- Interesting A6 trivia...it IS possible to put a rear bumper inside an A6 sedan
- Found a H3 bulb and holder in place of the Low beam today during an HID install
- Need some advice on wheel swap
- exhaust hanger
- will this work with my car?
- 92 100 : A/C Compressor keeps starting/stopping spinning. Is this correct behavior while AC is on?
- 95 A6 Q Avant- Worth more as parts or whole?
- Anyone have an extra A6 right-side headlight assembly kicking around?
- it's FRIDAY
- Hi, My name is Dave and I'm an Audi Addict....and I was weak again today
- well not to mention...
- EGR frequency valve is this the part #...026 906 283H
- So I broke my gas pedal and cant find a pic on how to fix it.
- Old School quattro IV is approaching. Click signature and get signed up!
- I will have a couple of front seats available if anybody needs
- Brant, finally got around doing the S4 hi-beam fix...
- Help Please
- I looked at a car last night...any input on a couple problems it has?
- C4 Caliper Rebuild Kits 2 Front + 2 Rear $5.00 starting bid
- Cam Tool w/ Crank Lock on EBay $5.00 starting bid.
- Vacuum diagram for 93 V6 2.8 whithout EGR
- A HUGE THANK YOU to DaveInSaltLake...
- Updates on the 92'
- Who wants a freebie!
- Anyone have "water damaged" / spotted roof rack?
- Source for Technical Bulletins
- i dont get whats goin on
- Goodyear Assurance Triple Tread on sale at Tirerack $88ea plus $40 rebate from Goodyear
- If you were getting a complete engine and trans, what would you replace before it goes in?
- Running different tire sizes with Quattro....
- Beware using Jiffy Lube for oil changes!
- Third Brake light LED Specs for A6 98 Wagon
- Tie Rod: End, or Whole Effing Assembly?
- Hesitation after EGR cleaning. Vacuum leak at the gasket?
- If Audi supplied pliers in the C4 toolkit you would have all you need for fuel pump replacement.....
- Fuel Pump Bad?
- Issues with 1996 A6Q, code is MAF reading too high
- C4 A6 Avant weight. I always thought it was about 3880 lbs however,...
- Where is the rear light control module?
- Automatic Gear Shift knob Wood Trim Light
- MAF screen purpose
- Off Topic. Does anyone watch UFC???
- New car...
- so here's my progress, i think i need a little input though
- right relay or not?
- Picture Friday?
- CLIMATE CONTROL
- I'd like to institute PICTURE FRIDAY on this forum!
- Shocks and springs question: Vogtland and Koni?
- well come to think of it an audi is a never ending project(lol)
- Can someone confirm 12v downpipe diameter of 2.25"?
- 97 a6 Q ODBII codes - Help!
- Here's a final shot of the new tail with Bmthorn's license bracket attached...
- Anyone have a spare moonroof arm set for sale? Mine are broken.
- Ok so i rummage a little today and this is what i found
- CEL = 1411 = everytime I get down to 1/4 tank remaining = ??
- Does anyone know if the engine and transmission can be pulled straight out the front of the car?
- Decision time. Fix or sell broken?
- B5 S4 Front Calipers on my A6
- Here's one for Mr. Thorn, the new Euro tail almost done...
- lol im going to pull a schlegle-- i know theres all this discussion about locks now
- crusininda944 ... any update on the lowering?
- could this actually be some good fortune?
- The dealer really PISSES ME OFF.
- This may help Schlegle910 or others with lock problems.
- Spark, no fuel?
- Check Engine Light
- Center cap refinishing.
- get some ! :P
- Compare latest list of O2 sensor manufacturers?
- ABS pump
- Finally going to attemp to tackle my high oil pressure issue. Any Input?
- 1994 Audi 100CS Quattro
- Has anybody here successfully put a V8 in one of these cars.
- Air bag sensor stop the car from starting ??
- OBD port for '97 A6???
- anyone here currently running 225/50/16
- [REMINDER] Tomorrow, TUE June 19 -- L.A. GTG @ The Stand in Encino (SFV)
- 1996 A6 with HVAC problem
- Need help diagnosing auto tranny problem in my A4q
- So Vb what was the final outcome???
- Well now...
- Mr. Thorn, I've sent you some pics by email, let me know that you got 'em.
- Alright guys need help with Craig's car with rough idle issues.
- Ok thanks allot everyone
- Well, it looks like I have to work my magic to fix V B chil-n A6 :-P
- 100 Avant FWD on the most recent FifthGear
- hardware sold, RS2 brackets still available
- ok so i pulled out the reciever &, after some digging, this is what i found
- Side Moulding/Trim
- Removing a steering column in a 92 100
- anyone doing a Big Brake Upgrade? i have some new hardware for sale
- ok so i noticed...
- wiring diagrams in GERMAN?!?!?
- Steering Rack - Gut Check
- [L.A. GTG] Tuesday, June 19th @ The Stand in Encino (SFV) - Who's coming???
- over heating
- A few pics of my new larger 5 1/4"front speaker conversion...
- i desperately need help with this
- First year of ownership....let's review.
- NGK O2 Sensors vs Bosch ... '97 A6Q 2.8
- Bose CD player
- Does anyone else have a weighted red gas cap?
- where to buy Motul ATF?
- Its like Jesus
- A6 Transmission flush
- my last post
- comercials in between posts.......sorry! ;)
- Castrol Syntec on Sale at Advance Auto Parts. $4.68
- Finally some good news, the exhaust leak
- Avant people: Is there a way to remove the roll-up screen from the rear...
- 95 a6 quattro check engine codes
- Time to Let My 95 A6Q Avant Go
- Which valve is on the bottom side of the air box?
- This squeaking is driving me insane
- overheating problems
- Block
- Too Rice???
