PDA
View Full Version : Audi 100 / A6 (C4 Platform)
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Dumb question from a newbie A6 owner
  2. Parking brake adjustment?
  3. anyone know which wire I would use fromt the bose connection in the avant for a remote signal?
  4. question for Squirt-Tortuga ... maybe ...
  5. Finally cleaned headlight projector lenses and installed euro glass, wow.
  6. Radiator install update. aka: If you have trouble bleeding the cooling system replace the radiator!
  7. Link to list of DTCs
  8. Attempting the impossible...no check engine light.
  9. Wheel bearing help please!
  10. Under the FAQ's I could not find info on steering rack replacement, does
  11. Will decarbonizing my motor(v6 12v w/ 203,000mi) help with burning oil.....
  12. Brake Job Preparations
  13. Climate control removale help!!
  14. I would assume a car could be driven with power steering rack out,
  15. Anyone looking for a bargain A8?
  16. EDIGREG
  17. So I posted a few procedures on the FAQs...
  18. does anyone have a picture of abs sensor on front wheels
  19. I've got a almost brand new ski-sack
  20. my question for today....
  21. 1996 Audi A6 Quattro - Rain water leaked into engine/electircal?
  22. couple of tech questions. audi 100s 2wd
  23. PLEASE HELP!!! transmission overdrive question!!!
  24. 97 A6 questions
  25. Locked In Park
  26. removing the axel need help
  27. The 95 A6 Avant is the same body style as the 92 Avant, right? The
  28. Interior Lights - Help please!
  29. Alternator and assorted sadness
  30. weird interior lighting problem
  31. Accounting results...
  32. Headliner Panel
  33. front tire issue
  34. Happy Halloween! ;)
  35. 1992 audi 100 5spd vacuum line routing???
  36. Oil leak after timing belt service
  37. I think I need a "new" trunk lid, my trunk leaks...
  38. My 95 A6Q is dropping bombs on the driveway.....
  39. Replacing spark plugs and wires
  40. What's she worth?
  41. Puking oil out of headgaskets
  42. need help diagnosing climate control '92 v6 100 quattro
  43. well, the warden passed her road test this AM........
  44. 96 a6q mann oil filter number
  45. Wtfffff. Rough Idle/Stalling at stop
  46. Dave, can you tell me a bit more about this little piston
  47. Radiator job begins.
  48. ABS control module is under the rear seat?
  49. Here's a good one
  50. heater cores all aluminum?
  51. Rad fan turns on right away with iggy on + is there a trans dip stick on 97 a6 q?
  52. Tractor sound coming from the rear with heavy power. Diff fluid low?
  53. I haz found best C4 ever.
  54. To everyone considering lowering their C4. No. Just don't.
  55. Is this the rain tray thingy that breaks?
  56. Last week was bad for my Audi. Long.....
  57. Radiator Leak
  58. Crap. MiL hit a deer with her silver 1995 A6, no insurance. Need d/s headlight, fender, hood. Ideas?
  59. Water pump - seems like I've been down this road before...
  60. well im an offical member of the c4 community
  61. FS: 1997 A6Q, 64k, CD Changer, $5790 - Pittsburgh
  62. what should I be running for anti-freeze?
  63. Could misaligned rear control arms cause a wheel to be crooked?
  64. I found the problem with the climate control buttons not working properly...
  65. Helpful forum hints from the Italian Audi club website
  66. *Might* be a repost but here is a link to a plain English 95 A6 wiring diagram set.
  67. no floor heat on a 95 A6 avant
  68. Frozen parking brake
  69. Suspension refresh
  70. It's eating strut mounts!
  71. Save them from being Melted...: Sorry, they won't work for you guys
  72. air bag light stays on
  73. Transmission/differential Breather assembly?
  74. Headgasket replacement is finished
  75. what is the weird spring-loaded panel under the far drivers side air vent???
