- Classic Jiffy Lube screw up
- For all of you S5 fans; MTM S5 GT
- Anyone know where I can get an S6+ front drivers side upper grill piece?
- see-through tires anyone???
- Bosch??
- Field Trip to Kindig-It Design Custom Auto Shop...
- need these out of my Garage...
- Shameless plug for my Audi Fans Ad...
- Anyone thrown this particular tranny code: PO 741? I've searched the archives and...
- Whilst browsing ebay... (for all you porsche lovers)
- Shifting Issues
- Radio Removal
- Readiness Codes....I'm stumped
- cheap '97 A6q avant for $1800
- for all you pearl Avant lovers....
- MAYDAY!!! My trunk is shut and wont open!!! How do I get it open if the button doesn't work?
- Just joined the C4 family. Bought a '97 A6Q for my son's first car.
- Tough Starts, Found a torn/burst Vac Line.. Pic Inside
- So the Audi's frame is bent
- Fuel Pump Replacement
- Need help with oil leak
- What else to change while changing
- ABS sensor problems
- Must......make.....money.....to.....get......an... ....audi!!!!
- Intake Manifold removal procedure
- Antena Question
- Just 4 fun... Audi A9...explicit content:-)
- Bose Amp Part Number
- Compressor Pics, anyone?
- Secondary Air Injection tubing connected by electrical tape??
- 100 s transmission
- What are the part numbers for the Crankshaft Bolt, and TB Tensioner bolt, and can I get them from...
- Bottom Engine Cover
- ECU failure?
- AC Replacement PAG Oil Question
- 97 A6Q Aut. Trans Problem Still
- Wiring accessory outlet to fuse box.
- Must . . . buy . . . S4 . . .
- Anyone use Meyle rear tie rods?
- Steering question
- Engine overheating, fan does not come on but does work.
- Transmission question
- Looking to pickup an Audi C4 A6, going to park my C5 A6, need a car to ONLY have liability on it...
- Hydrogen helper for better mileage ???
- Correct procedure for popping out/in lower ball joint?
- Oil filter magnet experience
- PSA: New Bolero Wheels on Sale - 8x17 ET35 5x112 $799
- How to replace the Brake Booster? Steering Rack History Development
- O Natureboy, check it out!
- Anyone have a CD changer bracket for an Avant or close-up pictures of how it's mounted? THX
- Power point under bonnet??
- Central locking actuator
- Vacaum line question. I did the EGR clean this weekend
- Need to rethread cylinder head for spark plug on '92 100: Tools to avoid removing head? <more>
- I am inquiring as to the availibility of timing belt tools?
- Steering wheel question
- Climate control left side out
- Update on selling the audi...
- Is anyone going to the AudiWorld/Inskip GTG in Rhode Island tomorrow?
- 95 avant engine codes
- Does anybody have a trailer hitch on thier C4? What are you towing?
- Any idea if this 2000 A4 cig lighter will work on my 97 A6?
- Adaptor or Repair Flange for connection between Catalytic Converters and Center
- First Pic of the new (used) rims
- '93 S4 on the cheap in SF Bay Area
- Radio Issue Update, may have bigger problems
- Early morning "whine" 98 C4 A6 Avant
- cleaning breather hoses and plenum
- Valve Spring Comp tool, anyone?
- Anybody in North Jersey?
- X-Post from the 12V forum...
- Anyone know the lugbolt size? I am looking to get a set of locking lugbolts . .
- De-Badged her today
- Anyone need Pearl 100 parts? check it out...300,000 miles on this one
- Autocheck computer - oil warning light
- Power Windows problem
- My transmission upshifts gears too fast....I think??
- So who's slowing down on the highway w/ high gas prices..? I'm now doing....
- Some stuff someone might be interested
- Audi 100 C4 Rockford Fosgate Audio...... Youtube video link
- Radio Issue in my 96 A6...any ideas?
- I am curious about something
- Fog light alternatives
- cruise control
- Will UrS avant springs lower a C4q 12v avant?
- Have my steering rack replaced now my brake pedal is stiff!
- Pulling engine codes on a 95 A6 avant
- TooManyAudis - do you still want to borrow the TB tools?
- Sunroof water channel needed!
- Rattling noise during hard right turn
- C4 Parts List with Diagrams posted in FAQ
- Picture Friday... Coming Late
- Washer fluid pump won't spray...
- air conditioner recharge
- What is this connector?
- Transmission leaking like a sieve! (lots of pics)
- this sounds like a nice project for someone in Seattle
- cruise control
- changing rear wheel bearings
- Steering wheel size for wheelskin?
- What is an "inverter module"
- So my last tank of gas was strictly city driving: 14-15mpg average. This is low right?
- part 2 --Electrical problems AUDI A6 aut Q '95 -multi functional switch MFS?
- Spark Plug How-To
- Cruise Control
- quick rim question
- Have you guys ever used Pro long in your car?
- I love this car but it's the little things that are killing me - remote, petcock, gas pedal...
- Timing belt success!
- Opening hood without release latch
- Paint repair questions
- Where to get `91 or `92 S4 Coils...
- Searching for a new bellypan
- quattro won't shift
- I still can't read engine control module
- Might be...
- Selling a few Parts... Any takers before going to ebay?
- Oil Leak '97 A6 Quattro
- how do you remove the front fender?
- 1995 A6q Failed CA Smog--EGR, "No Signal"
- anyone have an adaptor for the Cigarette Lighter? Or a tip on where to get one?
- Substitute oil filter...
- headliner
- DaveInSaltLake (or ETKA users) p/n for remaining side mouldings?
- Replacing gear shift boot???
