PDA
View Full Version : Audi 100 / A6 (C4 Platform)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. 95 A6 HVAC
  2. Bentley CD arrived today, but I have a question....
  3. Should my windows go up / down when I turn and hold the Key?....
  4. Any toughts on OE+'s oil filters??
  5. auto tranny service / flush refill. how long without it?
  6. seat for grandson, any young parents out there with audis?
  7. clockspring removal, how do you do it? The Bentley is on the way. TIA.
  8. Stubbie VS Arial: Are they interchangeable?
  9. Cruise Control - car slowly slows down
  10. 1989-1991 AUDI 100 BBS 15 INCH RIMS
  11. PS fluid info (G00 2000 vs. G00 012)
  12. Euro spec headlights and H4 100w h4 bulb installation question...
  13. Ordering parts for timing belt change. HELP !!
  14. Groan/grindy feel in steering wheel at 50 mph +...
  15. Transmission Service Cost (FYI)
  16. Timing Belt Change Cost & Parts List (FYI)
  17. Follow-up fuel pressure check valve
  18. Bought new car
  19. POWER STEERING, GASKET, VACUME LEAK
  20. P.S pump
  21. pulled wrong fuse , air bag light now on
  22. Need 7j x 15 10 spoke wheels for 92 100CSQ Avant
  23. Brake pad question...
  24. Bilstein Sport question....
  25. sorry, I have to ask it again: how to look at the PS leak.
  26. Bentley manual, paper version, volume three, does anyone know what is in this book?
  27. Squeeky grinding noise from wheel
  28. emissions test FAIL
  29. Moderate groaning/rough/vibration feeling when making low-speed full-lock or near-lock U-Turn
  30. Airbag light stays on for a minute+ after start...was fine before new ignition switch...
  31. Anyone in the Central NH region who has the tools & expertise to help do a timing belt change?
  32. Cooling fans quit running
  33. How do I get at the dash light behind the ashtray?
  34. Remote start for 92 100
  35. what do you think about this 94 100cs quattro i might buy
  36. What to look for in a high mileage car?
  37. Time to change my timing belt and a few other things
  38. Alarm triggers if car is locked
  39. Large german/english AudiA6 website revamped and enhanced!
  40. Tram, where you from?
  41. Hey Maini, I'm interested in doing a auto dimming mirror, can you tell how you did yours?
  42. PS fluid leak. Is it PS hose or rack?
  43. Drove the new C7 A6 yesterday...
  44. Thinking of getting a urs4!??
  45. 1990 Audi 100 Coupe Ignition Replacement PLS HELP!
  46. 1990 Audi 100 Coupe Ignition Replacement
  47. A6, 1996, looking for the plastic panel that comes with salon light
  48. Audi A6, Climate control - conditioner questions.
  49. Ignition Switch Replacement problems
  50. 95 A6 Quattro HEATING
  51. 95 A6 internal oil leak?
  52. Need help! Someone with a Bentley, I have been getting error codes and don't know what they mean....
  53. Lots more pictures added... applies to 92 100, but will probably be accurate through 97 A6
  54. Brake pads worn out warning - Current flow diagram?
  55. Who needs a fog lite?
  56. Anyone with a busted cd changer read this...........
  57. Window Closing Relay Problem Fix, w/o cutting wires....
  58. HOLY MOLY!
  59. Anyone have an old a6 headlamp? I'm looking for the new-style, with internals
  60. Some new pictures made, and will be added to the FAQ
  61. 1994 100S with a starting/stalling problem
  62. After market System
  63. Ignition Switch Recalls? 1996 A6
  64. may have messed up with the fuel filter.
  65. Emergency repair!
  66. Aircon clutch will not operate automatically
  67. Smell of burning oil in car
  68. Thinking about buying a 100 can you all help......
  69. Anti-Freeze leak
  70. where do I find headlight assembly glass?
  71. US C4's verses non-US models
  72. Headlight cleaning...96 A6, anyone done this?
  73. broken lug nut
  74. Any problems with using Dexron III ATF?
  75. My check engine light does not work!
  76. One bank is running rich, another - lean
  77. FAQ on AAH/VW parts interchangability?
  78. Changed Spark Plugs and mileage went down???
  79. Very low power
  80. selling soon......
