PDA
View Full Version : Audi 100 / A6 (C4 Platform)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Anyone from CT here?? There is a Krispy Kreme meet this sunday Oct. 19 @1PM
  2. Treo 180 Integration in Audi A6 1996
  3. Strut Tower Bar Installation
  4. beautiful 93 100s
  5. Brake pad recommendations? Caliper paint?
  6. Can't get OBD2 connector to work with OBD1 set up
  7. Paging Miktip...
  8. Poor Customer Support with Performancemotorcars.com (Long)
  9. 100cs quatro transmission
  10. I have a set of four used bent 16" rims for free
  11. How Many Washers on Fuel Filter Fitting?
  12. it's official! thank you EVERYONE!
  13. Need a starter...
  14. Time's running out to get in on the Penguin's Game GTG in Pittsburgh on 11/28.
  15. something is leaking....gearbox fluid??
  16. Well my IC Lights went w/o a hitch, but...
  17. Changed the transmission fluid (stick), found metallic flakes floating. Normal at 130 kmi?
  18. Oil recommendations please
  19. who has replaced their factory gamma (non bose) radio
  20. Attn: Beep-Beep
  21. Where is the resistor pack for the blower?
  22. A6 - 1996 rear door trim
  23. Guess what i hit.........
  24. Changing Fuel Filter Easy (100CS Quattro)?
  25. Hi all, question about doors!
  26. Audi A6 2.0 litre 8 valve intermittent misfire
  27. started my headliner project
  28. You Can Buy The Bentley CD Here
  29. Would appreciate it if all would read:
  30. Can't get my trunk open. (Kinda long...)
  31. Is torque for thermostat housing and water pump 7ft lbs? And...
  32. 92-94 100s keyless entry questions please look at your module
  33. I've searched but can't find any capacity information. I need to order stuff and don't have access
  34. 100 won't start!
  35. replace squeaky rear control arms or just bushings?
  36. Advice needed, looking into buying a 95 A6Q, what are the common problems?
  37. I really need some help. I haven't done any researching on the subject yet but here's what I have:
  38. Tools Needed to Change Serpentine Belt
  39. A6 Multifunction Transmission switch source
  40. 100 Headliner doing strip-tease
  41. Whine from engine '96
  42. Headlight housing
  43. Paging Pinball-Wizard
  44. 100CS Quattro Tune-Up Easy?
  45. time to replace noisy lifters, where can i get them?
  46. How to reset the radio safe code
  47. I need help to take off the front springs.
  48. As if audi clutches werent complicated to begin with...see if anyone wants to take a stab at this:
  49. I didn't recieve a response on my question on how to remove the ignition lock...
  50. Tach Question I need some info please
  51. corrosion warranty....
  52. Has anyone updated their headlight bulbs?
  53. **NYC Metro Area Audi Group" Cliffs of Insanity; AWD Driftin' UPDATE/REMINDER **
  54. Can VAG-COM shareware reset AirBag light?
  55. Transmission whine
  56. 100s Relationship Problems
  57. Weitec Lowering Springs
  58. torqx head bolt size
  59. New UrS4 owner, but I have a question that applies here too..
  60. Cruise Control question
  61. Wow Wow gotta have it let me have mama mama please
  62. Parking Brake Adjustment
  63. Diagnostic Codes
  64. key won't come out of IGN???
  65. Ordered something yesterday...
  66. followup
  67. Need help with brakes please (not working)
  68. More fresh-air blower woes
  69. Anyone want a factory Motorola carphone?
  70. 1996 A6 keyless entry fob
  71. Switch -blade key holder
  72. Alternator removal.
  73. Thinking about ditching my 93 100csq...too much work
  74. Back up lights now fixed, how another situation
  75. Power Locks doesn't work
  76. Better to just break the exhaust manifold bolts?
  77. oh no :(
  78. ventilation system problem
  79. Head bolts removal sequence?
  80. Warning light... ( O )
  81. is anyone interested in getting a porsche/brembo Big Red kit for their car?
