PDA
View Full Version : Audi 100 / A6 (C4 Platform)
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. is there 2 camshaft sensors to replace on
  2. Issue with removing ignition key.........
  3. 93 100s wont start sometimes
  4. 1997 A6 Avant Quattro - new owner, couple questions
  5. Simple wheel bearing question..
  6. Power Rear Window Sunshade problem on my audi a6 c4 2.8 v6 quattro
  7. control arm r&r questions
  8. Free stuff for pickup in Lynnwood, WA (10miles north of Seattle)
  9. Longevity and Problems
  10. drive shaft removal?
  11. 1996 A6 automatic Quattro shutter - Solved!
  12. Window regulator replacement
  13. 92Q bizarre electrical / transmission problem - help!
  14. Update - 1996 A6 automatic Quattro shutter
  15. Gamma radio power (on/off)
  16. Headliner Repair
  17. Water pump gasket
  18. looking for info
  19. 1996 A6 Avant Quattro repair questions
  20. Window And Sunroof relay 95' Avanyt
  21. Power Steering pressure hose replacement
  22. 1996 A6 automatic Quattro Failed emmisions!
  23. rear seal of center diff leaking
  24. Im a noob with alot of questions!! about getting an audi :(
  25. audi 100 to A6 fuel tank help ???
  26. Blown head gasket, wet wires?
  27. Does anyone have a set of snow or A/S tires cluttering up your garage?
  28. rear control arm/tie rod job. stuck ...
  29. Help- Paint code for C4 A6Q
  30. Help- Paint code for C4 A6Q
  31. Exhaust Leak
  32. '96 Avant rear hatch actuator wanted
  33. Headlamp washer
  34. Weird electrical problems???
  35. looking for parts (audi 100cs Q, c4 body)
  36. Audi Alignment? drifting problem?
  37. Another Gamma Radio Problem(aftermarket Install)
  38. S4 dash removal
  39. Questions on shock/struts, springs, and Blauparts...
  40. Timing Belt Length
  41. Rear Inner Fender Liners
  42. Need help finding Coolant leak..('95 A6Q)
  43. Head Bolt Difference
  44. Looking at a 92 100CS Q 161k- opinions?
  45. 95 A6Q front suspension and trans probs
  46. 97 A6Q quits when put in drive
  47. 1996 A6 automatic Quattro shutter - Possible Trans issue?
  48. Lucas Auto Transmission Slip fix? Does it work?
  49. Audi 100 S4 saloon auto
  50. Thanks to many - remember way, way back....
  51. 1994 100 avant door problem
  52. So american V8 rear wheel drive swap?
  53. audi 100 trouble starting
  54. Can you guys help me to find radio code for my GAMMA CC please?
  55. Tie Rod Replacement
  56. we have a c4 A6 Avant , any know where to find a front bra to hide my road rash?? :)
  57. PARTING OUT 95 A6
  58. audi 100 exhaust 1992 base model
  59. Car won't start (1995 A6)
  60. V6 swapping 2.8 12v to 2.8 30v??
  61. 1990 Audi Quattro 100 speedometer, battery issues.
