- 1990 audi 100 just won't run right
- what to disconnect
- Hot Start Problem
- lots of white smoke when at idle or low revs???
- Trouble with aircon
- euro parts
- Brake Light circuit short - blows fuse immediately
- Tire mixing
- Shudder Under Braking at Low Speeds
- 100 quattro pcv valve
- OUTER SILL TRIM WANTED
- Rail / Holder for Spark Plug wires for 1990 Audi 100
- Double snorkel air intake hose for 1990 Audi 100
- 97 A6 Avant Intermittent starting problem
- General info, how to troubleshoot blown fuses without blowing any more fuses.
- Headlight Upgrades?
- Help! Crazy high oil temp *yikes*
- Can't get it out of Park
- 96 A6 quattro hatch trim
- can anyone help me plzz
- Rear Defrost Relay location
- New clutch installed, now I can not get in all gears (93 S4)
- Wont start.. weiiiird !!! help?
- Last Minute Holiday Promotion - 15% off - Flat Shipping - $20 gift code on next order
- Blowing fuse - dealership can't figure it out and says there's no wiring diagram
- WTB 92-94 100 q or 95 a6 q 5spd
- BUY 2 GET 2 FREE UBER Microfiber Towels - Start now ends 12/8/11
- HELP! Is 96 A6 Quattro worth saving??? Trans/coolant mix
- retrofitting automatic climate?
- :: ECS Tuning :: 7th Annual Sale And Holiday Giveway!!!
- Black Friday Special at Detailer's Domain
- Exhaust pipe fix Help Request
- Audi A6, 1995 with transmission problems
- Help needed on Crankshaft position sensor
- First post- Input greatly appreciated
- 95 Urs6 radio wiring
- Weak heat. Thermostat issue or heather core? (pic inside)
- Instrument cluster
- Audi 100 1993 low beam
- A6 C4 1995 Central locking
- just wont fire up
- New front/rear brake pad set for sale cheap
- '95 A6 (C4?) Quattro Wagon reverse light problem
- headlights?
- Rare 2/92 100 Radiator
- Timing Belt Camshaft locking tool
- What are these nipples behind my catalytic converter??
- Detailer's Domain: 15% off Orbital Polisher Bundles and Car Care Kits
- '97 A6 Quattro Avant Auto Transmission Cooler Lines
- do i need a new alternator
- Audi 100 Sport for sale
- Help Needed! Wiring for my Radiator Fan 2.6 V6
- 92 100 quattro, catastrophic driveshaft failure?
- where is the EGR valve for 96 2.8 A6 avant please...
- Looking for seats to fit a 1997 A6 sedan (Albany NY area or NH/MA area)
- 17819 - Secondary Air Injection System; Bank 2: Insufficient Flow P1411
- Timing Belt - '96 A6 2.6ltr AFC engine
- EGR/ vacuum issues
- Anyone have a cream-colored armrest for '97 A6?
- Parting out my 94 100s
- 1994 A6 2.6 Indicator sound when driving
- 1989 Q100 Jumping RPM and Cough
- Avant Antenna
- Part number Help Request
- What type of brake pad wear sensors do I have??? Large round or oval???
- How much would you pay for a brake job on a 96 A6 Quattro???
- Sudden milage drop
- Seat Belt Light
- Losted the posiion of camshafts
- Sell Me Your Bigger MAF and Ported THB
- 1992 Audi 100 CS air conditioning help
- hmmmm need some advise
- Suspension Advice Needed, also just sharing my story
- Wheel Offset
- where to buy a audi manual
- Waterfest 17 Special at Detailer's Domain - 20% off!
- Looking to buy 96 A6 Quattro Wagon... options??
- Engine ECU computer questions
- July 4th Specials at Detailer's Domain
- 93 S4/100 engine computer (euro spec)
- 96 A6 Quattro 2.8L, Will not start. Possible ICM or Camshaft sensor?
- Headliner woes; at home repair.
- help! 95 a6 tranny!
- Door locks gone haywire!
- Where does the engine immobiliser live?
- 1997 a6 Exhaust Flange Tube Connection
- Father's Day Special at Detailer's Domain
- 93 Audi 100 idle problem
- 1993 urs4 underboosting,,need help..noobie
- 93 100 Auto Check
- radiator fans inop!
- 1996 A6 Avant Quattro needs radiator
- audi urs4 strut tower brace help
- Memorial Day Special at Detailer's Domain
- Advice/info on converting 2.3NG to EFI???
- Transmission shift points.
- Pre-purchase questions/ advice 94 a6 100c quatrro wagon
- Problems starting my 91 Audi 100
- Electronic faults
- Audi A6 Avant (C4) cd changer mounting bracket ?
- 1993 Audi 100 S fuel pump questions.
- S6 steering wheel retrofit Audi 100 94
- Blown heads, or worse?
- Audi A6 1996 Parcel shelf Red Light Cluster
- Immo Reader Coil problems - need new barrel?
- rear brake pad replacement on 93 V6Q
- Where is relay #30 located in Audi A6 Avant 1997 ?
- Help! Camshaft (hall) position sensor problem
- Where is the IAT 5 cyl 1991
- 1994 A6 2.8E FUEL TANK LEAK
- blue smoke
- c4/c5 2.8 142 kW
- continuous high pitched alarm sound
- First Road Trip in my new 1997 A6 Avant Q
- Best place to get a new IAC at a good price????
