- suspension for a 95 A6 2.8
- 12v 2.8 Can someone Please post the Procedure on how to clean EGR passage?
- Starting problems
- Hey, Seattle Scott, are your really switched teams? Are you going to hang around?
- '95 model A6 Thermostate location.
- Mechanic says ignition. I say he's nuts.
- Well, say goodbye to the pigboat guys, I switched teams...
- Just returned from my trip to St. Louis and the Audi was great!!!
- UPS man is my best friend, he just brought my new wheels!!!
- 2000 A4 OEM 16 " 5 spokes...
- Wheels
- 1 day + 2 cars + 3 hours = Ahh finally they're clean...
- radio problem
- 111,111 YAY!
- Temp Guage
- 93 100cs head unit
- My "new" 93 100CSQ (bought in Jan) has become a Project - also trip report & questions....
- 1997 Audi A6 Owner
- Sunroof leak
- Had my 1996 A6q timing belt replaced for $375.00
- Gear Selection Illunimated ?
- How to remove door panel / window switch?
- Need procedure to replace output shaft seal on transfer case
- Strange howl noise was only a wheel bearing. Thank God!....
- Spark plugs & wires
- how much could i get if a sold my car?
- upgrading from standard headlights to xenon or hylogen on 1992 100S
- HELP...again!
- water drain hole? 92 100csq
- New Audi 100S
- Help....
- Wiring radar detector into 97A6QA
- What are the prices of original parts in Frankfurt ?
- @#$@!# i smashed up the front end of my audi!
- Audi/VW gtg at Irvine Park, So. Cal. March 30, 11:00am
- Help...strange howl noise from front end...........
- Ever see oil droplets in coolant?
- Timing Belt Question 92 100cs Quattro Wagon
- Suspension/strut changes instructions
- Transmission fluid question 93-100CSQ
- Would 6-spoke TT wheels look good on a 97 A6?
- O2 Sensor Update
- Quattro put to the test
- My new (used) 1996 A6 Quattro Pics
- 1993 Audi 100CS
- Anyones Oil temp and coolant temp always read low?
- Transmission Fluid Change Really Needed at 45K
- ASR/aus light doesn't go off--1992100cs
- trans fluid
- Muhammad, Any chance that I can still get my hands on one of those S6+ Euro Tail Light Kits?
- Operating when low engine temperature.
- Event Test Pictures are up for the AutoX as well as updates and course map and Audi page.
- climate control orange blob
- 10 Year Air Bag Service?
- Got the Audi Back, 532 dollars but got all the little things fixed
- Replacement wheels
- 92' 100s gauge problems & check engine light
- Car is dripping something clear but slippery from right front...
- 18x7.5 wheels with 40mm offset, will they fit?
- Ok that's it, I couldn't do it... the A6 is staying.
- Help with 97 A6Q Purchase
- 1996 A6 Quattro, $13K, A good Buy?
- S. Michigan and surrounding area Audi get together...
- Hey Muhammad, everybody. I have aheadlight question.
- 1996 Gear Shift sticking key won't come out
- EGR sensor code 2411
- Ah my Audi has fresh oil!!!
- DID ANYONE DO A PAINT JOB LATELY? IN NYC AREA?
- ignition switch part number questions
- How much do you think it would cost to rebuild a 2.8L 12v?
- Block Heater Question - It's Cold in Canada!
- *Impromptu* NYC Area: 100 Octane Run!!! Come One Come All!!!!
- Scorpion A6....
- How long should it take to replace an engine in my 1990 Audi 100
- 92 audi 100 starting problem
- Passenger mirror backup mod.
- Help... I think my girlfriend broke my car...lol
- Audi Newbie with questions du jour
- Anyone make Coil Over suspention for the C4 Audi's?
- performance school
- In search of Good Mechanic
- Alarm Problem with 100csq
- Rubber Sport Floor Mats
- General Discussion Question.....
- performance question........
- Brakes
- Rotors
- Parts, where to find em??
- wheels off a 93 audi 90...
- 1989 thru 1991 100 :Anyone know the fix for the "dim instument cluster blinker and hi-beam indicator
- 95 MPH for 2 hours. How bad is this?
- Dead battery - funky sunroof
- Greetings from India
- crazy clicking/buzzing from relays 362 & 218 while parked
- Anyone want to buy my A6?
- MIL and transmission
- please help...quick! Need a used part..
- Brake Light
- Timing belt?
- Flaky Keyless Entry
- Just found the board. New 92 100 owner!
- A/C clima
- Light on the Key
- Dreaded tranny problem '96 A6 Q
- Delta CC display reads CONNECT if I power it up while holding the MODE button in...
- Sunroof--nonfunctional
- cruise control works sometimes
- What would you guys/gals do?
- setting memory seats - 1996 Audi A6
- FYI, neighbor selling Audi 100( orange co, ca) very nice condition.
- no power audi 100 2,3i 1993 Please!
- Audi A6 1.8 20v Turbo
- While I'm here, Is there anyway to re-finish factory 94 100s wheels?
- smoke and smell coming from back of engine
- Power Steering Hose problem / high repair price?
- A6Q/95 Engine wash
- Radio frequency dash display?
- Cold air blowing on Drivers feet. Anyone have this happen? Fix?
- Sway bars or strut tower brace
- Looking into buying a '96 Audi A6 Quattro - opinions ?
