- Heater temperature
- Heated mirrors and washer nozzles
- Stalling on cold start & engine oil temp
- Ohh yeah...
- Can u believe it...
- Recommended 75k mile maintainence?
- Need some advice regarding the A6...
- Any trany mounts out there?
- is this normal - temp?
- Remote Fobs
- Is there a way to...
- Bose or Not Bose
- Question about computer chips in the remote controls (key)..
- Wiring Diagram Request
- Anyone have Camshaft 3242 & 3243 Tools V6 Tool they can lend?
- DTC Number 00652
- audi 100 models
- cat convertor.
- cv joints
- would eighteens work?
- Wind noise
- 96 A6 - WAGON QUATTRO Gas mileage
- darn radio replacement.
- Oil ring/sender
- Anybody parting out a 100/A6? I need the e-brake lever.
- audi 100 BODY KITS anywhere ?? : /
- some questions for you peeps
- how to remove the fuel injector?
- get brake caliper new or rebuilt?
- Delta Cc radio available
- I just ordered Bel LaserPro 904 laser jammer. Any tips on installation?
- Keyless Control Module for a 1992 100
- 97A6Q keyless receiver dead?
- before i tackle the broken foglight
- How are your headlights?
- What A6 do these fit?
- Anyone selling one BOSE rear speaker?
- Creaking sound in right rear suspension & Rusted rear dust shields
- where is chassis number?
- Anyone ever try Denso 02 Sensors?
- Anyone know the specs on rear Bose spkrs?...
- What is the easiest way to change a starter?
- rear gate wiring broken
- No more noisy lifters for me! It was so hard to drive my luxury sedan...
- RPM's at 80mph
- Reboot alarm
- Newbie question- power steering
- What is the Audi Word? I still cant figure this out, I need some tips on switchblade disassembly.TIA
- 97 Rear Bumper
- My clutch update product...
- anybody knows good Audi mechanic or shop in northern NJ?
- Trans Range Controller
- ETKA came today
- Hey, check out this guy trying to rip me off.
- follow-up to my "Ping and wrong gas" thread last week...
- ABS and Cruise Control not working
- Suspension problem?
- Hey ck100q how does the trans shift now with the service done?
- Anyone know about this key question?
- Here comes regular Maitenance! Check it out...
- OT: I lost my Audi hat :(
- Trans. Fluid, let's clear this up.
- Whoa, Pennzoil Universal ATF. Z-F Approved & <$5. Says "Audi" right on the label!
- Shocks and Struts??
- A/C Control head
- I tried doing a search for my friend on this problem....
- I'm getting a lot of lifter noise...
- 92 100s auto tranny. what fluid (dextron) does it require VAG
- NE Ohio GTG 2/21
- Where do you guys buy parts? Need tmg blt, etc.
- Wheres the Fuel Pressure regulator located on these cars ?
- Fuel Pump Dead? Symptoms??
- Fixed two problems Now I have another
- Oil leak
- Anybody interested?
- Hey Sebastian how's the clutch job coming along?
- Do 92 csq use Dextron or Yellow Audi ATF?
- '97 A6 problems
- The warning beep mechanism
- Standard Spec on SE model
- online suppliers to Canada
- Overheating problem
- wheels, wheels and more wheels
- WELCOME the 2005 Audi A6!!
- ETKA CD is in the mail tomorrow
- Group Buy 18" RS4 is coming to a end
- Will 2001 A6 wheels fit my car?
- Silly chassis number question.....
- anyone ever seen this climate control
- Poll: Your next Audi will be???
- oil leak all over oil pan and some on cooler= too>>
- Hey Beep-Beep...
- **Dirty Wheel Contest!!**
- Oil leak...
- '96ish A6 dash/console parts needed...HELP
- Radio replacement
- CD Changer Installation on 1997 A6Q Sedan
- Tomorrow night feb 18 kansas city area club meeting at jake edwards at 630 pm
- How do I remove rear Bose speakers?
- 92 AUDI 100 CS PARTS
- transmission poll
- Owner's Manual A6
- audi 100 transmission
- Guess how many pieces my car is in!!!!
- so slow lately...
- Is the seal available for between the trunk lock button & tail light lens?
- Transmission Probs
- need info on tranny multifunction switch (shift problems) 92 100s
- What was the 100csq made for? What do you use it for?
- Booster Connection Question...
- '92 audi 100 v6 automatic
- 97 A6 Electrical Problem
- did you remove thermo fan switch with socket or>>
- foglight glass smashed
- what are some simple upgrades i can do?/
- Ebay deals?
- Newbie needs help!!!!!!
- Paging Beep Beep(trans question)
- Any suggestions on aftermarket foglights?
- I'm looking for 2 of these 15" wheels from a 100
- Just a thought...
- Cooler Leak Gone!
- Got the car back from the shop...
- Wheel Size?
- 3 Power Steering System Flushing Questions.
- Re: Anyone can rent a tool to press in/out front wheel bearing on 92 100?
- panic -- used wrong gas (I hope - I think?)
