- K04 questions, semi-urgent
- Audi A6 4.2 more questions with tires and cupping
- 2000 A6 4.2 L timing belt issue
- Help reading check engine light codes 2000 A6 2.7T
- Aftermarket headlight question -
- Check Engine Light! again!
- Is the Tip Chip for me?
- Help! 99 A6 Front Driver-side turn light goes crazy, other side fine
- Audi Owner Loyalty Program "$1,000-$5,000 depending on model" ???
- would appreciate any input on turbo upgrades
- Interior Code
- Audi A6 4.2 Tire question
- 98 2.8 code 17544, 17546. Vac leak?
- EGT sensors - RS6 ones do not work.....
- Audi A6 Airbag Warning Light / DTC 01218
- Wheel Spacers
- 2.5 TDI Titronic wavering rpm
- Threeway cats?
- Leaking Hydraulic Fluid
- Drivers seat leather ripped
- Turn Signal Relay?
- Grinding when turning sharply to the left
- HVAC Temp reading
- ►Auto tranny vs 45 degree incline◄
- 2.7T flywheel and 4.2 flexplate reluctor differences
- Performance ECU
- Aftermarket speakers in the REAR
- SoCA pricing for new tie rod ends installed?
- VAG radio recode question
- SAIP Issue--4.2
- This is how it's supposed to look!!
- Looking for DPT Tranmission
- Tiptronic doesn't work
- PaJames's project.
- n75 race valve
- Right cam plug, tight quarters
- Price Range to Change/Replace Fuel Pump
- '02 S6 Avant Rear Brakes
- Looking for 6-speed wiring and plumbing bits
- Which mod am I looking for?
- VMR | Wheels - V718 Signature Mesh!
- Fuel Pump? Fuel injectors? help please
- disabling Secondary Air Injection System 2.7T - Beating a Dead Horse
- custom made arm rest phone
- Differences in timing belt kits and tool rentals
- any way to tell if it has piggie pipes?
- Strange Interior Lights Flashing
- Seat adjustment motor bogs down... anyone know of good posts on this subject?
- NEW MEMBER
- Plastic Air Hose
- Help Please SAI on 98 A6
- Why is there engine oil behind a transmission bolt?
- 2.7t runs badly, need some help
- 2.7t mapping with auto box?
- New 2.7T A6 02 Owner looking for suggestions w/ new REVO ECU
- Eibach Pro-kit update.
- Brake Light Issues
- Clearing ambers
- Anyone parting with a fuel pump for '01 2.7T
- HELP!! Removing console 99' A6
- A lot of road feel thru pedals/steering wheel
- What do you guys think of this deal on 2004 A6 2.7T? Please help asap...
- How to Install Shifter Lock Solenoid
- Best way to fix scratches in paint?
- Urgent help needed! Idle clatter when warm
- After Wreck - Alignment - Subframe
- Let's play..Good news! Bad News!
- 2nd gear problems
- Brake Light
- Eibach pro-kit spring install. Rear didn't get any lower?
- doors won't lock/unlock with key only with remote
- '04 A6 3.0 bad ignition coils and now bad cats!
- Repair or service?
- Audi CPO replaced Timing Belt and parts...
- I finally the best tech in MN
- 2001 Allroad Pre-Buy questions
- 2001 2.7T startup clatter
- 17831 code-frustrated
- Educate me on A6 Headlights (2002 yr)
- Exterior Temp Sensor/Display (99 A6)
- V6 flywheel on V8 engine
- How do I reset the service light on Audi A6 after I change the oil?
- Alternator Gone Bad??
- when u fill up for fuel what does ur dash computer say ?
- Removing auto transmission 01 4.2Q
- Just bought an Audi A6
- battery, alternator or starter
- part number 4b0601165a which wheels used this part number center caps?
- Question about 2002 2.7T - Upgrade to Bi-Xenon?
- Vacuum issue after spark plug work ('99 2.8Q)
- Coolant return line for 2002 S6 (long post)
- Looking to buy a6 repair manual
- A6 owners can be proud...
- Headlight Washer Nozzle Replacement
- Auxiliary Coolant Pump
- New to A6 2.7t Few questions
- Any Interest in a DIY of installing lowering springs w/pics???
- Starter motor?
- It is amazing what Ebay throws up every now and again....
- S6 Avant rear sway bar bushings making noise
- wiggle the battery cable, starts - sometimes
- headlight problem
- update on some recent mods......
- Brake failure
- Alternator location?
- Does the 4.2L A6 - Aftermarket Headers?
- sneak peek S6 DRL mod
- DIY/HOW-TO: C5 A6/B5 S4 2.7T OXYGEN (O2) SENSOR REPLACEMENT W/ PICS- MUCH REQUESTED!!
- Aluminum control arms
- LED Automotive Headlight for Audi - VLine From VAIS Technology
- Lights Out
- Speedo, stalling and comm errors :-(
- 2007 Audi A6
- Service light!!!
- Ipod adapter hook up
- Leaking Water Pump
- A6 2.8 quattro
- Drivers side yellow lights stay on after car is locked by remote
- BTW, I'm new the to the C5 club. Few questions.
- Rear brake rotor diagnosis?
- 2004 2.7t lower rear left control arm part info
- Windsheild Wiper Plastic Cover Help
- TCU, Tranny Question
- Stock Flex exhaust piece for an A6 quat 2001 2.7
- Where to buy G12 coolant?