- I got VAG COM
- wet foot -work shoes threatened
- fogging problem
- 1992 100 CS
- Fuel Question for 1994 100S
- audi 100 engine cutting out
- Wind noise from door seals
- Finally "solved" problem with moonroof.
- Any recommendations for an independent Audi shop in NW Houston?
- RF Remotes... Question
- Getting ready to do my first timing belt R&R guys. I see some like to change the camshaft seal too??
- Finman..Thanks for the picture posting instructions!
- Ok now I got the oddometer backlight out. Had anybody fixed it?
- Lookie here ;-) I have to sell my baby.
- Pilot XGT H4's & Dunlop Sport A2's - first week
- Good Audi repair shop in San Jose?
- X-Post: Interest in a 12 Supercharger from PES?
- FS 10 spoke Audi Rims
- Bose front Speakers
- Suspension for 96' A6 Avant Quattro
- Streo Knob Problem in 100CSQ
- Extended Warranty
- Brake Update
- Crazy clicking/buzzing from modules near drivers left foot
- Please recommend a good DIY book for a Novice - Audi..
- check engine light...
- Recall - new fuel injectors
- Where is vehicle data plate located? The one that contains the engine code, paint code, etc.
- I cant find my thermostat
- Odd electrical gremlin
- fuel gauge and engine coolant
- Solution to the fast blinker problem.
- number of dash lights - 94 100CS
- '97 A6QW overheating, help! Waterpump?
- kamakaziep, I have 8 2W bulbs. Do you want them?
- A nice used 100CSQM on eBay...
- POWER STEERING FLUID
- Front brakes working less than the rear
- Any ideas why light bulb out light would stay on?
- Brake Rotors
- Delta Radio
- Mileage down with new O2 sensors
- Audi 100
- Wheels for 96' A6 Avant
- 2watt bulb conversion was great! What a difference!
- Mohammed: Pictures of Mein Lieber Fritz
- Brake Installation
- Anyone help please ?
- fuel requirement
- I'm actually passing people
- What is your voltage at the battery?
- Yay! It finally snowed in Wisconsin!
- New A6 owner and I'd appreciate some expert feed back
- Where can i find a heavy duty relay for the blinkers
- So can anybody recoment an extended warranty
- Anybody knows a good psychiatrist (or good warranty)?
- 100/A6/C4 Website w/content for each year?
- 93 Audi 100 CS Need info on shop manuals and web sites
- Time to sell. 93 Audi 100CS Quattro Pearl. Loaded!!!
- kamakaziep question for you...
- Odd thing when upshifting?
- Does anyone know this part number?
- The Instrument Cluster lights upgrade
- Oil Pump Keeps Going!
- Dash lights and speedometer issues...
- question about my fuel tank gauge
- Disc Brake Pad Question
- Wow, Ronal 17" RT, $159....
- What wipers are best/going to fit the 95 A6
- I am selling my Vag com!
- New O2 sensors have made a difference
- Steering wheel for sale....
- How much oil does your 12v V6 use?
- Quattro batlles ice - News at 11
- Hey you Dunlop A2 folks, Need some further feedback..
- See you guys in 2 weeks I'm heading out for my vacation
- I was driving and decided to clean the windows...read for more to my story....
- Looking for Audi 100 Quattro... and found one...
- NEW pictures of my Audi
- Quattro Rules! Blizzard in Colorado!
- Odometer LCD screen deteriorating!!!!!!!!!!!!
- Cruise Control/check engine light
- The word on feul filters.... benefit?
- Hook it up
- Had a battery thrown in - $98- is that too much?
- Where can i find new wire harnesses for my blinkers?
- idling problem
- Got dem ol' '94 100s steering rack $$$ blues...??
- Can not changing the oil for 6K mls. cause the car to struggle starting?
- How to set gap for 3-electrode NGK spark plugs...Help...
- Back to the Oil Change
- cold start
- Vag-COM baud rate question...
- engine light
- What do you guys think of this exhaust tip???
- Blower motor makes a squeeking noise
- Wheels for 96' A6 (call for photo post)
- Good calculator
- S-4 strut tie bar
- Has anyone put 225/50-15s on the stock 15" wheels on an 95 A6?
- POLL: what tires do you use? (brand name, size, Summer/Snow, etc).
- Electrical problem Audi A6 2.0 97'
- Now this is a speeding ticket!!!
- Squeky A6Q
- Has anyone removed the headlight lens off of the reflector housing? I wana replace w/euro spec lens
- HELP!!! A6 Won't start after water pump change
- Darn oil plug won't come out, broke two sockets already!!!! How to get out??
- CD for 97A6Q
- Oil pan drain plug size??
- Attn. Muhammad!!!
- Factory CD Changer & 17's.
- My 2.8Q needs your help, please she's dying :(
- A6Q 1995 rear dark grey velour head rests WANTED!
- Heated Door Mirrors?
- Tweak Audi A6/S6 engine...
- engine's sudden stops
- Would ET45 offset (S4 rims) fit 225's on 95 A6Q
- What do you do with 15" wheels, after you upgraded your car?
- somke form the Air vent
- anybody got any dark leather front seats for sale?
- Emergency Brake Problem
- Not happy with my Audi dealer
- What Audi wheels are these??
- Considering a used '94 100 CS Avant w/low miles - Anything to look out for? Price?
- Gamma CC Radio is mute if turning on
- Audi A6 data channel
- Weird Sound - No Start
- 1990 Audi 100 Question
- Check out this pics I found of body kits for 100/A6
