- No radiator fans, need some brain storm power!
- Ski Racks?
- PICTURE FRIDAY...post em!
- Bet it would be going to Audi heaven in US or UK?
- manuals on ebay (not mine)
- Mobil 1 vs Mobil 1 / High Milage oil
- pics of the broken thermostat I found during timing belt service
- i have a q about the radio code, if i have the #8 in my code which # do i use to enter that?
- UGLY :(:(:(:(
- Help finding part
- Audi 100 '93 - Oil warning alarm
- It's funny and tragic how the little things set you back sometimes...
- Audi 1994 A100C4 Opearation Manual
- Hi, I have a few questions about my car...
- Front anti sway bar bushings
- holly miles!!!
- Wheel Alignment
- coolant warning light when engine is started
- +1 for Worldimpex!
- Question on the protective cover underneath the front of our A6
- inside wheel rim rubbing on lower control arm...(more)
- Sorry, STFA buttttt, can anyone tell me
- Interesting observation on quality....Ford Focus vs A6 throttle body
- Well, I'm off to the airport....
- check out my install... and if you have a chance.....
- Has anyone been thru the torture of replacing this bushing in the rear suspension?
- auto transmision problem ..no shift from 2nd to 3rd or 4th
- Anyone had any luck using VIN's before '92? I can get data for VIN '92+ but not '91 back
- New motor and expansion tank boils over.
- Heads up, CT guys! Parts car.
- Intermittent low oil Pressure to Drivers side cyl head?
- Value opinion: '97 A6q sedan
- 100 CS Avant dead battery
- hi any radio gurus im installing a stereo but the harness that i got doesnt plug with the connectors
- Need 1992 100 A/C Help... a lot more inside, so please clicky <updated pics>...
- Parting out 1996 A6 5spd 90k
- Oil seeping through front crankshaft seal. Siliciting suggestions (austinado16, 4Driver4, others)...
- Little help needed here :) Help me identify and order the right parts...front damage
- Idea speed fluctuating and engine stall
- Where is the A/C service port on a 1992 100?! And is it low size (normal) or high?
- how do you...
- Picture Friday.
- Plugs after another induction cleaning
- Where is oil pressure switch?
- also, installing a stereo any tips or warnings i have a '92 100cs anything would help thanks
- hi, does anyone know where i can pick up a "2069 tool" ?
- S6 & A6 master cylinder question ???
- Fuel tank leak
- Pleeeeeze my fellow friends help again!!!!
- My next project...
- Here's something you don't see everyday...
- PSA: 94+ carpet will NOT fit in a 92!!!!
- OBD II fault code reading
- 84 Audi timing procedures
- A8...I have the itch again....but not enough cash in my 'play fund'
- Doug YGM
- Clogged Catalytic Converter
- 1999 Volvo S80, any opinions?
- Got some gremlins popping up with my remote locking, hmmm....
- Anyone have a source for C4 spherical blind-spot mirrors?
- kind of both..i think
- Considering an engine swap
- Hey crew, can anyone confirm that Avants (100 & A6) share the same outer tail lights? Thanks
- Overheating Fun...(kinda long)
- Air Tubes crack at side of Engine (Breather Hose)
- i need a big favor please (carfax account owners)
- Needs Brakes
- 100CS-Q or an A6-Q??? (c4 of course) ...
- Hello! Question for the suspension gurus...
- slight 'squeaking' sounding of metal rubbing almost?
- Shuddering/Power Loss Under Load
- 1992 100s problems communicating with ECU
- Source for Boost Sensor
- Radiator Fan Not Working
- 96 A6 Quatrro - No Power to Radio or side mirror control
- Wiring diagram anyone?
- Picture Friday...Bayer/Rinspeed ZaZen...
- Just wanted to share my car with you
- Kamei Front Grille, with Audi Rings?
- reverse puts car into limp-home mode
- Before you make your first post....
- EGR passage cleaning
- car stall when shift from D to N or P
- ATF Leak
- cleannnn 100
- Readin about Crusin's thread, reminded me to ask: anyone else's gas gauge move VERY slowly?
- Water Wetter + distilled water + wich one of these coolants?