  76. P0116, MIL on.........t-stat stuck open(got one,need to replace), question about readyness monitors
  77. Radio not allowing me to input the code.
  78. Water leak HELP PLEASE!!
  79. Picture Friday. This gave me a little scare at the junkyard the other day.
  80. so, here are some pics
  81. Still looking for a good website to buy pressure relief valves (078103363p).
  82. (longish) Sudden stalling, irratic idle, engine dies at stop, dying at idle....FIX Fixed Solution
  83. Is G 004 012 power steering fluid compatable for my 92 100Q?
  84. I need a rear bumper for my 98 Avant project...or any tips on repairing cracks/holes in the plastic?
  85. She finally did it
  86. Something that may interest someone ......
  87. Now hear this!!! I'm back 'on the wagon' hahahaha....
  88. 96 a6 avant
  89. friends 95 A6 stalled on road going up slight hill, starts and idles rough, put in drive and
  90. X-post from B5 forums my Octtro
  91. Todd (Austinado16) what's the update after headgasket job?Is the overheating solved?
  92. cig lighter
  93. Sunroof/moonroof rain channels available for $88 plus shipping...kudos to the A8 forum for pointing
  94. Bose or Original Door Speaker
  95. Summer heat is here= bad for starter
  96. 1997 A6 Wagon with Codes, help please
  97. Audi Floor Mats
  98. Prolly not happenin on my 95 huh .....
  99. Can anyone recommend a good online parts site to buy parts
  100. Do I have a EGR Valve problem?
  101. I can't get my VAG-COM to work. Any suggestion?
  102. Intermittent lack of power???
  103. Looking for source for v/c gaskets for plastic v/c found on later C4s Part# 078 103 483j
  104. Speaker
  105. Help! Suddenly no headlights or foglights!
  106. scary thing just happened...... wife calls me outside(by phone),mentions nothing...
  107. suspension
  108. Engine Swap
  109. New stablemate for my A6
  110. How do you install a sunvisor clip ? Thanks in advance!
  111. H&R special sale at Achtuning (Very limited time!)
  112. Bad battery? Poor crank and rough idle after sitting for a few days.
  113. How many C4's do you typically see in an average day...not counting your own?
  114. Time for a little housecleaning Audi-wise....
  115. I replaced my engine, please listen, strange noise.
  116. Audi Dealer taking the piss....
  117. Services : Oil vs Ins 1 vs Ins 2
  118. Climate Control Flaps
  119. Guys, if anyone needs a FREE 12V engine there's one (not mine) on the 12V Forum...
  120. Brake line (banjo SS) source for BBK upgrade (993TT)
  121. OT: Holg please email me. I've got a '71 VW Beetle for you.
  122. X-post: My new whip...
  123. Had to take advantage of such a beautiful day... bath time for both!
  124. What's the C4 A6 battery size/series?
  125. Meyle failure cross post. I wonder if those guys know about Meyle's trouble?
  126. How to remove the strut that blocks the back of the oil pan??
  127. Glove box removal
  128. Well, it's for sure the headgaskets
  129. Power steering high pressure hose replaced twice...
  130. Weird vibration on the car, How to Trouble shoot
  131. Can rocker panel below lower door trim be removed? (easily?)
  132. Radiator Flush A6 Quattro Avant (Wagon)
  133. With a heavy heart I announce that my beloved Avant is for Sale....
  134. I saw an odd number of C4s driving around boston tonight
  135. CEL DTC codes
  136. IATN post about tranny noise / aeration ... thought it was interesting.
  137. So after walking to work this morning from the garage ....
  138. Who here has a non working cruise control? post the troubleshooting steps you've done.
  139. Thank You Mr. austinado16
  140. Anyone else having problems with Photobucket? Crappy service the last week!
  141. How does one code a new diesel injection pump for an AEL engine?
  142. Anyone here from Syracuse? Might be moving there in 2009 and ...
  143. Anybody need a Washer Tank? I have an extra I got off ebay...
  144. Question about Power Bleeding.
  145. Finally a MAF swap 4 to 3 wire
  146. Power steering diagnostics? Could it be anything other than a pump?
  147. rack
  148. service questions
  149. rack update
  150. Clutch problems on my 1996 2.6 5speed Manual.
  151. Front bearing removal on a '96 Avant
  152. Great Items for Sale
  153. Any 100 owners need shifter console wood?
  154. just Screwed the iginition. how to remove?
  155. not to beat a dead horse .....
  156. Anyone have cam holding tool I can borrow?
  157. Does your car idle evenly? (2.8l 12v)
  158. 2312 .........
  159. just picked up my re-built axle from NAPA ..... ya ready ?