  62. FAQ or wiki
  63. Sun Visor
  64. Batter drain with humming noise under dash
  65. no indicators or hazards
  66. Just did 400 miles on one tank
  67. serp belt tensioner
  68. Tranny issues
  69. I need help with a cd player install please.
  70. Overheated 100...Any Thoughts?
  71. Timing Belt Tensioner
  72. battery mystery
  73. center vents suddenly stop blowing
  74. help please ac issues
  75. 93 100s a/c recharge
  76. Hydrolock or not?
  77. Thermostat Difference....??
  78. FS: TAP Cone Kit
  79. the time capsule - what to expect
  80. Front Seatbelts?
  81. HVAC head unit and flap motors
  82. Audi A6 won't start. Need help
  83. Cat help....96 A6 Avant Q with 167 k.....Cat converter is rattling like crazy inside.
  84. 94 100s Power steering
  85. A6 2.5Tdi
  86. Engine Oil 1992 100CS V6 2.8
  87. Compatible Engines for a 92 100 CS Quattro Manual
  88. Electrical bug when starting
  89. Electric window problem
  90. Computer interface in the trunk?
  91. UrS6 Plus rims and tyres
  92. Power steering troubles
  93. Squealing Rear Tie Rods
  94. Rear Seat removal/ complete interior exchange
  95. Which 2.5TDI Engine In My A6/C4?
  96. Stereo dead after battery replacement - not even SAFE code!
  97. Wiring diagram for Audi A6 - please
  98. Boot/Trunk Lock Not Working
  99. Transmision Fluid....???
  100. Where is the FAQ
  101. Pulled some codes possible egr problems.
  102. C4 A6 Front Wheel Bearing Press Tool?
  103. oil pressure switch
  104. '93 100c4Q - Water Pump replacement HELP
  105. 1998 Audi A6 plastic jack socket failed
  106. A/C trouble
  107. dome light
  108. The notorious headliner/ceiling rattle
  109. Door Trim Questions
  110. Vacumn Storage Ball
  111. Anyone has Multi Function Switch laying around?
  112. stripped six 10mm 12 pt tripple square bolts
  113. Suspension noise
  114. radiator fans won't come on
  115. need door trim and pass. mirror . Where to buy from?
  116. 1991 Audi 100 stalling issues
  117. How much are a brand new set of headlights (with citylights) worth? (in boxes)
  118. Suspension problems with 1996 A6 quattro
  119. leaking moonroof
  120. Idle flutter? 97 A6 2.8 Quattro
  121. Climate control fan question
  122. 1996 Audi A6 Quattro Wagon Low/High beams not working.
  123. FS: 92' 100 Front Driver Side Fender
  124. Ignition switch woes...
  125. Audi 100 Turbo?
  126. ignition problems, any help please?
  127. Hesitates when warm
  128. Another whats my clunk? Front Left
  129. Picture Friday Advance?
  130. 95 A6 Avant headlight adjustment
  131. How do you remove the headliner in a 93 audi 100 quattro C4?
  132. belt hanging under back end of car?
  133. Northeast Audi owners........
  134. Egr problem...
  135. I am blind or just vB'd? I can't find the 100/A6 front brake upgrade using TT
  136. Oil leaking?
  137. Exhaust tubing size 2.25?
  138. High pressure in cooling system - A6 1996
  139. Spark plugs after 15k miles
  140. stock fuel injector size?
  141. What transmission is in my car?
  142. what to do about timing belt?
  143. Flaky seat switch
  144. Instrument cluster (hard to remove)
  145. Chicago Vag tool?
  146. Got an auto report today...
  147. power steering hose leaking like a MOTHER!
  148. No Start possible MAF issue?
  149. Sticky parking brake
  150. timing belt troubles
  151. How come you boys don't have a FAQ sticky like we have in the Original S-cars Forum?
  152. Two codes
  153. 98 C4 A6 Avant - V6 Auto - shudders on acceleration, especially going up hill
  154. Im back
  155. ABS always comes on - 96 A6 wagon
  156. 1992 Audi 100 Clutch Bleed?
  157. Aftermarket stereo install
  158. I Killed her as she saved me. another dead Audi
  159. 97 Avant...ignition switch removal?
  160. Transmission/Power Problems
  161. loud metallic ping or click into reverse on incline
  162. Rear Hatch on Wagon will not open/locked
  163. A little help, please?
  164. Audi urS6 deutsch diplomatic car- MTM
  165. 1992 Audi 100 anyone
  166. Super Slow Leak
  167. bulb out bypass?
  168. Valve cover gasket
  169. Parking Brake Light
  170. 1992 100 S with AZB transmission Questions
  171. uncontrolled condensastion when car is washed
  172. Differences between a euro 200 and a 5000cs
  173. V8 acceleration surges/pulses
  174. 1990 Audi 100 5 cyl. won't start
  175. ok, I can live with this
  176. Does anybody know what this is? Picture attached.
  177. Salvage opportunity
  178. I have a crude mirror of the FAQ...
  179. Wtf is this censorship crap?
  180. New cluster - match old milage?
  181. 100/A6 FAQ....is it still working?