- Adjusting Gas Gauge Needle & Dashboard light question.
- Can't find any Chrysler forum equal to this one
- Anyone ever go from the older 100 platform to the C6 110 / A6 cars?
- I need a part number...
- Audi Idle control valve WTB
- I think I just found my next weekend afternoon mind-clearing drive
- Tripode - or - Non-Tripode CV Joint, WTF ...how do I know which ones
- Anyone need an auto trans(code CEZ) from a '92 quattro? How about an AAH engine?
- Now on to the 6. I'm thinking of doing some 007 Sh&* any ideas are apprecited.
- I feel like DISL "Dave In Salt Lake" Semi Long.. But what else you got to do? This is not an AD
- Nice vin decoder
- 93 S4 Fenders on my A6?
- 93 100 s
- Any carpenter in the house, I need some advice.. (not 56k friendly)
- Another Meyle nightmare (with a happy ending....)
- Shudder in accelerating tight turns... CV Joints?
- O2 Sensor Circuit Problem: Does this sound right?
- Idea speed Fluctuation
- side molding
- "Avant" = "Ambulance"
- Need some trouble shooting help
- Tinting Windows...How much would a person spend???
- I've finally found the perfect avant for me...
- Just broke 120,000
- Anybody got pictures of 100 avants in grey?
- Cracked heater box, will this affect anything?
- Could someone with heated rear seats AND a rear seat cigarette lighter check the P/N of the face....
- The never ending concert saga continues as I take one more baby step towards completion!
- Anyone need some small parts off a red on black 92 100cs?
- Want to replace my Engine and tranny mounts
- Longshot...anyone here have any leads on 1990 Audi 80/90 parts in the Seattle area?
- Here is my dilemma with my sons car. I stfa'd and did not find many details.
- Manual transmission interchange... Specifically 95A6q vs 92100q..
- would this stress bar be possible on our late model C4?
- Achtung! Picture Friday...
- New Code: P1528 Intake Camshaft Contr.Circ. Bank1 Open
- Did another wheel today, plan to have all 4 done by the Winter to throw em back on.
- wheels and tires anybody ?
- Pics of oil pan/pump R&R and some of the exhaust manifold gasket dilemma...
- X-post on exhaust valve coating...
- 92' 100 won't start - no crank & lights go on... Starter? How do I check it and where is it?
- AC charging port ???
- wish it was friday, o well.
- burning too much oil again
- Coolant leak
- DD's Waterfest Special starts now! 10% 15% and 20% off!!!!!
- Is 1996 Pearl white LOA9 or LOB9?
- Auto Transmission Gear box Jerking
- Looking for a good pair of fog lamps......
- Bad Rear Main Seals Make Noise?
- fuel pump relay location
- Question on Fail safe lock out on Auto trans for 94 100cs wagon
- AC Odor
- afc engine parts
- cooling fans, a/c operation
- Engine swap frustrations -- Damn california emissions! (rant)
- 1994 100s interference or non-interference engine??? HELP!!
- Any ideas as to where I can get S6+ Tail Lights?
- Repost: '95 A6 TPS Problem (long)
- Check my signature for new updates about Old School quattro, Cumberland, MD July 27-29
- 3000 or 15? I'll take the latter, thank you. (Sunroof Completion - LONG)
- Dashboard (Cluster) Lights
- Sunroof Update..
- Anyone else experience the mysterious drip?
- Manual Transmission oil: is it as important as ATF?
- Auto Transmission oil Dextron II or Dextron III
- Problems with the left motor mount on an A6.
- what to change while swapping an engine?
- is this the right power steering fluid?
- It took forever but I finally got my S6 rear brake conversion done...
- Check out the red 97 A6 Avant with only 26k miles on SLC Craigslist
- Hey it's Friday...the 13th!
- help!...tranny problem(long)
- Anyone need a super clean 97 A6Q Avant ?
- Stock Bose Deck & Speakers
- Mmh, it 'pays' to drive a wagon sometimes... [longgg]
- Anyone know if the "hard" rear brake lines (metal tubing) are tough to change? I have a leaking one.
