- Master Cylinder $285.00? WTF?
- I might buy a high mileage '93 100cs quattro. What to look for?
- can I clean egr passage WO removing throttle body???>
- High Mileage '93 100CSQ Wagon Oil?
- Thanks very much SMOKIESMAN
- It's nice to know there's people out there...
- A6 Misfire
- Newbie w/ a couple questions
- Anyone have the Bentley manual instuctions to take off this piece thats broken?
- Voltage drops rapidly
- SoCal REMINDER... SCC Audi's Fall Ojai Drive - Saturday Sept 18th beginning in Malibu
- These will be going in the avant this weekend...
- ebay stuff
- Reminder: 9/25/04 - Audi Dyno Day and Get Together - Come Hang Out - near Hartford, CT
- Any kind soul here to post instructions on .........
- anyone here from boston?
- In need of TCM 92 100CS
- I posted this a while ago but got no responses..
- Catalytic Converter Replacement
- X-Post: NE Ohio GTG - 9/18 @ Bunker's
- Will the CV axle from a 93 S4 fit on a 93 100s?
- Wetsanding, Any tips before I do it...
- window relay woes, i could have a solution at hand
- Steering Fluid '97 A6 Q
- Where can I find a (used) replacement rim for my 92 100CS?
- Bentley manuals on ebay
- knocking from rear drivers side suspension
- No instrument illumination,
- Engine mountings worn..
- Window Relay Malfunction
- Bad Ignition Switch, Is it OK to just jiggle key and "live with it"??
- The Previous Oil Recomendation Question Now Has Me Asking This...
- Anyone have a high pressure power steering hose for sale? - SMOKIESMAN???
- Kent Falls, CT gtg/bbq...Saturday, Oct 9th
- Fuel Filter, I am also changing the fuel filter on the 100S
- Custom Exhaust
- Excessive Tire wear
- Oil recomemdation for higher mileage for 100s
- I ruined a part of my pearlescent paint today, "learning" to wet sand...
- Rusty caliper pin, cant get hex head bolt out
- what tire size are you guys running I'm in the market for new tires on the A6
- Looking to make my audi 100cs wagon look new and nicer.
- What American car would you guys consider buying?
- How many people did this happen to recently? Rusted caliper carrier pin:
- Code: 16785 - Exhaust recirculation flow too low Audi A6, 1996
- Strange symptoms with Climate Control on Audi A6, 1996
- Looking for general problem solving
- Help me out a bit. Bentley is down for me. Where is the fresh air blower relay located?
- CAR SMOKING??? Catalytic Converter???
- Paint touch-up - Pearl White
- engine swap
- A6Q vs BMW 530
- Climate Control removal
- Intake collector for foglamp hole, I might be able to make more:
- MAF sensor
- Need mechanic in western MA area
- what happened to TDL racing web site?
- Need catalytic converters
- No Automatic Shifting, No 4th, Lock-up
- 9/25/04 - Audi Dyno Day and Get Together - Come Hang Out - near Hartford, CT
- Dash Pod bulbs install questiojn
- Anybody here ever thought about the bigred porsche brakes..?
- CV JOINT
- Touch up Paint Dark Green 92' 100 CS
- Control Arm Question - Size of Nut #8 Bigger than 21mm
- good audi techs-electrical problems
- Window relay: what can happen?
- guys in the B6 forums rambling about the new B7 model...
- 92 Automatic shift-into-park?
- HELP MY CAR WONT START !!!!!
- Antifreeze G12+
- A/C Woes Diagnosed - HELP PLEASE
- change bulbs in the gear shift unit itself???????
- time to sell the wifes 92 100s whats it worth?
- My Air Condition fail...
- Mysterious fluid in engine
- X-post: New LLTEK Side Skirts available...
- question removing the starter
- Lower control arms
- Relay (big window master control dual)
- Installing brake pads 92 100
- A lot of C4 A6s in 'I,Spy'
- Dashlight discussion
- Rear Armrest Needed for A6 - Blue Leather
- Check engine lite
- Audi 100 '90 High Beams work but not Low Beams
- Windshield Fluid Hose
- CLIMATE CONTROL 96 Audi A6 doesn't always come on???