- Grill pics for those who care =)
- Brant, You have G-mail
- So does anyone have a cargo cover for a A6 Avant in black?
- several parts for sale on e-bay
- So who is good with part numbers, or better can find it for me.
- trunk lights
- Hey EDIGREG...
- Is there a way to repair the black door trim on the bottom that is coming off b/c of rusty clips?
- Audi Repair Shops
- Leaky valve stem seals
- Hey Brant. Looks like your neck of the woods.
- PSA and I'm still having trouble
- I'm going to prep and paint a fender for my car, any tips or advice?
- This ever happen to anyone? Backing out of garage after car start up..
- I need some ecru rear dome lights with good switches.
- lol what a great pic...
- Brant, tomorrow is C1 D-Day. I'll Gmail you as soon as the biach is secure.
- Shocks and Springs?
- How much should a control arm run me?
- Caliper bracket bolts
- A pleasant update on the new RS3 MAF...
- 95 a6 12v, which pins to jump to flash codes
- Radiator source?
- Got around to skim my rear disks... What a surprise!!!
- ICV/IAC question
- Where can I buy this key fob. Never seen it before.
- 1995 a6 quattro no start
- Has anyone tried these LED instrument lamps?
- Anyone have an extra or available climate control servo for sale?
- Adjust or align the sunroof rails or tracks
- Rear Mud Flaps
- I am going to tackle the sunroof rain tray.
- I tried to flash my DTC's
- Man oh man, gas mileage is all about how you drive...
- Two problems...different search answers
- 1996 A6 Quattro Overheat colling fan malfunction
- I am a complete Moron!
- Avant hatch trim removal instructions
- Timing adjustment European spec '96 A6 2.0L 16v?
- Ok, ive got another stereo question, dangerous kinda
- 1.5 watt bulbs with red covers: before and after picture.
- SEARCH TUTORIAL WITH PICTURES FOR NEW MEMBERS
- Anybody notice that JET has added a link to the FAQ in the header above?
- Anyone with (I think the Delta) found a way for audio in? =)
- 0.00 Ohms across IAC terminals??? I guess that means its dead huh...
- please help
- My car is sitting high
- EDIGREG.....YGM. Gary is in Salt Lake today.
- What the hell is going on
- Erratic engine speed when slowing down-Power loss
- My new RS3 MAF is in...
- anyone with a (cps) for sale please call 773-301-3699 ask for rob
- Anyone w/ a CD changer in the Avant know how they run the wires to the HU? I need to...
- So, who thinks its the vacuum?
- Thermostat HELP!
- oil leak
- sunroof leak
- Sometimes you just have to take a break from fixing Audis and focus on something else for awhile.
- Grinding Sound in Neutral or Park
- dear daveinsaltlake, i think i need that (cps) becuase i got the car to
- cigarette lighter adapter for dvd player
- So whats the deal, i've always wanted to ask and keep forgetting
- Picture
- Brant (bmthorn) you got g-mail
- not having any luck with my crappy idle problem
- Airbag replacement in 92 100 CS
- Want to remove central console
- Transmission, Multi Finction Switch, Codes (Long)
- GF's car is a 1992 100... with AC blowing hot air in 90F+ weather. Few questions: How to diagnose?..
- '92 100 wont start no spark fuel before filter, im thinkin ignition module HELP!!!!
- 1996 audi a6 quattro wagon radio problem
- Phone Connection?
- how to replace kombi valve? anyone.
- 96 A6 Q master cylinder
- auto check system went retarded
- Fuel Trim Question??
- Today is not my day
- tie rod end not good. Should I replace whole tie rod assambly.
- sOld my car last night :/ 2k
- XPOST: S4 Rims Available
- Back, with a handful of new mods... woooo
- Installed 1.5 watt bulbs with red covers in my instrument cluster tonight.
- Did this happen to you?
- Set of floor mats with rings 4sale
- Expansion tank leak
- My car stalled a few times....
- Free to good home...K&N airfilter, oil & cleaner - fits A6 12v
- gamma stereo 4 sale
- Stereo Wiring ?
- Wheel Question
- Idle isues 96 A6 European spec
- I have a question about the dash board lights.
- Car is fixed!!!! Yippee
- anybody have a CD changer magazine for changer p/n 4D0 035 111...
- Where's Brandt?
- Challenged but your "IMHOs"
- What is the difference between the AAH 12v and the AFC
- Radiator buildup damage?
- Radio's acting up, any ideas
- After all these years of doing my timing belts by hand and eye, I finally got the cam tool... WHY
- Weird DTC codes
- Want to clean intake manifold
- AC Dead Again HELP!!!!
- wanted - 93 100 fwd auto trans
- Expansion Tank Problem
- Did any of the Avants come with Quattro script rear defrosters?
- Dodged a $275 bullet today
- Is the car trying to tell me something
- R134a refill
- Is this normal....?
- GLCQ Fun Drive pictures!
- Boston GTG pics--
- Public Service Message: 98 A6 Avant on Craigslist Boston...
- so 95 around highway turns going left, vibrations GONE!
- air bag light
- Do you really like your C4 A6/100?
- How can I power up my concert radio outside the car in my home to make sure it functions?
- BRANT YOU GOT IT!!!
- Probably dumb question, but I can try
- Replace Control Arm Bushings?
- Those with 14815 Magnaflow....
- Brake booster
- cannot communicate with OBD I
- obd code P1423,P1411 Sec. Air injection sys
- AC question
- Fuel Sending Unit Leaking Gas
- CEL coming on at 60 not 70+
- For whom it concerns, VAG locator site is back up...
- my understanding of low octain fuel is:
- Rear caliper carrier
- Auto trans problems (no surprise for an A6, I guess).
- A non Audi/Old Volvo Question... Can you help me?