- ECU connection cable for 1994 A100 C4
- Looking for a set of headlights from a 95+ A6 or S6
- Help Head Gasket
- Winshield washer fluid leaking?
- x-post. my trip to limerock ct =)
- leather seats
- Picked up the pearl hood today that I've been searching for...
- New shocks and springs installed today
- Car won't start when hot
- The C6 A6 Avant is a really sharp looking car.
- Car Engine idle speed surge during stationary
- I WANT TO CHANGE THE SPAEKERS IN MY 100 DOES ANYBODY
- a call to duty.. well sorta
- my warning lights are on
- Engine stalls on Highway!! Any ideas?
- 17x8.5 will they fit an Avant? ET 35 for the offset
- Engine Cooling Fans Always On
- anyone here with dead mirrors? anyone knows how to fix it? switch and module doesn't do it
- looking for drivers side door plastic molding trim...
- 5 speed acting up...... lets say im driving at 55 mph or higher and im
- Looking for some climate control trim
- Did someone here need a A6 DS clear corner? I couldn't remember....
- Does anyone have a drivers side mirror for sale? I am just looking for the mirror, not the housing.
- Drivers seat has some back and forth "play" to it. Anyone know where to start looking?
- off topic...saw this in the UrS4/S6/S4 forum...pretty insane
- anybody know if the low beam projectors size the same between the UrS4, 100 & A6?
- Update on the A4q Tranny Swap -- halfway there
- PSA: Fix for those of you that have had problems w/ low engine coolant temperature...
- Engine suddenly stop during driving
- Thinking of buying a 100 cs Quattro
- Anyone around with an OEM Webasto aux heater?
- A/C barely cold
- Exhaust manifold compatibility ("California models"...?)
- The lump is getting smaller...
- Lessons to be learned about torquing wheel bolts. Or how I learned to...
- Finally did the timing belt maintenance yesterday on my '96 A6 Avant...
- I am changing the motor in and '95 A6 q Saturday then selling the car.
- Looking to increase HP.
- Dave I got your package... thanks!
- Trailer Hitch Question....
- RS6 wheels?
- IT'S FRIDAY...POST EM UP!
- Just thought to share
- '96+ silver rear bumper?
- '95 A6 TPS problem?
- Whos going to waterfest from this forums?
- recommend mechanic/transmission shop in San Francisco or peninsula?
- Hammind Sound while car is moving
- Look what followed me home today...
- B5 S4 Seats in my C4 A6?
- transmission has "pressure escaping"
- should I buy this car?
- drivers side front panel anyone? pref brilliant black?
- Voltage with AC on, dropping below 12v when at stoplight.
- 97 A6 Avant for sale in Denver
- Are UrS4 doors same as 100?
- Mance's additional HP
- kinderutz, ygm...sent you an email inquiring on the belly pan for sale.
- Working on the engine out of the car is so nice... I am tempted to do a preventative head gasket job
- EGR valve pictures
- How the hell do you get the fuel pump out?
- just a quick question...
- Happy 4th from Pittsburgh!
- Needed: Passenger side clear corner
- to dave-addictors-alike, lol jk thought i'd throw this out there =)
- Difficulty starting when tank is below quarter mark
- So... does anyone know the actual color/color code of my car? lol
- So my headlight went out
- Sorry guys time actually came to leave.
- can someone guide me through fixing my sunroof broken arms
- After nearly 2 years of junkyarding I finally found a belly pan
- I searched the FAQ, no answer, where does this part go??
- Anyone want to add auto dims to their car?
- 1998 A6 Avant for sale in SLC....not my car
- More updates on the 100csqm
- For Sale: '90 90q20v Turbo, AAN'd, RS2'd and much more... (BWW)
- once more
- G004 000 M2 power steering fluid
- Sunroof problems... continued.
- Drove 650 miles this weekend...
- Newb Brake Light Problems
- Check out the cool Audi gizmo a friend from Germany sent me...
- Any of you guys close to Scotia and want a free set of steelies with marginal winters?
- Portland, Oregon area audi meet, 7/6/07, 4pm, Oregon Zoo parking lot...
- Day 3 -- making progress on the new project
- 225/55/17 or 245/50/17 work on a 2.8 A6?
