBOS?
- PES G2
- Auto Tranny Slips Then Bangs
- Bi-Pipe to timing cover plastic mounts
- Mechanic/shop needed
- Looking for information on control area kit from ECS Tuning.
- Need info on camshaft cap screw
- New Aux Water pump, wrong plug
- Anyone In Ocean County, Nj That Can Help
- Slow Coolant Leak in my 2001 A6 2.7T
- WTS ECU 2001 A6 2.7t 6 speed
- Looking to buy a 2003 S6 Avant
- 02-04 Headlights on 2001 A6?
- Can autozone code reader pick up tranny codes?
- 2001 2.8 p0441. Suggestions?
- ATF issues on 2000 A6?
- Major Clunk In Suspension Passenger Side
- Cylinder Misfires and Secondary Air Injection System Problem
- Molding removal from A pillar over doors on body
- ECS has $37 refurb Symphony I units...FYI
- Warning light came on, while GF borrowed car
- Detailer's Domain: 02 Audi S6 Avant - Full Exterior/Full Interior Detail
- The H&R Catalog, by AWE Tuning.
- Inner CV boot replacement
- Getting ready to change water pump and timing belt :go for it or run like hell?
- excessive petrol usage?
- Put my Car up for Sale today..
- whistle / howling noise
- no heat
- can you pull heads on a 2.7 in the car?
- Ambient Temperature Off 14-15 Degrees
- Looking getting back in Audi with a C5 4.2
- my c5 story...
- Drain and fill port above cats C5 2.8
- replacing front driveshaft flange seal
- What mounts are needed with shccks?
- Throttle body boot
- S4 calipers on A6 2.7t
- Coolant Leak Help
- boost actuated cutouts
- Isofix part number needed for C5 A6 - please help!
- Upper break lights parts number '02 A6Q
- Searching
- Need 4.2 Drivers side fog light trim
- 02 2.7 gas gushing out of tube after a fill up
- HELP! Can't find a new intake boot/gasket
- To all A6 Experts/Pros
- ABS & ESP system/lights going on off during drive
- WANTING TO DO COMPLETE MAINTENANCE OVERHAUL. EXPECTED PRICE??
- Replacing my A6 Avant Engine(2001)
- where is the crank locking plug on a 3.0L 2003 A6??
- APTuning End of Summer Service Specials - Timing Belts, & Alignments!!!!
- bump stop question
- 01 A6 for 3150 with 150K+ miles...
- S6 won't start occasionally / Randomly
- Difference between A6 4.2 and VW 4.2
- What is this leaking from???
- Have leak need advice...
- 2001 A6 Q : Exhaust leak. CEL on — Is this related.
- a8 Vs A6
- Auxillary fan constantly running?
- Difference between old and new oil caps; Oil Leak prevent
- bad abs control module???
- :: ECS Tuning :: C5 A6 2.7T Maintenance Products
- ESP/ABS/Misfires/Rough Idle
- Transmission Leak @ Radiator Connection
- Oil Leak Problem A6 1999
- Multiple CEL codes on 2003 A6 3.0
- Shell rotella t6 syn, vs valvoline premium blue?
- Fix for Rocking Front Seats - Need the Audi Part number
- Overheating 2.8 Avant what am I missing?
- 2001 A6 Vacuum Reservoir Precise Location
- vacuum q
- MAF LOCATION on 2.7t?
- 2000 A6 2.8: won't start/won't crank
- S6 ECU on A6: surging, lean conditions, odd behavior explained. Help!
- HELP ME SPEND MY $2000! 00 A6 2.7T
- still... random misfire
- A6 - Idle
- A6 Idle
- BOSE radio problem
- Driver Side Front Diff Flange Removal
- 2.7T Cam Lock Bar Needed - Boston Area
- 98 Audi A6 not starting when warm / No power to fuel pump
- Overheating question
- Rollover valve location
- Owners/Service/Repair Manual
- Help - various issues
- FRONT WINDOW PROBLEMS. PLEASE HELP BEFORE I BLOW A BUNCH OF MONEY
- A6 quattro TCU TCM question
- Electrical Problem: voltmeter displays 9V
- Top Dead Center/Cylinder One
- Just cut out my cats, have a few questions
- 04 Allroad ABS question
- Non-functioning Oil Temp/level sensor
- ESP or ABS braking problem
- Need entirely new exhaust? Help
- Rear Caliper Piston Won't Retract
- What is the latest thinking on batteries? I went with odyssey last time, but lifespan
- Please Help My 2.8 a6 wont start
- Door Skin Interchange
- need technical data from Bentley manual Rrepair book- who can help?