  160. Going to see a parts car tommorow..How do I pull front interior wood from doors?
  161. Thanks for help on bumper removal. My trailer hitch is installed.
  162. How do I get the side panels off when removing the rear bumper?
  163. Does this look ok ?
  164. I have new lower body molding.. Now what? (Install question)
  165. Audi 100 2.5 TDi AAT engine
  166. Audi A1 Sportback - anbody seen it yet?
  167. Another broken thermostat. Never seen one this bad before.
  168. I would like to publicly thank Todd and Dave for the parts sent ( Thanks Guys)
  169. Eureka! Cruise Control fixed, I'm babbling so its long
  170. Anyone separate cats from exhaust manifold before?
  171. Update: Transmission rattle/noise when cold STILL there. Sorry guys... still on the hunt.
  172. Any non-quattro guys need new tie rod ends or some KYB struts?
  173. fueling
  174. Extra handles?
  175. Does anyone have the FCC ID# for '98 Avant keyless remotes?
  176. c4 s wagon parts
  177. Headlights/Spark Plugs upgrades - any ideas?
  178. What is this part?
  179. rebuilt maval rack is shot
  180. Headgasket gone?
  181. In my never ending quest for more "DIY"
  182. idel fault
  183. No Footwell Lights
  184. Autoclosing windows
  185. Courtesy lights not switching off when I start the engine-
  186. Looks like I AM doing headgaskets
  187. Autocheck Lamp out fix? (continued) Here are some pictures... anyone figure this out yet?
  188. CD Changer?
  189. New owner of 1996 A6 Quattro - Any Advise?
  190. Looked at a lago '93 100 CSq avant today...
  191. Noise in tranny when cold (continued) ---maybe fixed!
  192. How do I turn out the "bulb out" signal? I just installed HIDz and the procedure to lobotomize the..
  193. Cruise control - the whole nine yards...........
  194. I'm back. Been busy........................
  195. Okay guys, I'm giving this a shot .....
  196. Which bank is which?...
  197. Stereo (Delta CC Radio) not working - fuse fine
  198. Cruise Control
  199. I just had to do it.
  200. CL Find: Someone on the DC craigslist is selling some parts
  201. cruise control
  202. Brant, were you looking for some 92 springs?
  203. $40 OEM AKG and febi brand heater cores available for our cars thru Worldpac
  204. Done some searching, any Avant owners installed a stubby antenna? Not the...
  205. ESL: CIVIACSER
  206. Bleeding the cooling system
  207. Transmission Rattle and Whine: A8 Guys have a potential fix for one of the causes
  208. Cruise Control update: Fixed
  209. Mechanic won't change differential fluid bc his service manual states "it's not necessary"
  210. remote locking
  211. The Sounds of Silence
  212. A6 is a mess
  213. So what do you think? Is it legal to mail an airbag thru the Postal Service?
  214. too bad I wasn't local
  215. Check it out: Harbor Freight caters to Audi owners
  216. Anyone have a rear Quattro badge like you see in my sig pic? I need one....
  217. Where does the vac line running through the firewall, to the valve near the heater core in/out...
  218. Finally a real mechanic around
  219. coolant nipple size? 1.25"
  220. 3litre a month oil leak!!
  221. Can someone tell me how to jumper the radiator switch so it runs
  222. Ignition switch ID
  223. just got back from the salt flats
  224. p/s pump in
  225. Okay.....
  226. Weird Tranny / Electrical Issue. Help Please!!
  227. Looked at another 100...this time a '93 100 (base). Tornado red over grey velour...
  228. Curious, who here other then Todd own VW Caddys?
  229. 92 cs100 with strange hesitation, mechanic stumped!
  230. Does anyone know the wattage specs for the stock gamma system in a '96 A6?
  231. A6 tail light problems
  232. We went to Europe,and saw my car's twin in Hungary...
  233. FS 9 Qts of Pentosin ATF1 and Filter/Gasket
  234. Worst front struts I've ever seen on my 98 Avant project
  235. anybody buy a p/s pump before?
  236. 12v has been down for a week at least...any other purely maintenece sites?
  237. Side trim removal
  238. Replacement Batteries
  239. economy/sport options on auto transmision and cleamate control questions.
  240. Cosmetic Projects.. need a couple of things/some Qs..
  241. speedo temp inop
  242. so I'm hitting the yard today.....
  243. C4 A6 & C4 100 projector headlight guys...4x 55 watt xenon kit, 20,000 lumens output!
  244. I searched the FAQ's
  245. So there's been a long-running discussion about whether or not the rear corner lights
  246. retrofit a climate control
  247. shameles "for sale": Rear shocl bump stops and dust cover sleeves
  248. Is it okay replace radiator fan with lesser temperature 85/93 Degree
  249. I can't figure out this climate control problem...
  250. keys and bulbs