- Road Trip!!!
- Ok, both bottom float-pins in my rear brake caliper carriers are bent, now (more)
- Need help with cruise control issue
- Looking for S6 Avant
- No start, 1996 avant
- Electrical shifting problem 92 100CS
- rear seal on center diff leak
- Need an affordable commuter in NJ???
- what could i get for it....
- Installing after market radio 92 100 CS
- Do anybody know where I can get the used plastic panel under the roof?
- CD changer
- Check engine light- it's the egr flow- I searched but
- Someone should add this new Radio Shack number to the FAQ
- What is the towing capacity of a A6 Avant??
- new battery time....any suggestions
- Mother nature has come to finish us off
- Driver's mirror for 1997 A6 wagon
- 9/25/04 Audi Dyno Day Spots are now Open - Wethersfield, CT ....
- Hey Steve - the Audi's dead!
- what the hell is this stuff??
- vag com - making recirc on the climate work regardless if the A/C is on???
- anyone got a factory gamma head unit for decently cheap....
- Anybody have a window relay for sale?
- 92 100csq clunking sound on rt front end when hitting
- What do you guys sell used parts for? I usually do 40% of whatever the lowest prices they can find.
- Need A/C flap actuator motor
- Does anyone know if the center console and e-brake console
- pulling a jefferson!!!
- Anyone know where to get factory speakers?
- Suede Headliner X-post
- thank goodness for the E-brake
- does anyone know how to change the bulbs in the climate control display??????????
- sun roof control panel sagging......
- A few questions
- Just bought a 1991 100 off eBay. Some ???'s
- I can't seem to find the A/C low side service port for my 95 A6 quattro!!!
- 99 a6 avant
- ACNA GingerMan event still has openings
- Fuel pump questions...
- My Passenger front lower control arm disconnected while driving down the road.
- light bulbs for the eurospec headlights from ebay
- Radiator coolant
- Need an affordable/reliable commuter? Near mint '92 100S in NNJ...
- power seat melted
- digital climate control box has an red sploch on the..
- Some G-tech numbers
- Oil sender question
- NGK Plug "Eternal Question" for '96 A6
- Help, I think I messed up my ABS
- is there a delay for the light on the outdoor temp.....
- Losing Power!! 100/91'
- CAMS - doing engine rebuild - do they improve much?
- Help! Need autotrans. & abs code for 96 A6Q (12v C4)..
- Anyone have any floor mats they are selling? E-Mail me.
- Possible causes of serpentine (drive) belt vibrating at 1,100RPM?
- 99 a6 avant
- the door panel that houses the sunroof manual wind...
- 1997 A6 Stereo Display
- Remanufactured Transmissions
- Mark - Steve's bro' QUESTION ABOUT AIRBAG LIGHT
- How do you remove the power window switch wires from the door panel?
- Where to buy universal cats for '96 A6? Keep in mind it's OBD-II w/O2 sensors attached.
- 2.5l 5 cylinder tdi (AEL)
- damn electrical gremlins......
- PA/NJ/DE/MD folks --> Reading PA Fun Fest/GTG this Sat! 48 hours left to RSVP!
- How do I check my manual transmission fluid??
- To all of you who helped me with my questions.......
- Check Engine light jumper
- Vagcom Interface consisting of
- Near Mint Audi A6 carpeted floor mats in Black
- Bentley Repair Manual on CD...available
- Anyone seen one of these before?
- Wiper Arms suck on my 100
- Cat-back exhaust ?
- Squeaky A6
- 93 S4 front spings??? Will they fit?
- Tie rod ??'s- can they seem tight but not be good?? how to test??
- Driver's Side Power Mirror broken
- FOR SALE: 1992 Audi 100 (Auto, FWD, Red, 131000 miles) in central NJ
- Cv boot repair complete
- engine stutters at idle.