  182. So long.
  183. I'm " migrating "
  184. kind of a simplq question but i wanna be sure
  185. Multifunction Switch
  186. Good-bye AudiWorld
  187. I'm actually logging out of Audiworld.com for the first time in years.
  188. Get a load of the aggressive monitoring and
  189. AW user contact sheet info...
  190. Ugh...I already don't like it
  191. 1992 Audi 100 Parts CARs in NJ
  192. My car's starter literally stuffed
  193. What do I need to convert an aux-in signal to match the stock cd-in signal?
  194. Vacuum Leak for Cruze Control
  195. Anyone have a working Gamma/Bose head unit?
  196. 1997 A6 2.8Q silver for parts
  197. Brake Warning Light Flashing - A6 1995
  198. check engine light comes on '92 quattro 100
  199. Vacuum leak for central lock ???
  200. Considering selling kelly's A6
  201. Rented Transporter 3 last night, did anyone else see the junked C4 in it?
  202. No joy with the new radiator and I've got an unrelated question
  203. Used or rebuilt tranny
  204. Just test drove a 1997 A6 Quattro Avant, have a lot of questions
  205. Cant search forum
  206. vB imminent
  207. cant unlock radio need advice '92 quattro 100
  208. Still fighting power seat memory. Does anyone's work with the white bulb burnt out?
  209. Urgent help needed!
  210. Auto trans seems to be slipping
  211. Well its driveable but not how i planned project a6t.
  212. '97 Audi A6 quattro Motor Oil
  213. I think I sold my S6
  214. Multi-Function coolant/water Temperature Sensor (4-wire to 3-wire)
  215. strut boots?
  216. Stereo removal (tried searching, broken?)
  217. Failed CT emissions - need cats
  218. need he;p with tranny problems and also New CD player wont let spreakers work
  219. Car is purging coolant out of expansion tank,
  220. 1994 audi 100 s Front wheel DRive transmision problems, wont shift into gear, drives but acts wacky
  221. 1994 100S/A6 TRANSMISSION PROBLEMS reverse wont work, Possibly COMPUTER problem,DRIVES working wrong
  222. So with my 409.1 VAG-COM now working (download version) any cool things I...
  223. Death of an Ignition Switch
  224. So DaveinSaltLake, got some questions for ya.
  225. Before I buy anyone have front struts for 95 A6 Q avant?
  226. Is it possible to use a 8-Pin CD Changer with a Concert I head unit?
  227. Hey guys, isn't there a refill step of a torque converter before reassy of motor to the trans
  228. Alignment adjustment?
  229. Help, 94 100S transmission is stuck in safe mode after a jump start
  230. Auto check brake warning indicator-light still on? Wired sensors together. Grounded T6i
  231. Windshield
  232. Need some advice on using Ross-Tech with a generic cable if possible...
  233. Simplicity is a virtue (or, "how i solved my slow, persistent leak")
  234. Changing F display to Celsius
  235. Does anybody have a front bumper and belly pan for a 96 a6q?
  236. Avant hatch air leak update
  237. Sorry to repost: but I'm not getting anywhere with this seat memory business.
  238. Tires question...
  239. Hello again
  240. Looking for a write up for replacing front struts on my 95 A6 quattro avant
  241. Thanks for the bumper Ed!
  242. Blowing rear wiper fuse. Motor or wiring?
  243. Avant rear hatch trim repair...
  244. air leak in hatch
  245. Avant hatch wiring update
  246. Pentosin at NAPA for the same price (or less) as AutohausAZ
  247. Power seat memory stopped working
  248. airbag light came on when I turned the ignition while battery was dead, but the code wont..
  249. Wanted: Black oval fender AUDI badge
  250. is there any wat to find out which
