- Testament for Quattro!
- 93 100cs interior question.
- The early results from my experiment with LED conversion.
- Black out trim
- i need the following part...
- anyone have clear corners for sale?
- What is the CCA on your original AUDI battery???
- Underseat battery
- Anyone has one 16" OEM 5-spoke for sale?
- 1971 "Audi vs. Rolls" vintage ad!
- Is there a way to fix a leaky winshield fluid reservoir?
- Hmmmm.....food for thought
- Okay, my 90 S is still sale, now only $6250 OBO!!! I know one of you guys wants this one!
- Spark plug wires - engine wibes
- Its upgrade time..
- Carbon deposits on Spark plugs
- Transmission woes
- Where to get new exhaust?
- weird problem with the remote flip key fob
- EDL question
- 2003 Audi Calendar - going, going....
- Does anyone have Rims for sale, I'm interested...
- Anyone heard of "Vogtland" springs?
- 94 Audi 100 S with excessive white smoke
- Tomorrow should be fun!!!
- damaging valves by hand!
- I predict warm weather for anyone in or around NJ because of Murphy's Law
- Variable Intake system possible?
- What is this on my dashboard?
- Nice way to rest your legs on a long trip
- Help Me Please!
- Procedure for changing spark plugs?
- SCCV Ice Time Trials, Again (VT)
- What's the sensor called,that starts the radiator fan when
- what to get for bday??
- speaking of trunk movers
- how should I keep box from movin in trunk??
- Went to the dealer to get touch-up paint....
- Hey A6qwDenver!
- OK Guys, i'm buying a switchblade key and wanna use it on my 95 S6...
- ITS ALIVE!!!!!!!!!!!!!!!!!!!!!!! THE AUDI IS ALIVE
- Do all oil cap (valve cover) leak, or is it just my car.. I have had
- Manifold Gasket leaking ?
- 1997 A4 -> Broken Headunit / Radio - Where can I get a new one?
- how often should the 4 oxygen sensors be replaced. I've got 15.5 miles per gallon :(
- SPAX springs/shocks
- Is there a way to put a switch in?
- Local Audi dealer wants an additional $95 to check ATF level!! I went
- OBD tool - if you have the software, how much is the connector for the OBD1 like in the ...
- bracket for factory multi disc
- Need help! if you have flipped your rear Bilstein spring perches to install lowering springs
- Ok, what I can do with the OEM shocks/springs/bushings/bearings?
- Poll: How hard do you drive your car? And is the idle rough?
- Broken heated seat!!!!
- Oil /Oil Filter Change done by dealer... $34.00!! Says should last 7500 miles...
- Is there a procedure for replacing bulbs in rear window switches?
- Question about keyless entries.
- you gotta love Audi dealers..
- Glove box light
- Hmmmm...need help identifying front right driveline/cv noise
- Want a cheap OBD II tool??? Look here... Auterra and Scantool???
- Does anyone know what my code is?
- Audi from "Der Teufel, " Part II
- Engine Swap?
- Mirrors De-laminating!
- ignition switch
- rear transmission seal.
- so, who can tell a difference?
- PIR Lapping Bonanza Saturday and Sunday, Feb. 22-23 2003
- you s6 guys might like this...
- Just came across this page... is he an audiworld participant... Charles Smith??
- odometer display
- if i order springs would i need new shocks/struts?
- Which Fuba Antenna?
- '95+ Bose stereo questions
- Where is the remote sensor for the key?
- where can i buy leather seats?
- oil, plugs,brakes?
- I just bought this
- Need help! for those who have flipped the spring perch on their bilsteins
- kamakaziep: I saw this in your pic poster. Please tell me more...
- where can I pick up plugs for underguard
- Ok yesturday I have been in '01 blue S4 Avant 6sp, MTM chip.