- 00 A6 4.2 Exhaust...need advice
- How many of you with chipped 2.7T 6-speeders notice clutch slipping...
- clatter on start-up
- 2004 A6 2.7T - Running a wire to the center armrest
- attention 2.7T owners, intake tract help needed
- 00 2.7T A6 vs 02 1.8T A4
- 2001 A6 4.2 wiper problem
- CEL: Intermittent Small Leak Evap Canister
- Metallic Rattling noise when accelerating hard - 2002 S6 Avant
- Replacing Battery (99 A6)
- questions about the a6 2.7t
- Water pump Cause loss of engine power?
- A/C flush and Brake pads question
- Major vacuum leak
- AR Lower Grilles Fit Pre-Face A6 2.7?
- Differences between 2001 4.2's fuel system and Direct Injection?
- 2002 AUDI A6 2.0L PETROL - SUDDEN SHAKING AND LOSS OF POWER
- Maybe starter?
- Mystery oil leak at exhaust monifold flange.. What can it be?
- What about the oil filter?
- Audi A6 C5 - Allroad Skid Plates!
- Altenator / Altenator Wiring Issues.....?
- Anybody install the blauparts shock/strut kit?
- Regearing 01E Final Drive?
- Test Drive the new Audi A6 3.2 T
- 99 A6 steering wheel overheats
- Spark plug change
- Looking for a transmission shop on Long island NY, multitronic, A6, auto
- P0741 my experience so far, pls help
- S6 wipers intermittently stop working?
- Stereo Options
- Power steering wheel will not tilt up and down
- some help please
- rs6 replica vs OEM rs6
- Dash skin is curling at windshield...any fix?
- For BB moderator..how to post/recommend a tech article?
- Topped off with wrong coolant
- Rechroming headlight and projector reflectors?
- Please tell me I'm not going nuts...
- Multiple problems could the drivers door lock be the fault?
- Intermittent Engine Rattle and slight loos of power
- MAF unit question on 2001 2.7T
- NEWBIE WATER QUESTION
- automatic vs manual
- what to look for..?
- 2001 A6 4.2 Passenger mirror
- Oil Level Sensor
- Howdy!
- is anyone using Motul motor oil?
- HELP! Driver's side power locks INOP!
- another headunit question....
- WAG Ice Trial
- engine oil sludge
- WTB, C5 compass auto dim rear view mirror. For 2K A6
- multitronic problems
- Replica RS6 Wheels
- Belt and tensioner problem
- vac leak codes 17544, 17546 2.8
- Just another "I love my car" thread...
- 2004 A6 S-Line question.....Did the trunk have a spoiler?
- double din lcd screen
- Special tool for Kombi valve
- 1.8T Starts, runs and dies
- 1999 A6 Part out
- Oil filter placement on a 4.2......
- having new exhaust installed tomorrow, is the
- Where is the RPM Sensor located on a 99 A6 2.8l Q Avant
- Looking for information about Cargo Shade
- TERRIBLE sound coming from Audi on start up -- With Recording!
- looking for a good mechanic in boston..
- Symphony II question....Will it work?
- OEM tyres recommendations please for a 2.7t
- Out of ideas - 2001 A6 2.8Q
- Oil Level Sensor showed MIN
- Thermostat...? Sort of long story but need opinions, please! :o)
- ac odor - how can i run some spray through the system?
- System to Lean: P1130, P1136, P1138
- Headlight Interchange - 2005 into 2001?
- need interior color code info
- 00 A6Q 2.8 RADIATOR REPLACEMENT INSTRUCTIONS
- Alarm siren/horn
- ESP,ABS and Suspencion light on
- ETKA
- horrible gas miliage!- getting rid of this car
- Instrument cluster
- Exhaust Gas Temp sensors....
- Need a simple thing avant wiper nozzle
- Air con question
- Steering Damper =vibration when driving?
- RS6 turbo install completed
- What is this??? Bent bar.
- Losing oil - how to determine between crank or cam seals?
- static in Radio on passanger side only
- After market head unit
- Wheel fit question for 2000 A6 2.7T
- Photos/instructions for Avant rear hatch moulding install? Paging TeddyBGame
- odd starting problem
- Where Can I Buy a Window Guide Online?
- tow hook socket?
- Fluid Leak and Power Loss
- A6 Sedan rear deck removable?
- How to replace turn signal bulb in Xenon headlight?
- Oil drip question,HELP!
- Brake pads installed - brake pad warning light still on
- hi all .allroad need help !!!!esp.abs. Torque Converter
- Hello AudiWorld
- 2002 a6 2.7T tow capacity?
- does anyone know the option code for xenons on
- PCV Suction Pump
- what is the most common PVC failure on 30v 2.8
- Leaking Coolant on New Clutch.
- Replacement clutch options for 2002 2.7T
- Insulated Spider/Spyder Hose Assembly Question
- Nitto Invo Tire Review [Video]
- Secondary air pump relay identification
- a virgin no more
- Exhaust blocked on right side?
- Remove SAI valves
- "OK" check light
- Rattling / squeeking sound coming from above....
- 3366 tool
- amp's
- Stern Drivetrain Mounts all in stock!
- Allroad Purchase Advice
- HELP - 1999 A6 2.8l Q Avant, Engine is turning but won't start.