  82. Steering Boot replacement .
  83. Squeaky Left Rear Suspension
  84. Will Mustang 2000 GT 17 inch wheels fit on a 1995 A6 Quattro?
  85. What happened to 12v.org?
  86. Headlight Warning light FIXED!
  87. Question on manual hvac controls>>
  88. 97 audi A6 alarm
  89. Oxygen sensors (again)
  90. RE: 92 100, oil warning light was coming on lately...,
  91. Can the air bag deploy with battery disconnected?
  92. Mass air flow sensor
  93. Do A6's Have the Rubberized Undercoat Like Sealant as the Type 44's Had?
  94. So I pulled my intake tonight....
  95. Need part numbers...repetitive
  96. a6 suspension?
  97. rooflining
  98. radio on 92 100cs
  99. A6 alarm Question or two
  100. Early Audi A6 Review from 'Audi Driver' Magazine
  101. Check engine light on - do I have to have dealer....
  102. Changed dash bulb, now Air Bag light on! Help...
  103. Programming the remote key fob for a 97 audi A6 quattro
  104. 95A6Q Wheel & Tire Upgrade
  105. power still on
  106. 2001 A6 wagon wheel fit on 96A6?? Please keep reading...
  107. Cali dyno smog test
  108. 2.8L V6 Specs 1992 100
  109. sun shade problem
  110. Shocks: 96 A6 FWD
  111. Fresno Area...GTG!!
  112. Slow leak near oil pan
  113. Loose door bracket
  114. 97 Audi A6 quattro delta radio
  115. coolant drain
  116. Sunroof Adjustment for Leaking?
  117. gotta love heated seats (if you dont have em you are missing out!)
  118. Dead windows???
  119. Suspension Problem
  120. Hey SKR- question about the axle assembly job-
  121. Is it possible and how easy/hard is it to add a trip computer?
  122. Amplifier installation
  123. I got the Power Steering Fluid (G 002 012) from Audi dealership.
  124. Is Body & Suspension Corrosion An Issue On A 97 A6 From The Chicago Area
  125. Trans fluid checked...but problem still remains.. new info
  126. Holy oil slicks Batman
  127. Need help with power steering pump churning up PS fluid
  128. instrument cluster short
  129. Eibach Pro-Kit Where are you?
  130. 96 A6 FWD
  131. Timing Belt Whipping '96 2.8
  132. Auto Check System & Trip Computer - Tech Advice Needed
  133. 93 100 direction flasher help needed
  134. Brake bad upgrades and possibly brake upgrades....
  135. Memory seat/mirrors
  136. 92 100S shimmys over bumps?
  137. do all 92 100 s have wireing for keyless entry?
  138. mikesho
  139. Dash panel removal - Dash Light replacement
  140. 92 100s gamma radio, will Bose fit??????
  141. ignition switch
  142. Noisy lifters- that clicky sound
  143. Tricks on getting crank bolt loose?
  144. NEWS FLASH: NorCal Audi Club Events for October 2003
  145. soon to be leaving
  146. little gimmick
  147. 0-40mph dont light up sometimes, bad bulb? If so where can I find a new one and how do I install?TIA
  148. Need help 92 100 FWD, new brake issues....
  149. New Plug Wires, Dash Lights
  150. Radio Code Help Needed!!!
  151. Parts List for Head Gasket change, ect.
  152. code 2312 ??? engine temp sensor or ecm sensor
  153. anyone have the wireing diagram for 92 100 v6
  154. Shocks/strut
  155. Windsheild Replacement
  156. Octane issue
  157. help, please have some mixed up engine wiring
  158. Sway Bar Brushings
  159. heated seat question
  160. bushing protection
  161. slow window operation fix
  162. I am puzzled: I cannot code the remote control unit.
  163. Rack and Pinion Leaking??
  164. LED Lighting upgrade
  165. Wind Noise Update
  166. A8 Brake upgrade.
  167. Door Locks
  168. Anyone have the bentley for the b4 cars, specifically a 93 100??
  169. which plug goes to the EGR valve?