- Location of Flap motor and Ait Flow flap motor
- HP increases
- Wall Street Journal front page today:
- Moment of silence...... 1995 A6 1995-2003
- 93 100CS right front fog light
- Sony Ericcson T68i Handsfree Install
- Changed the battery to Duralast 48-D... found that the original Audi battery was only 500CCA!!!
- 2003 NORTHEAST AUDI SUMMER EXPOSITION-info and registration online now
- where to find true HID lights cheap?
- Has anyone Used the new LED lamps to replace their turn signal/ brake lights, etc yet?
- What did you all do for any vibration dampening for your car if any...(Stereo)
- Just plain sick!
- Shifting into Overdrive to soon??
- system pics??
- tranny question
- almost like mine
- Have you gents seen this site yet?
- Anyone have those cool (1 piece) C4 european tail lights?
- Someone was talking about relays clicking at idle..
- can alternator power two 1200 watt amps at one ohm each??
- 91 audi 100 i need help
- Heater/Fan Rattle
- need parts for 98-99 a4
- time to bring in the brass monkey
- Going to Europe!!!!!!!
- Dealer says $200 for a new battery!!! Any suggestion on after market battery models I can use?
- Need to know if these lights will work
- Muhammed, still looking for a 100 grille with black surround?
- Åudïðs69, What year S4 Lights fit 94 100s??
- Is Mobile1 10w30 to heavy for current weather (10F)?
- -2F here in Chicago Car did not start.. Battery down... Any suggestion on new Battery??
- Got the brake pad warning light...am I ok for a couple hundred miles?
- Temp gauge
- Problem with my power door locks?
- Changed differential oil, now unable to shift gears when cold!
- What's a decent price for a timing belt/water pump/t-stat job?
- Front side blinkers?
- Long Island GTG Friday 8pm
- does anyone have a diagram of steering/tierods from Bentley CD?
- Hey vladc77, Henry K, Pacs Legend, Shopping Cart Racer..............
- No manual, dumb question: how much tranny fluid?
- Hi, I just got my A6. It is cool, but I need more power, what are my options?
- If I had $80k I'd go put my name down for this!
- Heat
- Beep-beep or anyone who replaced shift indicator in dash
- If anyone has problem finding red bulbs for seat heater switch
- Anyone selling AC/heater console unit?
- Wanted: Stock Radio for 96 or 97 A6
- Audi from "Der Teufel"
- bently for sale
- changing interior from tan to black
- Moaning/Grinding in 1st gear! WTF is it?
- CD Repair Manual
- Drunken russkis are dangerous(I repeated SKR's podvig)
- Factory sport suspension on a 100/A6 quattro??? how to tell?
- Do you htink these wheel size will fit my 92 100s? 16x7.5 et30mm offset, 5x112
- Nightmare on I-95
- Curious thought ?
- 98 A6 idle problem
- Trivia time?
- Bose Front Left Speaker
- First maintenance: new spark plugs different number than what came out of car
- Is the oil drain plug for the 100 and A6 the same?
- certain backlights not working!!?!?!
- O2 sensors
- Gamma radio removal
- my car on autotrader.com
- Cross Post: HELP! I can't remove oil filter...
- What mods, cosmetic or performance, have you done to your cars? Looking for new ideas.
- Service Shop in Milwaukee, WI?
- Car goes in the shop next week!
- Dead in the water and stumped....need some help!
- Does suspension sag/lower when its cold out. When I pulled my VW
- Has anyone had the oil cooler spin abit when removing the oil filter?
- Intake Sensor Mod.
- Climate control problems
- If I were to sell my...
- Car keeps blowing hot air, no matter what the temp reading is...
- how the hell do you change transmission fluid on our cars?! Where do you fill it in?! And...
- New Member.....just saying hi........have a few questions also
- I know this is not very exciting but look what I got today besides my case of filters
- I need a service manual
- Can't figure out why my A6 has more power
- 30 ft lbs, my ass!
- 93 100s bose speakers
- dual exhaust possible
- finally got around to doing the switchblade mod...
- OK, so I'm not getting the positive reinforcement I was hoping for....anyone want ...