- Tire replacement suggestions
- a/c compressor clutch
- you guys were great with helping me replace bulbs, i
- Fuel Filter maybe? When my wife takes out her
- Anyone have a part for a 94 100?
- i need help
- Anybody replaced the analog clock with oil pressure gauge? Where from to buy the gauge and sensor?
- I have returned to sell some audi accessories...
- SMOKIES have you gotten my messages?
- 1995 A6 overheating/thermoswitch/wiring harness problem
- After cleaning this 97 cluster, It's near perfect, I'm tempted to...
- 1989 100 - Voltage Regulator problem??
- iat sensor
- Well, saying goodbye to my Audi
- CD changer wanted (1995 A6)
- AC Cooling fan replacement
- Microfilter for 1995 A6 wagon
- one of the bulbs on my dashboard is out...
- Outside Rear View mirror glass install
- Check this car at an Auction going Cheap
- Recommendations on 15" rims, yeah I know their small
- 1992 audi 100 fuel filters/pumps
- emergency triangle reflector
- anyone fix their door upholstery or have any tips on how to
- Ronal, 17-18", R41-R38, Wheel/tire sale, 2 wks.
- Belly Pan
- My 94 C4 Avant (S4) has the Gamma Bose unit
- Starting the CVBoot drivers side outer repair
- Any recomendations for suspension? h&r or eibach springs and hows the ride quality?
- if you look on exist.ru, you can find many more C4 based models
- Vaccumm Hoses
- Ignition Fault ? 100/92'
- Looking for an instrument cluster...
- problem with the strut/cumber plates
- Rear wiper on A6 AVANT
- replacing parking brake cable ... phase 1
- My temp gauge is possessed by demons!
- is replacing a d/s fender difficult? 1-10...how close is pearl among audis
- retrofitting air-conditioning
- Will 235/45/17 tires fit on the car or are they too wide and hit the suspension?
- hood and fender needed to finish repairing collision
- do I still need to use premium fuel for my car
- aircon fault/repair -advice required
- 97 A6 - looking for a 2nd cigarette lighter fuse...
- what side is bank 1 on my car, driver or passenger? 97 A6
- I need a wiring diagram for Bose A6 95-97. Thanks
- How can I find FCC # for Keyless Remote?
- Need a working gamma radio....
- Wagonmann, can you try something for me?
- Help from someone with Bently: What O2 sensor is bad if I keep getting the position B1 S2?
- My oil temp guage does not work, would that be a bad oil temp sending unit?
- Hit a railroad track last fall and bent a rim pretty badly, should I get an alignment? Car ....
- the switch for the rear defroster on my 97 A6 only lights up with the lights, but the other switches
- My wife just got a flat tire on the 97A6QW. Do you think it needs an alignment after this?
- A6 Blowing power window fuses
- transmission question
- can't believe I had smoked front marker lights before...
- 96 A6 Wagon rear and lower air duct has NO AIR coming out????
- Anyone have the"How To" on replacing the parking brake cable??
- high pitched squeekin sound from wheel
- Anyone have a spare front hood gas strut?
- right rear tire smoked again with that burnt smell.....
- (KC) Reminder - GTG tonight
- Looking for photos of your a6/100 with oem 16 inch wheels...
- I also have a set of stock side marker lights FS...
- I'm selling my Audi/Bose head unit...
- A/C Woes
- Replacing instrument lights on 96 A6 Quattro Wagon
- Hey guys, I'm looking at a 94 100 cs quattro wagon for my wife....
- Anyone want my euro outer amber lenses... hurry i need a reponse in 3 hours...
- Installation of wide faced audi radios in a C4
- O2 sensors wiring question...
- Having problems with sunroof!!!!!!!!!!!!!!!!
- still clunking after all these repairs....
- Have you seen the new tail lights on ebay with the clear corners
- I just bought this (back up) Instrument Cluster off Ebay incase I screw up...
- How much are 95 A6 sunroof motors
- Brake Bleeding Procedure?
- need help with a starting problem
- wiring diagram