- Suspension Probl: Replaced Struts and the car has raised 1"
- Pulling back the Heater Core hose by the firewall to bleed the cooling system
- Stuck in park. Clicking. Limp mode. HELP. A6-01
- anyone with audi tool 3242...need dimensions asap
- 2001 A6 4.2L No Reverse - AM radio not working
- Coolant Flush Question
- What's wrong with the transmission?
- Planning on buying a used A6.
- Need help ASAP, leaving town tonight
- Which one 2002 2.7 or 2001 4.2
- Fog Lights and Cigaret Outlets
- Resetting ECU
- lowering spring for a 4.2 c5 a6
- Fans & Cooling Issues
- 2.7t alternator not charging
- A6 2.8l V6 Misfiring on all bank 1 cylinders only at low speed.
- seat repair question
- 1998 Audi A6 not starting when car is warm
- Right side speakers not functioning properly
- Inner CV joint boot...4.2A6
- Tranny Swap in a 2002 s6 avant?
- Chinese VAGCOM?
- A6 2.7T After Run Pump Questions
- 2001 audi a6 speedometer problem
- So I was driving along...
- Gas is spilling at the filler neck.
- Part from Shokan or Ebay top seller?
- Brakes All Around - '00 A6 4.2
- Few Quetions about 2003 2.7T A6 AWD
- Cruise control cuts out when driving
- Mini cat did not work.
- trans lines 97 A6 quatro
- Rack In Pinion Question on a 2003 A6
- Need help with alternator/generator
- 2000 a6 center drive shaft bearing
- my 2.7t cuts out at 4k, o2 sensor ?
- 1999 Audi A6 2.8 avant
- 2.7t feels slower. Boost leak? HELP!
- Massive Coolant Leak near firewall
- AUDI FAULT CODE P0741 17125 100% FIX.TORQUE CONVERTER CKT PERFORMANCE OR STUCK OFF/NO
- Some DV questions
- White smoke at start + slight coolant loss
- Reasonable estimate for Timing Belt service?
- Door not closing in cold weather
- Is there supposed to be play on the Timing Belt Tensioner Roller?
- 02 A6 engine sound normal?
- Transmission Shift Issue after Fluid Change
- Seafoam for 2.7 and 2.8 in oil?
- 2002 Audi A6 3.0 69k miles with steering wheel vibration
- excess toe......looking for a solution
- Radiator Fan Replacement - How much work?
- Sudden Involuntary Braking--any ideas??
- I finally had the time to remove the exhaust from the car to fix after the "rock" ...
- flex pipe 2.8 a6 2001
- A6 2.7T Quattro Avant tyre pressures
- Newbie - Buying an '98 A6
- 01E Trans Fluid Capacity
- 2004 A6 2.7T Oil on the Coil Pack/Top of Plug
- Power sun shield problem
- What are Early signs of Turbo failure? 2.7T A6
- How to recharge 02 A6 AC
- Suspension question
- Water Pump question
- Took Rear View Mirror off - how to get new one to stick?
- A6 Brakes
- Plastic linkage on left rear of 2001 A6
- 2002 AUDI A6 2.7t reaching 70k any suggestions?
- 2001 AUDI A6 FWD ABS LIGHT (ASR)
- Alarm repeatedly sounding on 2001 2.7t
- Evap Purge valve clogged - Dealer wants $180
- Smoked tail lights for 2000 a6 quattro
- Transmission Fluid Low???
- 2001-2004 Bumper Fitting.
- Air Conditioning and the Electric Aux Fan....
- OEM Sport Suspension for an Avant
- Clear code, or not to clear code
- Trying to fix an exterior door handle problem.
- Leather/Leatherette on the A6?
- shock fitment--2001 2.7t, sport (1BE) suspension
- MTC UPPER CONTROL ARMS. ANY GOOD?
- 2001 A6 facelift?
- interior trim coming undone......
- 4.2 overheating ..???
- o2 sensors