- Audi/VW Meet in Western-ish MA on Mon, Feb 16th at 3 pm.
- Did all 95+ A6s come with this armrest?
- Would you guys reccomend doing a BBK?
- Why am I having such a hard time selling my car?
- Cooling fan continuously on. Does anyone know where the relays and/or therm switch is located?
- IR has its own mind
- '96 A6 Avant radio code
- Newbie looking for advice on '96-'98 Wagons
- when do i change my AT fluid? + another question
- Strut brace...
- Will these fit with the correct offset and tire size?? (I know, I searched)
- Ok, new poll, who has the highest milege on his AT?
- Yakima/Thules For a 100CSQ Wagon?
- 94 100CSQ wagon Antenna De-capitated
- Bently CD Rom won't open up. Help!!
- Oil Dye ?
- Anybody speak German?
- Factory alloy wheels
- air bag warning light
- sam cooke...
- Is their a more comprehensive...
- Blower Motor Completed...
- Head Gaskets
- Blower Motor R&R Question...
- How accurate is voltmeter on dash?
- '96 A6 Remotes
- Another Transmission question...
- Attn: auto-trans owners. Anyone experience problems with hard downshifts out of overdrive....
- Head Gasket leak?
- The dealer does not have the clutch alignment tool...
- Gamma Radio/Cassette
- The Oil cooler gasket (O Ring) 96 FWD
- Calling all Beep Beep's, or just the one 8-)
- Factory CD changer v. Aftermarket Unit
- 1992 100 a6 avant wagon for sale
- Opinions on the Bentley CD (I just installed mine! :)
- Transmission Fluid Type for 95 A6???
- wagonman, did you get my last mail?
- i need help.
- How long to replace front struts and mounts
- Oil leakage from behind filter assy A6 FWD '96
- About those white gauges, turns out....
- Audi 100 2.6 V6 -93 Trouble
- Need help on sun visor repair issue please
- rear syspension bushes
- temp gauge?
- Vacums...
- This should be fun...
- Coolant Temp Sensor Location 97 A6
- o2 sensor question,
- side mirror control switch removal?
- Temperature control flap sensor g92 (error 8.5)
- shocks, springs vs coilovers
- how to hold the S4 spare?
- On going trouble...
- things to do/fix on the car
- Temp light (thermometer icon) on and off
- snowking, you get any work done on the grille with the led's?
- HELP!? car wont start / run.!!!!!!!!!!!
- How to remove the Auto Transmission Pan???
- How do like them apples???
- green, I know why that grille cost me $35 to ship it... (funny)
- chip
- anyone have a pair of clear corners that they'd be willing to sell?
- Does anyone know about the Electric Fan Kits? (EFK's)
- trunk lock cylinder and mechanism??
- Transmission service cost
- Head light washer cover 97 A6
- I just got shot...
- power steering problem,somebody help me
- 93 100 factory radio replacement
- general question: where do you keep your tools (box, chest, cabinet, brand, etc).
- Heater Blowing Not so Hot!
- HELP!!!! problem just popped up with temp guage
- is the clutch alignment tool neccessary because...
- Question on center console and rear vents
- Squealing from Engine
- Great news with the white face gauges
- Anyone know the part # for the front oil pressure switch on 96 A6
- The love/Hate begins on day 2...CAR won't start? Starter? Alarm module?
- One small Step for Man, One giant leap into Audi KIND. Purchase of 100csq story.
- those of you who have been following my white-face-gauge hunt...
- How can I pull fault codes from a 95 A6 quattro?
- decisions addendum
- decisions
- bumper bumpers
- Anyone know where to get a rebuilt engine???
- Cheapest Lowering springs!!!
- Leak in exhaust manifold 100 2.8l
- This totally sucks :-(
- Dip stick dimensions
- anyone need a p/s rack and high pressure hose?
- bleeding cooling system
- Transmission Problems (imagine that!)Please help!
- Trailer Lights
- Interesting Styling on this Euro A6
- How about something that is going RIGHT with your car for a change??
- What do you guys think about this stalling problem...
- Ok, here is another squeaking POS: rear gate.
- LOST MY "A" Key!! NEED HELP!!
- Beep beep, I was in home depot today and you can rent a welder from them for like $50 a day...
- My clutch kit came yesterday...with no alignment tool...
- intermittant clunking coming from Frt. Pass. area.
- car dies in park
- Ahhh! Fail-Safe mode in transmission...
- steering wheel squeeks!!!
- 93 100cs A/C hi and low valve where are they
- help.
- one of the mufler's mounts is broke off. How to fix it?
- paging 4N 4Ring
- Audi key blade
- Strange but true
- coding remote key audi 100cs q
- Anyone replace Steering Rack? or Cat Convtr?
- rdynamix , Did you solve the overheating wagon? Just curious...
- adjusting door for better (quieter) seal>>I already tried the
- The rear passenger quarter panel? Welded or not?
- VAG tool
- radio and climate control?
- This post is for anyone unfamiliar with beep-beep's FAQ section
- Installing shocks?
- I'm back, and living in Western North Carolina
- Snow amounts in North east