  81. 97 A6 CD changer question
  82. Very bad radio reception...Need help...
  83. 1997 A6Q
  84. BC Audi meet this Sunday Oct 24 @ 1pm
  85. Ignition Switch Replacement 96 A6
  86. I have replaced tie rod ends today.
  87. Wheel Question
  88. Poor starting: A6 '96
  89. looking for Audi mechanic
  90. Rear shocks '96 A6 100k
  91. weird smoke form under car
  92. CC Codes...
  93. I looked at this car today....
  94. New Ignition Switch...problems...Also Hard Starting
  95. Has anyone used this tool?......
  96. TCM Ground Connection
  97. 93 100cs Possible Electrical Problems
  98. Transmission doesn't shift on its own....
  99. Shift into gears when ignition off, automatic
  100. need headgasket, can anyone recomend good parts source
  101. timing mark
  102. Are my rims an aluminum alloy (probably nickel-Aluminum)?
  103. BGK44 vs techchron question to those who know
  104. anti-leak
  105. B5er here, thinking of searching out a 100CS Avant for a beater.
  106. Rear brake pads
  107. P0734 & P0116 - Help with these fault codes...
  108. BG44K Use
  109. engine guru's!! WHAT WILL CAUSE LOW compression in 1 bank of Cyl's
  110. Is there any trick to keep the internal air
  111. Finally did Ignition switch and IC bulbs...some questions, thoughts & recommendations
  112. Leaking AntiFreeze
  113. 92 100s injector not working?
  114. PICKUP SENSOR AND RELAY.
  115. Valve body solenoids???
  116. Need help! noticed two days ago, weather getting
  117. audi 100 v6 engine
  118. Re:Help, in process of removing the tranny...
  119. serpertine belt- need instructions to install 92 cs100
  120. Check Engine light
  121. Brake system Question?
  122. diagnosis? Fresh Air Blower gets 12v, but only mA. Does not run. Fan works with B+ jumpered.
  123. OOH NO horrible clangy sound from engine internals
  124. 93 2.8L poor start
  125. X-Post: 2nd Annual Cuyahoga Valley Fall Cruise and Clambake - 10/16
  126. A6 1995 Auto Battery Changed and Gears not changing
  127. Audi 100 CS recall/parts.
  128. 93 100CS quattro Timing Belt questions
  129. EKTA Owners: More Gearbox questions
  130. Oxygen Sensor
  131. Auto trans dipstick for an A6
  132. 97 a6
  133. Control arms, update
  134. Plenum water drain valve...
  135. how hard is to add oil to the center diff?
  136. ok electrical drain problems again......
  137. Fog lites 92-93
  138. Any Suggestions on installing a audi Concert w/ phat noise
  139. Last reminder: Kent Falls, CT bbq is tomorrow (10/9)
  140. Signs of dirty throttle valve?
  141. Ball joint failure, need to change immediately??
  142. Who's Succesfully lowered there C4 100/A6
  143. Brake pad warning light came on today and I have a 350 mile trip planed for this weekend...
  144. Looking for GAMMA RADIO
  145. ordered ignition switch & IC bulbs from Blauparts.com/ my mirrors don't work
  146. MMS 311-400-411?
  147. Plenum water valve cleaning
  148. Heater not working 96 A6
  149. How did you split the heater box?
  150. anyone ever pulled their motor out???
  151. DIY: tie rod end replacement ... please confirm
  152. radiator story; it is alive
  153. Which flap did I break? (heater core replacement)
  154. Are their any mods that you can do to a 93 100s?
  155. knock sensors
  156. RS4 17" Special Purchase $599
  157. master control window relay update
  158. power lock motor drain....
  159. WTB: Belly Pan / Splash Pan for 92-94 100cs
  160. Fumes in the cabin
  161. Any experience with blaufergnugen/www.blauparts.com?
  162. I am looking for a left headlight for a 1995 A6 quattro. It is tyhe kind with 3 bulbs. Any extras?
  163. Reminder: Kent Falls, CT bbq...this Saturday!
  164. 1997 A6 auto check beep
  165. '94 100 S4 Headunit replacement..please help
  166. Hey smokie, YGM.
  167. smokiesman!!!! thanks again,,youve made it easy.anyone out there looking for parts get in touch with
  168. I promise I won't start another thread..hehe. Gonna order parts & replace the IC bulbs...
  169. '96 A6Q - was an On Board Computer available?