- No Air Con since P/Steering hose was fixed
- Floating Caliper & Maint How-To ( crosspost )
- EGR cleaning ?: I think I have everything needed to do this but the crow's foot socket
- Oil, Oil Filter, Air Filter, Power Steering Flush, Summers mounted & Balanced :-)
- Hi guys question about 100 highs and lows..
- DaveInSaltLake: I'm headed to the boneyard tomorrow...
- rear parking light?
- Fog light wiring
- Fixed my power locks, but found out why it broke to begin with...
- fyi...found this store selling 'einszett Klima Cleaner' the cheapest...
- Still looking for a couple 5 spoke ET45's
- Audi Expo - June 28th
- cheap parts car anyone? dc area
- Window Regulator Cable
- OT: Gas Mileasge + Hauling Capacity on Trucks
- Urgent need some electrical system info. I was replacing a damaged Fog Light, and
- Ladies and Gentlemen, Riverside Audi's Online Parts Website, AudiPartsDepot.com is now live!
- P0401....Exhaust Gas Recirculation Flow Insufficient Detected
- In America
- I got to drive a new A5 today, whoo hoo! I have to say...
- Good info here. Might be a repost.
- Crankshaft Position Sensor P/N ???
- Where to find a radio wiring harness for a 1995 A6 Sedan with Bose
- Fuel filter changing is dangerous!!
- reverse lights and mirror angle does not change
- Car alarm keeps going off?
- Oil pressure sending unit/Oil temperature sending unit
- Keep Fog Lights on with High Beams
- Part #'s for 100 Door Trim
- C4 S6... not mine
- does any one know if a6, 100, and avant rear doors.........
- 94 Avant Power Lock Pump
- Anyone experience this? Delayed shift from 1 to 2 when it's cold out?
- Huh WTF?
- 97 A6Q AutoTrans Solenoid
- Front floating calipers, uh, don't
- Tips and write up on flexible brake lines, flare nuts and other fun topics
- Argh, Big oil leak!
- The no-go A6Q...
- heater core replacement
- 1997 A6 Avant 4.2?
- Does anyone have a clutch pedal I can buy on Sunday in or around Boston???
- No-go 1996 A6Q
- Ways to improve FM reception ,Which wire goes to the antenna amplifier??
- Need a pair of 16" 5 spoke wheels for the '98 Avant (or a whole set)
- 94 100CSQ Avant, CD mounting bracket
- piecing the inlaws audi together
- O-ring size/part # for engine drain plug?
- Somebody offered to buy my Avant last night...
- Fair asking price
- Heater bypass solution
- Anybody know what washers I need to replace the power steering hose?
- A nice Euro center section on AF:
- eBay: Stock Foglamps - $125
- C4 V8 A6 Avant Quattro...
- December 2008 Cross Country Trip Pics
- AC R/R
- Mom's Avant arrives
- BMthorn, can you make me a wiring harness for the concert for my 95 S6?
- What brand would you guys recommend for a water pump Graf or Hepu?
- There's a cheap cam holding tool (3243) on audifans....
- Hi dave my dad finished the tool oh hell i think there is trouble!!!
- Got paid to make this drive yesterday
- Water pump issues - quick response appreciated
- Looks like I'm getting Bilstein HD's!
- Suspension/Vibration issues
- Stereo Upgrade
- wacky brake wear light....
- Temp/Fan Speed settings on Climate Control are wacky
- Rims
- Finally a pic of the new A6 Avant.
- The Audi Dealer
- Summer Rubber
- Oil warning light on, no oil leak - pressure sender replaced...
- PSA - 3 wire unversal oxygen sensors on Ebay for $25
- Rattling tranmission syndrome - watch video - do you have what I have?
- Shift Indicator bulb and Outside Temp bulb? ........Questions.....
- weekend report: junkyards and mesing with a TR6
- Ignition switch woes! ....any help??
- Glass sunroof conversion
- Beg, Borrow or Steal...
- Installed variable intermittent wiper relay yesterday...
- How pos ible is it that the 1993 100CS A/T didn't have an ECU or a TCM?
- 4 pin vag com (2X2 -> obd2)
- Got a used PS pump online and the one that came was a ZF...
- Still having coolant temp problem.
- Clayt129 needs info on '92 100 5 spd manual diagram / parts list. Any help?
- Can you guys give me any pointers?
- Standing Invitation...
- Baffled by door issue...
- anybody parting a car or have a parts car?
- Steering shake when braking above 50mph
- Need anything transported East to West or West to East?
- plastic gauge lens - how to clean
- Struts
- Transmission parts list / Schematic for 92 CS100?
- Coolant bleed valve near heater valve is not in Bentley manual
- Is this Volatage reading normal - Just curious
- EGR Crud Removed
- new radiator finally installed
- "virgin" ski sack- anyone need one?
- Clear corner Depo method #2
- It's snowing here again...
- Audi A6 Quattro 2 for 1 Special!!!
- Wow, somebody should buy these heads
- Brake Light Issue
- Upper sump seal replacement
- No mystery as to what was wrong with my old motor...
- looking for a baige trunk cover for 97 avant?
- problem with emergency brakes
- weird C4 A6 Combo... 5 speed with cloth?
- Replace review mirror glass?
- Door Trim = Random-ized...
- Left side view mirror
- RE-Revisited: Trans. Limp/Fuse 14/Brake Overhaul/Glued Connectors...
- Oh man I think I forgot to put something back in my tranny filter
- Big makeover for the new A6 Avant...
- Gauging interest in my car
- Before - Halfway - Finished
- Oil leak from Rear right cam plug
- Can someone confirm exhaust stud is part # N90529501?
- Mommy's Avant is done. HUGE thanks to Brant!!!
- What is the part number for that cam plug on the right side?
- Depo Clear Corners
- 2 super nice Avants on CL