  170. A/C didn't work on my way home from work today...
  171. engine light
  172. REMINDER: today van nuys KK meet. 8:30pm
  173. AMSOIL 10w30 synthetic oil
  174. '93 100CS Radio Issue
  175. Clicking
  176. Audi meet near Amherst, MA this Sunday (28 Sept 03) at 2 pm.
  177. Best quality and pricing on T-belt kit (A6)?
  178. Oil Leak from ?
  179. Spark Plug Installation
  180. 92 100 v6 where is the tach sensor pickup?
  181. Anyone know the crankbolt size (95 A6)
  182. What grade of gas do you use in 2.8L V6?
  183. Service in Sheboygan, WI?
  184. Left indicator blinking extremely fast
  185. uh oh.. im clicking/ticking wicked bad!!!
  186. Gauge Cluster Peeling
  187. Has anyone changed the central silcener exhaust before?
  188. Help V6 owners need your engine pics ASAP
  189. Where to put jackstands?
  190. Winter will be here pretty soon, just read some posts and wondered if anybody had some snow...
  191. 1995 A6; 235/40/18 or 245/35/19
  192. What should we buy???
  193. Audi Bose Stereo
  194. '93 100 FWD auto transmission problem
  195. HA HA- Guess I stirred the pot a little with that last post
  196. need torque specs 92 v6 heads and cams
  197. Clicking when turning left
  198. eng light
  199. X-Post.......Speedometer/Odometer Repair
  200. who's silver mid-90's A6 2.8 did i just drive at triple-digits speeds for 2 hours up I-5 with?
  201. the frequent engine warning light ticking problem
  202. Where is the Air Flow Flap that will throw a 15.7 code. The bentley say that this isn't installed
  203. www.tdlracing.com down? Hope they're still operating, no website though
  204. Rear Door Panel
  205. Back Up light Switch
  206. Just installed new front pads & rotors-rubbing sound
  207. Re: Installing SS brake lines, Benltey...
  208. Warning Lights insistant Beeping
  209. 94 100csq wagon Security system
  210. which aftermarket radios do you have in the car?
  211. I'm passing this one up on Ebay!!!
  212. Voltmeter calibration
  213. I Need A Replacement Remote Door Locker/Unlocker Thingie
  214. Audi S6 Plus ???
  215. Replacing Factory Radio
  216. Cable for dumping the codes
  217. Audi A6 (c4) mar. 1997, 2500 TDI
  218. So Calif. - search for a Good Mechanic?
  219. Rear diff drain plug tap size??sucker is froze in (96A-6)
  220. Mixed messages- ignition labor
  221. Does anyone know if the A6 logo mats fit these cars?
  222. Problems w/1998 A6 Avant: front bumper, ignition switch.
  223. Anyone removed factory phone??
  224. How do I remove inst. cluster, etc. to replace light bulbs?
  225. Hand brake on 95 A6 Q auto
  226. 1992 100s v6 timming belt snapped
  227. Re: Exile on Main St*, looked at your site and..
  228. 1996 A6 Recall --
  229. Thermostat tip -
  230. Help - Delta Radio blowing out my ears !!!
  231. Maintenance
  232. Who has replaced the power steering high pressure hose themselves?
  233. What's the benefit of owning a VAG?
  234. thinking of selling my car...
  235. upgrading a 1993 100s
  236. Remote Central Locking
  237. WHERE CAN I FIND SHOCKS?
  238. Anyone have a parts car? (or suggest where to get...)
  239. My A6 Lemon
  240. Time to replace timing belt??
  241. replaced tail light in trunk, now water comes in. Any suggestions? More sticky black stuff?
  242. Combination shot -- 2 Audis
  243. Design Specs
  244. COMPRO los manuales y libros de mantenimiento del AUDI A6 2.5, TDI V6, modelo del año 99 de 150 cv,
  245. COMPRO, para AUDI A6 2.5, TDI V6, modelo del año 99 de 150 cv., el Sistema de Aparcamiento Acústico
  246. AM Radio "gone"
  247. Air box modification
  248. Air Bag Light Update...
  249. September meeting of the Audi Car Club Kansas City September 17th
  250. Suspension