  170. Ignition switch part # & where to buy?
  171. anybody want to sell radiator for 96 a6q wagon (AT)?
  172. replacing expansion tank
  173. smokiesman,,, youre terrific!!! thanks for your help and quick response!!!
  174. How to remove radio?
  175. hi guys, i need a weird part..if anyone can help i ,,
  176. I have a nasty oil leak???
  177. radiator leak
  178. Question to those who have replaced bulbs in power mirror control switch...
  179. Autosports Unlimited
  180. 1993 audi 100 cs wagon
  181. power window problem
  182. Re: Major transmission leak, 92 100 AT FWD ,..
  183. major electical problems....
  184. fuel pump check valve
  185. Need help on VAG codes
  186. 95 A6 Power Steering Hose?( Not High Presure Hose)
  187. Will not start
  188. A6 Avant 2.5Tdi SE 150bhp severe vibration judders at speed on corners
  189. Looking for a set of Oem wheels whith winter tires for a reasonable price...
  190. is BO13508 the correct bosch oxygen sensor for 92csq?
  191. Where to get a new coolant temp sensor from?
  192. SMOKIE do u still have the tail lights...
  193. Reminder: Kent Falls, CT gtg/bbq....Saturday, Oct. 9th.
  194. i'm interested in buying a C4 S6 avant at a "fair" price - leads?
  195. 100s Posiedon Adventure
  196. Catalytic Converters
  197. rpm on 93 100cs quattro wagon
  198. Climate control wood trim removal instructions (easier)...
  199. Differences between left and right control arms 1990 quattro
  200. 93 quattro transmission code CEZ
  201. 156,000
  202. All XXTuning Dyno Day Graphs (& pics) are now posted for you to compare to your hearts content..
  203. Bentley CD
  204. Was changing the oil this weekend when I found......
  205. 2.8 V6 AAH engine code
  206. Tie rod end P/N
  207. A6 reading lights.
  208. Just bought '96 A6...Steering feel?
  209. 1994 100s Avant
  210. antifreeze leaking into passenger compartment...
  211. Brdman*, you may be interested in my new sig
  212. Looking to buy '96 A6 Quattro, any tips?
  213. 100CSQ Trans Question
  214. Emergency...Smoke from engine...please help!!!!
  215. Audi wrecked.. (front end) what'll happen? HELP-- Could've died..
  216. X-Post: OctoBEERfest Trivia Road Rally & GTG in Eastern PA - 10/23
  217. can I add G0012 Castrol Syntec oil to central (torsion) diff?
  218. Road Noise
  219. Location of data plate with the Trans code??? Smokie
  220. new old 1997 A6 E-bay
  221. My brake-power sucks. 4 new rotors, pads WERE barely used on old rotors,
  222. whats going on guys?
  223. Brake Maintenance...
  224. 1997 A6 Cold Tranny Noise
  225. A6 Camber adjustment
  226. 97 A6 pricing advice
  227. Dead Powered Windows in 100 '92
  228. Rebuilt Tranny
  229. timing belt replacement
  230. This Saturday (9/25) - near Hartford, CT - Dyno Day and Audi Gathering - Come join the fun!
  231. half shaft
  232. engine swap
  233. Is my Gamma radio dead?
  234. ???? on cluster from a audi s4
  235. GOT ROAD NOISE????
  236. '97 A6Q Ignition replacement -- now problems...
  237. anyone interested
  238. Air vent actuator motor question...please help!
  239. Anybody got the Fuel Injection cleaning done??
  240. Brake Problems
  241. Blower motor woes: how to mod the housing to get the fan out *easier* (BWW):
  242. center console
  243. Gamma Unit Aftermarket Options
  244. i kicked the bucket, now need glass. smokies how about you?
  245. Anyone parting a C4?
  246. still looking for nice mags for a 97 a 6 q. cannot find...
  247. can any help me with changing fuel filter for 97a6 q...
  248. Audi 100 CS Quattro Power steering & Check Light
  249. (KC) GTG on Tuesday Sep 21 in Westport
  250. what do you guys think of Quaker State motor oil?