- Power steering problem
- What years did the 100's have the bose rear speakers in the rear deck?
- Near Disaster
- Audi 100 Avant Auto 1987 - Firing on 4 cyls 0nly!
- Anyone need a 100% working CC head i'm putting it up on Ebay here soon at a starting bid of $300....
- LED mirrors
- bitch, moan, whine....
- Hey Audios69- What's the skinny on your 100 not starting?
- Hey Malcom100 - email me re: clear corners.
- Problem with Dash (OK)
- Steel -> Glass Sunroof on 92' 100
- OK!! now I am confused about the snow flake in the temperature readout.....
- ratling fixed.
- Need vacuum schematics for 1992 A 100 2.8L
- Let me try this again: Gamma radio: CD-changer controls?
- A4 Sport Steering wheel...
- Moaning in first gear/Check tranny oil?
- No heat!
- I'm selling H&R springs for 92-94 100s
- Ok, I have ordered suspention. Now anybody can recomend place in NY/NJ, where I can install/align it
- I have a brain stumper for you all with my Fuses and Defrost switch...
- Anybody want to work a deal and swap their '97 A6 Avant for my '01 Allroad?
- all this great advice on this forum, and no one can tell me why my 100 doesn't start?
- March 8-9, Driving School, Las Vegas, wheels, more....
- Driving with under normal operating temp. Will this harm
- Beep-Beep
- So SKR...I got back in town last night,just got to reading your post. I hate to make you relive it..
- seatbelt warning light
- Hey, A6qwDenver, You said in previous post that you have....
- Intrax????????Spax???????????
- Suspension questions..... (there's been a few of them)....
- suspention upgrade
- cheapest place for springs
- pearl paint??
- anyone selling just one (or two) used/new standard Audi A4/A6 16x7 rim (pic inside)?
- CLEAR Head Lights and Corners going cheap on Ebay...
- kamakaziep, Re: HUD
- you gotta read this.. too funny
- 12V exhaust upgrade?
- beep-beep...send me an email so I know your email address and give you some worthwhile info
- FINALLLY got the tie rod end out!!!
- My $11 mod to my 100 :)
- 1/4 mile times
- Ok, I always made jokes about it, but now I need to upgrade suspention. Any advices?
- Cleaning the IAC / ISV on a 12v V6...
- Dashboard Info needed- '91 100
- Had a small fender bender, I need ....
- keyless entry
- Who needs an AC compressor?
- 96a6q sound sytem
- I might end up just like SKR... i just finished my DVD set up
- So shoppingkart, we're all waiting to hear.......what'd you do?
- Head unit adapters
- ISV ON 94 100
- Hey All you Audi Guys
- seatbelt light ON
- Guys!!!!!!!! ask Shoppingkartracer what he did to his car tonight!!!!!!!!!!!!!!
- Slight Coolant Loss ??
- Parking brake is sticking with the brake about half way applied, has anyone had this problem? If so
- My door open/ lights on chime seems to be going bad. Has anyone experienced this? What to do?
- is it ok to put balanced tires with rims on the car, and do the wheel alignment couple days later?
- Unlocking Gamma radio for 93 100s
- Damn it AoA!! I went to the Detroit Auto Show yesterday...
- Is YOUR car burning oil????
- Where can I find a shop manual for a '96 A6 Quattro Wagon???
- X-Post: A6 sighting in my apartment parking lot :-)
- Power steering
- Radiator Flushing
- In dash Radio display issue in my 92 100 cs
- Gamma Radio
- Great news! Car won't turn over , Battery good, Starter good, Ign. Swtch good,..
- Best place to mount a V1 and concealed display?
- What happened to QRS Motorsports?
- CV Boot
- (DTC Codes) I know a lot of people asked this already, but I wonder...
- 105K Service
- netsatwork post about lights brings up a question? Does anyone have HID installed? Pictures?
- 1996 A6 Quattro selling price
- Oil leak in my Audi 93 100s