- Instructions to replace heater core 92 100CS
- A6 battery died, now alarm is always on?
- Ur S4 a little rough at high rpms
- 94 100 quattro
- How To Remove The 'V6' Intake Cover?
- car wont start
- Wanted: C4 S6
- Average mpg of a A6 Quattro?
- Hello all....a few questions.
- Dash Lights Out
- Transmission Problems... Fluid or something else?
- What's a '95 A6 worth these days? Trying to decide whether to buy.
- 96 A6 - Big Time Power Steering Screw up
- 95 a6 door lock module
- 93 S4 Fog lights won't turn on
- Loud annoying squeak?????
- Front Defogger
- Instantaneous idle drop A6????
- HELP
- '98 A6 Avant
- 1989 Audi 100 Quattro...
- Where can I find a Mance Maf?
- 1989 audi 100 dash light
- Pentosin 7.1 or 11s???
- 97A6Q Avant - Replacing rear final drive passenger side axle oil seal
- '92 Avant sheetmetal & seatbelt interchange
- 1995 A6 Radio in SAFE Mode
- How to replace rear brake hose on 1997 A6?
- 1993 100 CS Lacks Umph at low speed
- Farnk & Stien
- Beat the Winter Blues wtih Detailer's Domain - 20% off.
- Is a C4 side marker bulb holder a separate part?
- 93 100 Auto Chek
- My 1994 Audi 100S one year later
- flasher fault
- input on a 100CS quattro
- Throttle Body Gunk
- partial heat inside car
- Lighter/phone Charge port...New 100 Owner
- timing belt slipped on s4 c4
- C4 Avant Multifunction Transmission Switch info
- Coolant Smell
- Sedan/Avant bumper grilles interchangeable?
- New owner of a C4!
- 1994 Audi 100s For Sale
- Sunroof Motor Questions
- Heater Issues - 1997 A6 Quattro
- Any Audi A6 (C4) owners here?
- Braking urS4 avant.
- 1990 100 Issues
- 90 audi 100 locks dont work
- 1989 Audi 100 Fuel Pump Removal
- 97 Quattro Avant Tranny Fill Plug
- Audi 1992 100 CS
- AZB or CDT Transmission?
- Anyone have a how to for removing front and rear springs?
- 1994 Audi S4
- New member can any one help?
- Noisy Tappets after Heads Replaced
- bluetooth hand free for older Audi
- C4 transmission
- fuse problem - shorts constantly
- Thinking of purchasing a 100 cs
- Vacuum leak?
- Blauparts customer service??
- Wet audi 100 s
- anybody have a A6 passenger-side headlight to sell?
- Defrost/heating problems
- anybody need the cabin air filter?
- Audi 100/A6 1990-1997 repair and operation manual
- oil leak 1992 100 175K
- "OIL TEMP GAUGE", what's the problem???
- Turbo Introduction
- Selling Extra Light stuffs
- Removing front struts
- 1992 100CS electrical/transmission problems only 26K miles no BS!!!
- Adding angel eys to hella headlights?
- 1994 A6 Running like crap.
- Engine swap comments please
- Lights upgrade
- I've decided to keep it.
- Should I or should I not keep my car?
- 94 100S Starter Issue
- 98 a6 overheating
- Just sold my C4. free parts in Brooklyn
- power steering question
- where the euro tail lights with the euro plate holder?
- where would I go about getting this rear window wing?
- 1989 100 % Speed Jumping RPMs
- Thinking of buying this a6.
- clunk sound when put in reverse!!
- Car will not start but engine turns over
- crackling electric noise under steering wheel
- coolant question
- How many Audi 100 onwers are out there?
- 97 a6 Quattro 2.8 overheating
- Car Not Starting - Fuel Problem?
- 1994 Audi 100 CS Quattro, Two problems.. help please.
- 1993 audi S4 bose radio mp3 need help
- 95 A6 - Power Steering Pump issue?
- 1994 100 CS Q - How do I pull the codes?
- Wanted -- S6 Avant
- How much fuel pressure should I have?
- climate control problems
- Audi "Gamma" radio for '92 Quattro
- Additional fog/driving lights
- 10 disc CD changer w/ gamma radio
- Need some help....
- How do I go about lowering a 1995 A6 Quattro Avant?
- 92 quattro ignition switch
- Parts car/rebuild for sale - I need to sell it fast ..
- screeching sound from the under the car?
- Need help, air in brakes!
- missing OBD port 94 csq wagon
- 93 s4 to 96 a6
- 1992 Audi 100 cs quattro 25K original miles - service advice
- instrument cluster panel lighting problem!
- METAL BUILDUP AROUND TIE ROD
- 1994 Audi 100 CS Heater Core bypass issue
- 95 a6 - Coolant issues after fender repaired
- 1993 100 CS Aircon
- sendin the ecm back
- What's that clicking noise?
- Audi 100 2.5TDi (AAT) > 2.5TDi (AEL)
- 1994 Audi 100 CS Quattro - Power locks, stereo, and side power seat getting no power.
- wont start HELP
- got back up lights to work,but trans stuck in2nd gear & no speedo
- speedo,backup lights came on for a minuite ,and then went out.
- Disable Factory Alarm
- 93 100s. speedo & backup lights out.
- What have I done? 97 2.8 quattro
- 1993 100 starter issue
- C4 A6 Steering Rack Issues
- 1993 100 CS thermostat replacement
